2022 Hybrid mod install reference
Discussion in '3rd Gen Tundras (2022+)' started by pnw.tundra, Oct 20, 2022.
  1. Dec 21, 2022 at 6:15 AM
    #61
    MateoAirborne
    MateoAirborne New Member
    Mateo
    2023 iForce Max 1794 TRD Off Road Package
    Will upgrading to any aftermarket exhaust throw a code in the computer?
    dirtydeeds[QUOTED] likes this.
  2. Dec 21, 2022 at 9:40 PM
    #62
    Ayoandiee
    Ayoandiee New Member
    Southern California
    2022 Lunar Rock Tundra TRD PRO
    XL80 Ditch Lights, Nitto R Grapplers 35s, RC Boards, Taco Tunes Cat Shield, CBI Covert Bumper, Smitty X20 10k winch
    I had the engineers at Baja Designs calculate everything for my gen 3 10k Smittybilt. After their research, they agreed that I should go directly to the 12v battery. I’m glad I got confirmation. Now I need to calculate distance/gauge
  3. Dec 22, 2022 at 7:08 AM
    #63
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    I ran about 17ft and that barely made it of 0 garage wire
    GG.Offroad and Ayoandiee[QUOTED] like this.
  4. Dec 23, 2022 at 6:53 AM
    #64
    bballjames
    bballjames New Member
    Inland PNW
    22 Tundra Platinum 4x4 Hybrid Crew Max 6.5ft bed
    Question for the group here. I just ordered the Diode Dynamics stealth light bar along with the SS3 ditch lights. Where is everyone wiring these? Empty fuse spot under the hood? Or wiring all the way back to the battery in the rear seat? I understand a winch or something that uses quite a bit if power needing to be back at the battery, but curious for those running aftermarket lights where they wired?
    I will be using these switches to turn them on/off.
    https://www.etsy.com/listing/132396...kmdjLlMjLW6MfUL3shSso34d-Zu55-h0aApq3EALw_wcB
  5. Dec 23, 2022 at 7:09 AM
    #65
    Hadsen15
    Hadsen15 New Member
    Trey
    22 tundra magnetic grey
    I wired my DD light bar directly to battery under rear seat with same switch…works great!
  6. Dec 23, 2022 at 7:14 AM
    #66
    jcmartin11b
    jcmartin11b New Member
    2022 lunar rock pro
    Ran a garmin PowerSwitch under the back seat, then a thermal “extension” to the under hood area
    GG.Offroad and iiawah808 like this.
  7. Dec 26, 2022 at 1:01 PM
    #67
    DesmoDoe
    DesmoDoe New Member
    Canada
    22 SO TRD Pro
    Put 285/75R18 Wildpeaks: no rub, no lift. But tight clearance to the mud flaps.
    Anti-glare screen protector and Valhalla Shields Cat protector.
    WesternDawg, Yaboy and Classy63 like this.
  8. Dec 26, 2022 at 1:07 PM
    #68
    iiawah808
    iiawah808 New Member
    Oahu, HI
    2022 iForce Tundra Limited TRD Offroad
    Currently Searching....
    Make a kit and please sell this!
  9. Dec 26, 2022 at 1:13 PM
    #69
    jcmartin11b
    2022 lunar rock pro
    Look up blaze off-road out of Colorado!
  10. Dec 26, 2022 at 10:37 PM
    #70
    graf_von_tundra
    graf_von_tundra Not so new
    Central Texas
    2023 Tundra 1794 4x4 Black
    Where does your wiring enter the cab to get to the 12V battery? Thanks for the help
  11. Dec 27, 2022 at 1:09 PM
    #71
    DexterL
    DexterL New Member
    grommets under the driver and passenger seats, then ran through the kick panels into the hybrid battery bay
  12. Dec 29, 2022 at 11:09 PM
    #72
    Ayoandiee
    Southern California
    Anyone have ideas on what route to take for a tire inflation system? Kits aren’t designed for battery location.
  13. Dec 30, 2022 at 10:23 AM
    #73
    graf_von_tundra
    Central Texas
    I'm hanging my ARB dual compressor inside the bed fender cavity on the rear driver's side. I'm taking inspiration from @PapaDave418 build with the nice clean ARB switch and quick connect bracket.
    For power, I'm planning to run from the 12V battery under the driver's side kick panels, through the large firewall grommet just above the pedals, and then back to the compressor under the truck. There's grommets under the front seats but I'd rather keep those intact to keep water out...for me, I'm going to the better-safe-than-sorry route. Currently, pulling together all the pieces.
  14. Dec 30, 2022 at 2:50 PM
    #74
    DexterL
    DexterL New Member
    mine haven’t leaked once under the seats, but I did silicone everything up solidly once I was finally done
  15. Jan 26, 2023 at 10:32 PM
    #75
    dirtydeeds
    Keith
    USA
    more than I can list here
    Nope. Only deleting the cats will.
    pnw.tundra[OP] likes this.
