2022 Tonneau covers
Discussion in 'Tonneau Covers, Caps and Shells' started by ak407, Jan 22, 2022.
  1. Aug 8, 2022 at 8:53 AM
    #781
    DrZoidberg
    DrZoidberg New Member
    Dave
    SATX
    Tesla MYP
    Damn the no rail might be a deal breaker. I guess I'll do the mx4 because you can keep the rail
    Roctane84 likes this.
  2. Aug 8, 2022 at 9:05 AM
    #782
    JoeLR22
    JoeLR22 New Member
    Yeah i understand that, if I had know that in advance I would have gone a different route too.
  3. Aug 8, 2022 at 11:28 AM
    #783
    Roctane84
    Roctane84 Tread On Them
    Louisiana
    ‘22 TRD Pro Solar Octane (SOLD)
    You cant see it but it is on top of this foam section here. On the top of it before you set that panel down. I carried the sealant over into the edges also (second pic)
    46340566-0DAF-45FC-B332-47CA3871D48B.jpg 5DF71E5E-BA1C-4FBF-8004-CD753DC21045.jpg
    9OH1 and DBWA[QUOTED] like this.
  4. Aug 8, 2022 at 11:33 AM
    #784
    Roctane84
    Louisiana
    Not saying you did, but you cant use anything like Armor All on BakFlips. That’s verbatim what they say. Apparently they can tell and it will void warranty. You can, however use 303 spray protectant. I feel like 303 works better anyway and has no odor.
    ryanwgregg likes this.
  5. Aug 8, 2022 at 5:56 PM
    #785
    dan.tist
    dan.tist New Member
    Update, I received the x4s cover today, 8/8/22
  6. Aug 8, 2022 at 8:59 PM
    #786
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    I installed my RetraxPro yesterday. Yes, I drilled out the holes for the drain tubes. The largest bit I had was 1/2 inch, which is just a tad too small. With a little effort, I made it work. The bed already has small holes in it, but if you got the spray on liner, they sprayed over them. I can tell you one thing I learned the hard way. I was afraid to drill through from the bed, fearing I'd hit the gas tank or something (I may have done this before :frusty:) so I drilled from below upwards. I thought I did my best to lay to the side vs directly under where I was drilling; I clearly did not. The dust/particles got on my hands and arms and felt like 1000 splinters. It was much better today, but still have some in the soft skin on the sides of my fingers - miserable!
    As far as the tailgate opening, just spray a light coat of silicone spray on the rubber weather seal and the tailgate will open as it should with the button etc.
    9OH1 likes this.
  7. Aug 8, 2022 at 9:35 PM
    #787
    9OH1
    9OH1 New Member
    Memphis, TN
    White Crewmax Limited LB w/ TRD Off-Road package
    That’s much classier than what I did in the corners. I tore off a couple of pieces from the extra weatherstripping and shoved them in the corners.
    I also drilled holes, I ended up drilling into the top corners(looks like a triangle) right above the tie down hooks and left the factory holes alone hoping that if water does get in then it can drain there, also didn’t want to jack my tubes with plywood or any other stuff I end slamming into the front of the bed from it being so slick. I still haven’t gone back and cut my tubes to length so they’re just dangling somewhere under the bed. Gah, wish I wasn’t so lazy now that I think about, maybe I’ll remember tomorrow to do that. Ha
  8. Aug 8, 2022 at 9:40 PM
    #788
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    I checked underneath and the extra length didn't interfere with anything so I just left them full length......maybe that gives you a reason to be lazy and just not do it, lol
    9OH1[QUOTED] likes this.
  9. Aug 8, 2022 at 9:50 PM
    #789
    9OH1
    9OH1 New Member
    Memphis, TN
    Ha! I didn’t need any extra motivation, definitely just got moved to bottom of the list of priorities. Thanks!
  10. Aug 9, 2022 at 5:42 PM
    #790
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    Question for Retrax owners. In looking at the channels that the cover bearings ride in, it's shaped like a "C". When I was installing it, I couldn't understand why water wouldn't just roll off the top to the edges and leak into the bed from the bottom rail edge. Well, I washed the truck today and that's exactly what happens. Is this normal or have I installed it wrong?....(granted, it may just be the pressure and will stay dry during rain, haven't had any yet!)
