2022 Tonneau covers
Discussion in 'Tonneau Covers, Caps and Shells' started by ak407, Jan 22, 2022.
  1. May 23, 2023 at 6:54 PM
    #1411
    Dirtdog
    Dirtdog New Member
    2023 Tundra SR5 TRD off road premium
    Is your rail pushed all the way up to the front Toyota rails? See picture below.
  2. May 23, 2023 at 7:32 PM
    #1412
    Woocawachie
    Woocawachie New Member
    Dickens
    Philadelphia
    2023 Tundra Limited CM 6.5. WindChillPearl
    Yes I have the SR, no factory rails. Used the other clamps provided. I did push the rails as far as they go to the front, however the cover itself I had to move slightly back as to provide enough overlap for the seal over the tailgate
  3. May 24, 2023 at 3:36 AM
    #1413
    Dirtdog
    Dirtdog New Member
    Ok. If you don't have enough length to cover the front and the back then that is a problem. With my cover the only issue that I had was getting it far enough forward for the gasket to cover the front. The back is ok You could contact the manufacturer and convey the issue and the fact that you just don't have enough length to cover the bed. It seems like it could be a manufacturing issue if you do have the length to cover both.
  4. May 24, 2023 at 3:51 AM
    #1414
    DMackler
    DMackler New Member
    Dustin
    Burleson, Texas
    2023 Celestial Tundra CM TRD OR
    I've seen that issue with every Undercover I've installed. Seems like they could all use an extra 1/2". Doesn't matter what make they are installed on.
    Woocawachie likes this.
  5. May 24, 2023 at 8:59 AM
    #1415
    bosscib
    bosscib New Member
    PA
    2023 TRD Pro
    For those of you with the Undercover UltraFlex, what made you choose that over the ArmorFlex? I have a 2023 on the way and I'm trying to decide which one to buy.
  6. May 24, 2023 at 10:47 AM
    #1416
    TRDoffroadPRO
    TRDoffroadPRO New Member
    2023 Hybrid CM Limited TRD OFR
    BAK makes Undercover as well as they are the same company. I have the F1 with a 5 year warranty but wish I had the drain tubes from the Ultraflex even though I am not a fan of the carpeted underside.
  7. May 24, 2023 at 11:10 AM
    #1417
    Woocawachie
    Dickens
    Philadelphia
    I had no factory rails, ultra flex comes with own attachment clamps, and it’s sold on Amazon which I get 5% off and can spread monthly payments over 12 months no interest. Those were my reasons
  8. May 24, 2023 at 12:26 PM
    #1418
    Dirtdog
    Dirtdog New Member
    One of the big differences is your preference of the finish on the top of the cover. If you clean your truck often and expect to clean the cover I with a rag or a sponge I think the Ultrafex is a better option. If you use your truck more for a work truck and only occasionally hose off the cover then you may prefer the more heavy duty finish of the armorflex. I haven't seen the armorflex in person but I think the finish is rough and textured like a Linex truck bed so it may not be easy to clean using a wipe down method. I think it comes down to your preference on the finish and the usage of your truck.
  9. May 24, 2023 at 1:43 PM
    #1419
    bosscib
    bosscib New Member
    PA
    2023 TRD Pro
    Interesting, I never realized how many brands were under Realtruck.
    Makes sense. I'll have the rails so I wasn't thinking about that.
    Thanks for sharing. That is part of the reason I was leaning toward the ArmorFlex, hoping that it would be more durable.
  10. May 24, 2023 at 2:26 PM
    #1420
    Schmidt_l
    Schmidt_l New Member
    Leidir (Lay-Jeer)
    2008 Tundra Sr5 DC
    Grille??
    Would you mind giving me the total dims of your cover L"xW"? please
  11. May 24, 2023 at 3:40 PM
    #1421
    G3ardnut
    G3ardnut Brushed Chrome is COOL
    Joe
    Canada
    2023 Limited TRD Offroad Crewmax Celestial Silver Metallic
    I am in the same boat as my Tundra should arrive in July. I am going with the Armorflex versus the Ultraflex for the following reasons. One is I like the look of Line -X flat black coating better. Two the Line-X is more durable and resists scratches and dents better. Thirdly, when flipped up all the way it does not rest against the cab and finally, I've heard of reports that the Ultraflex can absorb water within the FRP panels over time and results in the panels getting heavier and heavier. There are some YouTube videos I believe on this last issue.
  12. May 24, 2023 at 8:47 PM
    #1422
    WoodyOne
    WoodyOne New Member
    Spring, TX
    2023 1794 Blueprint 4x4
    I got 82" x 67.25". I have the standard 6'7" bed. The measurement may be off a tiny bit because of the beveled top and a solo job on measurement. But I think it's pretty accurate.
  13. May 25, 2023 at 7:41 AM
    #1423
    Schmidt_l
    Leidir (Lay-Jeer)
    2008 Tundra Sr5 DC
    Grille??
    awesome, man
    really appreciate it
    WoodyOne[QUOTED] likes this.
  14. May 25, 2023 at 8:28 AM
    #1424
    Breathing Borla
    AZ
    my undercover ultra flex seems like it fits perfect , maybe I got lucky or something then
  15. May 25, 2023 at 9:48 AM
    #1425
    DMackler
    DMackler New Member
    Dustin
    Burleson, Texas
    Maybe... Even though they are both truck hero companies, I could install a bak flip on a truck and an ultra flex on an identical truck the same day and the ultra flex would always be a mess to get good coverage in both front and back. Ironically, they have more robust seals on the sides which add coverage on the bed rails.
