2022 Tundra development
Discussion in 'Valhalla’s Shield' started by Classy63, Dec 24, 2021.
  1. Dec 24, 2021 at 1:22 PM
    Classy63
    Classy63 [OP] Valhalla’s Shield guy
    Tyler
    Cypress Texas
    15 platinum Barcelona red
    Toytec Aluma 2.0 front and rear, Toytec shackles, Toytec add a leaf pack, Tuff Country UCA’s, Firestone bags with daystar cups. JBA long tubes, w/3” cats, Dirty Deeds TRD replacement, DAP tune, AFE filter
    Instead of watering down my massive post I decided to start a new one for the 2022. Before the new year I plan to have a prototype made for at least the cat plate for the 2022 tundra. Once I get under one, I will be able to better plan the rest of the plates. The front skid plate I have planned WILL HAVE TOW HOOKS BUILT IN!! I just gotta make sure it is durable enough for some abuse.
    Just like my other post, I am very open to suggestions and ideas. This is kinda an open forum, so as long as you stay on topic, go for it
  2. Dec 26, 2021 at 8:19 AM
    Classy63
    Tyler
    Cypress Texas
    I am going to go measure a 2022 for the cat plate today, I hope to have the measurements sent to my plasma cutter so he can cut out a prototype for me to test fit this week.
    BobsYourUncle, BTBAKER and ColoradoTJ like this.
  3. Dec 26, 2021 at 9:56 AM
    art64
    art64 New Member
    That's awesome! Glad these Tundras only have 2 cats as I've seen from the video. Maybe just one cat plate to protect both.
  4. Dec 26, 2021 at 10:51 AM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    They still have 4, but only 2 are exposed (unless 5 year old are stealing cats). And I'm sure a cat plate would stop any access to the higher 2 as well.
    BobsYourUncle likes this.
  5. Dec 26, 2021 at 11:50 AM
    Classy63
    Tyler
    Cypress Texas
    I just got done measuring for the front cat plate, I am going to have a cheap prototype made and I will test fit it this week hopefully.
    I also spent a lot of time measuring for the front tow hooks! This is 100% happening. Instead of having a separate non skid plate option, I am going to make a short skid that will go between the bumper and the current plastic engine cover. I will eventually build off this for a full skid
  6. Dec 26, 2021 at 2:35 PM
    Classy63
    Tyler
    Cypress Texas
    Shackle mounts or standard tow hooks
  7. Dec 26, 2021 at 2:42 PM
    Henry2019
    Henry2019 N/A
    Houston, Texas
    2019 SR5 CM CEMENT GREY
    3/1 Lift Kit 20X9 Fuel Assaults +1 295/60R20 Falken Wildpeak A/T3W
    definitely wouldn’t want to yank the shield off while recovery lmfao
  8. Dec 26, 2021 at 2:44 PM
    Classy63
    Tyler
    Cypress Texas
    I 100% agree. I have a plan to make them stronger than OEM
  9. Dec 26, 2021 at 2:54 PM
    Outbound
    Aaron
    Northern Alberta
    Shackle mounts have my vote. You probably know this too, but a critical thing is to be able to tug from an acute angle without destroying the plastic. I haven't got in person with a '22 though so the specifics of making this possible I'm unsure on.
  10. Dec 26, 2021 at 3:14 PM
    Classy63
    Tyler
    Cypress Texas
    So I would be making the plate flush with the bottom of the bumper, so the shackle or tow hook would be further below the bumper. It will only be a few inches back from the bumper. But in any case, a large upgrade from nothing.
    I am leaning towards a weld on shackle mount. Unlike all my other plates, this one will likely be 3/16 steel without options, but I might make the actual plate that goes across available in aluminum. Although technically the plate itself is not needed, it will add strength to side loads. Plus it will aid in aerodynamics by creating a flatter bottom to the truck and will lead into the front skid plate I will be designing. I want to have this tow hook piece and the cat plate completed so I can make sure the piece that goes between fits nicely as a package.
    BobsYourUncle, belanger9 and Outbound like this.
  11. Dec 27, 2021 at 4:19 PM
    Classy63
    Tyler
    Cypress Texas
    Please ignore the 3 bolts holding it up and how it is hanging down a bit, but I get you the cardboard template for the gen 3 tundra cat plate!! I am going to spend tomorrow making a good drawing and sending it off to be made so I can test fit a production plate.
