2019 Tundra TRD Pro parts
Discussion in 'Toyota of Cool Springs Parts' started by Roman, Aug 3, 2018.
  1. Aug 3, 2018 at 1:35 PM
    Roman
    Roman [OP] Toyota Parts Master Vendor
    Roman
    Franklin, TN
    I have some updates on the 2019 TRD Pro parts. I'll be adding these to the Ultimate parts thread some time soon. Here's a link to that thread in case you have been under a rock for the past 5 years. :D
    https://www.tundras.com/threads/ultimate-oem-toyota-parts-thread.10707/
    2019 TRD Pro grille
    I have some TRD Pro grilles in bound in 040 Super White and 218 Attitude Black. I did not order them in Voodoo Blue because no one is going to have that color. If you do not have one of these two paint codes, I would recommend ordering the black one, and having it painted to match. Same rules apply to these grille surrounds as they do with every other grille. Check out the Ultimate thread above, and this one for more information:
    https://www.tundras.com/threads/tundra-grille-how-to-get-what-you-want.26577/
    White Pro grille (Paint code 040)
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-grille-sub-assy-rad-531010c070a0
    Black Pro grille (Paint code 218)
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-grille-sub-assy-rad-531010c070c0
    Going to be AT LEAST a few weeks before I get my hands on them. I am expecting them to go on back order once the word gets out like the last time Pro grilles were made available back in 2015.
    ALSO, and this is not good, there is a small piece that goes in front of the TSS sensor on the grille. It is pictured here:
    That piece can be found here in the store:
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-garnish-radiator-gr-5314134010
    It does not come with the grille, and it is expensive as hell. It costs more than the grille does. I don't really know of a way around it, though. The sensor itself is a different part number for the TRD Pro as well. I'm not real sure what that is all about either, and won't know until I can get my hands on one to check it out.
    2019 Tundra headlights
    So, there has been a part number change on the headlights. HOWEVER, the number change is slight. They are now 81110-0C211 and 81150-0C211. They fit the TRD Pro, the TRD Sport, and the TRD Off Road packages. This leads me to believe they are a revised version of the 2018 LED headlights. I won't really know if there are any differences in the way they look until I can get my hands on them. Yes, I will let you know as soon as I get my hands on them by posting in this forum.
    ***UPDATE***
    As you can see in the pictures below (hopefully) there are some small differences between the 0C210 and 0C211 part numbers. First, the the black chrome portion above and below the side marker on the 0C210 is now a gloss black color on the 0C211. It isn't matte, and is definitely a gloss black. Second, the inner bezel around the high/low beam portion on the 0C210 is chrome, where on the 0C211 it is black. These are the only differences between the 0C210 and 0C211 headlights. Everything else is identical. Connections in the back are the same, it still has the leveling motors, same bulbs, same light output, etc.
    2019 TRD Pro left - 2018 TRD Sport right
    2019 TRD Pro bottom - 2018 TRD Sport top
    2019 TRD Pro right - 2018 TRD Sport left
    Close up of 2019 TRD Pro headlight
    2019 TRD Pro fog lights from Rigid
    Here are links to them in the store:
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-fog-bezel-rh-tundra-pt22834190aa
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-fog-bezel-lh-tundra-pt22834190ab
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-fog-lamp-rh-tundra-pt22834190ac
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-fog-lamp-lh-tundra-pt22834190ad
    The first two part numbers are for the bezels, and the second two are for the fog lights. You will need all four if you are adding the fog lights to your Tundra. They use the same style plug that your factory fog lights use now, so they are plug and play.
    That's the only new information I have right now. I'll keep posting as I receive more information.
  2. Aug 3, 2018 at 1:42 PM
  3. Aug 3, 2018 at 2:14 PM
    TRD PRO 17
    TRD PRO 17 New Member
    Tyler
    2015 Inferno Crewmax TRD PRO
    Interested about those rigid fog light mounts once you get some information on those!
  4. Aug 3, 2018 at 2:37 PM
    Erichudgins
    Erichudgins New Member
    Eric
    Murfreesboro, TN
    2017 Super white Limited DC
    https://www.tundras.com/threads/the-un-limited-build.25949/
    Yep.. gonna need them headlights:spending:
  5. Aug 3, 2018 at 2:51 PM
    .manny.
    .manny. New Member
    Manny
    2018 Cement Tundra SR5 Crewmax
    Well, shit. The sensor looks like ass and it's separate and expensive. :(
    edit: my concern was answered below. Looks like I'll order one. :)
  6. Aug 3, 2018 at 3:27 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Can you just relocate your current sensor using @ARES 's sensor mount?
    SoCal.Tundra.Guy and ARES like this.
  7. Aug 3, 2018 at 4:08 PM
    charliebison
    charliebison New Member
    Yup. I have done the relocation with his bracket and it works fine.
  8. Aug 3, 2018 at 4:18 PM
    Cfincke
    San Antonio
    Was going to retrofit a set of 2016 SR5 lights i picked up, but may sell them to buy the 2019 lights
    mlucas555, 1UPPER and Pudge like this.
  9. Aug 3, 2018 at 4:37 PM
    dradd
    dradd Sometimes there is just us
    City of Champyinz
    '17 TRD Pro
    pending...
