2022 SR5 TRD offroad
Discussion in '3rd Gen Tundras (2022+)' started by YoitsGW, Mar 26, 2022.
  1. Mar 26, 2022 at 8:13 PM
    YoitsGW
    YoitsGW [OP] New Member
    Glenn
    2022 SR5 TRD off road
    Hello I just joined and took possession of my Tundra yesterday.
    I am looking at installing a Westcott Design leveling kit with my local garage. Does anyone have experience with this kit?
    I think this will allow 35 x 12.5 x R18. Does anyone on the forum have any experience with this?
  2. Mar 26, 2022 at 8:16 PM
    Henry2019
    Henry2019 N/A
    Houston, Texas
    2019 SR5 CM CEMENT GREY
    3/1 Lift Kit 20X9 Fuel Assaults +1 295/60/R20 Falken Wildpeak A/T3W
  3. Mar 26, 2022 at 8:51 PM
    digitalwiz
    digitalwiz New Member
    2024 LR Defender 110/ 2022 Superduty Tremor 4x4/ 2017 Porsche 911
    Pictures or it didn’t happen…
  4. Mar 26, 2022 at 10:00 PM
    Bradanglin22
    Bradanglin22 New Member
    Brad
    Here ya go. Can confirm.
  5. Mar 27, 2022 at 7:24 AM
    Buellride
    Buellride New Member
    Olympia
    THE BOULDER
    BD Lights, Banks PM, Fuel Vector 18" on 295/70R18 Cooper AT3 XLTs, Black-Out badges, TRD front grill
    Methods or Fuels? Assuming you have the Westcott on your truck? Very good looking truck.
  6. Mar 27, 2022 at 7:46 AM
    Bradanglin22
    Brad
    Yes sir! Method 317’s with +18 offset.
  7. Mar 27, 2022 at 10:49 AM
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    Show us more
  8. Mar 27, 2022 at 11:50 AM
    KroppDuster
    KroppDuster Out with the old and in with the...older?
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Double Cab gang FTW! :)
  9. Mar 27, 2022 at 1:05 PM
    fluke702
    fluke702 New Member
    With 12.5" width tires, and with a Wescott Collar Lift I heard that there may rubbing against the UCAs and suggested to add 7mm shims in order to add space. However, i don't know if that's good if it shortens the bolt threads. Can anyone confirm, and if it would be better to use 11.5" width tires instead?
  10. Mar 27, 2022 at 1:29 PM
    Bradanglin22
    Brad
    I was worried about the same thing so I opted to go with falken wildpeaks in a 295/70/18. They come out to be 34.5x12. I figured that extra 1/2” in width would prevent any potential issues whatsoever and I was right!!! I’d highly recommend this setup.
    Yaboy likes this.
  11. Mar 27, 2022 at 2:45 PM
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    can I see how far they stick out, I have the 317s and am interested with the 295 tires
    ja5er likes this.
  12. Mar 27, 2022 at 3:10 PM
    Bradanglin22
    Brad
    I’m not home right now but can get a better shot in a few hours. These are the best pics I got right now to give you an idea… about 1.5” of poke.
  13. Mar 28, 2022 at 6:42 PM
    Bradanglin22
    Brad
    Apologies for the delay. Here’s a better shot of the poke.
    Yaboy likes this.
  14. Mar 29, 2022 at 4:35 AM
    king_fish
    king_fish I caught you a delicious Bass...
    "BK"
    Western PA
    2022 4x4 TRD Off Road - MGM
    That is one bad ass looking ride there Bro... Congrats!
    Bradanglin22[QUOTED] likes this.
  15. Mar 29, 2022 at 4:49 AM
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    Based on this I’m going to get some cooper XLT 295/70/18 thanks
  16. Mar 29, 2022 at 6:40 AM
    bigjuice
    bigjuice Researching and collecting parts…
    WA State
    2022 MGM Crew Max SR5
    Assuming you are still looking for an answer those tires will rub on the upper control arms if you retain the stock wheels.
    You will either need to get narrower wheels (wouldn’t go past 12), run a shim/spacer on those front wheels or get a set of aftermarket wheels with a lower offset.
  17. Mar 29, 2022 at 9:48 AM
    YoitsGW
    Glenn
    Ok I am going to use my TRD wheels
    my options that will work are
    295 x 70 R18
    305 x 70 R18
    Correct?
  18. Mar 29, 2022 at 10:21 AM
    KroppDuster
    It's interesting the different experiences regarding 12.5" wide tires.
