2022 Tonneau covers
Discussion in 'Tonneau Covers, Caps and Shells' started by ak407, Jan 22, 2022.
  1. Jan 22, 2022 at 8:01 PM
    ak407
    ak407 [OP] New Member
    Alex
    2022 MGM Tundra Plat
    Technology package, power running boards
    Anyone have or planning on getting a retractable tonneau for the crew max 5.5” bed?
    Sportyginger and TopClass AUTO like this.
  2. Jan 22, 2022 at 8:06 PM
    Breathing Borla
    Northern Illinois
    No , absolutely not. Nobody is going to do that :yes:
    RavingOx, bigjuice and Cpl_Punishment like this.
  3. Jan 22, 2022 at 8:57 PM
    ak407
    Alex
    Why is that?
  4. Jan 22, 2022 at 11:38 PM
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    I think he is just pulling your leg there (check the yes emoji right after) :)
    when you say retractable I am assuming you mean like the “roll n lock” ones we have seen on the 2nd gens?
    …otherwise a lot of folks on here are trying to get the tru-fold hard/soft tonneau, diamondback (not necessarily retractable) and such.
    raylo, toyofan87 and Breathing Borla like this.
  5. Jan 23, 2022 at 1:07 AM
    Chrisquint9
    Chrisquint9 New Member
    22’ Limited LR TRD
    GoHooterGo, Mattedfred and ak407[OP] like this.
  6. Jan 23, 2022 at 5:47 AM
    toyopl
    toyopl New Member
    How are they in winter ? Can they freeze, and be hard/impossible to open ?
  7. Jan 23, 2022 at 6:06 AM
    Breathing Borla
    Northern Illinois
    yes, I had one on my dc tundra, not the best idea if you live up north, mine was frozen shut several times
    And it rattled on bouncy roads
    Archive and toyopl[QUOTED] like this.
  8. Jan 23, 2022 at 6:09 AM
    ak407
    Alex
    I’m here in FL. I’m between a tri fold or retractable. I like the look and functionality of the retractable, but I figure the tri fold from the dealer fits perfect
  9. Jan 23, 2022 at 6:12 AM
    Breathing Borla
    Northern Illinois
    I have had every kinda cover you can think of lol, the tri fold that doesn’t rest on the cab when fully open is the best , I have the Bak F1 at the moment
    JustDave and Tundrastruck91 like this.
  10. Jan 23, 2022 at 6:36 AM
    ak407
    Alex
  11. Jan 23, 2022 at 6:56 AM
    Toyota1234
    Toyota1234 New Member
    Jack
    2022, army green limited, off road, DC
    I had really good luck with the tonnopro trifold. I’m waiting for them to update one for the 2022. Probably try the hard fold this time. They thought it would be available in a couple months. I don’t like the ones that sit low profile as they take up bed space. And the tri fold opens and is ready to go so quickly. And completely waterproof.
  12. Jan 23, 2022 at 7:19 AM
    ja5er
    ja5er New Member
    New York
  13. Jan 23, 2022 at 7:36 AM
    Tundra-G
    Tundra-G New Member
    2022 Tundra Ltd 4x4 TRD Off-road
    I am planning to get the RetraxPro XR cover. I had emailed them, and was told they expect availability of covers for the new Tundra at the end of February.
    https://retrax.com/retraxpro-xr
  14. Jan 23, 2022 at 8:13 AM
    raylo
    raylo not so new member
    Frederick, MD
    I have a Pace Edwards retract on my Tacoma and love it. No problems in cold weather except if and when it is literally covered with ice. That doesn't happen that often here and it has never happened when I needed to open it. The folding type would have the same problem. You would just need to scrape the snow and ice off. Internally there is no issue with ice as any liquid that enters the mechanism exits via the drain tubes. I am 90% going to go with another retract if and when I get a Tundra.
  15. Jan 23, 2022 at 8:14 AM
    Tundra-G
    Tundra-G New Member
    UptopOverland has a one. These come as mid height or full height. You will need the full height for a canoe.
    https://www.uptopoverland.com/products/truss-afs-retrax-adaptive-full-size-bed-rack
    Mattedfred[QUOTED] likes this.
  16. Jan 23, 2022 at 8:16 AM
    raylo
    Frederick, MD
    I am going to look at those, too when the time comes. I believe that is one that does take the above bed racks for kayaks, bikes, or whatever. I need to see how they work, first, and how hard it might be to pop the racks off when you need that space above for carrying bigger stuff in the bed.
  17. Jan 24, 2022 at 5:04 PM
    kuralex
    kuralex New Member
    Alex
    Ontario, Canada
    I also was looking to get combination TracRac SR Sliding Truck Rack + BAK Revolver X4s Hard Tonneau Cover for 6.5' bed
    but seems like we need to wait more
    theripper, Henry1jg and Mattedfred like this.
