2019 Tundra TRD Pro parts
Discussion in 'Toyota of Cool Springs Parts' started by Roman, Aug 3, 2018.
  1. Aug 7, 2018 at 4:06 PM
    #61
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    The only colors for 19 are white, black, voodoo blue. So unless the 20 pro comes in MGM, you'll have to get it painted or buy another MGM surround and swap the center
    Roman[OP] likes this.
  2. Aug 7, 2018 at 4:07 PM
    #62
    MT1794PRO
    MT1794PRO New Member
    Paul
    2014 MGM 1794 CM
    Debadge, Dechrome, TRD Pro Grille, 2018 Headlights, Amber Grill Lights, Carbon Wrapped Wood Trim, Pace Edwards Switchblade Tonneau....
    Got it, thanks for the info!
  3. Aug 7, 2018 at 6:52 PM
    #63
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Thanks for the pic, does the original Rigid Dually have a double switch or is it brighter? I'm confused what that means, I thought the fog was just on/off like OEM.
  4. Aug 7, 2018 at 7:35 PM
    #64
    silverhack
    silverhack New Member
    Sacramento, CA
    2018 CrewMax Inferno
    @1UPPER or @GreatAvalon can correct me if I'm wrong, but @anthonygan, if you are just wanting to change out the amber turn signal on the 2018 headlights you can also save some money by going with the VLED 'High Visibility Amber 6 LED' (see here: http://www.vleds.com/shop-products/led-bulbs/7443/7443-6-hv-a.html )
    It's $100 for a set of 2 of these with the hyper flash fix (resistor) instead of $300 for the V6 Tritons. The main difference that I am aware of is that these are 450lm instead of 500lm.
    That's my plan for the next mod.
  5. Aug 7, 2018 at 7:41 PM
    #65
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    I think those would work still but they won’t be as bright. The biggest difference I see is the V6 Tritons shine light 360 degrees around. I paid $160 for all the parts I listed above from vleds not $300.
    silverhack[QUOTED] likes this.
  6. Aug 7, 2018 at 7:54 PM
    #66
    silverhack
    Sacramento, CA
    Yep, $160 looks better, I'm getting tired. I overlooked that the V6 are sold as a pair and added 2 to my cart. Doh!
    1UPPER[QUOTED] likes this.
  7. Aug 7, 2018 at 9:13 PM
    #67
    fullofbs
    fullofbs Project SnowFlake
    Hi Roman,
    Is this still the bulge that goes with the new grill?
    FRONT MOLDING (White - 040) - Toyota (76180-0C030-A0
  8. Aug 7, 2018 at 10:38 PM
    #68
    anthonygan
    anthonygan New Member
    2017 Cement TRD PRO
    7in BDS lift, Spyder Smoked Taillights,
    Yeah I’m also getting it for the switch back feature ! So it isn’t amber all the time! It’s only amber when I signal
  9. Aug 8, 2018 at 6:46 AM
    #69
    Roman
    Roman [OP] Toyota Parts Master Vendor
    Roman
    Franklin, TN
    Yes, it is.
  10. Aug 8, 2018 at 2:13 PM
    #70
    atxtundra
    atxtundra New Member
    Someone already has a grille for sale on eBay. Pic taken from there. You can see the missing spot where that other piece goes. Hopefully @ARES bracket fits nice and snug there.
    #70
    JoshuaA, Spitfire and ARES like this.
  11. Aug 8, 2018 at 6:51 PM
    #71
    GreatAvalon
    GreatAvalon New Member
    2016 Tundra Limited DC
    Yep. If I would have known with my harness the amber would not have lit up with the parking lights, I would have done the high vis amber instead of the V6. I have a buddy who uses them and they’re great and plenty bright. Only reason I did Tritons is fit the better hi/lo ratio...but they’re never on in lo mode with the harness so that ratio doesn’t matter lol.
  12. Aug 8, 2018 at 8:03 PM
    #72
    fullofbs
    Thanks
    Roman[QUOTED][OP] likes this.
  13. Aug 9, 2018 at 5:08 AM
    #73
    Blueknights75
    Ron
    Clayton, NC
    Damn!!! That bracket just ruins the entire 19’ grill! Is there not a way that the bracket can be placed behind the grill??
    Tundradrenalin and Newm like this.
  14. Aug 9, 2018 at 5:17 AM
    #74
    1UPPER
    TEXAS
    Flux capacitor!
