2022 Tonneau covers
Discussion in 'Tonneau Covers, Caps and Shells' started by ak407, Jan 22, 2022.
  1. Nov 10, 2022 at 9:08 AM
    #1081
    jproy12
    jproy12 ¯\_ (ツ) _/¯
    JP
    Ottawa, Canada
    2023 Supersonic Red Platinum Hybrid
    Do you have more info on your "home made" fix, I'd be really curious to see what you used for your rack.
  2. Nov 10, 2022 at 10:40 AM
    #1082
    djbarnett
    djbarnett New Member
    2022 Toyota Tundra Platinum CrewMax 6.5'
    Can report that the Lomax has remained water tight through car washes and a few rainstorms. Extemely happy with it.
  3. Nov 10, 2022 at 1:05 PM
    #1083
    CKOPIX
    CKOPIX New Member
    Curt
    2022 SR5 TRD Lunar Rock
    BAKFlip MX4 Tonneau Cover & Truxedo Elevate FS Rack with T-Slot Runner
    i used some metal plates I found at the local Ace Hardware, drilled holes and cut them in half, you need 5 for each side. So far so good, no issues with the mod.
    I think you can see how I dropped the hardware down from the image. Screwed the plate in where the rail was originally located, dropping the mounting point under the hardware clamps used to hold the MX4 and rack combo to the truck (3 on each side). The key was using low profile carriage bolts to attached the MX4 hardware I wasn't able to use as intended. The carriage bolts allow you to tighten down the nut without the bolt turning. Then mount the rail like you would on a "normal" cover install (w/out the rack). BAK may make some sort of relocation brackets but I was needing to get it done... Hope that helps.
  4. Nov 11, 2022 at 8:03 AM
    #1084
    CKOPIX
    CKOPIX New Member
    Curt
  5. Nov 16, 2022 at 7:13 AM
    #1085
    FALQN
    FALQN New Member
    Midnight Black, 4x4 Crew, TRD Sport
    OEM Running Boards, Wheel Locks, Hard Cover, Home-made Kicker Sub
    Posted this on "What have you done today...", but putting it here also for those that are interested in hard tops.
    Put on my new Undercover Elite hard cover yesterday. With the winters we have in the midwest, I could not see having full functionality of a top that rolls or folds up. The ice and snow would just get in the way. Rained (and snowed) after installation and there was no water intrusion. There is a nice gasket running all the way around the cover. I put it on myself, using rope suspended from my garage door...drove under it and set it down right on top. The final adjustment dragged on as I tried to get it just right for the tailgate elevation. I have to press each corner down to engage the latches on either side, but this is due to the stiff gasket. I'm sure it will flatten out over time. I purchased the ABS version which is black and unpainted. Looks good sitting on a black truck. Got a deal through Santana at RealTruck. The only issue, with the delivery process, was the first one arrived beat all to hell. Every side and every seam of the box was busted. I took pictures and then refused delivery. I called RealTruck immediately and sent the pictures after they opened a case. I new one was ordered the next day. When it arrived, the box was in better shape but one of the ends was mangled pretty well. I looked inside to make sure there was no damage and took the chance that the rest of the cover was in solid shape. I unboxed it and performed a full inspection...and I was good to go. The top supposedly supports 500 lbs. The second order added another week of wait time. Took it out for a test drive and it seems quiter in the cabin.
  6. Nov 16, 2022 at 7:32 AM
    #1086
    CKOPIX
    CKOPIX New Member
    Curt
    Looks great.
  7. Nov 20, 2022 at 1:25 PM
    #1087
    JohnRYan
    JohnRYan New Member
    Went with the Backflip MX4
    Very happy so far, seems to be a nice upgrade from the Extang I had on my Tacoma. The flush fit and ability to open it up more than 1/3 is a huge plus. Big test for me will be when it rains.
    CKOPIX likes this.
  8. Nov 20, 2022 at 3:42 PM
    #1088
    Kanadakid
    Kanadakid New Member
    Donald
    2023 Tundra 1794
    Nothing yet
    I'm defineatly going to need one once my truck arrives, so I'll be watching the comments so I select one that is good. This is a useful post. Don
    CKOPIX likes this.
