2020 PLATINUM CREWMAX MGM COLOR MATCHED DOOR HANDLES
Discussion in 'General Tundra Discussion' started by mech_engineer09, Oct 14, 2019.
  1. Oct 16, 2019 at 12:29 PM
    Spakylpm
    Spakylpm New Member
    2024 Tundra
    Thanks Chris for all the info! @Roman is the price for all fours handles and the plastic caps?
  2. Oct 16, 2019 at 12:37 PM
    chrisbusnut
    chrisbusnut New Member
    Pasadena, CA
    2020 Tundra Crew Max SR5 4x4 w/TRD Off Road pkg
    DiamondBack bed cover, SDHQ sliders, SwitchPro, Katzkin leather seats, TRD Pro grille, TRD Pro wheels w/Nitto Ridge Grappers, Toyota OEM leather steering wheel, SSO Slimline Hybrid Bumper w/Baja Designs S8 light bar, Warn Zeon Platinum 10-S winch, Baja Design rock lights & flush mount rear bumper lights
    My pleasure, and yes, Roman can get you the info.
  3. Oct 16, 2019 at 1:12 PM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    Yes, the Crewmax link is for all four door handles.
  4. Oct 16, 2019 at 1:38 PM
    phabej
    phabej New Member
    Washington
    2018 Platnium
    if you got the time and skills, DIY. Cheaper by 1/2-1/3 of the price.
    automotivetouchup.com
    In the end, it's the same result. COLOR MATCHED
    bosscib likes this.
  5. Oct 16, 2019 at 2:08 PM
    Spakylpm
    Spakylpm New Member
    2024 Tundra
    @chrisbusnut do you have to disconnect the cable first before attempting to remove the handles?
  6. Oct 16, 2019 at 2:14 PM
    Spakylpm
    Spakylpm New Member
    2024 Tundra
    phabej how do you prep the handles especially the chrome part?
  7. Oct 16, 2019 at 2:55 PM
    phabej
    phabej New Member
    Washington
    2018 Platnium
    you can tape off the painted areas, sand down the chrome area for paint. I won't be surprised if they can separate if not tape should work. Use 380 grit then some adhesion promoter before priming. I did it on extra set of chrome handles I bought for $50 bucks.
    1. take off
    2. tape and mask off area for sanding
    3. sand with 380 grit
    4. adhesion promoter
    5. prime it (then flash sand with 600-800 grit to smooth it out)
    6. couple layers of base coat super white or whatever color you're matching
    7. finish with multiple layers of 2k clear, flashing time 30-40min in between each coat.
    I use a small wire and some nuts to hang them while spraying and use a approved face mask when spraying.
    Spakylpm[QUOTED] likes this.
  8. Oct 16, 2019 at 3:43 PM
    Spakylpm
    Spakylpm New Member
    2024 Tundra
    Thanks for all the help and advice phabej, romen, chris, mech_engineer 09!
    phabej likes this.
  9. Oct 16, 2019 at 6:07 PM
    Spakylpm
    Spakylpm New Member
    2024 Tundra
    I played audiobook today and the sound was perfect no "S" issue not sure maybe you have one bad speaker.
  10. Oct 16, 2019 at 6:53 PM
    mech_engineer09
    mech_engineer09 [OP] Tundra Enthusiast
    Ohio/Pennsylvania
    2020 MGM Platinum
    Ceramic Pro, XPEL Ultimate Plus, Woolwax Undercoating, Diamondback HD, TRD Air Intake, TRD Skid Plate, TRD Front & Rear Sway Bar
    I actually took it to the dealership today to have it looked at. I had them bring another truck with the jbl speakers in it over and we hooked it up and it made the same sound so I’m thinking it’s just the app and my hearing is good enough that I can hear it.
  11. Jul 15, 2020 at 2:04 PM
    Dr.X
    Dr.X New Member
    Antonio
    2018 Tundra Crewmax TRD Sport 4x4
    Does the order include all 4 handles or just 1? Price is like $230
  12. Jul 15, 2020 at 2:31 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    @Roman, Are these available as a pair with a key on the drivers side?
  13. Jul 16, 2020 at 9:23 AM
    Roman
    Roman
    Franklin, TN
    The links I have posted in the Ultimate parts thread for the 2020 model smart entry handles are a kit. One kit is for the double cab and one for the Crewmax. It includes all handles, though they are not $230.
    https://www.tundras.com/threads/ultimate-oem-toyota-parts-thread.10707/
    The handles with the chrome on them? Sure, I can get them. Might be several people on the forum looking to off load them, though. Might be cheaper than purchasing new. :)
    Rex Kramer[QUOTED] likes this.
  14. Nov 28, 2020 at 4:47 PM
    49ºNRTH
    49ºNRTH New Member
    2025 Limited MGM
    Been all over the interwebs twice it feels like with no luck.
    Anyone know the actual part numbers for the colour matched handles for the keyless entry PTS Tundra? I'm looking for the MGM (1G3) and not having much luck with my local dealer, even after mentioning they're for a Sequoia SR5.
    They'd be installed on a MY21 Platinum Tundra.