    I will say I really like this cover so far. It's definitely the highest quality tonneau I've had, but should be for the cost.
  11. Aug 9, 2022 at 7:35 PM
    #791
    9OH1
    9OH1 New Member
    Memphis, TN
    We had an absolute downpour for about an hour and a half here in Memphis earlier today, I waited until it stopped and went and checked under the cover(mx4) for any water in the bed. To my surprise it was bone dry inside, for those who are curious about this cover. Still haven’t driven in the rain with it, I’ll give a report whenever I do.
    TheSS712 likes this.
  12. Aug 10, 2022 at 7:28 AM
    #792
    22TrdNoob
    22TrdNoob New Member
    2022 TRD Pro
    Any Retrax Pro XR Owners with Rhino Rack Crossbars?
    I'm installing a Retrax Pro XR next week and was going to order the crossbars to go with it. Anyone install the Rhino Rack Vortex crossbars? Were you able to go with the 65" bars or are the 71" required? The 71 would be a sure fit, the 65 seems like they might be just long enough... but without the cover on my truck I can't get exact measurements of the distance between the tracks. I would rather go with the 65 if they fit (was thinking the overhang of the 71" might generate a bit more noise and drag since it would out wider than the cab of the truck.
    Any reviews or opinion on crossbars to go with the retrax are well appreciated.
    Also... did any of you also add any sealing/weatherstripping around the tailgate. I can see straight through the gap between the tailgate and the side of the bed, so clearly water will be able to get in there easily.
    Thanks!
  13. Aug 10, 2022 at 9:05 AM
    #793
    DBWA
    DBWA New Member
    Dave
    2022 Tundra TRD Limited 6.5' Bed
    The install instructions really emphasize pushing the track back against the wall of the bed and inclining the inner most point up 2 degrees as a way to help with leakage while you're tightening the mounting brackets. I had to ask someone to help and found it challenging to do both simultaneously.
  14. Aug 13, 2022 at 12:19 PM
    #794
    JoeLR22
    JoeLR22 New Member
    update: received the replacement cover from RealTruck and they were great to work with on it. Unfortunately though the new Under Cover Armor Flex leaks in exactly the same spot and a lot. It’s at the first hinge from the tailgate where the straps for tying it down when open and the latch are. It just streams in right on the drivers side there where the rivets are. I expected a little water to get in and for it to not be water tight but this is a stream of water. I love how the cover looks but definitely can’t recommend it. I am reaching out to @SantanaRealtruck to see what my options are as it appears to be an issue with the production of this cover.
  15. Aug 13, 2022 at 5:48 PM
    #795
    galacius29
    galacius29 New Member
    2001 Tundra V6 RWD
    Just installed my retraxone XR.. love the cover but had a few issues:
    1. The threaded holes in the rails were either too small or sprayed in so i couldn't get the screws in.. Had to use my power drill to get them in.
    2. I couldn't get my rear width to be within 1/8th inch as the front of the rails. Plus the plastic adjustment screws got stripped within 2 sec of me trying to adjust them... so for right now it works ok but i'm going to need to find a longer term solution. Seems like some cheap plastic screws
    3. The drain hole tube inserts into the bottom pan don't stay put. Tried turning it but its a dumb design in my opinion. Could be better with a threaded option.
    Few quirks but the overall look and functionality is good. Wish they could improve on some of these smaller things though.
  16. Aug 13, 2022 at 8:55 PM
    #796
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    I couldn't get mine a consistent ⅛ inch either. I would have everything perfect then when I tightened the bolts it pulls it out of whack. I found the adjustment screws to be almost worthless; for me, one turn definitely didn't move the rail ⅛ inch. I re-measured and tightened at least 5 times and said screw it, I'm done.
    I experienced leaking from the bottom of the track for the first couple days but yesterday when I took it through the car wash not a drop came in. I haven't decided if that was a fluke or something needed to settle.
