2022 Tonneau covers
Discussion in 'Tonneau Covers, Caps and Shells' started by ak407, Jan 22, 2022.
  1. Apr 5, 2022 at 1:47 PM
    #271
    molson7
    molson7 New Member
    ya i really like the material too. It's a heavy tarp/tent-like fabric. Should hold up pretty well from the weather. I'm in Wisconsin so high-90's to below 0 is the norm depending on time of year. Wasn't sure about it when ordering but like how it looks.
  2. Apr 5, 2022 at 2:45 PM
    #272
    22PlatWCP
    22PlatWCP New Member
    Mississippi
    2022 WCP Platinum 4x4
    What about cleaning it? I had some tree sap get on the OEM tonneau I had on my Tacoma and it took ages to get it off. Bird crap comes off of aluminum, fiberglass and other hard tonneaus, how about the fabric ones?
  3. Apr 5, 2022 at 4:23 PM
    #273
    molson7
    molson7 New Member
    If you have those situations where tree sap is gonna be a problem then a fabric tonneau may be tough to clean. Bird crap doesn't matter to me because I'd clean that off like I would the rest of my truck.
    There's no perfect tonneau for everyone but for me, I have no sap concerns so it fits my needs well.
    damnfingers likes this.
  4. Apr 6, 2022 at 7:24 AM
    #274
    molson7
    molson7 New Member
    Yes it does have similar seal. Here's a pic of it properly seated. I messed with the cover last night and got it to latch but it required shifting the drivers side rail up slightly on tailgate end so it's not flush on top of bed. Not a permanent solution but will do until i can figure out a way to limit the rail flex that stops the latch from actuating prior to cover topping out on tailgate.
  5. Apr 6, 2022 at 8:04 AM
    #275
    tropro
    tropro New Member
    Troy
    MN
    2022 Blueprint Platinum
    I hear you on the the flex at the rear of the cover track. I was super carefull making sure the track was "level". I tinkered with this a little bit making sure the rail clamps were adjusted just right when fixing it to the truck rails. Not a lot of adjustment but got it as close to level as I could eye balling it from the rear of the truck. Did you try moving the last clamp as far back to the rear of the rail to truck to try elimanting some of the flex? I know it throws the spacing off but the realtruck rep said additional clamps can be ordered. I asked this when ordering because I notice it only came with 6 clamps. I didn't have any issues latching my cover but maybe this will help you?
  6. Apr 6, 2022 at 8:18 AM
    #276
    thekoop
    thekoop New Member
    Shawn
    2022 Lunar Rock Tundra TRD OR
    Can you snap a pic of the latching mechanism on the Sentry CT? I have a feeling they are different. It takes a lot of force for me to close the X15 and nothing I have tried works if the tailgate is up. Truxedo is sending me a new cover, should be here tomorrow.
  7. Apr 6, 2022 at 10:10 AM
    #277
    tropro
    tropro New Member
    Troy
    MN
    Here you go. The detent slippes below the rail when closed. I also included a pic on the ability to move the clamp back to the rear of the rail to try to help with the "flex". I didn't need to do it for my cover but thought it may help others with the X15 cover? Not sure if the set up is the same?
  8. Apr 6, 2022 at 10:49 AM
    #278
    thekoop
    thekoop New Member
    Shawn
    That looks like it would work much better. That latch looks like it doesn't apply an nearly as much pressure to the rail as the X15 latch. Thank you!
  9. Apr 6, 2022 at 11:52 AM
    #279
    Ryan P
    Ryan P New Member
    Ryan
    2022 Tundra Platinum
    I have a ProX15 on the way. I'm guessing I can plan on having this same issue? That is kind of a bummer.
  10. Apr 6, 2022 at 12:08 PM
    #280
    22PlatWCP
    Mississippi
    Are these tonneaus really made for the 2022 beds or are they a carryover from previous years? The BAKFlip covers for the previous years are not being sold for the 2022’s…this year’s tonneaus won’t be available until the end of this month.
  11. Apr 6, 2022 at 12:10 PM
    #281
    molson7
    molson7 New Member
    my ProX15 had 2022 Tundra on the label outside of box. Fitment to the bed is fine as far as size is concerned
  12. Apr 6, 2022 at 12:13 PM
    #282
    molson7
    molson7 New Member
    Will be interesting to see how yours closes with tailgate up. It's a nice cover and fits well, just the excessive rail flex when trying to latch with tailgate closed is an issue. Bottom line is i think there needs to be a reinforcement of the end-of-rail on tailgate end so it's rigid when closing cover.
    Let us know how your install goes.
  13. Apr 6, 2022 at 12:19 PM
    #283
    molson7
    molson7 New Member
    So here are 2 pics of how i got the ProX15 cover to close with tailgate up. Basically on the drivers side i raised the rail up high enough to compensate enough for the flex so the latch would catch before cover fully pressed against tailgate. You can see it's much higher than the passenger side pic. Not a solution but a temporary fix until i figure out how to reinforce latch-end of rail to eliminate the flexing.
  14. Apr 6, 2022 at 3:50 PM
    #284
    MarkO
    MarkO New Member
    Mark
    '19 Limited TRD
    I put my order in for one on Monday. I guess it won't be coming in any day soon. :(
  15. Apr 6, 2022 at 4:14 PM
    #285
    damnfingers
    damnfingers New Member
    Gene
    I chatted online with BAKFlip yesterday and they said they'd be released by the end of the month so it shouldn't be that bad. At least it'll fit (hopefully) when it gets here.
