2022 Tonneau covers
Discussion in 'Tonneau Covers, Caps and Shells' started by ak407, Jan 22, 2022.
  1. May 22, 2022 at 8:31 PM
    #511
    MMTundra
    MMTundra New Member
    2022 Army Green TRD OR Ltd
    Installed Gator Srx today - no wet/storm test yet but seems like a really solid cover for <$300… reason I bought it was to have something while I hold out for a topper, but this thing is actually really nice!
    B0D63FDF-926F-4074-9D81-9CDB421C1E85.jpg 7F0F23E0-3AC2-40E8-87B7-9DBD7FA9E15F.jpg B0D63FDF-926F-4074-9D81-9CDB421C1E85.jpg
    NMTRUCKER, TweakedMang0 and 22PlatWCP like this.
  2. May 23, 2022 at 1:36 PM
    #512
    hivetyrant
    hivetyrant New Member
    2022 Limited Tundra
    This has convinced me to skip a hard/tri-fold cover for now. I just can't justify $1000 when there are so many other accessories or mods to buy.
    Stupid question though, as it's not spelled out on the website but does this cover essentially "lock" when the tailgate is locked and closed?
    Obviously anyone with a knife can easily enter a soft cover but does it prevent easy opening?
    TweakedMang0 likes this.
  3. May 23, 2022 at 2:02 PM
    #513
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    Well, had the Bakflip F1 out in it's first rainy drive today. To say disappointed is an understatement! Almost my entire bed is wet. I fully understand tonneau covers aren't designed to be water tight, but is this normal for the Bakflip brand or OEM? This is from being in on and off moderate rainfall for about 4 hours.
    I contacted Bakflip and sent photos. Upon closer examination, the entire seam on the cab end leaks (the seam between the short fixed panel and 2nd panel in) and water is dripping from most of the plastic cable pull brackets, not sure exactly where it's coming in. I can only assume this is not normal :annoyed:
    Tibetan Nomad likes this.
  4. May 23, 2022 at 2:06 PM
    #514
    MMTundra
    MMTundra New Member
    Yes, there’s a little trigger switch on the driver side to release the cover that you can only access with the tailgate down. So far I really like it, and can definitely say I’m impressed with the value. For anyone installing, I would clamp the rails as high as possible - otherwise you can’t get the cover to latch with the tailgate up. Other than that, instructions are pretty clear.
  5. May 23, 2022 at 2:55 PM
    #515
    hivetyrant
    2022 Limited Tundra
    My brother, you are just having all the luck!!! At least this one isn't exactly on Toyota :(
    Donas[QUOTED] likes this.
  6. May 23, 2022 at 2:55 PM
    #516
    hivetyrant
    2022 Limited Tundra
    Awesome, thank you! I think I'll order that one tonight. Any thoughts on how weather proof it is?
  7. May 23, 2022 at 2:58 PM
    #517
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    Story of my life, LOL....if it goes smoothly, it's an ambush.
  8. May 23, 2022 at 6:30 PM
    #518
    Rutterbg
    Rutterbg New Member
    Ben
    I would definitely move those drain tubes. Mold will grow where the water sits and eventually clog the tube. The drain tubes need to go as straight down as possible. I just made the 2 holes on the floor near the corners 9/16 or an inch and they fit nice and snug. You can get to those holes pretty easily from under the truck so you can drill them out.
  9. May 23, 2022 at 6:34 PM
    #519
    MMTundra
    MMTundra New Member
    No weather to speak of yet, and no time for a car wash… but, reason I got the Gator was there’s a bunch of YouTube videos with minimal leakage.
  10. May 24, 2022 at 6:38 AM
    #520
    JPD
    JPD New Member
    2022 Black Tundra 1794 TRD OR
    Been getting storms here non-stop here in NC and so far (knocks on wood) the weather-Tech trifold has held up great w no leaks at all. Happy with the look of it and install was relatively easy.
    golfersa likes this.
