2020 Differential needle bearing failure
Discussion in '2.5 Gen Tundras (2014-2021)' started by CreekDweller, Dec 30, 2020.
  1. Dec 21, 2023 at 9:11 AM
    #271
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Have you greased your driveshafts? I’d start by ruling out the simple things
  2. Dec 21, 2023 at 9:30 AM
    #272
    yakeng
    yakeng 3URFE Apologist
    2020 Tundra 4x4; 2014 Sequoia;
    ECGS Bushing; GCS Cooler RASHD; Fox 2.0
    The joints aren’t serviceable on a 2021. No zerk fittings to grease.
  3. Dec 21, 2023 at 12:16 PM
    #273
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    We are talking about removing the CV axle from the front wheel bearing hub? Did you remove the two lower ball joint bolts. Also the brake caliper has to be unbolted. You don't want to be hammering on the end of the CV axle or you could end up buying a new axle because of damaged threads.
  4. Dec 21, 2023 at 12:43 PM
    #274
    myfirsttundra1
    myfirsttundra1 New Member
    2023 Platinum crewmax
    Yup all of that was removed before I tried hammering on it
  5. Dec 21, 2023 at 3:22 PM
    #275
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    That’s a first. They normally only take a couple of taps and they’re out. Your going to have to get a puller that attaches to the wheel studs and pushes the axle out.
  6. Dec 21, 2023 at 3:59 PM
    #276
    yakeng
    Mine didn’t remove with a few taps either. I did the few taps, nothing. moved to a deadblow hammer to avoid damage and then moved onto a brass punch into the center notch. Saw plenty of videos were it folks separated it like that but mine just didn’t budge.
    The puller will do the trick and is gentle on it. The fact the CV has a center divot and pullers having a conical threaded pin would almost lead you to believe they are designed to be used with each other.
  7. Dec 22, 2023 at 7:49 AM
    #277
    Wallygator
    Yep, mine is starting to do the same thing. My truck is loud or my ears are bad so can't really hear a noise. I feel it's the needle bearing cuz my 4Runner did the same thing. I plan on getting this taken care of in the spring.
    Tbrandt[QUOTED] likes this.
  8. Dec 22, 2023 at 8:04 AM
    #278
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    I've been paying very close attention lately and notice a vibration at ~35 MPH as well. I though it was maybe tires, but given the intermittence based on vehicle speed it has to be in the driveline somewhere. I figured on jacking it up this weekend to check all the u-joints, carrier bearing, wheel bearings and ball joints for play. If everything is tight I'll go ahead and get the parts to do the needle bearing.
    Wallygator[QUOTED] likes this.
  9. Dec 22, 2023 at 8:05 AM
    #279
    yakeng
    Sure seems like a lot of 20-21’s had this issue.
    Ruggybuggy and Tbrandt like this.
  10. Dec 22, 2023 at 8:10 AM
    #280
    Wallygator
    Given the experience with the 4Runner I figured it was only a matter of time until this one needed done also. I'm right at 40K miles now on the Tundra.
    The 2016 4Runners was done around 45K miles if I remember correctly? IMO, It is a worthwhile investment to switch to the bushing from ECGS instead of trying to deal with a dealer in some fashion. But I'm not a fan of dealers so there is that. Just figure why put the same thing in there again so I would have to change to the bushing after warranty anyways?
  11. Dec 22, 2023 at 11:16 AM
    #281
    Tbrandt
    Tristan
    Kansas City
    I'm with you there even though I'm still under warranty. Under $200 in parts and a couple hours in the garage for a guaranteed fix is worth more to me than a trip to the dealer for the diagnosis, a trip back to drop the truck off once the parts are in, and another trip back to pick it up with the chance that the problem will just come back again.
  12. Dec 22, 2023 at 11:23 AM
    #282
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Does anyone know if there's a cut-off (mfr date) to when the problem was resolved w/the '21s, or is it pretty much any 20-21 is susceptible??
  13. Dec 22, 2023 at 11:40 AM
    #283
    Tbrandt
    Tristan
    Kansas City
    According to T-SB0121-08, Toyota fixed the problem in 2008 for the 2007-08 model year and "Production changes have been implemented to help prevent this noise". I dunno if there have been subsequent TSB's that have addressed this though, and wouldn't describe my symptoms exactly like this TSB does.
  14. Dec 22, 2023 at 11:46 AM
    #284
    Tripleconpanna
    gotcha... thanks!
    so, did you leave the portland area??
    PS>>> Merry Christmas!!!!
  15. Dec 22, 2023 at 11:49 AM
    #285
    yakeng
    I tried the old TSB to no avail at my dealership. The techs and service manager played dumb, said it didn’t apply to the 2020. Even though it went away in 4HI.
    My guess is that COVID allowed quality to slip more and a bad batch of carriers were installed.
  16. Dec 22, 2023 at 11:52 AM
    #286
    Tbrandt
    Tristan
    Kansas City
    Thanks, you too! Yeah, moved back home to the Midwest in May - wife and I were out there for a 2 year work assignment. The west coast was fun, the work was good, but it wasn't home. Baby #1 is less than 2 weeks away right now and we knew it was time to come home!
    Wallygator likes this.
