2022 Tonneau covers
Discussion in 'Tonneau Covers, Caps and Shells' started by ak407, Jan 22, 2022.
  1. Dec 8, 2022 at 12:47 PM
    #1141
    JUNNEL20
    JUNNEL20 New Member
    Junnel
    I had to adjust mine and moved it a little bit forward so the tailgate release would work. The gasket at the edge of the cover is too grippy.
  2. Dec 8, 2022 at 5:34 PM
    #1142
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    You guys really need to try applying some silicone to the seal. I've had 4 tonneaus on my 22 so far and all of them stuck the tailgate closed. I'd hear it unlock but not move. One spray of silicone across the rubber seal, problem solved with all of them.
    taylorutah likes this.
  3. Dec 8, 2022 at 6:18 PM
    #1143
    Maharisc
    Maharisc w/Patty
    Karl
    2023 Tundra Platinum MBM Hv CM Adv Pkg
    Build date: 12/05/22
    I have the Truxedo Sentry CT and the tailgate never sticks. No silicone either. It's a hard roll-up and works well in the winter of Montana too... Had this on my 2020 Taco as well with no issues.
    the4rdan likes this.
  4. Dec 8, 2022 at 11:20 PM
    #1144
    topdec
    topdec New Member
    AWD Sprinter, 2023 4R ORP, 2 3rd gen Tundras - sold
    Looks great. Can you provide pics and detail on the Thule XSporter Pro install?
  5. Dec 9, 2022 at 4:54 AM
    #1145
    99ways2die
    99ways2die New Member
    NJ
    2022 Tundra Platinum
    **Copy/paste from a convo I had with someone here not long ago, as I was asked the same thing:
    So the rack system is a modified XSporter from Thule (in black; I got mine off Craigslist).
    Example:
    https://www.thule.com/en-us/roof-rack/truck-and-van-racks/thule-xsporter-pro-_-500xt
    I didn't use the mounting bases at all, and I cut the vertical bars to fit my need (I did this a while back, when I had my 2017 with a soft roll-up cover, so that I could still roll it up under the rack-worked well).
    The shortened vertical bars have been threaded top and bottom, to mount the cross bars on top, and HomeDepot brackets on the bottom. I don't have a part number of the HomeDepot bracket for you however (can't easily find n on their web site), but those were found in lumber section and are just the right shape, size and finish to then mount underneath to the truck bed's rail system (inside the bed). Drilled a couple of holes in them and bolted it all up.
    Since my 2022 has a hard cover I had to notch the rails of it for the brackets.
    See pics below for a visual on how it's all done.
    I run 2 set ups (bought a 2nd set of XSporter cross bars): summer set with 4x Thule bike racks, and winter cross bars with ski racks on them (currently installed).
    Hope this helps.
    -99
  6. Dec 9, 2022 at 8:01 AM
    #1146
    topdec
    topdec New Member
    Wow, nice work! Thanks for all the detail. It looks like you got the system configured exactly how you want it.
    It took me a few times to read through the post to understand that you notched the tonneau's base so it sits flat on top of each of the home depot brackets.
    Now I have to find bed racks that sit on it's own rail system and slide front-and-back. I'll probably copy your workaround for bolting the rack's rails to the truck's rails. I don't know if I explained this well.
  7. Dec 12, 2022 at 2:52 PM
    #1147
    Leif84
    Leif84 New Member
    2023 Tundra TRD PRO
    My Retrax is frozen and won't slide open. I gave them a call and they recommended banging along the tracks to loosen any ice...well that didn't work. Any suggestions?
  8. Dec 12, 2022 at 2:57 PM
    #1148
    KroppDuster
    KroppDuster A normal guy trying to survive this crazy world
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Bilstein 5100s
    Have you tried using some liquid de-icer? I used to spray that on my bed toolbox in the winter so I could get it open during ice storms. Worked like a charm. Just spray it on everything that moves like you would WD-40. Keep a can of it in the truck.
  9. Dec 12, 2022 at 3:29 PM
    #1149
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Perhaps some window washing fluid that is good for cold weather. I use that on doors and window rubber to cut ice. I put it in a spray bottle and go to town.
  10. Dec 12, 2022 at 4:14 PM
    #1150
    Leif84
    Leif84 New Member
    2023 Tundra TRD PRO
    I don't know how that would work because the tracks are in the truck.
  11. Dec 12, 2022 at 4:18 PM
    #1151
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Can you open the tailgate? If so, perhaps you could put a small space heater in the box, close the tailgate and let the heat do its thing. Just be careful not to melt the box liner.
  12. Dec 12, 2022 at 6:17 PM
    #1152
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    It's pretty much a C channel. I'd think if you sprayed the de-icer into the tracks from the top it would make it's way in.
  13. Dec 13, 2022 at 5:51 PM
    #1153
    lrtexasman
    lrtexasman New Member
    Larry
    Rockwall, Texas
    2023 Tundra Crew Limited 4x4
    I installed the Bak Rev4. Seems to be a good fit so far. Had two pieces of weatherstripping, I saw where the thick one went (bulkhead). No idea where the thin strip goes? They have a good on-line video if anyone else tackles the job themselves. Word of warning if you have cargo rails, the metric T-head strips easy if you are not careful. I had one strip and it was PIA to get out.
