2022 Tonneau covers
Discussion in 'Tonneau Covers, Caps and Shells' started by ak407, Jan 22, 2022.
  1. Jul 21, 2023 at 5:24 PM
    #1501
    ziznack
    ziznack New Member
    Texas Y'all
    2024 Lunar Rock Platinum
    It's brand new, been on the truck less than 48 hours. It showed up on day 2.
  2. Jul 22, 2023 at 4:33 AM
    #1502
    HMNYC
    HMNYC New Member
    If anyone is wondering if you can fit a motorcycle (21” front wheel) in the bed without removing the Truxedo Pro X 15 you definitely can! I am really loving this cover. IMG_4312.jpg
  3. Jul 22, 2023 at 6:43 AM
    #1503
    ziznack
    ziznack New Member
    Texas Y'all
    Weird, over night it went back to this from the white lines.
  4. Jul 24, 2023 at 9:54 AM
    #1504
    jcmartin11b
    jcmartin11b New Member
    2022 lunar rock pro
  5. Aug 16, 2023 at 8:31 PM
    #1505
    Oldandfat
    Oldandfat New Member
    Cannuckastan
    2024 SR5 TRD Offroad Lunar Rock
    How long of a wait? Does it leak?
    There’s not a ton of YouTube out there for this cover (other than renegade) and one that I did see showed leaks.
    I asked the video guy what was leaking and am still waiting.
    I’m really really wanting to buy this cover as it’s perfect for my needs, but I haven’t heard a lot of good about renegade.
    just curious as to your wait times, and overall thoughts?
    jcmartin11b[QUOTED] and cartage1 like this.
  6. Aug 25, 2023 at 12:55 PM
    #1506
    jcmartin11b
    2022 lunar rock pro
    Plan for a really long wait. Website showed 12weeks when I ordered it (which was Oct 28th and just got it the other day when I made this post.
    The wait is certainly the bad part of this.
    I have gotten a little moisture in the bed when it rains hard but it’s been pretty minor. I’ll try and get some videos for you if it decides to rain here again!
  7. Aug 25, 2023 at 2:27 PM
    #1507
    Oldandfat
    Cannuckastan
    Yikes it took 3x as long as they said. 9 months. That’s crazy. Must be a one man show, or a couple guys doing this part time.
    I really like the cover, and I think it’s more thought out than diamondbacks tri fold.
    it holds more weight, and the cab panel folds up (making it a clamshell in addition to a flip cover). I also like the ability to place the tie downs exactly where you want, and when you don’t need em take them off and the cover is a nice sleek look.
    but the wait……..
    jcmartin11b likes this.
  8. Sep 2, 2023 at 8:37 PM
    #1508
    Yota802
    Yota802 New Member
    2023 Tundra Hybrid Limited CM WP
    Any tailgate seal suggestions? I tried the ESI bulb seal. Maybe I installed wrong but the tailgate doesn’t close as well and water still gets in after going through a high pressure car wash test. Any suggestions or insight that works for you greatly appreciate the advice!
  9. Sep 3, 2023 at 9:21 AM
    #1509
    dekeman
    dekeman New Member
    Derek
    Ottawa, ON, CANADA
    2022 Tundra Limted TRD
    Undercover Armorflex: You can use the factory cargo tie downs, just can't make them sliding. Unscrew the big knob, use a flare nut on the factory bolt, position where you want and tighten down.
    G3ardnut[QUOTED] likes this.
  10. Sep 3, 2023 at 10:48 AM
    #1510
    G3ardnut
    G3ardnut Brushed Chrome is COOL
    Joe
    Canada
    2023 Limited TRD Offroad Crewmax Celestial Silver Metallic
    Which flare nut did you get for this?
  11. Sep 3, 2023 at 12:19 PM
    #1511
    G3ardnut
    Joe
    Canada
    I had some nyloc nuts and stainless flat washers and worked like a charm. Installed all 4 that came with the truck. Thanks for that idea.20230903_145124.jpg
    dekeman[QUOTED] likes this.
