2019 Tundra TRD Pro parts
Discussion in 'Toyota of Cool Springs Parts' started by Roman, Aug 3, 2018.
  1. Aug 28, 2018 at 8:04 AM
    #181
    Tundramaniac
    Tundramaniac New Member
    14 tundra limited dc
    Can someone please help a brother out? I have a 14 limited with no drl. Unfortuna I bought my harnesses from retrofit source and of coarse their harnesses are no dim and no turnsignal adapter. So I have to repin? Mine has pink white and purple wires so what do I need to do? I think I'm gonna need to buy the relay option any help plz. Tia
  2. Aug 28, 2018 at 8:05 AM
    #182
    Tundramaniac
    Sorry I'm new to the site
  3. Aug 28, 2018 at 8:55 AM
    #183
    Roman
    Roman [OP] Toyota Parts Master Vendor
    Roman
    Franklin, TN
    You might want to hit up @iHacker to see if anything can be done. If you can, I'd send them back and buy a harness from him.
    Watt maker and SoCal619 like this.
  4. Aug 28, 2018 at 9:32 AM
    #184
    smooosh
    smooosh This place costs me too much $
    2018 TRD Offroad Limited Crewmax.
    Ongoing project
    Its an easy fix. I zip tied mine to a couple of the mounting brackets and they dont move any more
    newguy209[QUOTED] likes this.
  5. Aug 28, 2018 at 3:08 PM
    #185
    newguy209
    newguy209 New Member
    Central CA
    Do you have a pic?
  6. Aug 28, 2018 at 7:15 PM
    #186
    smooosh
    Ongoing project
    No. I do not. You can just look up there and put a zip tie on each side of the light. You don’t need to take it off. It’s a pain but you can do it on the truck.
    newguy209 likes this.
  7. Aug 28, 2018 at 10:44 PM
    #187
    newguy209
    Central CA
    Thank you
  8. Aug 29, 2018 at 10:08 AM
    #188
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    @Roman , Any part numbers for TRD Pro fogs and housing?
  9. Aug 29, 2018 at 10:41 AM
    #189
    Roman
    Roman
    Franklin, TN
    None yet.
  10. Aug 29, 2018 at 11:05 AM
    #190
    MAH3998
    MAH3998 New Member
    Edit: Removed P/Ns. Not sure if they are active yet.
  11. Aug 29, 2018 at 12:19 PM
    #191
    Roman
    Roman
    Franklin, TN
    I believe I have the part numbers, but I have to make sure first. The ones I think they are, are currently on MAC and limited to service replacements. Until I know for sure, I can't say.
    Watt maker likes this.
  12. Aug 29, 2018 at 12:26 PM
    #192
    MAH3998
    MAH3998 New Member
    I removed the ones I had because I don't know if they start with PTXXX or 81XXX on the dealer side but yeah...there are P/Ns for the LH and RH fog light assemblies.
  13. Aug 29, 2018 at 1:15 PM
    #193
    Roman
    Roman
    Franklin, TN
    If they're the ones I'm thinking, they start with a PT. Those 81XXX are more than likely a stamping Toyota put on them, but not for use at the dealer.
  14. Aug 29, 2018 at 1:26 PM
    #194
    SleeperTRDPro
    SleeperTRDPro The small package good things come in
    Austin, Texas
    Here is the right side fog light bracket
  15. Aug 29, 2018 at 1:32 PM
    #195
    MAH3998
    MAH3998 New Member
    It is an internal P/N for supply chain, however TMS designed and implemented parts seem to end up with PTXXX at the dealer. Just my observation and I don't always see the PTXXX P/Ns.
  16. Aug 29, 2018 at 1:35 PM
    #196
    Roman
    Roman
    Franklin, TN
    Almost every accessory begins with PT. They only show up in the Toyota accessories sales guide.
    MAH3998 likes this.
  17. Aug 29, 2018 at 1:39 PM
    #197
    MAH3998
    MAH3998 New Member
    Makes sense now. TMS is responsible for Toyota accessories.
  18. Aug 29, 2018 at 8:14 PM
    #198
    SleeperTRDPro
    Austin, Texas
    None yet as my driver side bracket was broken, waiting on a replacement
  19. Aug 30, 2018 at 3:45 AM
    #199
    Matthewkort
    Matthewkort New Member
    Im sure it wont come close to the actual rigid and baja, I was hearing that its only half led(top half) so that im sure will lower output already. The rigid sae are very bright and I dont think toyota will use that power for these ...
    Now it makes me wonder why tacoma went with the sae but tundra went a different route...
    drhntr and Watt maker like this.
  20. Sep 1, 2018 at 8:01 AM
    #200
    manofsteele2003
    manofsteele2003 New Member
    Grant
    24 Sequoia TRD Pro
    Westcott designs 3"/1" lift 295/70/18 Falken Wildpeak RTs Canvasback cargo liner aFe Tow hooks
    So I’m guessing the new fog light brackets won’t work with the metal bumper ends?
  21. Sep 1, 2018 at 8:03 AM
    #201
    619Tundra
    It probably will. If not, I will adapt these bad boys myself.
  22. Sep 1, 2018 at 2:26 PM
    #202
    Matthewkort
    I dont see why it wouldnt..
    619Tundra likes this.
  23. Sep 1, 2018 at 3:41 PM
    #203
    Ace402
    Ace402 New Member
    2011 Tundra 4x4 SR5
    ADS 2.5 RR front and rear. MCM UCA & Shackles
    Any update on suspension availability?
  24. Sep 2, 2018 at 7:31 AM
    #204
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
  25. Sep 4, 2018 at 4:14 PM
    #205
    SuperSilverTundra
    SuperSilverTundra i didnt pull up i Landed
    Nick
    Los Angeles California
    16 TUNDRA 5.7 PLATINUM-PRO
    3"/1" TOYTEC 18x9 XD818 Heist 295/70r18 COOPER XLT DirtyDeeds BAMuffler 2018 LEDs KatzKin Leather S&B CAI
    how much does the new trd pro skid plate cost ?
  26. Sep 4, 2018 at 4:24 PM
    #206
    Blueknights75
    Ron
    Clayton, NC
    @Roman any word on the PRO exhaust in black yet sir?
  27. Sep 5, 2018 at 12:44 PM
    #207
    Roman
    Roman
    Franklin, TN
    None yet. They're still showing a stop sale on them and are not available.
  28. Sep 6, 2018 at 9:58 AM
    #208
    PATTEN
    PATTEN New Member
    Neil
    Guntown MS
    2018 CM XSP MGM SR5 4X4
    This may have been asked already but I didn't come across it.
    I have a 2018 SR5 with the single bottom LED DRL strip (non led headlight)
    I am ordering the TRD PRO headlights 81110-0C211 & 81150-0C211
    Do I need a new harness to make this swap?
    TIA
  29. Sep 6, 2018 at 10:25 AM
    #209
    94slowbra
    94slowbra New Member
    john
    new orleans
    2016 TRD pro
    Yes. @iHacker makes the harness you are looking for
  30. Sep 6, 2018 at 10:47 AM
    #210
    Neshra54
    Neshra54 New Member
    DE
    2016 TRD PRO
    Yes you still need the harness, but different than the one i have ( a little cheaper too). Keep in touch with @iHacker , he will guide you to the right direction.