  16. Jan 27, 2023 at 6:15 AM
    #76
    Welderdude80
    Welderdude80 New Member
    JP
    Alberta
    2023 Tundra limited hybrid crew max
    working on it
    I doubt it. I got the Trd exhaust installed on my ‘23 hybrid no issues at all it sounds good on sports mode Who has installed cold air intakes on their twin turbo hybrid ? Any major sound difference? And I also want to add this grille and light bar kit https://raveoffroad.com/products/2022-tundra-complete-heritage-pro-grille-kit
    Might be a PIA to wired switch inside the cab tho.
  17. Jan 27, 2023 at 7:19 AM
    #77
    dirtydeeds
    Keith
    USA
    There’s no such thing as a 22+ trd exhaust. There’s a trd tailpipe which is useless since it still uses the factory restriction style muffler as seen here:
    https://youtu.be/fnRQSdpa64Q
    FLKX and Welderdude80[QUOTED] like this.
  18. Mar 11, 2023 at 9:08 PM
    #78
    TheManderson
    TheManderson Former Tundra Owner
    Mark
    2022 Tundra Hybrid Limited 4x4 TRD Off Road (SOLD), 2024 Ford F350 Lariat Ultimate Tremor 6.7L HO Diesel
    Very nice! Anyone else doing something similar? I've been contemplating running some heavy-gauge cables to a set of terminal studs under the hood, like those in the pic below (with a circuit breaker close to the battery), but would that be safe? I feel like that would be the easiest way to wire in the winch and switch kit I'll be purchasing sooner or later
  19. Mar 11, 2023 at 9:56 PM
    #79
    dirtydeeds
    Keith
    USA
    mayan and WesternDawg like this.
  20. Mar 11, 2023 at 10:12 PM
    #80
    GoFast157
    GoFast157 New Member
  21. Mar 12, 2023 at 7:02 AM
    #81
    dirtydeeds
    Keith
    USA
    Give a call in a few hours. 760-877-4234
    Keith
  22. Mar 12, 2023 at 8:31 AM
    #82
    graf_von_tundra
    Central Texas
    Here’s what I did for a compressor but with a future winch in mind: https://www.tundras.com/threads/arb-compressor-fender-well-mount-for-hybrid.117757/#post-3078766
    For the winch, I plan to run a large ground back to battery and replace the 150A circuit breaker with something much more substantial. Probably a circuit breaker bypass where I can switch between always having 150A power for the compressor and then 500A for the winch. This should do the job: https://www.bluesea.com/products/11...y_3_Position_Selector_Battery_Switch_with_AFD
    Now, I understand you could need 600A on a max capacity pull but I try to never do that and typically use a snatch block which doubles your capacity / reduces the necessary line pull by half.
    Here’s a nice article about winches and amps needed for specific pulls: https://www.mikesjeep.com/articles/choosing-a-winch
  23. Mar 12, 2023 at 1:17 PM
    #83
    TheManderson
    Mark
    Love your compressor mount (I may copy that) and the way you ran the cable to the underhood buss bar.
    To simplify things, couldn't you leave the 500A circuit breaker by the battery and move the 150A underhood, coming off the buss bar? That would be simpler, so you wouldn't have to switch anything when you started winching.
  24. Mar 28, 2023 at 7:18 AM
    #84
    graf_von_tundra
    Central Texas
    Yeah, probably so. I might just be playing it too safe with the breakers and high capacity switch. The thought was to limit the possibility of a high amperage short with the 150A breaker and have the 500A only when I need it.
  25. May 23, 2023 at 5:42 PM
    #85
    chill_trd
    chill_trd New Member
    '22 TRD limited
    Do you have more pictures of your garmin setup? The double row terminal in the bay with the negative location , as well as the garmin under under the seat? Also do you know what length of wire you needed from the battery to the terminal?
  26. May 24, 2023 at 8:48 PM
    #86
    matth66
    matth66 New Member
    matt
    Nor cal
    2023 Black Tundra Trd Pro
    Follow
  27. May 30, 2023 at 12:08 PM
    #87
    jcmartin11b
    2022 lunar rock pro
    Ill take some pictures this weekend. Blaze offroad in denver was the one who did it.
  28. May 30, 2023 at 3:51 PM
    #88
    chill_trd
    '22 TRD limited
    Yeah I contacted them for info but they pretty much told me to kick rocks.
  29. May 31, 2023 at 11:37 AM
    #89
    jcmartin11b
    2022 lunar rock pro
    Damn sorry about that.
  30. Jun 28, 2023 at 4:42 PM
    #90
    Hkeplr
    Hkeplr New Member
    VlD
    Army Green 2023 Hybrid
    Watching for Switch Pros install, did it on my 18 4Runner. Order all the parts I think I may need for the SP install.