  11. May 24, 2022 at 7:08 AM
    #521
    kluge9
    kluge9 New Member
    Andy
    2022 Crew Max TRD Sport
    Been reading through all these threads as I was looking for something to add to my TRD Sport. I'm coming from a Taco where I had an ARE MX mounted for the room but this round I went with a Diamondback HD. Hopefully it'll be here by end of this week but who knows what sort of vacation days they plan on taking.
    NewImprovedRon likes this.
  12. May 24, 2022 at 12:32 PM
    #522
    MarkO
    MarkO New Member
    Mark
    '19 Limited TRD
    For those who wonder between MX4 or Retrax, I can tell you I've had both. Both work well, overall I prefer the MX4, mainly because the Retrax takes up more cargo space. Living in NH, I experience a lot of snow. Not much this winter since I got my truck in March, but they both can easily handle the weight of snow. The Retrax did have issues at times with freezing up at times, but not something that really bothered me. You have to clear your truck off anyway. A couple whacks with the gloved fist would usually free it up. The canister the Retrax rolls into got pretty banged up with skis being tossed in the back. Overall, I feel that the MX4 is a little higher quality. My lock on the retrax used a different key (which I never used) and also lost the ability to lock down midway.
  13. May 24, 2022 at 12:58 PM
    #523
    fieldsjm
    fieldsjm New Member
    Jonathan
    2022 SR5 CrewMax TRD-Off Road
    Same here, the weathertech cover has done great, no leaks for me so far. Pleasantly surprised.
  14. May 24, 2022 at 8:10 PM
    #524
    TundraTun
    TundraTun New Member
    Just had the retrax pro installed. Really nice cover. Unfortunately, the stock bed rails have the molded plastic top trim that aren’t uniformly smooth. Therefore, this cover, and I’m sure most covers will have limitations on how water proof they are. The foam seal just doesn’t get a good enough seal with the plastic top trim groves. With how much detail Toyota put into design elements, I’m surprised this was over looked.
    I’m still happy with the Retrax and other than a few drips along the sides, it’s a great cover.
  15. May 24, 2022 at 8:25 PM
    #525
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    Def not normal…I get a few drip drips from the tailgate area and cab area where I need to re-apply the putty they sent (OEM)…but with all the rain we have gotten here in the PNW my bed hasn’t looked anywhere close to that.
    sorry man
  16. May 24, 2022 at 8:36 PM
    #526
    WrapCO
    WrapCO New Member
    Eagle , CO
    2022 Toyota Tundra 6.5’ CM
    Westcott lift, Method 316 17” wheels, 35x12.5x17 Toyo Open Country AT3
    If anyone is in need of an OEM 6.5' tonneau, I would part ways with mine. I just don't see myself taking it on and off. I haul 2 dirtbikes with the tailgate up, so this puts a damper on that. Any interest? I will post in Buy/Sell after my 30 day re-initiation.
  17. May 25, 2022 at 1:05 PM
    #527
    Boon22
    Boon22 New Member
    2022 Tundra Platinum Crewmax 4x4
    I just installed my Undercover Ultra Flex today and can confirm that the bed cleats do not work with the cover. I even checked with the Undercover sales rep.
  18. May 25, 2022 at 1:12 PM
    #528
    DrZoidberg
    DrZoidberg New Member
    Dave
    SATX
    Tesla MYP
    I had an undercover ultraflex on my 21 Pro and an MX4 on my 21 F150 and honestly I found the MX4 to be very weak. It dented way too easy. I set my empty laundry basket on top and it put a dimple in the metal. Since I had one I tested with something else and I dropped my airpods case on it.........dented.
    Not sure what I'll go with for my 22 Pro but I do like the tri folds.
