2022-2024 fuel tank gauge defaults to FULL
Discussion in '3rd Gen Tundras (2022+)' started by txag85, Oct 1, 2024.
  1. Oct 1, 2024 at 10:52 AM
    txag85
    txag85 [OP] New Member
    scott
    2024 Tundra Platinum
    Had to lemon law my 2022 tundra platinum for this issue. Now my 2024 Tundra Platinum doing the same thing. Anybody else?
    sometimes when you start the truck on an incline up or down, the fuel gauge will default to full, even though the tank may only have half a tank of gas and will not reset until you go and fill the tank back up at the gas station. There is a sequence of button pushes that you can do with the odometer and the start engine button that restores it back to normal.
    Toyota had aTSB for the 2022-2023 but it didn’t work. Nothing for the 2024s.
    About 3 weeks ago they replaced my dashboard. But that didn’t work.
    waiting for dealership to let me know what they want to try next.
    since it will reset after the button sequences, I gotta believe it’s a software sensing issue.
    But for now I have to use my odometer to guess how much gas I have in the truck.
    Thanks Scott
  2. Oct 1, 2024 at 10:56 AM
    donia
    donia New Member
    Miss’ippi
    2023 Celestial Silver Tundra 1794 4x4
    Welcome back to the faulty gas gauge club! TSB slowed mine ('23) down from a couple of times a tank to once a tank. It was only doing it with 3/4 of a tank at first, then progressed to didn't matter how much was in the tank.
  3. Oct 1, 2024 at 11:05 AM
    kirkb
    kirkb Tired New Member
    DFW
    2024 Tundra Limited 4x4 WCP Nightshade
  4. Oct 1, 2024 at 11:16 AM
    sandiegosteve
    sandiegosteve New Member
    San Diego
    24 Limited TDR Lunar Rock
    I've had it happen once on my '24. I'm sure it was when launching boat on ramp. I've launched many times with just the one problem. I'm sure it can and will happen again which I don't love. There is a fix through button presses, so I agree it is software.
  5. Oct 1, 2024 at 11:40 AM
    txag85
    scott
    Well after 3 years it should have been fixed. Not a complicated system. may have to do lemon law again. Was easy process.
    sandiegosteve likes this.
  6. Oct 1, 2024 at 11:48 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
  7. Oct 1, 2024 at 12:54 PM
    TheSS712
    TheSS712 New Member
    Shayne
    2022 Army Green Tundra Limited
    Mine still does it after the so called reset or whatever they did.
    therandomsuit likes this.
  8. Oct 1, 2024 at 4:35 PM
    NY24SR5
    NY24SR5 New Member
    White 24 SR5
    Have a 24 SR5 and my driveway has a slight incline. Has been doing this since brand new. Sometime it even does multiple times on the same tank. Dealer claims to know nothing and insists nothing is wrong although they reset the gauge every time I bring it back. I showed them the 22 tab and they said that doesn’t apply to my truck even though they follow the steps in it to reset the gauge. Engaged Toyota corporate who had a field tech look at it. No resolution either. Now I’ve been told to hang tight they have to research it and that it’s most likely software related. Odd they can’t figure this out since it seems to date back to 2022. Overall I love the truck but it’s also very frustrating. I’d be interested to know if anyone in NY has tried to lemon law this?
  9. Oct 1, 2024 at 5:50 PM
    TundraDan723
    TundraDan723 Not as new as I used to be...
    2023 Celestial Silver Tundra 1794 TRD CM
    My truck has done this twice in the past couple months. I called the local dealer to request a service appt to have it looked at. The kind lady booking my appointment was shocked about the problem and said that would stress her out to no end! :)
  10. Oct 1, 2024 at 6:23 PM
    Duckinatruck
    Duckinatruck New Member
    Don’t do that convoluted button push sequence. When you come to a stop, turn off the engine while still in drive. Then wait several seconds and you will see the gauge drop back to normal. Works for me every single time except the one time I did it while on a step incline.
    Ausfahrt likes this.
  11. Oct 1, 2024 at 9:17 PM
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    At least once a month for 15 mos now (‘23). Always at 3/4 full parked on any incline/decline. *Curious, we know '22 thru '24 are affected, how about the new ‘25s Anyone?
  12. Oct 2, 2024 at 9:10 AM
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    This has been happening to me recently a few times. So I, like most of you I bet, keep good tabs on your fuel levels. We were recently in the mountains camping, and I had topped off the tank so we would be set for the trip. Had about 7/8 of a tank when it reset to full. This was such a small variance I could see how it could have been missed. Also we were in the backcountry a good deal, and knowing your fuel levels is very important on a situation like that. There seem to be 2 ways to reset it, but there really needs to be a permanent fix.
  13. Oct 3, 2024 at 11:56 AM
    RayRay27
    RayRay27 New Member
    Mile High City
    2023 SR5
    Stock
    My 2023 SR5 CM (2022 build date) started doing this a few weeks ago and today as been stuck on full today even though I have a 3/4 or less tank of fuel. Have a service appointment on the 18th to investigate.
  14. Oct 3, 2024 at 1:01 PM
    PNW Tundra Mike
    Southern Cal
    Did you do the simple reset? Stop on a level surface still in Drive and push the start button once. Wait and watch your oil guage reset followed by the fuel gauge. (about 10 secs) Shift to Park, restart and drive away.
    TundraDan723 likes this.
  15. Oct 3, 2024 at 1:18 PM
    RayRay27
    RayRay27 New Member
    Mile High City
    2023 SR5
    Stock
    Didn't do the reset yet. I was going to leave it the way it is until I take it in so that the service tech can see it first hand.