    That's the only knock I can give the ultra flex, besides that, they are really nice covers.
  16. May 25, 2023 at 10:52 AM
    #1426
    kilocharlie106
    kilocharlie106 mmmm Bourbon
    TRD Pro in LR
    I have had my WeatherTech hard cover for 9 months so far. Doesn’t leak. Have no issues other than my 80qt Cabelas cooler doesn’t fit underneath. I would recommend this cover. It’s made by Lomax, but Weathertech will back it up for life so that’s why I went this route.
    surfmc likes this.
  17. May 25, 2023 at 11:59 AM
    #1427
    Breathing Borla
    AZ
    The weather tech only folds twice though right doesn’t go all the way up to let the entire bed use right ? My busniess partner has one on his ram, nice cover but it didn’t fold all the way up you had to take it off if you wanted access to where the third panel is
  18. May 25, 2023 at 2:06 PM
    #1428
    kilocharlie106
    TRD Pro in LR
    Correct. Doesn’t fold on cab. Every cover has its pros and cons. But there’s no recall on it for flying off and it keeps the bed dry.
  19. May 25, 2023 at 8:24 PM
    #1429
    bosscib
    bosscib New Member
    PA
    2023 TRD Pro
    Thanks for replying. I’m going to order the Armorflex too.
    G3ardnut[QUOTED] likes this.
  20. May 30, 2023 at 1:53 PM
    #1430
    Carolina Peej
    Carolina Peej Hey can you hold the light for me real quick?
    North and South Carolina
    2022 Midnight Black Metallic 4x4 Tundra Platinum 5.5 w/ load leveling + AVS, HUD, and Power Running Boards
    Yes the revolver X4s roll up hard cover. Just not a great fit or design.
  21. May 30, 2023 at 6:17 PM
    #1431
    BluePete
    BluePete New Member
    Utah
    2023 SR5 TRD Off-Road Blueprint
    I had my BakFlip MX4 delivered over the weekend. Still waiting for the truck to come. Should be here this week. Should install it within the first day or 2.
  22. Jun 2, 2023 at 7:57 PM
    #1432
    djmeen
    djmeen New Member
    ‘23 Tundra Platinum
    Thanks to everyone on this thread for sharing thoughts and advice on bed covers. It was a lot to go through but finally made a decision. RetraxPRO MX installed today by a local shop in Houston.
    Pretty excited about it. Love the look. And after a brief rain this afternoon things look promising in terms of being rain resistant.
  23. Jun 2, 2023 at 8:57 PM
    #1433
    Robbsolid
    Robbsolid New Member
    Puyallup, WA
    2022 LTD HV WCP.
    I disagree with this. I have the Revolver X4S and it's the best cover I've ever owned.
  24. Jun 3, 2023 at 11:33 AM
    #1434
    Dirtdog
    Dirtdog New Member
    I have an Ultraflex and I noticed that I had a small leak in water collector where it interfaces with the aluminum extrusion. The water was coming out the small rectangular channel that is in the middle of the extrusion. The picture below shows where I had the RTV nozzle in this channel. I filled this with RTV and also the end of the rail where the rectangle is wide open. The RTV seems to have fixed this leak. To see if you have this problem you can just flip the cover all the way back and slowly pour some water in the channel. One side of my rails had a leak and the other did not. But I just filled both to make sure neither would leak in the future.
    IMG_20230603_100839198.jpg IMG_20230603_101421645.jpg IMG_20230603_101346317.jpg IMG_20230603_101956197.jpg
    G3ardnut and AND like this.
  25. Jun 3, 2023 at 1:50 PM
    #1435
    G3ardnut
    Joe
    Canada
    That makes sence to plug that end of the channel. Not sure why they would even leave that open if that channel collects the water. I was also thinking on the other end of the channel where it butts up to the front of the box to use a piece of foam to seal that joint during installation. Use the same foam that they give you for the back of the box.
  26. Jun 3, 2023 at 2:34 PM
    #1436
    Breathing Borla
    AZ
    Good call just added some marine sealant to mine, I think they made the rails a touch short if they wanted to drain the overflow out those little holes at the end of the rail .
    I also sealed the hole in the end piece that slides in.
    every cover I’ve ever owned has always needed a touch of sealant here or there , it’s no big deal .
    thanks for the info as I just got mine and starting to make sure it’s as water tight as it can get
    G3ardnut likes this.
  27. Jun 4, 2023 at 10:33 AM
    #1437
    Philipl
    Philipl New Member
    Philip
    North Mississippi
    Had my weather tech for over a year. Five hunting trips at 570 miles each way often in driving rain. No leaks. Coleman 316 150 quart cooler fits under it.
  28. Jun 5, 2023 at 5:22 PM
    #1438
    WesternDawg
    WesternDawg New Member
    2024 Ice Cap Tundra TRD Pro
    Harmacist, AND and DMackler like this.
  29. Jun 7, 2023 at 7:48 AM
    #1439
    Harmacist
    Harmacist New Member
    Alex
    NC
    2023 MGM 1794 TRD OR
    This might be a game changer. 900lb static load is awesome, plus a 400 lb haul rating, not just weight-bearing. Only other trifold with that high of a weight rating I’ve found was the renegade cover. But I haven’t found many reviews or good reviews about it.
    WesternDawg[QUOTED] likes this.
  30. Jun 7, 2023 at 10:02 AM
    #1440
    Harmacist
    Alex
    NC
    @jcmartin11b
    I’d hope by now you’ve received the renegade cover. How do you like it? Pros and cons?
    jcmartin11b[QUOTED] and Maharisc like this.
