2020 and 2021 DSR1 Issues PLEASE READ AND POST IF YOU HAVE ISSUES
Discussion in 'Audio & Video' started by james@tech12volts, Jan 21, 2021.
  1. May 7, 2021 at 1:31 PM
    #61
    Root5150
    Root5150 New Member
    Rusty
    2021 Tundra 1794 4x4 Smoked Mesquite
    Predator TX Step Bars, Tech12Volts Sound Upgrade, ReTrax Cover, BedRug Liner
    I’m pretty sure non-JBL systems don’t require the DSR1 which is where the issues in this thread seem to have been experienced. I could be wrong, so maybe someone with a non-JBL upgrade will chime in?
  2. May 12, 2021 at 2:52 AM
    #62
    johnxmccoy
    johnxmccoy New Member
    Grove City, Ohio
    2019 Crew Max
    I an having the same issues, now the volume does not work. Get's a little sound and then no sound. Very frustrating product.
  3. May 12, 2021 at 4:04 AM
    #63
    JackwagonJim
    JackwagonJim New Member
    Purlear, NC
    ..speaking of volume..i had this observation..
    When udating your settings on the dsr1, if you adjust the volume while the update is in progress it will be "stuck" at a low setting. The fix seems to be powering off the vehicle a few minutes, then uts back to normal. I am assuming thwt the dsr1 just needs to shut diwn for it to sort itself out..
  4. May 12, 2021 at 7:37 PM
    #64
    johnxmccoy
    Grove City, Ohio
    2019 Crew Max
    James assisted me today. Seems my DSR1 is not powering my amp/turning it on. Got power to DSR not from DSR to amp.
  5. May 12, 2021 at 7:41 PM
    #65
    JackwagonJim
    Purlear, NC
    Update to 2.0. Should take care if it for you.
    tundra 1794 wow likes this.
  6. May 13, 2021 at 2:06 AM
    #66
    johnxmccoy
    Grove City, Ohio
    2019 Crew Max
    We are going to try that today. I need to take the DSR1 out and go thru my desktop. I sure hope it works.
  7. May 13, 2021 at 8:29 AM
    #67
    johnxmccoy
    Grove City, Ohio
    2019 Crew Max
    It works!! reflashed or updated the DSR1.
    James was a big help and provided great customer care and was very patient with me.
    Saltyhero13 likes this.
  8. May 13, 2021 at 11:35 AM
    #68
    Justbass
    Justbass New Member
    Steven
    Ohio
    2020 Platinum
    TRD Sway bar, Lomax Tonnueau cover, Bed rug, Havoc HS2 Steps, Tech 12 Volts stereo upgrade, Yakima bed extender, misc trim and bling,
    Yep, decided to take the plunge today and update. Got the same thing (2,0) so going to assume 2.1 was for either Lexus or Subaru. When I put it back in, see they fixed part of the startup sequence, so AMP is turned on earlier in the radio boot up. I'll test the apple/google maps thing later, but it sounds like it should be working now from some comments in this thread. Also downloaded the latest firmware for the JBL radio to put on tonight. Software in vehicles are getting to be like keeping all your other tech devices up to date now, its exhausting...lol
    dkahs05[QUOTED] likes this.
  9. May 13, 2021 at 3:18 PM
    #69
    johnxmccoy
    Grove City, Ohio
    2019 Crew Max
    I thought I had it all fixed. Got ready for work and went back out to leave and nothing but silence from the radio.
    James helped me again tonight but no luck.
    Anyone have a factory amp I could purchase and I reinstall?
  10. May 15, 2021 at 1:38 PM
    #70
    dkahs05
    dkahs05 New Member
    2020 Tundra TRD PRO
    Have you had a chance to try it out? I bit the bullet and just replaced the HU for now.
  11. May 17, 2021 at 5:32 AM
    #71
    Justbass
    Justbass New Member
    Steven
    Ohio
    2020 Platinum
    Yep, all is good. It is a little wonky on the music coming back, rear then front, but my guess is there is a timed delay programmed into to the front speakers. But yes, apple/google maps, waze now work with voice and music returns. Text and phone always worked fine prior. Reason I finally jumped on it is that the subscription services was coming due and even I think it is a little pricey and too separated to have enough value. 3 services at 8 bucks a piece is more than a netflix subscription, which is a no go for me. Too bad because some of the features are fairly decent, but not all of them. I may do a head unit one day, but pretty low on a list at the moment.
    Glad the DSR is in a better position for those keeping their JBL headunits, changing speaker and AMP with any of the @Tech12volts packages.
