2022 blown front differential :-(
Discussion in '3rd Gen Tundras (2022+)' started by brow, Dec 23, 2022.
  1. Dec 23, 2022 at 8:12 AM
    brow
    brow [OP] New Member
    2022 LTD TRD
    Felt and heard grinding coming front front end last night. Took to dealership this morning. Confirmed front diff is toast. Was full of filings and metal.
    Have truck back hopefully don’t need 4wd (brutal snow and ice here right now) and new diff will be at least a couple weeks. Between all the rattles and some fit and finish issues I’ve had this sure isn’t like my previous tundras. Ugh. 12,000kms FWIW.
    Leo's first likes this.
  2. Dec 23, 2022 at 8:14 AM
    Taco-Spike
    Two Trucks
    Damn, sorry OP.
    Had you used it before?
  3. Dec 23, 2022 at 8:19 AM
    Terndrerrr
    Terndrerrr guzzling dealer repellent
    Music City
    Dual 5.7s
    TRD Fox, RAS, 285/75 DTs, dual battery, SS3 Pro
    Sorry to hear it, OP. Seems like this is the first time I’m hearing of a diff grenading on the 3rd gen.
    My old Suburban grenaded the rear diff at 220k miles. I had to limp home in 4wd using the front diff only. Not fun.
    brow[OP] likes this.
  4. Dec 23, 2022 at 8:33 AM
    brow
    2022 LTD TRD
    Thanks!
    I have been using 4WD sporadically, perhaps out of the 12k I have on the truck maybe a total of 500kms?
    I wonder if something was frozen, we have been experiencing nasty weather. Cause felt the hop at full crank even in 2WD, almost like the system was not engaging/disengaging properly? Hopefully no other issues with TC or anything else. Have the truck back until new diff arrives, but we are driving on ice up here so 2WD is going to be a little painful.
    Hopefully mine is the exception and this isn't seen more.
    Kap1, Masterchef and Eurodriver like this.
  5. Dec 28, 2022 at 9:26 PM
    Masterchef
    Masterchef New Member
    I'm an owner (not a proud one at all) of a 2022 Toyota Tundra Limited trim with 14,000 kms. I'm just north of Toronto and took my truck into the dealer today after hearing some noise from the front end which got worse over the last two days. After leaving it with them for the day its finally been determined that my front differential has given out and requires replacement. I'm really upset.
    The above blown differential as noted is not the only issue I've had with the vehicle. I have suffered a complete loss of power on the vehicle while travelling at highway speeds, approximately 45 days after driving it off the lot. After the selling dealer scanned it, it was explained to me that the code showed a 'backfire', but that no further fault could be found. I was told to drive it and bring it back if anything further came up. I have had endless amounts of wind noise coming through the vehicle, the dealer has replaced the weather seals and window seals, but still with no success in remedying the issue.
    I've owned, and still own a 2010 Tundra since almost new, and never had an issue with it. Only ever had to do maintenance on it, nothing more. It's why I put my faith into the brand and purchased this new one out-right from the dealer with the intention of a long-term hold. I cannot express how very sorry I am that I made this purchase. I must confess that the likelihood of me getting out of this vehicle as high possibility, based on my above experience.
    Any feedback is always appreciated.
    Leo's first, brow[OP], myt1 and 2 others like this.
  6. Dec 29, 2022 at 4:35 AM
    PWMDMD
    PWMDMD New Member
    Worcester, MA
    2020 Tundra Platinum
    It seems every single manufacturer, Toyota included, is in a race to the bottom. The name of the game is to cut costs on design/manufacturing and engineer the vehicle to get just outside of warranty to minimize those costs and maximize profits. The kicker is you can still do this and be "better rated" than other manufacturers - you don't have to build reliable vehicles, you just have to build vehicles that have fewer problems than other vehicles from other manufacturers. This less-than-great philosophy will still put you right at the top of CR while producing shit vehicles.
  7. Dec 29, 2022 at 5:39 AM
    jgoliath
    jgoliath Northeast Rust Fighter
    2022 Tundra, SR5 Offroad, Lunar Rock
    What driving conditions where you in when it blew? Stock truck or any lift installed?
    If you were full crank in 4WD and felt it “hop” I’m guessing you might’ve been driving on pavement and that will most definitely cause damage from repeated turns in 4WD without any surface for the front wheel to slip on.
  8. Dec 29, 2022 at 7:03 AM
    brow
    2022 LTD TRD
    We also complained about wind noise but were told "could not duplicate". Also have quite a few rattles in the cabin headliner throughout, outer window seal that's popped out, speakers that rattle. etc.
    Agree the quality appears to be lacking to say the least esp compared to previous Tundras.
  9. Dec 29, 2022 at 7:06 AM
    brow
    2022 LTD TRD
    Truck is stock, no lift.
    Have been driving on packed snow and ice since pretty much Nov 1st. It was hopping on ice. Your guess is incorrect: I don't drive on bare pavement with 4WD and don't do repeated turns in 4WD without any surface for the wheel to slip on.
  10. Dec 29, 2022 at 7:07 AM
    2000 Limited TRD AC 4X4 Thunder Grey 270k miles. 2019 Limited TRD CM 4x4 Cement Grey 75k miles
    2000: Bilstein 5100's 16x8 589's with 265/75/16 and 1.25" spacers Flowmaster 50 series over the axle dump Pioneer touchscreen with backup camera Full interior and dash LED conversion Trailer brake controller with 7 pin Bedliner coat bumpers & trim ARE topper 2019: ARE topper with full Bedrug kit and Vortex rack TRD shifter 1.25" wheel spacers (I like to live dangerously) Red tow hooks for that +15 grip bonus
    How'd you get it to hop on ice? Crazy
    clownkillerloaf and jgoliath like this.