  19. May 25, 2022 at 2:56 PM
    #529
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    Just thought I'd provide and update on my post from earlier this week on the extremely leaky Bakflip F1 cover. I reached out to Bakflip and sent pictures. In less than 48 hours, I received an email confirming an entire new product was being sent, rails and all. The email stated the usual policy was to show proof of the product being destroyed prior to shipping the replacement, but due to possible delays they would process the order and I did not have to destroy the existing cover until the new one was received and installed.
    I am not happy about the excessive leaking, but the customer service is exceptional! Many companies claim to have great warranties until it's time to use them. I wish I was receiving this kind of service from Toyota!!
    JPD, in_the_mud and bigjuice like this.
  20. May 25, 2022 at 11:46 PM
    #530
    jjackkrash
    jjackkrash New Member
    Jack
    2022 Army Green 1794
    If it gets wet and then freezes it can freeze in the rails that house the rollers it won't move until you thaw it. I have had this happen on a few occasions.
  21. May 26, 2022 at 8:04 AM
    #531
    murtro
    murtro Life is unpredictable. Eat dessert first!
    Alberta
    I see pictures that the OEM one folds up against the cab. Can it be secured there? Can you drive around with a load and the tonneau folded up against the cab - any concerns?
  22. May 26, 2022 at 8:25 AM
    #532
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    I'm pretty sure the OEM cover is the same as Bakflip. With that said, the Bakflip is designed to rest against the cab in the fully open position. It has foam pads that protect the cab and can be secured there with metal arm/rod on each side. No worries.
    My first tonneau cover on the Tundra was a different brand that did not rest against the cab but was held upright by rods. In my opinion, this was not near as secure as the folded cover, standing at 90 degrees, would rock back and forth while traveling down the road. In less than a week, the metal arms on mine were already showing a slight bow and the brackets were pulling out of the thin aluminum to which they were screwed. I think the design of leaning against the cab is much more secure.
    murtro[QUOTED] likes this.
  23. May 26, 2022 at 8:39 AM
    #533
    DrZoidberg
    Dave
    SATX
    Tesla MYP
    Anyone have experience with Retrax one vs pro? Live in hot texas is there a benefit to one over the other? Trying to see if the all aluminum pro is worth the 5-600 upcharge.
  24. May 26, 2022 at 8:56 AM
    #534
    in_the_mud
    in_the_mud GSD
    Raph
    Calgary, AB
    2023 Limited L TRD OR MBM
    I was wondering the same thing. Anyone?
  25. May 26, 2022 at 10:34 AM
    #535
    DrZoidberg
    Dave
    SATX
    Tesla MYP
    I went ahead and ordered the Retrax Pro XR and go rhino RB20 in bedliner finish for $2600 shipped.
  26. May 26, 2022 at 1:13 PM
    #536
    gmcguire7220
    gmcguire7220 New Member
    Ontario Canada
    2022 Limited TRD OR Crewmax - WCP- 2019 Toyota RAV4 Hybrid XSE
    TRD running boards & Bridgestone Dueller Ascent tires
    For the Canucks looking for Bakflip MX4 - for 3rd gen. AutoEQ emailed me today that they have stock. Ordered mine!
    JPCanadian likes this.
  27. May 26, 2022 at 6:53 PM
    #537
    JPCanadian
    JPCanadian New Member
    Although I'm sure it is Hella backordered, what is the price for the OEM cover in the great white north?
  28. May 27, 2022 at 4:44 AM
    #538
    gmcguire7220
    Ontario Canada
    $1830 +tx
    Yaboy likes this.
  29. May 27, 2022 at 5:10 AM
    #539
    Psam
    Psam New Member
    Philadelphia
    2019 Tundra Trd Pro voodoo blue
    I’m sure this has been answered but I can’t seem to find any info. Will any previous gen bed cover fit? TIA.
  30. May 27, 2022 at 6:52 AM
    #540
    damnfingers
    damnfingers New Member
    Gene
    If it's not listed as fitting the 2022 it may fit but not be totally watertight.