  12. Sep 5, 2023 at 2:44 PM
    #1512
    2TunGet1
    2TunGet1 Tundra owner since 2000
    2020 Limited 4x4 CM QS / 2000 Limited 4x2 AC Black
    Sorry if this has already been covered. How does the Retrax Pro XR hold up when doing moderate to heavy off-roading?
  13. Sep 25, 2023 at 8:13 AM
    #1513
    Oly73
    Oly73 New Member
    2023 Tundra TRD Pro, 2014 Tundra Platinum
    Looks really nice! Quick question on the RetraxOne install, can you retain our factory rails/tie downs? On their website there is a box to check for "with factory rails" and "without" for our trucks. Does the Retrax sit above the factory rails or do you move them down a bit? Thanks in advance.
  14. Sep 25, 2023 at 8:50 AM
    #1514
    Yota802
    Yota802 New Member
    Yes, you can keep the factory rails. The cover mounts on top, rails don’t get removed. Only thing that gets temporary removed is a small cap at the tailgate end of the rail so you can slide tonneau cover brackets in the rail, then put the cap on the rail.
  15. Sep 25, 2023 at 9:06 AM
    #1515
    Oly73
    Oly73 New Member
    Sweet, great to know the OEM rails are retained! I am between the RetraxOne MX and Pro XR. I don't need to install racks over the cover, and all the reviews sound like the polycarbonate is strong a durable enough -and it's $500 less. Did you go with the Pro XR for the aluminum/strength aspect or for adding racks above the cover? Thanks again for the pics and your info! :thumbsup:
  16. Sep 25, 2023 at 9:28 AM
    #1516
    Yota802
    Yota802 New Member
    I went with the XR for strength since I live in the north, heavy snow. Also for additional security. My only complaints, not water tight… and in the winter it ices up and won’t retract at times.
  17. Oct 1, 2023 at 1:38 PM
    #1517
    MRJD
    MRJD New Member
    2023 Tundra SR5 TRD Sport 4x4
    Tint, PPF, partial de-badge, Falken WILDPEAK A/T3W 275/60/20, BAK X4S Tonneau
    My X4S had the same white lines which basically disappeared after a few days. Not sure I would go with the X4S again due to the below 2 issues:
    1. After 6 months I am still cleaning out aluminum shavings that fall into my bed. There was a ton when it was brand new but I keep finding them. The aluminum shavings make me paranoid they are going to fall into the stroller or get into other kid things I am hauling around and my kid is going to accidentally eat them.
    2. The plastic corners fall off every time I roll it up. This is a terrible design and I cannot believe this was what they settled on. I am planning to glue them on at this point.
    I emailed BAK about these issues and they didn't have too much to say other than they would send me a new cover which will probably have the same issues, definitely will still have the plastic corner issue and if the shavings are still there I will have to start over on the cleanup. Considering asking them if they will swap it for an Armor Flex now that I see there is a way to use the factory tie downs in the rails that @dekeman & @G3ardnut figured out.
  18. Oct 1, 2023 at 2:00 PM
    #1518
    G3ardnut
    Joe
    Canada
    There is also another hard tri-fold cover out there that has its own mounting rail system and provides brackets that allows you to lower the existing factory tie down rail to it so you can use the factory tie downs. The tie towns with this cover can be moved and not fixed like in my case. I did not know this cover even existed until a few days ago when I saw it on this forum. It is made by Tonnoflip. Cost is lower than Armor Flex and they provide a lifetime warranty. I really don't know what long term durability of the Tonnoflip cover is but it looks pretty good. The hardware to secure the cover at the front of the bed uses a T-bolt configuration which probably cause less distortion to the the top of the cover when clamped down. The underside uses a thumb wheel style clamp on the underside like most other covers. See link below.
    https://www.tundras.com/threads/tonnoflip-for-tundra-great-bed-cover.131114/
  19. Oct 1, 2023 at 9:06 PM
    #1519
    ziznack
    ziznack New Member
    Texas Y'all
    I have not had issues yet with the corners, but gluing them on seems like an easy fix
    I didn't have a ton of shavings at all from the x4s, but I also don't have a concern as I'm past the stroller phase . However! I went through two MX4s and they both had a ton of shavings. They eventually swapped my MX4 out for the X4s and I am really happy with it.
