2022 Tonneau covers
Discussion in 'Tonneau Covers, Caps and Shells' started by ak407, Jan 22, 2022.
  1. Nov 29, 2022 at 8:03 AM
    #1111
    Maharisc
    Maharisc w/Patty
    Karl
    2023 Tundra Platinum MBM Hv CM Adv Pkg
    Build date: 12/05/22
    The hard roll up, isn't that the X4 or X4s? If you like the hard roll up, you should check out the Truxedo Sentry CT. No leaks, fits well.
  2. Nov 29, 2022 at 8:50 AM
    #1112
    Durtywrench
    Durtywrench New Member
    Lou
    23 Tundra platinum
    None
    thank you ! This will be the first time ol get a tonneau cover in new condition. Always bought used so I should just appreciate it
  3. Nov 30, 2022 at 6:47 PM
    #1113
    the4rdan
    the4rdan New Member
    Pennsylvania
    2025 WCP Ltd. TRD OR CrewMax
    Evening, everyone. This thread has been great, and I've overall been pretty happy with the TruXedo Pro X15 I got, but coming from a Leer 100 XQ cap on my '19, one thing I'm still getting used to is the dampness in the covered bed with a tonneau vs. a hard cap on damp/dewy mornings. This tonneau seals well from rain, so it's not a matter of leaking necessarily.
    What's your take on the bed not being as damp in the mornings with a different tonneau than a roll-up style like the Pro X15? Or is it tough to achieve the drier condition overall with the light weight of a tonneau vs the hard cap? Thanks!
  4. Nov 30, 2022 at 9:03 PM
    #1114
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    Just a FYI that may help, I have the Retrax Pro Mx and had more leaking than I was happy with the first week or so. I guess the seals and what not just need to settle in because it remains quite dry now, minus a few drops at the tailgate, even through high pressure washes.
    RickyBobbysTundra likes this.
  5. Dec 1, 2022 at 6:28 AM
    #1115
    ElJefe
    ElJefe New Member
    2023 Wind Chill Pearl Tundra Limited 4X4
    I had this on my 2013 Tundra. Very little leakage even in heavy rain. The issue I had with it was that when it went below freezing the aluminum would warp and the cover would not close unless I pressed down on the cover. At first it looked like someone tried to pry the cover open but when the temp went up to the 40s it went back to normal operation. For this reason I went with the RetraxPro XR for my 2023. Hopefully it isn’t an issue but for the extra $600 I get a lifetime warranty instead of just 1 year.
    Flubez[QUOTED] likes this.
  6. Dec 1, 2022 at 6:42 AM
    #1116
    JUNNEL20
    JUNNEL20 New Member
    Junnel
    I have the retraxpro xr as well. I've had it installed for about 2 weeks now and it leaks a little bit on the sides above the rear wheel wells. Are you having any leakage as well?
  7. Dec 1, 2022 at 10:17 AM
    #1117
    ElJefe
    ElJefe New Member
    I haven't installed the Pro yet. Still on its way. BTW, did you have to drill out the drain holes to make the tubes fit? The ones in the bed are super tiny.
  8. Dec 1, 2022 at 10:24 AM
    #1118
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    I did.....a dumb mistake I made was thinking I'd drill from the bottom up to ensure in wasn't drilling into anything. I was a damn itchy mess for about a day with that ground fiberglass on me, lol. I'm an idiot, now you can avoid that mistake LOL.
    ElJefe[QUOTED] likes this.
  9. Dec 1, 2022 at 10:33 AM
    #1119
    ElJefe
    ElJefe New Member
    On my 2013, there were drain holes that you just popped out. Like this
    https://tnstatic.net/attachments/20200408_175250-jpg.413918/
    I wonder why they didn't add those to the newer gen even with the composite.
  10. Dec 1, 2022 at 10:39 AM
    #1120
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    I don't think so. If they are there, they are so covered I didn't see them.
  11. Dec 1, 2022 at 10:49 AM
    #1121
    Swarley
    Swarley New Member
    I had the same experience, less leaking after the first few weeks. Pretty happy with it now.
  12. Dec 2, 2022 at 12:37 AM
    #1122
    AWDDude
    AWDDude New Member
    2023 Tundra Limited - Crew Max TRD Off Road 4x4
    Hoping you guys can help me find a bed cover that fits my needs. I like having a bed cover during the winter to keep the snow out of the bed. However, for the rest of the year I like to have an open bed for hauling stuff or for my dog. On my last truck (3rd gen Tacoma) I had the factory trifold hard cover, which sat on top of the bed rail and didn’t require additional rails to be installed, making it very easy and fast to completely remove.
    Most of the covers I see on the market for my new tundra seem to require installing rails that take up bed space when the cover is retracted. I don’t care so much about a low profile look. Are there any trifold, quadfold, or hard roll up covers that don’t require the installation of additional rails?