  9. Nov 20, 2022 at 5:43 PM
    #1089
    firehawk003
    firehawk003 New Member
    Anyone find any good Black Friday deals on the mx4? Looking at getting one. I missed out on prime day.
  10. Nov 21, 2022 at 6:07 AM
    #1090
    RealTruck
    RealTruck New Member Vendor
    We are running Black Friday deals on the Forum this entire week! If you'd like a quote on an MX4 or any other tonneau just shoot me a PM!
  11. Nov 21, 2022 at 8:44 AM
    #1091
    Limitrd
    Limitrd New Member
    Oregon
    22 Lunar Rock Limited Hybrid TRD Off Road CM 6.5
    Does diamondback run any Black Friday deals?
  12. Nov 21, 2022 at 9:20 AM
    #1092
    Limitrd
    Limitrd New Member
    Oregon
    I will answer my own question. They DO have a sale going right now.
  13. Nov 22, 2022 at 5:29 PM
    #1093
    bcj001
    bcj001 New Member
    Brad
    Oregon
    22' Tundra Limited
    Was just going to say I got an email with up to $400 off ... was leaning that way myself but I like the lower profile looks of the MX4... watching to see what kind of Black Friday sales are going on... Still annoyed a missed a local dealer selling the factory covers for $850 .... havent been able to find a deal like that since... ugh... just being patient... (BTW if anyone knows of any great sales, let me know! ) =)
  14. Nov 24, 2022 at 10:02 PM
    #1094
    LevelUp
    LevelUp New Member
    David
    2016 DCLB SR5 w/ TRD OR in MGM
    OEM LED headlights, interior ambient lighting, running boards, Firestone airbags, misc led swaps, started blacking out phase and chrome delete, Diamondback HD w/ Yakima Overhaul HD (on the way)
    Yup now. Goooo!!! Got $400 off a HD cover and Yakima overhaul racks. Coming in a couple weeks.
  15. Nov 25, 2022 at 7:28 AM
    #1095
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    The HD is a brute. I went with the SE on the Tundra but had an HD on my Ridgeline. I like that you can add whatever you like to it and it works. I attached a TracRac to the SE for the Kayaks.
  16. Nov 25, 2022 at 10:10 PM
    #1096
    ShotsnClicks
    ShotsnClicks New Member
    I have been looking at that Rough Country Toneau cover however, does anyone know if this is offered in a 6.5 bed? I can't seem to find it but maybe I am missing something.
  17. Nov 26, 2022 at 5:26 AM
    #1097
    X42069
    X42069 New Member
    M
    Southwestern Ontario Canada
    23 SR5 CrewMax TRD Off Road 6.5ft box
    Excellent to hear I am installing one next week. Did you get the removable one or the one that folds up against the cab?
  18. Nov 28, 2022 at 9:17 AM
    #1098
    Carolina Peej
    Carolina Peej Hey can you hold the light for me real quick?
    North and South Carolina
    2022 Midnight Black Metallic 4x4 Tundra Platinum 5.5 w/ load leveling + AVS, HUD, and Power Running Boards
    Update, now on my 3rd tonneau cover.
    1st: Rough Country soft roll up.
    Pros: Fit great. Stayed Dry. Only +/- $300.
    Cons: Not secure. Velcro sides. Soft vinyl top.
    2nd: BakFlip Revolver MX4.
    Pros: Looked great. Easy operation. Decent security.
    Cons: Did not fit. Leaked on all 4 corners. The rails are just too short. Bakflip not very helpful. Recommended super glue and shims.
    3rd: WeatherTech alloy tri fold.
    Pros: Fits great. Bone Dry. Super easy removal. Decent security.
    Cons: Doesn't look as good as the Revolver.
    Also... Just saw today. The Softopper has a product for the 2022 Tundra now.
    https://softopper.com/products/softopper-truck-bed-cap-toyota-2022-tundra-for-5-6-ft-bed/
    What is the over / under that I order my 4th bad cover this week?!!
