2022 Tonneau covers
Discussion in 'Tonneau Covers, Caps and Shells' started by ak407, Jan 22, 2022.
  1. Mar 26, 2023 at 7:46 AM
    #1321
    Dirtdog
    Dirtdog New Member
    2023 Tundra SR5 TRD off road premium
    So I decided to go with the Undercover Ultraflex. One down-side to this cover vs. the MX4 is that the Ultraflex rails cover up the Toyota rails to some degree and thus you can't get the standard Toyota plastic cleats on the rail. I did mount some of the D-ring tie downs that I used on the bed mounts. I have a posting in the Accessories thread that shows these in the bed mount bolts. I mounted these using the T-nuts that I also bought on Amazon. When I was looking at the different covers I wasn't able to find much in terms of details on the brackets so I'll post some close-ups of the brackets and some of the other install details. Let me know if you need any other info.
    Toyota Rail Bracket Close-up:
    T-nuts and D-rings:
    Angle of Ratchet Strap: (You can go up about 45 degrees before you hit the Undercover rail. ~26 to 27" at the wheel well).
    Hole for Drain Tube: (The drain tube is pretty big ~5/8" in OD. I had to drill out the two corner holes to about 3/4" to make it fit.)
    Rails with D-rings:
    Final Photo:
    Overall it went pretty well. The cover does seem to be very heavy duty. Let me know if you have any questions.
  2. Apr 1, 2023 at 11:36 AM
    #1322
    Woocawachie
    Woocawachie New Member
    Dickens
    Philadelphia
    2023 Tundra Limited CM 6.5. WindChillPearl
    Looking for the deck rails. Recently obtained a 2023 SR crewmax. And it doesn’t come with the rails to secure the tonneau cover. I only have one side towards the driver side of the bed. Anyone on here selling a set or know where I glcan find one. Stupidest configuration with these SRs
  3. Apr 1, 2023 at 12:00 PM
    #1323
    Maharisc
    Maharisc w/Patty
    Karl
    2023 Tundra Platinum MBM Hv CM Adv Pkg
    Build date: 12/05/22
  4. Apr 1, 2023 at 12:13 PM
    #1324
    Woocawachie
    Dickens
    Philadelphia
  5. Apr 1, 2023 at 12:16 PM
    #1325
    Maharisc
    Maharisc w/Patty
    Karl
    Calling @ryanwgregg , could you assist with part number on cargo rails? Thank you sir.
    Woocawachie likes this.
  6. Apr 3, 2023 at 1:16 PM
    #1326
    Woocawachie
    Dickens
    Philadelphia
    5’5.
    ryanwgregg likes this.
  7. Apr 3, 2023 at 1:46 PM
    #1327
    Woocawachie
    Dickens
    Philadelphia
    Awesome! Thank you. I can always cut them down.
  8. Apr 3, 2023 at 2:34 PM
    #1328
    Woocawachie
    Dickens
    Philadelphia
    is there any difference in these rails from the 2021 model of tundra? If I’m going to be cutting them, and it’s the same diameter I don’t see why it’s not doable with the ones from 2021 model year. They are way cheaper
  9. Apr 3, 2023 at 2:36 PM
    #1329
    ziznack
    ziznack New Member
    Texas Y'all
    2024 Lunar Rock Platinum
    I know the rails on my 2023 appear to be identical to the ones from my 2013, but I can't say for certain.
    Woocawachie[QUOTED] likes this.
  10. Apr 3, 2023 at 2:54 PM
    #1330
    Woocawachie
    Dickens
    Philadelphia
    Good to hear. I’ll compare my one rail that they included for the front of the bed, with my buddies 2018 rails and if they are the same I’m buying the previous gen model
  11. Apr 3, 2023 at 6:12 PM
    #1331
    Descend
    Descend New Member
    North West
    '23 Tundra TRD Pro MGM
    My Bakflip MX4 leaks on the regular. I thought it was just the tailgate but today I saw it dripping from the middle of the cover. I don't think it's coming straight through. Probably from the sides.
    Has anyone with the MX4 had luck sealing this cover?
  12. Apr 3, 2023 at 6:21 PM
    #1332
    ziznack
    ziznack New Member
    Texas Y'all
    I just put mine on on Saturday and haven't had rain yet. I'll let you know lol. Looking at the tailgate area, I can't see how water would not be able to get in as there are gaps. I had an extang solid fold on my 2013, it did good but some water always got in. I am tempted to drill an extra two holes at the back. Two for the drain tubes and two for water that makes it in.
    Descend likes this.
