2020 Differential needle bearing failure
Discussion in '2.5 Gen Tundras (2014-2021)' started by CreekDweller, Dec 30, 2020.
  1. Jul 13, 2021 at 4:05 PM
    #151
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    They ordered a transfer case. Whatever. I'm dropping it off when the transfer case comes in and they can have it until the noise is gone.
    Wallygator likes this.
  2. Jul 23, 2021 at 9:12 AM
    #152
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Just got the truck back after the transfer case change. Noise is still there. I talked to the service manager today and he's ordering up another new front differential. Figures that the replacement is a bad rebuild.
    Wallygator and Leo's first like this.
  3. Jul 23, 2021 at 9:28 AM
    #153
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    If it wasn't for bad luck, you'd have no luck at all. :(
  4. Jul 23, 2021 at 11:21 AM
    #154
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Ya what are the chances!
    Actually I do consider myself a luck person. The service manager has been great to work with.
    JLS in WA and Wallygator like this.
  5. Jul 23, 2021 at 11:50 AM
    #155
    Wallygator
    This is why on my 4Runner I drove to ECGS and had them install their bushing even though I could have gone through the warranty night mare you are going through now. An if this happens on my Tundra I will do the same thing. Don't have time to go back and forth and the bushing is good for about 400,000 miles. Hope this last diff will fix the issue for you.
    2mchfun likes this.
  6. Jul 23, 2021 at 12:40 PM
    #156
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    In hindsight that's exactly what I should have done.
    Wallygator[QUOTED] likes this.
  7. Aug 17, 2021 at 4:29 PM
    #157
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    To update thos further. The dealer has had the truck for more than two weeks. They have replaced and checked everything. They have check the transmission (dropped pan), changed the transfer case, replaced both front and rear driveshaft, pulled the rear diff pumpkin and checked the backlash, replaced the front differential, replaced both front CV axles, replaced both front wheel bearings and tried another set of tire assemblies and the vibration continues. Toyota engineers have been asking them to measure driveshaft angles and everything is good. They even asked the tech to remove my TRD sway bar. At this point Toyota corporate and the dealership are running out of ideas but they are still working on it. The dealership principle is seriously think of buying the truck back to make the problem go away. I may take him up on that.
    Kratos, JLS in WA, ColoradoTJ and 5 others like this.
  8. Aug 17, 2021 at 4:47 PM
    #158
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    Sorry to hear that but I'm glad your dealership and Toyota is working with you rather than brushing you off.
    Ruggybuggy[QUOTED] likes this.
  9. Aug 17, 2021 at 4:50 PM
    #159
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    Have they inspected for any runout at the axles? Are the rims running true?
  10. Aug 17, 2021 at 4:54 PM
    #160
    Tyman
    Tyman Isaiah 41:10
    Tyler
    Indiana
    2020 Tundra Sport 4wd MGM
    You have been more than patient. I say sell if they offer.
    Terndrerrr and Ruggybuggy like this.
  11. Aug 17, 2021 at 5:42 PM
    #161
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    It only vibrates at around 55mph in 4WD during deceleration. The front diff has been changed along with the CV axles and driveshafts. Different tires and rims where installed and it still vibrates.
  12. Aug 17, 2021 at 5:43 PM
    #162
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Yes the dealership has been very good with everything.
  13. Aug 17, 2021 at 5:49 PM
    #163
    crewmaxlmt
    scott
    The only other thing that it could be are mounts. Everything else has been replaced.
    Terndrerrr likes this.
  14. Aug 17, 2021 at 6:04 PM
    #164
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Actually that's not a bad suggestion but the service manager said they could feel a heavy vibration in the front differential when they drove the the truck in 4wd when on the 4 post hoist.
  15. Aug 17, 2021 at 6:44 PM
    #165
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Good idea. This is a very prevalent problem with Rams.
  16. Aug 17, 2021 at 6:47 PM
    #166
    crewmaxlmt
    scott
    Sounds like a cracked weld or two sections were not seated when riveted. I am spit balling here since I am not laying under my truck looking at the frame. There is always going to be vibration, but how much is allowed to transmit could be the issue,
    JLS in WA likes this.
  17. Aug 17, 2021 at 6:59 PM
    #167
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    The way the tech and service manager described it there is an abnormally heavy vibration from the front differential @ 55mph when they placed their hand on it when running on the hoist.