  13. Dec 2, 2022 at 6:01 AM
    #1123
    Point Man
    Point Man New Member
    Mark
    Racecity USA Mooresville, NC
    2023 1794 MGM
    Tonneau Cover, Cat Shield, Power Boards, Bed Mat, Rear Light Bar
    I can’t speak for others but the MX4 mounts with the existing rails. Real truck site has a video showing installation on a new Tundra
  14. Dec 2, 2022 at 6:47 AM
    #1124
    JUNNEL20
    JUNNEL20 New Member
    Junnel
    I opted to drill on the side of the bed so that I can still have the factory drain holes for when I wanna wash the bed. Otherwise, the water would just sit there for days. Pardon the puddle of water around the front passenger side. I didn't know until later on that the o-ring washer came off of the drain grommet prior to installing it. Luckily, I found it under my bed mat lol.
    BTW, I drilled the holes 2" from the bottom.
  15. Dec 2, 2022 at 6:48 AM
    #1125
    tbrady
    tbrady New Member
    Southern Idaho
    2022 DC LTD Army Green
    Leer Canopy, TRD Steps
    Replacing my Toyota OEM tonneau with a Leer shell today. I thought I would like the tonneau better than the cover I had on my 2012, but the need to carry larger items that needed weather protection outweighed the desire for a little less weight. The tonneau was generally water tight except in really hard rain, but couldn’t keep dust out around the tailgate no matter how much I tried to seal it. I did manage to keep it from getting all the way to the front of the bed.
    RickyBobbysTundra and ryanwgregg like this.
  16. Dec 2, 2022 at 7:15 AM
    #1126
    ElJefe
    ElJefe New Member
    Nice! That is where the drain holes were located in my 2013 so it makes sense to put them there.
  17. Dec 2, 2022 at 9:23 AM
    #1127
    AWDDude
    AWDDude New Member
    The video shows them installing side rails
    https://youtu.be/0VJ69_h0yyk
  18. Dec 2, 2022 at 12:16 PM
    #1128
    Point Man
    Mark
    2023 1794 MGM
    Thx. I was in an airport and could not attach the link. It seems to be a straight forward install.
  19. Dec 2, 2022 at 4:01 PM
    #1129
    AWDDude
    AWDDude New Member
    That’s funny, I was in an airport too,lol. I’m looking for a cover that doesn’t require side rails at all.
  20. Dec 2, 2022 at 4:40 PM
    #1130
    Point Man
    Mark
    2023 1794 MGM
    Weary travelers unite! Actually I think the MX4 can be mounted either way.
  21. Dec 5, 2022 at 6:26 AM
    #1131
    Jibber82
    Jibber82 New Member
    LOMAX professional series tonneau cover. Super easy to install and seems nice so far. Easy to take on and off too.
  22. Dec 5, 2022 at 4:26 PM
    #1132
    Leif84
    Leif84 New Member
    2023 Tundra TRD PRO
    I had the Retrax Pro XR installed and I'm wondering if the exterior tailgate release along the left tail light should work? I hear it release but it doesn't deploy.
  23. Dec 5, 2022 at 4:32 PM
    #1133
    Unitdosed
    Unitdosed New Member
    '22 Celestial Silver SR5, CREW CAB TRD OR 4X4
    None, yet
    What about when you use the fob?
  24. Dec 5, 2022 at 5:15 PM
    #1134
    tbrady
    tbrady New Member
    Southern Idaho
    When I installed my OEM cover I had to be sure it was far enough forward that the last panel’s down force on the top of tailgate didn’t hold it closed even when it was unlatched.
  25. Dec 6, 2022 at 8:05 AM
    #1135
    iiawah808
    iiawah808 New Member
    Oahu, HI
    2022 iForce Tundra Limited TRD Offroad
    Currently Searching....
    love this tonneau!
    what is this floor truck mat that you are using? It looks like I have the same garage flooring and want this mat!
  26. Dec 6, 2022 at 11:06 AM
    #1136
    Leif84
    Leif84 New Member
    2023 Tundra TRD PRO
    Same. Unlocks but doesn't drop down.
    Unitdosed[QUOTED] likes this.
  27. Dec 6, 2022 at 2:08 PM
    #1137
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    14800.jpg Oem cover here, wanted all oem parts on this truck. I like it.
  28. Dec 6, 2022 at 2:13 PM
    #1138
    Leif84
    Leif84 New Member
    2023 Tundra TRD PRO
  29. Dec 6, 2022 at 3:33 PM
    #1139
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    Just wipe a light coat of silicone spray on the tailgate seal and it works great.
    2000army likes this.
  30. Dec 7, 2022 at 6:25 AM
    #1140
    Jibber82
    Jibber82 New Member
    Auto Floor Guard
    iiawah808[QUOTED] likes this.