  16. Apr 6, 2022 at 5:19 PM
    #286
    MarkO
    MarkO New Member
    Mark
    '19 Limited TRD
    Hopefully it fits. I've heard it's the one Toyota installs at the dealership.
    22PlatWCP likes this.
  17. Apr 7, 2022 at 6:47 AM
    #287
    CMCaleb90
    CMCaleb90 New Member
    '22 Blueprint CM 4x4
    Just installed the Bison Tonneau Cover Backflip style. Ordered April 1 and it arrived on the 5th. (Canadian made about an hour away from where I live). Fit is pretty good overall, sat outside last night in a constant rain and only minor water infiltration - mind you I did not hook up the drain tubes. I did need to remove the tie down cleats and rails to get the side rails to fit nicely.
  18. Apr 9, 2022 at 10:57 AM
    #288
    Sparky916
    Sparky916 New Member
    Blake
    22 Lunar Rock Limited TRD OF
  19. Apr 11, 2022 at 9:45 AM
    #289
    offshore2005
    offshore2005 New Member
    TEXAS
    2022 Tundra Limited 4x4 RC leveling kit and 295/65/20 Cooper STT PROs
    Do you have a link to where you ordered it from?
  20. Apr 12, 2022 at 10:58 AM
    #290
    kstateskier
    kstateskier New Member
    Bradley
    Kansas City, MO
    2022 Tunda 1794 - Dark Metallic Grey
    offshore2005[QUOTED] likes this.
  21. Apr 12, 2022 at 12:24 PM
    #291
    Ryan P
    Ryan P New Member
    Ryan
    Not surprisingly, I'm having the exact same issues. The rail is flimsy as hell and flexing down as I try to latch with the gate closed. I shimmed it out so it sits higher, and this seemed to make it better, but it certainly isn't easy to latch. My wife won't be able to shut it, I can tell you that for sure. For $600, I'm not very satisfied. I think I'm going to return it for something that works.
  22. Apr 12, 2022 at 1:12 PM
    #292
    crazygill
    crazygill New Member
    i am going with the Retrax POWERAXPRO XR. RETRAX stated they should be aviable next month. I like the power option and the fact you can install cross bars on top of it and still access the bed. Waiting for my 2022 (will be called 2023) Tunbdra TRD PRO to arrive in a few months
  23. Apr 12, 2022 at 2:11 PM
    #293
    tropro
    tropro New Member
    Troy
    MN
    Dang! That's a bummer. The CT closes no problem. Must be a different design?
  24. Apr 12, 2022 at 3:57 PM
    #294
    golfersa
    golfersa New Member
    Fingerprints are completely worn off from clicking thru and reading all 301 posts, plus following all the links provided. :thumbsup:
    Sold my 2009 SR5 5.5' bed, which had an Extang tri-fold on it for 12 years. No complaints, just looking at what's come out since then... I'm leaning toward the BAK Revolver X4S... great looking, secure, and as waterproof as any... and I don't want a tri-fold covering the rear cargo camera. A decent 4 fold below the camera would be an option.
    But I saw no one mentioned the low profile tri-fold WeatherTech is putting out for the 2022 Tundra? Looks viable:
    https://www.weathertech.com/toyota/...-bed-size-3/5-1-2-bed/tundra-deck-rail-3/yes/
  25. Apr 12, 2022 at 4:42 PM
    #295
    offshore2005
    TEXAS
    Has anyone ever had a weather tech?? I am liking the look of this one.
  26. Apr 12, 2022 at 5:26 PM
    #296
    MarkO
    MarkO New Member
    Mark
    '19 Limited TRD
    FWIW, it appears as though the BAKFlip MX4 Tonneau Covers may now be in stock at Real Truck. I got an estimated delivery date of Thursday, Apr. 21 - Tuesday, Apr. 26
  27. Apr 12, 2022 at 5:42 PM
    #297
    offshore2005
    TEXAS
    don’t get your hopes up look at my chat with real truck.. Still 6 weeks out for the F1. No date for the MX4
  28. Apr 12, 2022 at 8:58 PM
    #298
    cjdelaney3
    cjdelaney3 New Member
    2022 Tundra
    I had the mx4 pushed back a few times and finally canceled my order. Hope it shows up soon for everyone.
  29. Apr 13, 2022 at 12:02 PM
    #299
    southdunes
    southdunes New Member
    2022 Tundra Limited CrewMax
    Hey @cjdelaney3, when did you order and how many delays did you encounter? Doesn't sound promising.
    Placed an order for the MX4 on 4/8 with an estimated delivery date of 4/15-4/20. Still 'pending fulfillment', but will update if/when it arrives.
  30. Apr 13, 2022 at 12:25 PM
    #300
    cjdelaney3
    2022 Tundra
    I ordered on 3/28 and it was pushed twice (don't recall dates and deleted my email) but the last update was something like a 4/21 delivery date. I ended up ordering the Rough Country on 4/9 and it was supposed to ship 4/19 but I got a notification that it shipped today.
    southdunes[QUOTED] likes this.
