2022 Tonneau covers
Discussion in 'Tonneau Covers, Caps and Shells' started by ak407, Jan 22, 2022.
  1. Sep 18, 2022 at 3:57 PM
    #901
    gnc1017
    gnc1017 New Member
    22 Tundra Platinum Hybrid 6.5 Blueprint
    1.75 leveling kit Nitto Ridge Grappler tires (305/55/20) Black Rhino Arches Gunmetal wheels Truxedo Deuce cover w/ TonneauMate box
    Maybe I missed it but can someone please post a pic of the Toyota tri-fold (or other brand if works similar) in the fully open position? Does it lean against the back of the cab?
  2. Sep 18, 2022 at 3:59 PM
    #902
    Unitdosed
    Unitdosed New Member
    '22 Celestial Silver SR5, CREW CAB TRD OR 4X4
    None, yet
  3. Sep 18, 2022 at 4:01 PM
    #903
    Unitdosed
    None, yet
    At the 11:25 mark in the video above, it's folded up. Not my video but found it very helpful.
    gnc1017[QUOTED] likes this.
  4. Sep 18, 2022 at 4:30 PM
    #904
    gnc1017
    gnc1017 New Member
    Thanks a bunch!
  5. Sep 18, 2022 at 4:57 PM
    #905
    Point Man
    Point Man New Member
    Mark
    Racecity USA Mooresville, NC
    2023 1794 MGM
    Tonneau Cover, Cat Shield, Power Boards, Bed Mat, Rear Light Bar
    For the drain tubes being the same size are you referring to the OEM or the BakFlip or both?
    Unitdosed[QUOTED] likes this.
  6. Sep 18, 2022 at 4:59 PM
    #906
    Unitdosed
    None, yet
    OEM install showed to use drain tubes that are the same size as the pre drilled holes.
    I'm still thinking I'll add a y-splitter and have each of the supplied tubes split to make use of all 4 pre drilled holes.
    Point Man[QUOTED] likes this.
  7. Sep 18, 2022 at 5:14 PM
    #907
    Point Man
    Mark
    2023 1794 MGM
    Thx. I think the BakFlip drain tubes are larger and I don't want to drill the bed so maybe I'll go with the OEM or call Realtruck and see if the OEM size tubes are available.
  8. Sep 18, 2022 at 6:35 PM
    #908
    BillorJackorPeteorDennis
    BillorJackorPeteorDennis New Member
    Washington, DC
    ‘25 TRD Pro - Mudbath
    Great info, thanks. I was toying with getting some after-market weatherstripping but now I’m sold as a must.
  9. Sep 18, 2022 at 6:39 PM
    #909
    Washington, DC
    ….or, go to hardware store and buy smaller tubing and a reducer coupling to go from the BakFlip tubing to the new piece of tubing. 5 minutes, no drilling, better cover than the OEM from what I’ve heard/read.
  10. Sep 18, 2022 at 7:05 PM
    #910
    Maharisc
    Maharisc w/Patty
    Karl
    2023 Tundra Platinum MBM Hv CM Adv Pkg
    Build date: 12/05/22
    1. The quick release is no longer, there is a bolt/nut in each front corner so not nearly as quick as previous versions. Only take a minute vs 10 seconds.
    2. Yes, the OEM plastic tie down points are still usable, when removing them from the rail, you have to almost complete unscrew them before turning them at an angle to remove.
    3. The Elevate TS rails are like the rails that come with the cover but extend over the top of the box, the tie down points are still usable just like with the rails that come with the cover.
    Hike5[QUOTED] likes this.
  11. Sep 18, 2022 at 7:48 PM
    #911
    bobby4
    bobby4 New Member
    I am a truck newbie, and relatively inept mechanically - but having fun learning. I bought a BAK revolver but they sent me the wrong hardware kit. A few phone calls and 3 weeks later the right kit arrives. The install seems smooth, until I find out cover is about 3/8” too narrow. Now they are sending me shims. Is nothing ever simple?
  12. Sep 18, 2022 at 8:00 PM
    #912
    Washington, DC
    only in theory. ;)
    bobby4[QUOTED] likes this.
  13. Sep 18, 2022 at 8:56 PM
    #913
    22PlatWCP
    22PlatWCP New Member
    Mississippi
    2022 WCP Platinum 4x4
    I did drill the holes larger to fit the tubes but only because I couldn’t be bothered trying to cram them in the original bed holes. The size difference was about 1/8” and once done you would never notice it if you removed the tubes later on.
    Donas likes this.
  14. Sep 18, 2022 at 9:08 PM
    #914
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    Short answer -no, not in my life.
  15. Sep 19, 2022 at 5:59 PM
    #915
    kilocharlie106
    kilocharlie106 mmmm Bourbon
    TRD Pro in LR
    Washed truck again. No water in at all.