  18. Aug 17, 2021 at 8:10 PM
    #168
    Wallygator
    Sucks this is happening but sounds like they are on top of it. Hopefully this gets resolved soon one way or another.
  19. Aug 19, 2021 at 5:49 AM
    #169
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    So the question is, do I bail on the truck and let the dealer buy me out if the price is good. Not really liking that they can't find the problem and the the truck has been torn apart and put back together. I was thinking I should dump it because I fear that when the problem is finally found I will be out of my warranty. I tried to get a Toyota to extend the powertrain warranty but they wouldn't commit. I kind of leaning of dumping it, buying and older Tundra and wait until the 2022 Tundra proves itself. The wife think we should keep the 2020 because she only thinks day to day.
  20. Aug 19, 2021 at 6:09 AM
    #170
    blanchard7684
    blanchard7684 New Member
    What a shitshow. Feel for ya man.
    Only thing I can offer technically at this point given the scope of what has been done and checked: If the right side hub, shock tower is off putting the front diff in a bit of a bind. This would of course be a grotesque manufacturing issue or tolerance stack issue.
    If not in 4wd you'd not notice it. Only when ADD actuator engages does it load the right side axle.
    Its the only thing not replaced or touched at this point.
    I'd be working the buyback in a hurry.
    Ruggybuggy likes this.
  21. Aug 19, 2021 at 7:31 AM
    #171
    crewmaxlmt
    scott
    Do they have the lemon law in Canada?
  22. Aug 19, 2021 at 7:34 AM
    #172
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Unfortunately no.
  23. Aug 19, 2021 at 7:37 AM
    #173
    crewmaxlmt
    scott
    If Tundra prices are as crazy up there as they are here, I would sell it and get a beater for the time being. Once this whole auto market calms down, you will have many options to choose from V8 Tundra or V6.
  24. Aug 19, 2021 at 7:40 AM
    #174
    mech_engineer09
    mech_engineer09 Tundra Enthusiast
    Ohio/Pennsylvania
    2020 MGM Platinum
    Ceramic Pro, XPEL Ultimate Plus, Woolwax Undercoating, Diamondback HD, TRD Air Intake, TRD Skid Plate, TRD Front & Rear Sway Bar
    Yep i second this. get as much as you can squeeze out of them to buy the truck back. buy a pos that can get you through a year and buy a brand new 2022 or 2023 once this market cools off.
  25. Aug 19, 2021 at 8:22 AM
    #175
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    That the way I'm leaning. I will come down to what they offer on the Tundra. We dont really have a buy back from Toyota Corporate in Canada that I'm away of. The dealer principle had mentioned buying the truck back to get me out of the mess but we'll see based on their dollar offer if they are just looking for an opportunity to make some cash. They do have an older 2013 Nissan Frontier with low mileage that I could drive for a year. We'll see what they come back for on numbers.
  26. Aug 19, 2021 at 8:27 AM
    #176
    mech_engineer09
    Ohio/Pennsylvania
    2020 MGM Platinum
    yeah it would be nice if you can buy whatever you drive for the next year or so with whatever they offer you over what you owe, drive for a year with no payment and save up some $$$
  27. Aug 19, 2021 at 8:29 AM
    #177
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    My 2020 is paid off so I'm good there.
  28. Aug 19, 2021 at 8:33 AM
    #178
    mech_engineer09
    Ohio/Pennsylvania
    2020 MGM Platinum
    even better lol. so anything you get over what you owe is an added bonus. hopefully they offer you something fair for it.
  29. Aug 20, 2021 at 6:38 AM
    #179
    Wallygator
    Tough call but one thing is for sure, at this point you will always be thinking you hear or feel something in that truck and it will weigh on you mentally. I have never been through such an experience but I would probably try and get as much as I could out of them and let them have this one.
  30. Aug 20, 2021 at 7:34 AM
    #180
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I gave them a call yesterday and told them to come up with some numbers. They have a Nissan Frontier that's in good shape with low mileage that would carry me through until the new Tundra arrives. They said they would be having a meeting with Toyota corp, the dealer principle and the service manager. Unfortunately they dont have any used Tundras on the lots. We'll see how this all plays out. If I can't get a fair trade in price I'll keep it and push for an extended warranty and trade it in before the warranty is up.
    Kratos and Wallygator[QUOTED] like this.