  19. Nov 28, 2022 at 12:42 PM
    #1099
    4genRunner
    4genRunner New Member
    Southwestern MO
    2022 SR5 CrewMax TRD OR 4x4 CSM
    RB20's, Extang Xceed Cover, Tint.
    I went with the Extang Xceed. Should be here this week.
  20. Nov 28, 2022 at 2:53 PM
    #1100
    Point Man
    Point Man New Member
    Mark
    Racecity USA Mooresville, NC
    2023 1794 MGM
    Tonneau Cover, Cat Shield, Power Boards, Bed Mat, Rear Light Bar
    Sad to hear that the MX4 did not fit properly. There is one sitting in my garage waiting for my truck arrival. That would suck, especially if they won't refund. I was going to go with the Weathertech but went with the BakFlip instead. Maybe wish I had gone with Weathertech. Should know in another three weeks.
  21. Nov 28, 2022 at 3:59 PM
    #1101
    Fr0zenTundra
    Fr0zenTundra New Member
    Wi
    '22 platinum hybrid
    i have the mx4 on my platinum 5.5 bed and it stays dry in the bed. ran it through a touchless car wash last week and there was a t8ny bit of water that got in by the tailgate corners but that is more of a tailgate problem than an mx4 problem i think.
    and if i find myself in a situation where i have water coming at the tailgate as hard as it does in a touchless car wash i have bigger problems to deal with than a few drops of water in the bed. ;)
    TheSS712 likes this.
  22. Nov 28, 2022 at 4:52 PM
    #1102
    Paul Moll
    Paul Moll New Member
    Paul
    Idaho
    2023 1794 TRD off-road
    @Point Man: I too have a MX4 in my garage awaiting a truck to go under it :) MX4 arrived today, truck next week sometime.
  23. Nov 28, 2022 at 4:54 PM
    #1103
    22Tundraplat253
    22Tundraplat253 New Member
    Chanh
    2022 Tundra Platinum
    Wheels,lift,air level std stuff
    More details please..I'm looking for so.ething like this for my r.t.t.
  24. Nov 28, 2022 at 5:05 PM
    #1104
    TheSS712
    TheSS712 New Member
    Shayne
    2022 Army Green Tundra Limited
    Just installed the MX4 and I like it but looks like it’ll leak nicely at the tailgate. Like the rails aren’t long enough as @Carolina Peej has stated. Not cool.
    Carolina Peej likes this.
  25. Nov 28, 2022 at 5:28 PM
    #1105
    Durtywrench
    Durtywrench New Member
    Lou
    23 Tundra platinum
    None
    Is the Toyota brand tonneau cover any good ? The truck I put a deposit on comes with it and can’t take it off . I’d assume at that price is the best lol . Looking for pics of it so I can daydream about it all
  26. Nov 28, 2022 at 5:38 PM
    #1106
    Carolina Peej
    Mine was the Bakflip Revolver MX4, the roll up hard cover. Not sure about the tri-fold MX4, but the Revolver just didn't fit.
    RickyBobbysTundra likes this.
  27. Nov 28, 2022 at 5:48 PM
    #1107
    TheSS712
    TheSS712 New Member
    Shayne
    My mx4 is the trifold. When I’m not under the weather, I plan on messing with the rails to see if I can make it any better. If not, I may have to send back. Lol
  28. Nov 28, 2022 at 7:27 PM
    #1108
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    I don't remember seeing a 6.5 option.
    I have the 5.5 and it works great for me.
  29. Nov 28, 2022 at 8:33 PM
    #1109
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    It’s similar to the MX4 but Toyota branded….if not sealed properly at the bed corner’s with the caulk or parked nose down (like on hills) then it may have small leaks in those corners but quite honestly I don’t expect bone dry…especially here in the PNW where we get a good amount of rain/precipitation.
    my driveway is a hill and mine stays relatively dry (very small leaks) after days of rain so I am happy.
    Durtywrench[QUOTED] likes this.
  30. Nov 29, 2022 at 7:58 AM
    #1110
    Flubez
    Flubez New Member
    Arizona
    2023 Tundra Trd pro