    Point Man and 22PlatWCP like this.
  16. Sep 19, 2022 at 6:26 PM
    #916
    Point Man
    Mark
    2023 1794 MGM
    Thanks for letting us know. Were you able to get pics of the install with the bed rails?
  17. Sep 19, 2022 at 6:53 PM
    #917
    kilocharlie106
    TRD Pro in LR
    My bad. I’ll take some in the am. I took pictures today bc I think my weathertech rails are missing a tab on each side that help the middle section lock down
  18. Sep 19, 2022 at 8:45 PM
    #918
    Unitdosed
    None, yet
    Where have you read that BakFlip is better than OEM? The reviews I've seen for each on YouTube make them look identical.
    22PlatWCP likes this.
  19. Sep 19, 2022 at 9:09 PM
    #919
    Washington, DC
    Let me rephrase. It is my opinion, trough what I've both read, heard, and witnessed in person (granted only on one unit, but still...), that the OEM has more leaking issues off the bat.
    Maybe they are identical, maybe the OEM's report more leaks due to install rather than hardware, maybe what I saw was isolated incidents.
    I just know that if I do searches for both with reports of leaking, I see less negative reports from the BakFlip.
    There are even posts on this forum, sharing/reporting the same opinion. Next time, however, I'll be clearer that my post is an educated opinion, and not peer reviewed, bibliographical data.
  20. Sep 20, 2022 at 6:08 AM
    #920
    kilocharlie106
    TRD Pro in LR
    @Point Man
    You can still use slide cleats but only to each clamp for the tonneau rail
    surfmc likes this.
  21. Sep 20, 2022 at 8:06 AM
    #921
    TweakedMang0
    TweakedMang0 New Member
    Jimmy
    2022 Limited - MGM - CM - 6.5ft - 4x4
    Might've not looked hard enough but I don't think I've seen a 6.5 ft quad-fold hard cover in this thread. Does anyone have quality recommendations?
  22. Sep 20, 2022 at 9:54 AM
    #922
    gmbarnette
    gmbarnette New Member
    2022 Red Tundra Ltd
    My dealer wants 1800 for the regular bed OEM Cover. Is that basically what they have been going for? Seems a little high to me.
    Yaboy likes this.
  23. Sep 20, 2022 at 10:08 AM
    #923
    kilocharlie106
    TRD Pro in LR
    you could buy a retrax for that. OEM cover is a MX4 Blackflip essentially, Realtruck sells them for about half that if you contact @SantanaRealtruck
    RealTruck likes this.
  24. Sep 20, 2022 at 12:23 PM
    #924
    gmbarnette
    2022 Red Tundra Ltd
    Done and Done. Thanks for the info. She gave me an excellent price. I already purchased it.
  25. Sep 20, 2022 at 1:15 PM
    #925
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    If your dealership is like the ones around me yes, that's a little high but normal. It's not good, but normal. I think it's about $1000 + tax then they charge almost $300 to install.....just crazy. My dealership mandates they install it as part of the rip-off scheme.
  26. Sep 20, 2022 at 1:25 PM
    #926
    gmbarnette
    2022 Red Tundra Ltd
    My bad. I think in my mind I saw Santana and I automatically gravitated towards Carlos Santana and made an assumption. I made the correction. Thanks for the heads up. I went with the Bakflip MX4. My dealer wanted 1800 just for the cover. They wanted 2400 for the cover + installation. That just seemed ridiculously high to me.
  27. Sep 20, 2022 at 1:33 PM
    #927
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    $2400 is beyond comical!!! Who would pay that? That's almost $1000 more than I paid for my Retrax Pro, crazy. And I did the same with Santana, except I was corrected on the phone by one of her colleagues about the 4th time I said "him" LOL.
    You won't regret dealing with Realtruck!
  28. Sep 20, 2022 at 3:09 PM
    #928
    Hike5
    Hike5 New Member
    2022 Tundra Limited Crewmax
    I’m about to pull the trigger on a Sentry CT cover + Elevate Rails, are there discounts to be had by calling Realtruck vs. ordering from the website?
  29. Sep 20, 2022 at 3:13 PM
    #929
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    My experience has been yes, with every purchase I've made. Reach out to Santana on here.
  30. Sep 21, 2022 at 8:51 AM
    #930
    DRCO
    DRCO New Member
    Missouri
    22 Platinum Hybrid 4x4
    Looking to order a tonnaeu cover soon and deciding between the MX4 Backflip and Extang Xceed. I like the look of Xceed and has good reviews from the site, but not much from Tundra owners. I've only seen one post on the Xceed on this thread, can anyone else comment? Likes/dislikes?