    TundraRyan likes this.
  20. Oct 3, 2023 at 10:38 AM
    #1520
    TundraRyan
    TundraRyan New Member
    2014 Crew Cab TSS
    Stock
    Love the bed cover, do you mind if I ask how much of the bed this takes up in the front? I'm just trying to decide myself. I have a long bed 6.5' and want to put my atv in bed, but I'd like to find something that doesn't take up much room.
  21. Oct 5, 2023 at 7:44 AM
    #1521
    TundraRyan
    2014 Crew Cab TSS
    Stock
    I know this is an older post however how are you liking the cover? I'm trying to choose between this and the X4s.
  22. Oct 5, 2023 at 12:50 PM
    #1522
    RickyBobbysTundra
    RickyBobbysTundra New Member
    Phoenix
    2023 Solar Octane TRD Pro
    Follow up:
    Have had that Retrax Pro XR (T-80861) since February and I absolutely love it. My favorite addition to the truck so far. I'm in and out of the bed constantly, and the retracting feature is very convenient, especially compared to manually flipping back the cover like with my Silverado.
    Did have an issue with it not closing properly, but thankfully Rack Attack (where I purchased from) took care of me thanks to warranty
    Otherwise it's been great for off-roads, trails, hauling stuff, and works great with the bed extender. It does eat up space but that's what the bed extender is for!
    A++ product, especially if it lasts another ten years.
    Oly73 likes this.
  23. Oct 10, 2023 at 5:09 PM
    #1523
    obgod3
    obgod3 New Member
    NC
    2023 Tundra Limited
  24. Oct 11, 2023 at 12:41 PM
    #1524
    TundraRyan
    2014 Crew Cab TSS
    Stock
    Looks good! I have a Honda TRX 450r Race quad and I got this cover just so I could roll it up and still have my quad in the back and close the tail gate! SOOOOOOOOOOOOOO happy I got the 6.5', These covers are nice for sure!
    obgod3[QUOTED] likes this.
  25. Oct 16, 2023 at 12:33 PM
    #1525
    amazingswami
    amazingswami New Member
    I had a Retrax on my F250, but I was concerned about losing so much bed space on the Tundra. How much bed space does the roll canister eat on our trucks?
  26. Oct 22, 2023 at 1:34 AM
    #1526
    RickyBobbysTundra
    Phoenix
    Enough that I recommend getting a bed extender.
    I'm able to store my go-bag/emergency stuff under the canister: rope, hitch, straps, etc. But I have 100% gotten my money's worth from the bed extender.
  27. Oct 22, 2023 at 1:56 AM
    #1527
    BenInILM
    BenInILM New Member
    Ben
    Surf City, NC
    2023 Toyota Tundra Platinum (Hybrid)
    OEM Bronze 18" Wheels Rokblokz Mud Flaps
    I have had BakFlip Revolver X4s on my last two Tundras. They have been great!
  28. Nov 24, 2023 at 9:07 AM
    #1528
    Lunar * Rock
    Lunar * Rock New Member
    Was this with the mx4 cover? Just curious if the hoses are the same or do different manufacturers use different sizes?
  29. Nov 25, 2023 at 12:06 PM
    #1529
    Harmacist
    Harmacist New Member
    Alex
    NC
    2023 MGM 1794 TRD OR
    Now that you’ve had it for a bit. What your overall opinion? How is the waterproofing?
  30. Nov 30, 2023 at 12:09 PM
    #1530
    jcmartin11b
    2022 lunar rock pro
    Sold the truck a few weeks ago. But I will be ordering another one of these when i get a new truck. It let very little water in and only on heavy rains. Very easy to put areobars with the bike rack on top of it.
