2020 Differential needle bearing failure
Discussion in '2.5 Gen Tundras (2014-2021)' started by CreekDweller, Dec 30, 2020.
  1. Jul 6, 2023 at 11:28 AM
    #241
    yakeng
    yakeng 3URFE Apologist
    2020 Tundra 4x4; 2014 Sequoia;
    ECGS Bushing; GCS Cooler RASHD; Fox 2.0
    It’s not the longitudinal movement (hub towards diff), but up and down, when pushing the CV right at the diff, perpendicular to the CV. I have a video of mine before and after, will upload for reference.
    If yours doesn’t have a pronounced harmonic whoosh, then you probably don’t have the issue.
    When you hold the needle bearing against a bushing, it’s obvious why the needle bearing exacerbates bad tolerances of the diff carrier.
  2. Jul 6, 2023 at 1:13 PM
    #242
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    That makes sense. I was going by your other comment of no movement being normal. Passenger side shaft has no movement. All driver's side ones i tried had a little movement. Enough that while i was doing it, you could hear it knocking.
  3. Jul 6, 2023 at 1:27 PM
    #243
    Jack_A_Lope
    Jack_A_Lope New Member
    Aaron
    Santa Barbara County, CA.
    2019 Tundra 4X4 SR5 TRD Sport
    Pro Comp Lift, Tires & Wheels, Steel front bumper with LED lighting, Cross bed tool box, bed rails, custom aftermarket sound system
    Toyota supposedly fixed that problem back in 2008 but apparently they didn't. They should have adopted the bushing.
    Wallygator likes this.
  4. Jul 6, 2023 at 1:28 PM
    #244
    Jack_A_Lope
    Aaron
    Your right. I saw that after I reread it.
    2mchfun[QUOTED] likes this.
  5. Jul 6, 2023 at 3:31 PM
    #245
    teamtlr
    teamtlr New Member
    Denver Colorado
    2020 Sequoia TRD Pro
    I have the harmonic wooshing on my 2020 sequoia with 22k miles, all stock. Does anyone know if the sequoia has the same diff as the tundra? Will try 4wd to see if it goes away.
  6. Jul 7, 2023 at 5:12 AM
    #246
    campbell_j_c
    campbell_j_c New Member
    JC
    North Carolina
    2020 Platinum MGM
    It looks like the same part on the ECGS site fits 2007+ Tundras and 2008+ Sequoias
    yakeng likes this.
  7. Jul 7, 2023 at 5:31 AM
    #247
    yakeng
    Should be the same. Based on the parts diagram, 2020 Sequoia and 2020 Tundra use the same 41110 front differential assembly.
  8. Jul 7, 2023 at 6:15 AM
    #248
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    Exactly why I went with the bushing as soon as I confirmed the cause of the noise.
  9. Jul 27, 2023 at 8:49 AM
    #249
    damabo
    damabo New Member
    2021 limited army green
    Have a 2020 Toyota Tundra Crewmax 4x4 with 26000 miles and the dealer just identified the front differential as bad. Replacing under warranty.
  10. Sep 3, 2023 at 5:03 PM
    #250
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    hey. Would you happen to be finished with those tools? I’ll buy them for you so I can save a few bucks as well. LMK. Thanks.
  11. Sep 3, 2023 at 7:37 PM
    #251
    damabo
    damabo New Member
    Sorry wish I had the tools!! Dealer replaced the complete front differential
  12. Sep 4, 2023 at 5:21 AM
    #252
    BlueCrushSC16
    Charleston, SC
    Anyone else have the tools laying around?
  13. Sep 4, 2023 at 8:43 AM
    #253
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Anyone happen to have a clip of the sound that happens when the bearing goes?
  14. Sep 4, 2023 at 8:54 AM
    #254
    Wallygator
    I actually drove over 4 hours to ECGS and had them put one in my 4Runner when I owned it. I think it was around $110?? for them to do it. That was years ago so I don't know the current rate. That included everything, even the oil. I'll probably do the same if/when the Tundra needs one. Not saying you should do this but it is an option for you.
    Got several free t shirts out of the deal also. Good people
    2mchfun, Mater and tundra_20 like this.
  15. Sep 4, 2023 at 9:08 AM
    #255
    BlueCrushSC16
    Charleston, SC
    Thanks for the option. 9+ hour round trip for me plus all the other costs. I’ll most likely do it myself.
    Wallygator[QUOTED] likes this.
  16. Sep 4, 2023 at 9:16 AM
    #256
    Wallygator
    Yeah that's what it was. I actually enjoyed the drive, I'm weird like that:notsure:. Plus I'm lazy. An yeah it would surely be cheaper if you did it yourself, I believe, even if you bought the tools they sell.
  17. Sep 6, 2023 at 2:05 PM
    #257
    Avi8or
    Avi8or New Member
    Johann
    MO
    2020 Limited Crewmax
    This is what my half shaft and needle bearing looked like when I replaced the needle bearing with the sleeve.
    I leveled the truck with 1.3” of lift in the front when it had a couple thousand miles on it. It still had a small amount of rake but not really noticeable.