  11. Jan 10, 2023 at 8:33 AM
    Masterchef
    Could not have said it better myself.
    Leo's first and brow[OP] like this.
  12. Jan 10, 2023 at 8:46 AM
    PBNB
    PBNB TRD Crew
    Peter
    Vancouver, BC
    2022 Limited Crewmax L
    MBM - TRD Offroad
    I have a simple question. Is the front diff "open" "limited slip" or "locker"? I really can't see the diff exploding if either of the first 2 are what we have. I don't think we have a locker up front but I really don't know.
  13. Jan 10, 2023 at 8:55 AM
    Breathing Borla
    build date?
  14. Jan 10, 2023 at 9:48 AM
    Black Wolf Bigfoot Hunter, Sasquatch too, but not Yeti
    Aurora CO
    No locker up front. Open diff.
  15. Jan 10, 2023 at 9:57 AM
    PBNB
    PBNB TRD Crew
    Peter
    Vancouver, BC
    MBM - TRD Offroad
    Open diff makes sense, is it always engaged up to the T-case or are there other actuators that disconnect the diff and or axle to minimize the drag on the system? I am thinking about my locking hubs on my long gone little truck.
    I am thinking that there would be something electronic that would disengage the front drive train near the front wheels to save on fuel.
  16. Jan 10, 2023 at 10:37 AM
    PERRY1060
    PERRY1060 Hammer Down
    Perry
    Indiana
    Blk on Blk 22 Ltd 4x4
    TRD wheels, skid plate, black fender flares, mud flaps and running boards. Pirelli Scorpion 275/70/20 Allterrain Plus tires
    Can we get the build date of your truck to add to data on this type of failure. Thanks
    brow[QUOTED][OP] likes this.
  17. Jan 10, 2023 at 10:44 AM
    brow
    2022 LTD TRD
    Good question, and I actually don't know the answer to that question! FWIW it is a Canadian Limited TRD OR, not sure how they are normally specc'd
  18. Jan 10, 2023 at 10:45 AM
    brow
    2022 LTD TRD
    Was built in May 2022
  19. Jan 10, 2023 at 12:49 PM
    PERRY1060
    Perry
    Indiana
    Curious if the build date of your truck is near OP build date May 22.
  20. Jan 11, 2023 at 10:29 AM
    Masterchef
    MAY 2022
  21. Jan 11, 2023 at 10:30 AM
    Masterchef
    My truck was built in May of 2022 as well.
  22. Jan 21, 2023 at 11:07 PM
    Lumberjack
    Lumberjack New Member
    Same story as above. May 2022 build. Lives in Idaho.
    Masterchef likes this.
  23. Jan 22, 2023 at 6:31 PM
    jproy12
    jproy12 ¯\_ (ツ) _/¯
    JP
    Ottawa, Canada
    2023 Supersonic Red Platinum Hybrid
    Woah, just browsing the forum, and noticed this post, I guess I'm no longer the only one... Mine went at roughly 1100km, they replaced the front diff and was good after that.
    Build date was June 2022... Maybe there was a bad batch of diffs during that time?
    See my post here:
    https://www.tundras.com/threads/front-diif-issues.111141/#post-2868504
    Traded the truck in shortly after and now expecting my '23 in the next couple weeks.
  24. Jan 23, 2023 at 8:28 AM
    vegask
    vegask New Member
    Kurt
    Northern NV
    2023 Tundra SR5 Premium
    So whom ever was setting up ring and pinions in May of 2022 hopefully is working for Ford now.
    raylo, Chadwicktr and Masterchef like this.
  25. Jan 23, 2023 at 8:30 AM
    mass-hole
    mass-hole New Member
    Nah, Ford diffs are good. You need a whippled 5.0 making 800 hp to piss them off. Not a stock truck with no lift.
    dekeman and Black widow TRD like this.
  26. Mar 6, 2023 at 7:30 PM
    rpw513
    rpw513 New Member
    Add a March 2022 build to the grenaded front diff list. 6700mi, driven maybe 40 in 4WD (never on dry pavement).
    Chadwicktr likes this.
  27. Mar 6, 2023 at 10:01 PM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    Yeah Ford makes some killer diffs. At work we out then thru he’ll, not one died. Come on Toyota!!
  28. Feb 5, 2024 at 6:21 PM
    gallen70
    gallen70 New Member
    Greg
    2023 Black Platinum Tundra
    Leveling kit, 35 in tires
    I have a 2023. The front differential died at 14K miles.
    02/07/2024: I just got it back after having the differential replaced. The ride seems to be smoother now. Its starting to snow here so I'll get to try it out. The people at my dealers service compartment were great to deal with. I hope that's the last I have to deal with it though.
  29. Feb 5, 2024 at 8:32 PM
    PNW Tundra Mike
    PNW Tundra Mike New Member
    Western WA
    MX4 Tonneau, Talon's Trans/Cat Shield
    Deserves to be a line item in @ryanwgregg 's issue tracking list. Build dates seem random.
  30. Feb 7, 2024 at 10:29 AM
    GrudyGill
    GrudyGill New Member
    Randy
    Toyota 2022 Tundra Limited
    None
    My 2022 Limited Tundra developed a clunking noise just over this past weekend and only has 22K miles on it. Dealership just called and said the metal filings and metal pieces were coming out and the front differential was toast. I used 4wd for the very first time in this truck last month during a snow storm here in Eastern PA. I had a 2018 Tacoma Limited and never had any issues with it. Hoping that I didn't make a mistake buying a new generation model. Ugh!