  18. Jan 24, 2022 at 5:14 PM
    oxlsu40
    oxlsu40 New Member
    2022 Black SR5 4x4
    I'm surprised no one has mentioned diamondback yet. They will have their HD and SE versions available in a couple weeks.
  19. Jan 24, 2022 at 5:49 PM
    RavingOx
    RavingOx Member
    WNC
    2022 Tundra Platinum in Black
    They were mentioned a number of times in the accessories thread.
  20. Jan 24, 2022 at 5:50 PM
    oxlsu40
    oxlsu40 New Member
    2022 Black SR5 4x4
    You're right, my fault, onward.
  21. Jan 25, 2022 at 2:55 AM
    raylo
    Frederick, MD
    Just a couple of other points to make after owning a cover... some retracts like mine have key locks and an external latch, so you can open the cover without opening the tailgate. Most others seem to have no key lock but the latch is concealed underneath so you have to drop the tailgate to get to it. There are obvious pros and cons to both types. And one uncommon issue to be considered is what happens if your electric tailgate lock fails in the locked position. If your cover needs the tailgate down to gain access to the latch you'd have to do surgery to get at that tailgate inside panel to fix the lock. Not likely with the factory electric tailgate lock but just something to consider.
    RickyBobbysTundra likes this.
  22. Jan 25, 2022 at 5:25 AM
    toyopl
    toyopl New Member
    I'm new to pickups, and have it on order, but need ladder rack + cover like in your pic.
    This combo looks pretty nice, does any cover work with ladder rack, or did you have to modify it to make it work ?
  23. Jan 25, 2022 at 6:42 AM
    kuralex
    kuralex New Member
    Alex
    Ontario, Canada
    What I investigated the narrow BAK Revolver X4s Hard Tonneau Cover will work with TracRac SR Sliding Truck Rack.
    Another approach is Adarac ladder rack, but it's not removable and load capacity is not like with TracRac SR Sliding Truck Rack.
    That is the good explanation https://www.etrailer.com/question-556093.html
  24. Jan 25, 2022 at 7:02 AM
    raylo
    Frederick, MD
    That looks like a nice setup and those Revolvers are interesting. Only thing I don't like is that they don't seem to have a way to be secured in an intermediate position. That is one thing I really like about the retracts. For instance I can open mine about a foot or so and carry tall gas cans for the mowers without having to leave the rest of the contents uncovered and exposed to the wind.
    And to answer an earlier question, no, those add on high racks are not compatible with all covers. For instance, they do not work with my Pace Edwards Jackrabbit tonneau. The Retrax brand (and maybe some others?) has some models that come with specific side rails that do accept those racks.
    Just FYI, here is a photo of my Tacoma with the Pace Edwards cover. I also installed an aftermarket electric tailgate lock so this makes for pretty secure storage. Tundra seems to come with electric tailgate lock, at least in all the trims I might consider.
    RickyBobbysTundra and Mattedfred like this.
  25. Jan 25, 2022 at 7:11 AM
    kuralex
    kuralex New Member
    Alex
    Ontario, Canada
    Thanks raylo!!! Good point and looks good as well. I think this variant also will work with TracRac SR Sliding Truck Rack
    raylo likes this.
  26. Jan 25, 2022 at 9:46 PM
    ak407
    Alex
    Anyone have a recommendation on a good retractable tonneau for a 5.5’ bed around $1k? Or know of a company making one soon for the 2022’s
  27. Jan 26, 2022 at 2:01 AM
    TF_CC
    TF_CC New Member
    One may exist, Truck2Go. I can't vouch for it though as to whether it's "good" or not. Double your budget to $2k and then you can shop for sure.
    I'm a multi-time Roll 'n Lock owner and have never had any issues with them. Retrax also makes one that I've read here is highly rated.
  28. Jan 26, 2022 at 5:59 AM
    SirSwish32
    SirSwish32 New Member
    Nick
    North Carolina
    2022 Tundra SR5 XP 4X4
    1.75" Rough Country Level
    I just made a tonneau post in the accessories thread actually. Anyone that claims "fits 07-22," isn't true. I ordered Rough Country's hard tri fold which stated it fit but it did not. About 1/2" too short and 1/4" too narrow.
    WesternMassOutdoors and raylo like this.
  29. Jan 26, 2022 at 6:07 AM
    bigjuice
    WA State
    2024 Terra TRD Pro
    Yup…just saw that and responded (good not bad way)
    …there is another post I quoted with a RC fitment from that thread that said it fit so it’s a good question of “why it worked for 1 but not for the other?”
    raylo likes this.
  30. Jan 26, 2022 at 8:06 AM
    DesmoDoe
    DesmoDoe New Member
    Canada
    22 SO TRD Pro
    May I ask why you're going with the ProXR vs the OneXR? I know there is the obvious weight capacity increase with the Pro given the materials, but anything else I'm missing when comparing the two?
    I'm leaning heavily into a Retrax XR model so I can mount ski boxes and bikes above the bed (and still get access to the bed) but can't decide if the Pro is worth the extra cost for me.