  12. May 17, 2021 at 12:02 PM
    #72
    Justbass
    Justbass New Member
    Steven
    Ohio
    2020 Platinum
    Seems pretty drastic instead of trouble shooting why it is not working consistently. You might consider starting a separate thread with what changes you did, some pic's and what you are experiencing. My first DSR had issues when it got cold outside, returned and replaced with a new one and it has been working fine since, even better after the 2.0 firmware update.
  13. Sep 14, 2021 at 6:50 PM
    #73
    Bentarm13
    Bentarm13 New Member
    Does anyone know the most current firmware for the DSR? I can only find 1.9.4 but I feel like there should be more. This thing is kicking my ass on my install.
  14. Sep 15, 2021 at 5:08 AM
    #74
    Justbass
    Justbass New Member
    Steven
    Ohio
    2020 Platinum
    2.0 is the current firmware, 1.9 still had some bugs which were resolved. When you are on the iData site with the DSR plugged in, it will get you to the right spot. Mine has been flawless since installing the firmware.
    RdKing likes this.
  15. Mar 17, 2022 at 1:33 PM
    #75
    P in the rock
    P in the rock New Member
    Any update on DSR1 issues? I lost my sound today.
  16. Mar 17, 2022 at 3:40 PM
    #76
    Bentarm13
    I have heard nothing. Googled it and found nothing recent. RF has nothing on their site. I know some guys have had to basically reset and start over with it, basically a reboot.
  17. Mar 18, 2022 at 4:19 AM
    #77
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    So far since my install done with the DSR1 has been awesome sounding. Been a few months and loving the sound.
  18. Mar 18, 2022 at 4:37 AM
    #78
    Justbass
    Justbass New Member
    Steven
    Ohio
    2020 Platinum
    What have you done to trouble shoot? What firmware version are you running? Firmware version 2 has been flawless for me since last year.
  19. Mar 18, 2022 at 8:00 AM
    #79
    P in the rock
    I lost my sounds when I dropped my truck off at the shop for wheels and tires, picked up today and I have sound. How do you check the firmware? James programed mine last Oct.
  20. Mar 18, 2022 at 8:12 AM
    #80
    RusPro21
    Don
    Pa.
    James did mine. Would disconnecting the battery to cause that? I don’t know why they would do that just to mount wheels and tires if that was done? Just checking.
  21. Mar 18, 2022 at 8:17 AM
    #81
    Justbass
    Justbass New Member
    Steven
    Ohio
    2020 Platinum
    I would bet James put the most current firmware on it based on date. As far as checking yourself, you can either hook it up to a computer and the iDatalink site, or download perfect tune for either android or IOS which allows you to further tune the system. I would guess it was a minor hiccup truck startup, and when it restarted it was fine.
  22. Mar 18, 2022 at 8:18 AM
    #82
    P in the rock
    Like others, I think when I powered down it reset.
  23. Mar 18, 2022 at 8:19 AM
    #83
    RusPro21
    Don
    Pa.
    Sounds good!!
  24. Mar 18, 2022 at 8:28 AM
    #84
    P in the rock
    Thanks!!!! James told me after the install to delete perfect tune app, he said it would do crazy things. I have sound so I'm good. I'll jump back on if I have anymore issues.
  25. Mar 18, 2022 at 10:21 AM
    #85
    Bentarm13
    Check all your connections. Things work loose over time. Check em all, ground, speaker wires, amp wires, harness connections, etc. If 1 or more are loose it may also be a cause. I have my calendar set to check the system every 6 months..I know, overkill
  26. Mar 18, 2022 at 10:49 AM
    #86
    P in the rock
    Got it!!! Thanks
  27. Mar 22, 2022 at 7:41 PM
    #87
    tundra 1794 wow
    tundra 1794 wow New Member
    ben
    2017 tundra
  28. Mar 22, 2022 at 7:42 PM
    #88
    tundra 1794 wow
    ben
    2017 tundra
    yes i think so im having the same problem i download the app still not working like before i bought a new dsr1 and still the same problem my sound is very low
  29. Mar 23, 2022 at 5:47 AM
    #89
    RusPro21
    Don
    Pa.
    Maybe try and get a hold of James for help.
  30. Apr 26, 2022 at 10:31 PM
    #90
    Ragnarkov
    Ragnarkov New Member
    Stephen
    2021 Silver Sky Metalic Platinum Tundra
    Nothing.... yet.
    So I was just checking the Maestro website, and it shows the DSR-1 got a new firmware on March 30, 2022?? But its showing Ver 2.0 still. Has anyone had a chance to see if this fixes anything?
    I might take the laptop out to the truck and see if I can check this out...