  17. Jan 5, 2024 at 1:14 AM
    #287
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    If it's a front Toyota diff made any time this century, it's part of the bad batch of carriers. When the solution to growling is to hope and pray the stackup of tolerances in another unit is good enough to tame spider gear movement, I consider them all bad.
    Now that it's winter and cold my truck is making the racket again. Woo woo woo at 30 mph. It's the Toyota mating grunt. Someday I'll deal with it. So far this is the seventh noisy winter and it hasn't exploded, yet. I really should order that bushing kit
  18. Jan 5, 2024 at 5:57 AM
    #288
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I think what your experiencing is not the left front CV axle support bearing if you have gone seven years and it's remained the same. On my truck it only took about 30,000kms (20,000 miles) and when the left front axle was pulled there was enough damage to the journal that it had to be replaced.
  19. Mar 3, 2024 at 7:36 AM
    #289
    Tbrandt
    Tristan
    Kansas City
    I replaced my needle bearing yesterday at 34k miles with the bushing. Vibrations are gone.
    I think my symptoms were considerably different from what the TSB states. I had pulsing vibrations at ~35 and ~55 mph. I first noticed it at less than 5k miles and it was purely felt, but by about 30k miles it was audible. My truck is very quiet (exhaust resonator, insulated cab, hwy tires) so maybe that’s why I noticed it so early.
    I noticed some very obvious wear on the needle bearing, but not on the actual needles themselves. The carrier that holds all the individual needles inside the outer race was obviously rubbing on the axle shaft. It’s very difficult to get to show in pictures, but the wear is there.
    I also lost probably half a quart of gear oil with the axle and seal out, so definitely keep some handy if you do this.
    Wallygator and Terndrerrr like this.
  20. Mar 3, 2024 at 9:12 AM
    #290
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    No marks on your CV axle shaft?
  21. Mar 3, 2024 at 10:36 AM
    #291
    Tbrandt
    Tristan
    Kansas City
    Nothing significant enough that had me worried. There appeared to be swirls but I couldn’t feel anything under my finger nail.
    Ruggybuggy[QUOTED] likes this.
  22. Mar 3, 2024 at 11:14 AM
    #292
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    The replacement bearing that Toyota provides is a different bearing. If my memory serves me correctly it's a wider bearing.
  23. Mar 3, 2024 at 11:51 AM
    #293
    yakeng
    Isn’t Toyotas TSB protocol to replace the entire front diff? I didn’t think they were only replacing the bearing. The ECGS bushing is a decent amount longer than the factory bearing.
  24. Mar 3, 2024 at 5:52 PM
    #294
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    TSB if your under warranty. Out of warranty the customer would be shocked at the cost of the whole diff so the reason for the updated bearing.
  25. Mar 4, 2024 at 3:32 AM
    #295
    yakeng
    I get that part, but this is the first I’ve heard of an updated needle bearing. If the wider needle bearing fixes the issue, I’m confused why Toyota didn’t start using them after issues were discovered.
    Just look at how many 2020-21 models here had the problem (including mine). Kind of bothers me to know Toyota had a bearing that would have helped resolve the issue all along.
    What is the updated part number?
  26. Mar 4, 2024 at 4:32 AM
    #296
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Sorry but I don't know the part number. I just remember reading about it a couple years back when I was going though all this. Wether or not it solved the issue, I don't believe it did. Might just last a little longer. Personally I don't believe it's a design problem but an assemble/manufacturing issue. The problem with the bearing first came about in the first gen for a couple of years then didn't start showing itself again until 2020 and 2021. There are many high mileage Tundras that are running the original bearing.
    Rather than take a chance on a "revised" bearing, just install a ECGS kit and be done with it.
    tundra_20 likes this.
  27. Mar 4, 2024 at 5:20 AM
    #297
    yakeng
    Yea, I agree with that. I installed the ECGS to resolve it. I tried looking up the needle bearing and found one that has a superseded part number. I’m very curious if the newer longer bearing is installed in the later years of the 2.5 gen and if it’s longer than the earlier years. Unfortunately I tossed mine and can’t get a measurement.
    coTony and Ruggybuggy like this.
  28. Mar 19, 2024 at 3:26 PM
    #298
    Tbrandt
    Tristan
    Kansas City
    Now it seems like I’ve created a new issue. It was dead smooth right after install, but over the last 500ish miles I have harmonic vibrations develop that peak at 35, 45, and 60 MPH. They actually get worse in 4HI, I can hear them and feel through the steering wheel and floor. Over 65 and it’s smooth.
    Any ideas? Maybe a bad bushing? I know I got everything back together correctly, the axle seated correctly and easily.
    The axle spins freely. When I put everything back together there was no tolerance where the CV rides in differential housing, but now I can wiggle it very slightly (much like the passenger side).
  29. Mar 19, 2024 at 5:31 PM
    #299
    yakeng
    What did the CV look like?
  30. Mar 19, 2024 at 7:37 PM
    #300
    Tbrandt
    Tristan
    Kansas City
    Some swirl marks but nothing I could catch with my fingernail.
    I also just rotated my tires and that’s when I started noticing it. They’re craptastic OEM Bridgestone Duellers that are 3 years old, maybe they’re going bad. I have some new tires I’m mounting up this weekend, I’ll see if that changes anything.