  16. Oct 3, 2024 at 1:26 PM
    TundraDan723
    Probably smart. I have several issues with my DIC not working correctly, and have taken photos of the problem. If Toyota can't "reproduce" it while it's in the shop for 90 minutes then it must be working correctly. The service tech doesn't care about my photos as proof, even though photographic evidence is used in a court of law to convict people! :rofl:
    Tundrastruck91 and eddiefromcali like this.
  17. Oct 3, 2024 at 1:38 PM
    eddiefromcali
    Eddie
    100% Stock
    Might want to talk to someone about that
    22whatwedo and MaineTundy like this.
  18. Oct 3, 2024 at 5:13 PM
    TundraDan723
    I have tried and they tell me if they can't replicate it, they won't do anything about it. My local dealer is one of the least helpful dealerships I have ever worked with.
    :fistbump::rofl:
  19. Oct 4, 2024 at 12:33 PM
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
    no Mine is more least helpful....
    TundraDan723[QUOTED] likes this.
  20. Oct 4, 2024 at 2:22 PM
    Wtundra2023
    Wtundra2023 Bad Weld Aficionado
    2023 Limited Tundra, 2014 Limited Sequoia
    I had the opportunity to talk to a lead tech at my dealership today at length about several issues with my tundra while he was collecting data for TAS regarding throttle lag. According to him, the fuel gauge issue is a software issue (no surprise there) where the fuel level is somehow linked to the DTE and changes position based how the truck is driven as opposed the fuel level being linked only the fuel level in the tank (this is assuming I understood what he was saying). Regardless, he stressed Toyota was well aware of this issue and is working on a fix for it or at least trying to figure out a way to make it more obvious what they are trying to do.
    BoomBoomGanoom likes this.
  21. Jan 7, 2025 at 6:53 PM
    scott2732
    scott2732 New Member
    Scott
    Panama City Beach
    2023 Limitted
    I have been dealing with the gas gauge issue since the first week in May of 2023. Took it in about 4 times and just gave up. Starting to push again with my dealer's service center since FL lemon law is for 24 months. It is nuts that the most basic of systems, a gas gauge is messed up.
    Guess I am spinning my wheels and not in a good way.
  22. Jan 8, 2025 at 12:09 PM
    PNW Tundra Mike
    Southern Cal
    Same since 7/23. It’s an absolute shame we have to live with this on a $60K+ vehicle. If I didnt love all the rest of it so much the answer would be to sell it. I shut off in Drive all the time to avoid the auto re-start so I just let the gauge reset then.
  23. Jan 13, 2025 at 11:45 AM
    Stanton18
    Stanton18 New Member
    Charles
    I've had mine since 4/22 and it still does it. Every time I take it to the dealer; they can't replicate the problem. I've just gotten used it at this point.
    Woocawachie likes this.
  24. Jan 13, 2025 at 11:51 AM
    TRDoffroadPRO
    TRDoffroadPRO New Member
    2023 Hybrid CM Limited TRD OFR
    Do you have the Hybrid? Does your fuel door lock? only Hybrid has the locking fuel door, and your resets sounds exactly like what happens when Hybrid owners press the fuel door release button and begin fueling. I assume you all have the TFT display if you have a Limited or up.
  25. Jan 13, 2025 at 6:00 PM
    scott2732
    Scott
    Panama City Beach
    2023 Limitted
    What style gas gauge do you have if you are having the problem? My Limited has a needle gauge. I am wondering if folks with the digital display have the issue also. This picture is the last time it went from just under 3/4 to full. I always reset my trip A when I fill up for a reference, had 166 miles when it tripped to full. DTE jumps to 400+ once I start to drive. 20250111_175900.jpg
    Went in again today 25k service and gas gauge, tech reset it and told me I need to ensure I turn the truck off all the way when fueling.
    I contacted Toyota Brand Engagement Center, uploaded the two letters I have mailed to Toyota USA. The rep called me today and said nothing other than they are working on it. I am perplexed, happy with the truck but with my driveway the gas gauge trips to full several times a month.
  26. Jan 13, 2025 at 6:10 PM
    donia
    donia New Member
    Miss’ippi
    Mine is digital and I noticed it happening a few months after I bought it (April ‘23). They, at least, acknowledge it is happening now and have been told the standard “they’re working on it” (for the last year around the elephant in the room).
  27. Jan 15, 2025 at 10:56 AM
    BoomBoomGanoom
    BoomBoomGanoom New Member
    Corey
    Columbus, Ohio
    2023 Tundra Limited off-road
    TRD Pro Heritage grille with marker lights, TRD Pro fender flares, TRD Pro front sway bar and end links, TRD Pro aluminum front upper control arms, Fox Performance 2.0 coil overs and shocks, Alpharex Nova Black headlights w/amber DRL. OEM tonneau cover
    Thanks for reporting the issue to corporate. I have the same issue with my 23 limited off road. I don't have the digital cluster since it was only offered on the hybrid models for the 22-23 limited models. I noticed this issue the first week I had the truck with no support from the dealership. I hope they were not giving you a line of BS to pacify you and really have a team investigating the issue.
  28. Jan 15, 2025 at 11:14 AM
    TRDoffroadPRO
    I park on an incline have the digital cluster and have not had an issue with it. I do have my refill light does not come on till way low on gas like 10 miles to empty or something. I rarely if ever see it, and I never shut the truck off at refuel time. It is a hyrbid, it shuts the engine off once warmed anyway.
  29. Jan 15, 2025 at 1:25 PM
    nodak67
    nodak67 New Member
    JR
    this thread should be merged with the original fuel gauge issue thread.
    kirkb likes this.
  30. Jan 15, 2025 at 5:27 PM
    kirkb
    DFW
    Yes