    It had been making the growling noise for 25,000 miles. The needle bearing had a loose fit on the shaft and would rock back and forth a little. The new sleeve didn’t rock at all but spun easily.
  18. Sep 8, 2023 at 5:17 AM
    #258
    BlueCrushSC16
    Charleston, SC
    Got my bushing kit from ECGS. Nice and well packaged. Probably do the needle bearing/ bushing swap in a couple weeks after I clear my current schedule.
    equin, Mater and Wallygator like this.
  19. Nov 19, 2023 at 9:26 AM
    #259
    Tundra-dude
    Tundra-dude New Member
    2020 Tundra SR5 CrewMax
    I'm hoping folks can help me with some photos and some ideas since my front differential needle bearing failure saga continues. My dealership did replace the front differential housing a few months ago. The good news is that did fix the front needle bearing issue. The bad news is the front differential housing leaked oil after their repair. I took it back and they claimed to have fixed the oil leak and a few weeks later the oil leak is worse. I took my truck back again and they had it for 8 days to fix the oil leak. I finally got the truck back and literally ~ 1 mile from the dealership I can hear a very subtle scraping noise that sounds like its from the front differential area. The scraping sound is intermittent and very difficult to hear. It only lasts about 2 seconds...pause, and then it can be minutes before you hear it again. I'm not taking it back to the same dealership again since the 8 days was a complete mess on their side. From what I see, they replaced the front differential housing with another new one. Does anyone have pictures of the oil seal in the housing? How does the half shaft connect? What could cause this scraping noise? I am taking it to another dealer but I'd like to get some idea of what they messed up.
  20. Nov 19, 2023 at 10:52 AM
    #260
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    That's probably your best bet if your dealer is crap. I figured I would let my dealer handle the repair and they royally screwed up the job. I ended up selling it. With covid prices I was glad to get my money back.
    Terndrerrr[QUOTED] likes this.
  21. Nov 19, 2023 at 1:33 PM
    #261
    yakeng
    Is it leaking at the CV?
    If it is leaking gear oil there, it might be that they drove the seal in too far, which is a common mistake. I had to measure mine with a caliper. There is no stop and it’s really easy to push it in too far.
  22. Nov 19, 2023 at 5:42 PM
    #262
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    The dealership service manager was using parts from his Tundra to swap parts in mine. His truck drove as smooth as glass and they swapped in both his driveshafts and I still had the vibration. I disclosed to the buying dealer about the issue and they didn't seem to care.
  23. Nov 20, 2023 at 5:52 PM
    #263
    Tundra-dude
    I went to a different dealership and it didn’t take them long to find the source of the scraping noise after the oil leak repair. Evidently they pushed the rotor dust shield into the rotor and it was rubbing. A quick spin of the driver side wheel reproduced the sound. The leak was on the drivers side oil seal leak at the half shaft. You could see the oil running down the side and around the fill plug. I think their first attempt to fix the oil leak assumed the leak was at the drain plug. Time will tell if they fixed the leak correctly. So for now, no more front diff needle bearing growl, no scraping, and hopefully a final fix on the oil leak.
    Wallygator, tundra_20 and Terndrerrr like this.
  24. Dec 20, 2023 at 9:10 AM
    #264
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    My truck has been producing a pulsing vibration at ~55 mph that has become more noticeable over the last 10k miles. It's still fairly light, but it seems to go away in 4HI. I wouldn't describe it as a noise or a growl, but a felt vibration in the steering wheel and footwell. Feels like it's coming from the driver's front of the vehicle. The truck has seen maybe 2-300 miles of 4HI use but the front differential oil was just as dirty if not more dirty than the rear oil at 30k miles. The drivers side axle has significantly more play in the differential carrier than the passenger side, you can hear it clicking when you wiggle it by hand. However, my Dad's 2010 has pretty much the same play but no vibration issues.
    Does this seem like a needle bearing issue?
  25. Dec 20, 2023 at 9:43 AM
    #265
    myfirsttundra1
    myfirsttundra1 New Member
    2023 Platinum crewmax
    I took a crack at it but I simply couldn’t separate the cv axle out of the hub, despite using plenty of PB blaster and a smallish sledgehammer.
    Would a puller be the next step? If so which size should I buy?
  26. Dec 20, 2023 at 10:33 AM
    #266
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    Gotta air hammer?
  27. Dec 20, 2023 at 10:42 AM
    #267
    myfirsttundra1
    unfortunately not. should I buy an electric hammer?
  28. Dec 20, 2023 at 10:50 AM
    #268
    Tundra-dude
    I would stay what you describe does not sound like the front diff needle bearing issue. I think I caught the issue fairly early and it was more of a continuous growl. Very subtle at the time and you needed smooth roads to hear it. I don’t think there was any vibration. Now, if it ran that way for another 20k miles I’m not sure what it would have sounded like.
  29. Dec 20, 2023 at 9:05 PM
    #269
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I takes some talent, a BFH and a large heavy drift.
  30. Dec 21, 2023 at 8:57 AM
    #270
    yakeng
    I had to reread this and realized you were talking about the hub and not the diff. You can use a bearing puller to push it out. I used the one from a Maddox Harbor freight slide hammer set. It’s the one with the three hooks and a center screw.