    Looks like my patience may have paid off @Roman . Do you want a deposit on my headlight order now?
    Tophergt99 likes this.
  10. Aug 3, 2018 at 5:01 PM
    Blueknights75
    Ron
    Clayton, NC
    :spending:White pro grill and bracket please Roman. I guess I will wait on the sensor since you have advised the sensor may be different than what is on our ‘18 models.....
    ARES likes this.
  11. Aug 3, 2018 at 5:38 PM
    Newm
    Newm New Member
    KC
    Glad I waited for what appears to be updated headlights. I want in on the first batch!
  12. Aug 3, 2018 at 5:39 PM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    Wouldn’t you still need the shield to complete the grill though? Or just rock it with a gap where it is supposed to go?
  13. Aug 3, 2018 at 5:43 PM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
  14. Aug 3, 2018 at 6:02 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    You know what we want Roman. Thank you!
    Roman[OP] likes this.
  15. Aug 3, 2018 at 6:08 PM
    ninjajay
    Spoolston, TX
    word, I'm about to order a bracket instead of trying to fit the 19 pro. Toyota probably did it on purpose
    ARES[QUOTED] and Roman[OP] like this.
  16. Aug 3, 2018 at 6:15 PM
    Travo60
    Travo60 New Member
    Travis
    Austin, TX
    2018 Limited CM Cement
    I’m slow in the head... if we order the grille with out the sensor/sensor bracket, there won’t be a hole where it’s supposed to go? It will be a complete black honeycomb?
  17. Aug 3, 2018 at 6:22 PM
    Travo60
    Travo60 New Member
    Travis
    Austin, TX
    I agree 100%, what the heck were they thinking. I may go this route knowing that and get your bracket in the future :bananadance:
    HecticEnergy likes this.
  18. Aug 3, 2018 at 6:31 PM
    KnuckleHD
    That’s exactly what I wanted to hear, thanks Ares!
    Getting ready to pull the trigger on one of your brackets any day. Just having trouble deciding if I want to go with the old Pro grille, honeycomb, or wait for the 19. I’ve been on the fence about getting a 19 grille, partly because of the horrible design of that shield.
    If I can get one and not worry about that shield, it may be the best of both worlds.
    ARES[QUOTED] likes this.
  19. Aug 3, 2018 at 6:42 PM
    Blueknights75
    Ron
    Clayton, NC
    @Roman what is the best way for me to get the colored matched surround and bulge and just keep the honeycomb grill insert that is standard on my 18’ SR5? Currently it is chrome.
  20. Aug 3, 2018 at 6:42 PM
    KnuckleHD
    I completely agree. The fact that I can get a 17 Pro grille for half the price already painted to cement is a major selling factor...
    Ironmandd26, Roman[OP] and ARES like this.
  21. Aug 3, 2018 at 6:44 PM
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    What other parts are available?
  22. Aug 3, 2018 at 7:14 PM
    Cfincke
    San Antonio
    @Roman - I did not see you mention free shipping if we pre-order the headlights?
  23. Aug 3, 2018 at 7:29 PM
    GreatAvalon
    GreatAvalon New Member
    2016 Tundra Limited DC
    Bummer, bet that means the Pro does have the black headlights vs the black chrome.
  24. Aug 3, 2018 at 8:18 PM
    Spitfire
    Spitfire New Member
    Long Island
    2018 Cement Limited Trd off road
    I really want that 19 pro grill.. although o might take the easier cheaper route and get the 17 pro grill and parts bc they are already cement.. seams the ares bracket has been pretty successful
  25. Aug 5, 2018 at 11:03 AM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    Hi Roman -
    Regarding the headlights:
    Other than the differences in look (more flat black vs. black chrome), do you know or is there any speculation that the mounting bolts and/or wiring plugs will be different?
  26. Aug 5, 2018 at 11:53 AM
    Travo60
    Travo60 New Member
    Travis
    Austin, TX
    What do we know about the fog lights? They are rigid corrrect? Do they have sturdier mounts so they don’t bounce around if we were to place them in ourselves?
  27. Aug 5, 2018 at 12:27 PM
    atxtundra
    atxtundra New Member
    That’s because the grille is plastic, and the body panels are metal. If you look at any trd pros other than black, the color is a little off on all of them. Just the nature of the beast. Even if you paint it “to match”, it won’t be exact since the material being painted is different.
  28. Aug 5, 2018 at 12:59 PM
    kb1982
    kb1982 New Member
    2014 MGM DC
    Does the 2019 parts being available soon indicate the 2019 trucks are going to be showing up soon?
  29. Aug 5, 2018 at 6:57 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    I would imagine in the next month or so. Several dealers around here have started advertising '18 inventory closeout sales. Tells me they're trying to make room for the '19s.
  30. Aug 5, 2018 at 7:32 PM
    kb1982
    kb1982 New Member
    2014 MGM DC
    I was kicking the idea of selling my DC for a CM and noticed that dealers seemed to be offering bigger ‘upfront discounts’ than they were a couple months ago, made me curious. Also saw a couple articles online (unknown credibility) that stated that 19s should be out late summer.
    Vic4x4 likes this.