  13. Apr 3, 2023 at 7:51 PM
    #1333
    walleyes
    walleyes ‘23 Tundra
    @Maharisc I believe you have the Truxedo Sentry CT tonneau cover, correct? If so would you be willing to provide the minimum bed height with the tonneau closed? Want to make sure I have enough height for some of my gear. Thank you
  14. Apr 3, 2023 at 7:52 PM
    #1334
    Kona_boy
    Kona_boy New Member
    Jeff
    Kent, WA
    2023 white tundra 1794 TRD
    took 6 days to ship from my order date. From there about 5 days to delivery, everything intact installed yesterday pretty happy with it besides the price but they were cheapest of all companies. Real truck with their price match policy wouldn't touch their price
  15. Apr 3, 2023 at 9:44 PM
    #1335
    Hella Krusty
    Hella Krusty New Member
    Those suck in Canada where it freezes. My Extang was frozen to the box all the time....hated it
  16. Apr 3, 2023 at 9:53 PM
    #1336
    Yota802
    Yota802 New Member
    2023 Tundra Hybrid Limited CM WP
    Are you looking to get a visual, roughly how much space the canister takes up? I have the Retrax cover with shortbed Limited.
  17. Apr 4, 2023 at 7:23 AM
    #1337
    Maharisc
    Maharisc w/Patty
    Karl
    Here is a pic with cover on and a rubber mat in. Hope this helps. I don't have this truck as of Jan 25, traded for current 23 with OEM. Waiting to see what comes of the recall then decide to keep or go back to Truxedo. No issues with cover in extreme cold temps here in Montana.
    troutback likes this.
  18. Apr 4, 2023 at 6:01 PM
    #1338
    walleyes
    walleyes ‘23 Tundra
    Yes, that does help. Thank you!
  19. Apr 15, 2023 at 1:55 PM
    #1339
    ziznack
    ziznack New Member
    Texas Y'all
    I feel like maybe bakflip sent me the wrong rails? Does anyone else's MX4 on the newer tundras fit like this? The cap by the tailgate looked right, but the cap by the cab seems off.
    mayan and AND like this.
  20. Apr 15, 2023 at 2:00 PM
    #1340
    Breathing Borla
    Northern Illinois
    I ordered a undercover ultra flex from real truck vendor since my oem Toyota one got removed from the build
    I much prefer this route anyways
  21. Apr 15, 2023 at 2:01 PM
    #1341
    AND
    AND New Member
    Washington, PNW
    Call them, their customer service is phenomenal.
  22. Apr 15, 2023 at 5:12 PM
    #1342
    NickyF25
    NickyF25 New Member
    Nick
    SE Pa
    2017 Platinum 4x4 Silver Sky-Sold
    I have the X4s on my Gen 3 Raptor and love it. Much better imo than the Tri folds. Had an undercover flex on my tundra and hated that you lose the
    use of the rails and that it blocked the rear window when fully open.
  23. May 2, 2023 at 7:28 AM
    #1343
    ziznack
    ziznack New Member
    Texas Y'all
    Update. I contacted BAK and they asked for me to measure the rails. When I went to measure the rails I noticed this. The metal is cutting into the rubber when I have it folded up. They told me that the rails are slightly out of spec and that the panels on my cover are misaligned. They are sending me new rails and a new cover.
  24. May 2, 2023 at 7:43 AM
    #1344
    Woocawachie
    Dickens
    Philadelphia
    Are you sending the old one back to them ?
  25. May 2, 2023 at 7:45 AM
    #1345
    ziznack
    ziznack New Member
    Texas Y'all
    They told me to destroy it. That I need to drill holes in it and send them a picture.
  26. May 2, 2023 at 7:48 AM
    #1346
    Breathing Borla
    Northern Illinois
    Im kinda glad I went with undercover at this point.
    although its still in the box in the garage until my rig is ready, lol.
  27. May 2, 2023 at 8:19 AM
    #1347
    Woocawachie
    Dickens
    Philadelphia
    Sell it to me. I’ll send you pics with holes in it
    ziznack[QUOTED] likes this.
  28. May 2, 2023 at 9:41 AM
    #1348
    ziznack
    ziznack New Member
    Texas Y'all
    Lol. My coworker already wants it.
  29. May 2, 2023 at 9:44 AM
    #1349
    Woocawachie
    Dickens
    Philadelphia
    Darn… let me know if he changes his mind
  30. May 2, 2023 at 11:12 AM
    #1350
    ziznack
    ziznack New Member
    Texas Y'all
    I feel like shipping wouldn't be worth it lol