    Driven Companion on YouTube shows his truck on true 35's without any rubbing issues. He's running a simple 2" leveling kit (same one I'm running) up front and has 35x12.5x20 Goodyear M/T tires without any rubbing issues on his UCAs. He's running the stock TRD OR 20" rims that came with his Limited trim. No wheel spacers.
    I don't know how he's done it, but he claims it's totally fine with zero rubbing. I'm running 34's (295/70/18) on my truck and I had to remove the front mud flaps & tuck the front wheel well liner back a little to stop the minor rubbing. I guess that's because I'm running +18 offset vs the +60 on the OE rims.
    Link to his video: https://www.youtube.com/watch?v=3oqNZZqFWxY
    Serge752 likes this.
  19. Mar 30, 2022 at 9:54 AM
    TexasTundra90
    TexasTundra90 New Member
    Aaron
    2022 Crew Max Army Green Tundra TRD Off-Road
    2022 Crew Max Army Green Tundra TRD Off-Road Mods so far: 295/70/18 Falken Wildpeaks ‘18 Battle Born wheels ‘1.75 Rough Country Leveling kit
    Excuse my ignorance here with these few questions. I'll be taking possession of my new truck here in 3 weeks. It's the TRD Off Road. I am wanting to do the Westcott leveling kit.
    1. Is it easy enough to install or something that I should take to a shop?
    2. I am wanting to do bigger tires on it but I also don't want to do any additional "adjustments", etc. So what would be recommended with that small lift/leveling kit & the stock rims?
  20. Mar 30, 2022 at 10:23 AM
    KroppDuster
    All depends on your comfort & skill level. I would be comfortable doing it, but I also have all of the needed tools (spring compressors, impact tools, etc). I haven't installed their kit, but I've installed plenty of other leveling & lift kits in the past. Including a 2" leveling kit on my 2022 Tundra. If you've installed other leveling or lift kits before, the hardest thing you'll run into with the Westcott kit is the disassembly & reassembly of the front coilover units. If you're comfortable doing that, then you'll be fine. Watch their YT video. They have a full walk-through of the installation and judge for yourself. Otherwise...just pay the ~$800 to have a local shop install it for you.
    If you want do something easy with a lot of impact...I'll selfishly recommend my setup: 2" Leveling kit upfront and 295/70/18 tires. You can run that tire size on the OE wheels. You don't gain a lot (in my opinion) by going with the Westcott kit for the price difference. With a 2" leveling kit, you can run 34" or 35" tires with little to no issues. I spent $50 on a 2" leveling kit and installed it in about 2.5 hours in my garage vs $450 for the Westcott and probably 6+ hours of install time.
  21. Mar 31, 2022 at 4:17 PM
    YoitsGW
    Glenn
    My westcott kit goes on tomorrow! 295 70 R18 falcons will be mounted on stock TRD wheels. Pictures to follow!
    sn_85, Bradanglin22 and Yaboy like this.
  22. Apr 2, 2022 at 1:37 AM
    Henry2019
    Henry2019 N/A
    Houston, Texas
    you’re not OP..
  23. Apr 2, 2022 at 8:39 AM
    Bradanglin22
    Brad
    Your point?
  24. Apr 2, 2022 at 10:56 AM
    Rwaters
    Rwaters New Member
    2022 Tundra TRD SR5 Crewmax
    He doesn’t have a point. He’s the guy that goes from thread to thread starting stuff with people just to see who’ll bite.
  25. Apr 2, 2022 at 5:41 PM
    YoitsGW
    Glenn
    Me? I just joined.
    thank you for the info it was helpful making my decision.
    truck comes back Monday. Can’t wait
  26. Apr 2, 2022 at 7:02 PM
    Henry2019
    Henry2019 N/A
    Houston, Texas
    Lol you’re funny pal.. smh
  27. Apr 2, 2022 at 7:02 PM
    Henry2019
    Henry2019 N/A
    Houston, Texas
    you jacked the OP’s thread
  28. Apr 2, 2022 at 7:41 PM
    Rwaters
    Rwaters New Member
    No, not at all you. I was replying about the reply. Welcome to the forum by the way. I have an SR5 TRD as well, but I went a different route. I used an old Gen 2” leveling kit with 18x9 +18 wheels and 275/70 Coopers. Let us know what you decide, plenty of folks are running 35’s.
  29. Apr 2, 2022 at 7:45 PM
    ToyoTundra89
    ToyoTundra89 Member
    Seattle, WA
    2022 Tundra SR5 TRD OR CM 6.5
    I got the westcott front level installed on Friday. Love it. Rides great!
  30. Apr 2, 2022 at 8:26 PM
    YoitsGW
    Glenn
    Awesome! Do you have a couple pics to share?
    ToyoTundra89 likes this.