  14. Dec 19, 2022 at 7:36 AM
    #1154
    the4rdan
    the4rdan New Member
    Pennsylvania
    2025 WCP Ltd. TRD OR CrewMax
    Hoping for some insight from anyone with the OEM tri-fold or Bakflip MX4...if you get a chance in the next couple days, any chance you could measure the height from the bed itself to the underside of the opening with the tonneau closed? My son has a wheelchair that fits with my Truxedo Pro X15 to place on it's side and slide under the tonneau, but considering switching to a hard cover and want to make sure I don't have a height issue switching.
    Thanks!
  15. Dec 19, 2022 at 7:49 AM
    #1155
    Fr0zenTundra
    Fr0zenTundra New Member
    Wi
    '22 platinum hybrid
    I have the mx4 - it's 20 1/8" to the bottom of the cover. the release latches, rubber bumpers and whatnot mounted to the bottom take up another inch.
  16. Dec 19, 2022 at 7:56 AM
    #1156
    lrtexasman
    Larry
    Rockwall, Texas
    I have the BAK REV 4. There is a solid 20” under the cover from the top of the c channel. I like that I can open and close the tailgate with the cover in a fixed position. I can also close the cover with the tailgate in any position as well.
  17. Dec 19, 2022 at 8:22 PM
    #1157
    walleyes
    walleyes ‘23 Tundra
    @Maharisc, do you have any problems with the Truxedo Sentry CT freezing up during the winter preventing it from rolling up? I’ve read that’s a problem with the BAK revolver covers.
    Also, is it difficult to clean this cover? I wonder because it’s a woven top not solid vinyl.
  18. Dec 20, 2022 at 3:58 AM
    #1158
    the4rdan
    the4rdan New Member
    Pennsylvania
    appreciate it!
  19. Dec 20, 2022 at 3:58 AM
    #1159
    the4rdan
    the4rdan New Member
    Pennsylvania
    appreciate your help!
    Fr0zenTundra[QUOTED] likes this.
  20. Dec 20, 2022 at 7:35 AM
    #1160
    Maharisc
    Maharisc w/Patty
    Karl
    I haven't had any issues opening it, even in the cold, unlike those with the X4S have (YouTube video). As for Cleaning, take it to the car wash - pressure was, no leaking in the box even though it is like canvas top. Do be aware of scratches, they are noticeable just like on vinyl. Keep in mind, this is manufactured in Yankton, South Dakota and they get very harsh winters there, so I'll assume they have done some test during extreme weather.
    walleyes[QUOTED] likes this.
  21. Dec 21, 2022 at 8:05 PM
    #1161
    RShackleford54
    RShackleford54 New Member
    Phoenix, AZ
    2023 White Tundra LTD 4x4
    Apologies if this has been answered, I can’t find an answer! For those with the OEM trifold, is there a lock so that belongings can be secured?
  22. Dec 21, 2022 at 8:10 PM
    #1162
    Paul Moll
    Paul Moll New Member
    Paul
    Idaho
    2023 1794 TRD off-road
    Installed MX4 the other day. Noticed that where the BakFlip rail ends at the rear it's not quite long enough, been discussed on this thread I think. There is maybe a half inch gap that of course will let water in. So I called BakFlip today and asked them about this. They of course were "unaware" of this problem. But...after me mentioning that this is a problem twice, they offered to send me a couple of rubber / foam pieces that they ship with the Tacoma cover for just this purpose. I'll take pictures with and without when I get those. Hope this helps.
  23. Dec 22, 2022 at 2:55 PM
    #1163
    tbrady
    tbrady New Member
    Southern Idaho
    2022 DC LTD Army Green
    Leer Canopy, TRD Steps
    When the tailgate is closed and locked the cover can’t be opened. There is no external handle or lock.
  24. Dec 22, 2022 at 3:24 PM
    #1164
    topdec
    topdec New Member
    Interesting how this looks very similar (if not identical) to the Toyota trifold tonneau.
    What bed rack system works well with the bakflip mx4?
  25. Dec 24, 2022 at 11:44 AM
    #1165
    lrtexasman
    Larry
    Rockwall, Texas
    Happy with my set up. Too cold to put bedrug mat Velcro adhesive down though. Have to wait for a warmer day.
    mikvic and RickyBobbysTundra like this.
  26. Dec 24, 2022 at 12:41 PM
    #1166
    Paul Moll
    Paul
    Idaho
    Is that Bed Rug? I don't recognize the color pattern. How do you like it?
  27. Dec 24, 2022 at 12:47 PM
    #1167
    lrtexasman
    Larry
    Rockwall, Texas
    I really like it. It’s the impact mat. Was just over $100. Very well made.
    RickyBobbysTundra likes this.
  28. Dec 24, 2022 at 1:02 PM
    #1168
    lrtexasman
    Larry
    Rockwall, Texas
    Here they are. Santarealtruck on the forum hooked up. Saved me some $$
    AND likes this.
  29. Dec 24, 2022 at 10:30 PM
    #1169
    Unitdosed
    Unitdosed New Member
    '22 Celestial Silver SR5, CREW CAB TRD OR 4X4
    None, yet
    From what I've seen... You can't open it unless you drop the tailgate. The tailgate has a lock so your tonneau should be secured if the gate doesn't drop.
    Am I missing something?
    R2theD2 likes this.
  30. Dec 28, 2022 at 1:20 PM
    #1170
    Leif84
    Leif84 New Member
    2023 Tundra TRD PRO
    My Retrax is working without any issues and the tailgate drops with both the FOB and tail light release. Their customer support has been top notch.
    Thought I'd pass this along.
