2022 SR5 TRD offroad
Discussion in '3rd Gen Tundras (2022+)' started by YoitsGW, Mar 26, 2022.
  1. Apr 3, 2022 at 1:56 AM
    sn_85
    sn_85 New Member
    Boise
    2006 DC Tundra 4WD, 2013 Land Cruiser, 2022 RAM 2500 Bighorn
    To follow up on @KroppDuster installing the lift yourself will be easy enough. I've done a few suspension changes myself and once you do a few times it goes smoother each and every time and you accumulate all the necessary tools. The one thing about the Westcott kit is that you'll have to disassemble the shock and strut and put it back together. If you've never used a spring compressor before I would give you a wise word of warning and be very careful with them. Failure or improper use of them can be pretty catastrophic. If you still want to tackle the job yourself you can always take the strut off, bring it to a shop and they can always disassemble and reassemble it with the westcott collars using a wall mounted spring compressor for like $50. That's the way to go if you don't want to use janky spring compressors.
    ja5er and TexasTundra90[QUOTED] like this.
  2. Apr 3, 2022 at 6:23 AM
    DiamondW
    DiamondW Stockblocker
    Kent
    CenTex
    ‘17 CM
    Looks perfect, that was the exact truck I was planning on ordering until I backed out. You kinda make me regret that lol.
    ToyoTundra89[QUOTED] likes this.
  3. Apr 3, 2022 at 6:43 AM
    Rwaters
    Rwaters New Member
    2022 Tundra TRD SR5 Crewmax
    Or you can disassemble and reassemble it yourself, but take the struts to a shop and have them install the collar kit for you. I helped a friend install his leveling and he didn’t have a spring compressor kit. The rent a tool stores didn’t have one either. I called the shop down the street and they charged him $20.
  4. Apr 3, 2022 at 7:31 AM
    YoitsGW
    YoitsGW [OP] New Member
    Glenn
    2022 SR5 TRD off road
    Wow those tires and level change the whole look of the truck
    ToyoTundra89 likes this.
  5. Apr 3, 2022 at 3:00 PM
    wayoflife
    wayoflife Exploring Cascadia and beyond
    Seattle-ish, WA, USA
    '22 1794 6.5' TRD Offroad Blueprint/Cream
    Westcott 3/1 Method 705 18x9 18mm Maxxis RAZR 295/70R18
  6. Apr 8, 2022 at 8:55 AM
    TexasTundra90
    TexasTundra90 New Member
    Aaron
    2022 Crew Max Army Green Tundra TRD Off-Road
    2022 Crew Max Army Green Tundra TRD Off-Road Mods so far: 295/70/18 Falken Wildpeaks ‘18 Battle Born wheels ‘1.75 Rough Country Leveling kit
    Did you end up paying a shop to do it or do it yourself?
  7. Apr 8, 2022 at 8:59 AM
    ToyoTundra89
    ToyoTundra89 Member
    Seattle, WA
    2022 Tundra SR5 TRD OR CM 6.5
    Went with a local shop. With the front level, its actually pretty easy to do, but I didnt feel like messing with spring compressors. Shop knocked out the install and alignment in a couple hours.
  8. Apr 8, 2022 at 9:05 AM
    TexasTundra90
    Aaron
    Nice! You mind if I ask how much the install was for the leveling kit?
  9. Apr 8, 2022 at 9:07 AM
    ToyoTundra89
    ToyoTundra89 Member
    Seattle, WA
    well Washington tends to overcharge for everything lol. It was $400 for the install, a little steep since they only touched 2 corners. Then another $150 for alignment.
    bigjuice likes this.
  10. Apr 8, 2022 at 9:10 AM
    TexasTundra90
    Aaron
    Granted I don't know a ton about installs but $400 doesn't sound terrible at all, honestly. It's also a good reference point for me. Thanks for the info! Looks great.
  11. Apr 8, 2022 at 9:39 PM
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    Amen to that…everything around here seems to carry a premium o_O
  12. Apr 10, 2022 at 8:53 PM
    YoitsGW
    Glenn
    Ok the job is done. Wescott leveling kit and 295 70 R18
  13. Apr 10, 2022 at 8:53 PM
    YoitsGW
    Glenn
  14. Apr 10, 2022 at 8:59 PM
    YoitsGW
    Glenn
    I just finished a road trip and I noticed my fuel economy went from 13L / 100km to 14.2.
    I am thinking I need to flash my computer to update the tire size? Hoping that will bring back some fuel efficiency?
  15. Apr 10, 2022 at 9:16 PM
    ToyoTundra89
    ToyoTundra89 Member
    Seattle, WA
    Looks amazing! Tires look really good with that level.
    Yup, once you flash the computer for tire size it should improve you mpg calculations. Excuse my ignorance in the metrics system.. since im used to only calculating mpg, but chances are youre really traveling ~105-110km on the 14.2 liters of gas. Even though the trip is only showing 100km. So in reality youre getting better fuel economy numbers than the truck is telling you.
  16. Apr 11, 2022 at 7:24 AM
    ColumbiaGorge
    ColumbiaGorge New Member
    Joe
    Columbia Gorge
    24 Limited
    I was quoted $700 at two different places in Oregon.