    My suggestion would be to use vinyl graphics or paint. If you did the rectangular blocks and continued the pattern over the center badge it would help tie in the badge. Photo attached for sample. Another idea would be to use a vinyl sticker design over the badge. E68BC50E-BBA7-47CB-BBD8-DC7C4EBBC9C3.jpg
    If you painted the whole grille with the new badge first the new plate would disappear more. Then install the rectangular paint or graphics. I think it would look good! Especially and high gloss black color with a matte black contrast. It would look tough!
  15. Aug 9, 2018 at 6:21 AM
    #75
    thomasbus337
    thomasbus337 New Member
    2020 TRD Sport DC
    If I didn't already have 7 different grille inserts sitting in my basement I'd be ordering up one of these new grilles for my 2016. I thought the same thing about using gloss black and matte black over a plastic dummy panel. I also thought it would be a great spot to incorporate a flush mounted forward view camera into the rectangle dummy panel since I have no sensor to worry about.
  16. Aug 9, 2018 at 6:53 AM
    #76
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    Well, thanks for letting us know about this! I guess that solves my dilemma of choosing between the honeycomb and Pro grille when I eventually color-match...
    ARES and Blueknights75 like this.
  17. Aug 9, 2018 at 10:02 AM
    #77
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    I’m excited to see this new design. Thanks for looking out @ARES!
    ARES[QUOTED] and Tinycow like this.
  18. Aug 9, 2018 at 10:44 AM
    #78
    BuckWallace
    Oregon
    Sierra 3500 AT4 L8T
    That would make things easier since the 2017 Pro grille is the only version that comes in cement. I am kind of digging the look of the honeycomb with a color match though. Maybe if I could find someone who wants a 2017 Pro grille I could order a Platinum grille in whatever color and a Pro grille in cement, then just swap the inserts...
    ARES[QUOTED] likes this.
  19. Aug 9, 2018 at 10:26 PM
    #79
    newguy209
    newguy209 New Member
    Central CA
    This is not the TRD pro one?
  20. Aug 10, 2018 at 6:30 AM
    #80
    Roman
    Roman
    Franklin, TN
    That picture is of a TRD Sport.
    newguy209 and ARES like this.
  21. Aug 10, 2018 at 7:17 AM
    #81
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Interesting, so if I put nothing there, it looks like a hole. Ideas for non TSS peeps? (cue the suction cup dildo jokes)
    #81
  22. Aug 10, 2018 at 8:29 AM
    #82
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    Let's see what @ARES for his new cover. On his thread he stated he will make the faceplate match the design, and with all the great work he's done so far I figure just get the faceplate from him would work for pre-2018 Tundras.
    ARES likes this.
  23. Aug 10, 2018 at 9:12 AM
    #83
    Waterman
    Waterman Some Days Life Almost Makes Sense
    18' Crewmax 4x4
    Stuff
    @ARES Please put me down for the bracket and cover once you begin selling them.
    Thanks,
    Egan
  24. Aug 10, 2018 at 9:24 AM
    #84
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    The emblem cover for the regular grill is $42 so I'm hoping for a competing price, it's a tossup whether I'll go 2018 honeycomb or 2019 Pro grill.
    Either that or maybe Roman can come up with something for a simple cover.
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-emblem-sub-assy-rad-7530160020
  25. Aug 10, 2018 at 9:35 AM
    #85
    Waterman
    18' Crewmax 4x4
    Stuff
    @ARES
    Thanks and yes I will PM you. To confirm, by next week you will be able to ship the 2019 Pro Bracket and cover?
    Egan
  26. Aug 14, 2018 at 7:49 AM
    #86
    Roman
    Roman
    Franklin, TN
    Updated OP with headlight information.
    RLHULK and iHacker like this.
  27. Aug 14, 2018 at 8:53 AM
    #87
    manguy
    manguy New Member
    2017 TRD PRO Barcelona Red
    Waiting on the part number for the wheels! I wonder how much they’ll be :confused:
  28. Aug 14, 2018 at 10:03 AM
    #88
    GreatAvalon
    Saw the new info on the lights Roman just posted. So they are all black inside...dam!!!
  29. Aug 14, 2018 at 10:13 AM
    #89
    charliebison
    charliebison New Member
  30. Aug 14, 2018 at 10:27 AM
    #90
    atxtundra
    It’s in the first post.
    monaco730 likes this.