    I also made a crappy cardboard template for the tow hook mounts.
  12. Jan 6, 2022 at 12:34 PM
    Classy63
    Tyler
    Cypress Texas
  13. Jan 6, 2022 at 1:22 PM
    biebs96
    PA
    Very cool. The idea with the integration of tow hooks is perfect.
  14. Jan 8, 2022 at 1:14 PM
    Classy63
    Tyler
    Cypress Texas
    Picking up the first production plate tomorrow, I will test fit it tomorrow aswell
    AGSport and ryanwgregg like this.
  15. Jan 9, 2022 at 11:53 AM
    Classy63
    Tyler
    Cypress Texas
    Quick bolt up of the plate, I need to make some changes, but this was very close to a production version.
    ryanwgregg likes this.
  16. Jan 29, 2022 at 5:20 PM
    damnfingers
    damnfingers New Member
    Gene
    Anything new on this?
  17. Jan 29, 2022 at 5:55 PM
    Classy63
    Tyler
    Cypress Texas
    Sorry, the new prototype is cut, but needs to be bent, I should have it Monday or Tuesday
    damnfingers likes this.
  18. Jan 29, 2022 at 5:59 PM
    damnfingers
    Gene
    Will the tow hook placement be visible on this prototype?
  19. Jan 29, 2022 at 6:16 PM
    Classy63
    Tyler
    Cypress Texas
    Oh, tow hooks won’t be on the cat plate. I need to pull the front bumper and grill off one to make a solid tow hook prototype
  20. Jan 29, 2022 at 6:23 PM
    damnfingers
    Gene
    Sorry, guess I misunderstood this.
  21. Feb 2, 2022 at 3:34 PM
    Classy63
    Tyler
    Cypress Texas
    Prototype 2! It is welded just to make it easy to bend, the production version won’t need the welds
  22. Feb 2, 2022 at 3:51 PM
    damnfingers
    Gene
    Looks great!
  23. Feb 3, 2022 at 6:04 PM
    Classy63
    Tyler
    Cypress Texas
    Alittle hick up last night… plus the roads in Houston got bad this afternoon… the plate is going to get fixed, but the prototype is done and will be bolted up soon.
    As far as pricing, it is safe to assume it will be very close to the 07-21 front cat plate.
    I am about to add it to the website
  24. Feb 8, 2022 at 6:35 AM
    Classy63
    Tyler
    Cypress Texas
    The prototype is fixed and getting installed today!
    AggiePhil and ryanwgregg like this.
  25. Feb 8, 2022 at 10:43 AM
    Classy63
    Tyler
    Cypress Texas
    And it is installed!!! I am going to take alittle material off the front but that is really it!!
  26. Feb 11, 2022 at 5:37 PM
    planehappy
    planehappy New Member
    Are there any issues with heat running this?
  27. Feb 11, 2022 at 6:31 PM
    Classy63
    Tyler
    Cypress Texas
    Nope, been tested by customers, not just me
  28. Feb 11, 2022 at 6:57 PM
    planehappy
    Right on. Thanks. New to shielding along the exhaust area.
    Jackson Smith and Classy63[OP] like this.
  29. Feb 11, 2022 at 8:07 PM
    Classy63
    Tyler
    Cypress Texas
    If it got hot via the cats, it would burn off paint/powder coat/bed liner off the plates, I have zero stories of this happening. Transmission temps have been data logged and it seems like there might be a few degree difference, but it is so close it could just be the way it was tested. Either way, safe to run
  30. Feb 12, 2022 at 10:03 AM
    Classy63
    Tyler
    Cypress Texas
    So, there was something that made me uncomfortable after reviewing the install of the front cat plate on the 2022, the truck it went on was 4x4, and the nut was a bit closer to the 4x4 half shaft yoke than I liked, I don’t think it would cause an issue, but I don’t like relying on I hope.
    So, I will be adding a nut plate option for 4x4’s, it will be just like my TRD PRO nut plate, but it will have the nuts pointing down so I can use a shorter bolt to prevent issues. Also, getting the nut and bolts started with the front diff right there was a bit of a PITA.