    If you are talking about the small screws that hold the rails to the canister, yes, mine were very tight. I ended up using the technique I call - brute force and ignorance. This seemed to get them in fine.
  17. Aug 13, 2022 at 9:14 PM
    #797
    galacius29
    2001 Tundra V6 RWD
    Looks like you had the same experience as me. Seems like a few easy fixes for them to make this even better. A little disappointed at this price point they didn't do this but we'll see how it breaks in over the next few weeks.
  18. Aug 13, 2022 at 9:27 PM
    #798
    Galoong
    Galoong New Member
    '22 Tundra Limited SB Blueprint
    Truck2Go SyneticUSA retractable bed cover.
    Installed SyneticUSA retractable cover from Truck2Go. Looks good but not sure how well it will keep water out of the bed. Will run it through a brushless car wash soon to test.
    Dfrink, DimSum07, =JSG= and 2 others like this.
  19. Aug 13, 2022 at 9:51 PM
    #799
    galacius29
    2001 Tundra V6 RWD
    That box looks smaller than the retrax! Nice
    Galoong[QUOTED] likes this.
  20. Aug 13, 2022 at 10:17 PM
    #800
    Galoong
    Galoong New Member
    Thanks!
  21. Aug 14, 2022 at 2:35 AM
    #801
    knewcomb
    knewcomb New Member
    For those of you who have a diamondback, is the latch next to the cab suppose to be under more tension? It seems like it is more difficult to open than the one next to the tailgate.
  22. Aug 14, 2022 at 3:40 AM
    #802
    BadTrainDriver
    BadTrainDriver New Member
    2022 Tundra Capstone
    Smaller individual slats that hold less weight, and no ball bearing on the sides.
  23. Aug 14, 2022 at 6:14 AM
    #803
    galacius29
    2001 Tundra V6 RWD
    Ahh I see why now.
  24. Aug 14, 2022 at 9:46 AM
    #804
    Maharisc
    Maharisc w/Patty
    Karl
    2023 Tundra Platinum MBM Hv CM Adv Pkg
    Build date: 12/05/22
    They have them on their website for the 22 Tundra, I think the installer is mistaken or doesn't have access to them yet through their distributor.
    RickyBobbysTundra likes this.
  25. Aug 14, 2022 at 2:10 PM
    #805
    22PlatWCP
    22PlatWCP New Member
    Mississippi
    2022 WCP Platinum 4x4
    I like my MX4 but had to additional foam to seal the front corners and the rear where the tailgate closes close to the rear tonneau rails. I also added a seal around the bed of the truck to keep out dust and dirt. Now the cover is finally rain tested waterproof.
    TopClass AUTO likes this.
  26. Aug 16, 2022 at 8:25 AM
    #806
    kilocharlie106
    kilocharlie106 mmmm Bourbon
    TRD Pro in LR
    macribas likes this.
  27. Aug 16, 2022 at 8:50 AM
    #807
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    Oem cover for sale in Boise, ID- short bed, had it since June
  28. Aug 16, 2022 at 9:00 AM
    #808
    GoTTi74
    GoTTi74 New Member
    Bay Area, California
    2022 Tundra Ltd TRD OR CM LB
    Is it possible that Retrax uses US screw sizes whereas Toyota uses metric screws?
  29. Aug 16, 2022 at 9:54 AM
    #809
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    I don't see why it would matter. The screws supplied by Retrax are screwing through and into Retrax parts. It's not a big deal, they were just very tight; I was afraid I was going to strip them out. Luckily, the technique of brute force and ignorance works equally well for imperial or metric.
    GoTTi74[QUOTED] likes this.
  30. Aug 16, 2022 at 10:00 AM
    #810
    GoTTi74
    GoTTi74 New Member
    Oh… misunderstood… I thought they are being screwed into a Tundra part… just saw a few other installation instructions and videos and was wondering why some companies are supplying imperial screws to a truck built with metric screws… Certainly, if the accessory is not attached to an existing thread, it’s not an issue… personally I’d hate to have to deal with metric and imperial screws mixed on one truck.
    22PlatWCP and Donas[QUOTED] like this.
