2019 Tundra TRD Pro parts
Discussion in 'Toyota of Cool Springs Parts' started by Roman, Aug 3, 2018.
  1. Sep 10, 2019 at 12:40 PM
    #361
    Philly Tundra
    Philly Tundra New Member
    Tre
    2018 Limited
    Debadged chrome Color matched side mirror door handles Swap chrome grill for color match platinum honeycomb
    Wow great timing I just got done with sparks parts griping about the $300 for the sensor cover.
    Have you used this? Look very similar to the surrounding Grill?
  2. Sep 10, 2019 at 12:56 PM
    #362
    Philly Tundra
    Tre
    2018 Limited
    Have you used this? Look very similar to the surroundingGrill?
  3. Sep 10, 2019 at 2:33 PM
    #363
    xx-cloudy
    xx-cloudy New Member
    Manny
    NorCal
    2018 Barcelona Red Tundra SR5 TRD CM
    No problem. It hasn't arrived yet but once it does I'll snap some pictures once its installed. I've seen a few other guys on the forum who have the part and it looks pretty good. I'll attach a picture from the website itself. (Not mine)
  4. Oct 1, 2019 at 4:02 AM
    #364
    1794Canuck
    1794Canuck New Member
    Ryan
    2018 Black 1794
    6112/5100s, shackles, remote start, full stereo upgrade, PRO grill, front bumper shellz, colour matched mirrors and door handles, Cooper discoverer AT3 XLT 285 75 18 on Fuel Kranks, 8" BAMuffler
    I have the ares installed on my 2018 pro grill. The fit is perfect and when I ordered I had the option to select if I wanted it painted gloss or flat, so I think that would prevent the fading. Way cheaper than going with the OEM part for what it is.
  5. Oct 4, 2019 at 9:20 PM
    #365
    x3rzr
    x3rzr New Member
    I just put on my 2019 TRD pro grill I bought a sensor cover from eBay not Toyota. And my sensor light is one has anyone bought eBay sensor grill cover ?
    iHacker likes this.
  6. Oct 5, 2019 at 7:31 AM
    #366
    x3rzr
    x3rzr New Member
    Ok so I took off the sensor cover. And still the light is on. So does it need a cover to work ?
  7. Oct 5, 2019 at 7:48 AM
    #367
    x3rzr
    x3rzr New Member
    You didn’t have any problems with yours ? Did you disconnect battery
  8. Oct 5, 2019 at 8:36 AM
    #368
    silverhack
    silverhack New Member
    Sacramento, CA
    2018 CrewMax Inferno
    I did not have any problems swapping to my grill. The PCS light usually goes off and resets every time you turn the engine off so it's easy to reset and try again.
    The TRD Pro grill lowers the sensor about 2" from the non-Pro grill position so it could be that it doesn't like the new position, although most people have not had problems with swapping to the Pro grill.
    x3rzr likes this.
  9. Nov 14, 2019 at 2:05 PM
    #369
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    I have a '2020 SR5. Do I need a patch harness for the Pro headlight?
    With the upgrades I've been putting on my truck since I bought it 4 weeks ago, I could have just got a Pro. :-( I just did not like the hood scoop.
  10. Nov 14, 2019 at 2:13 PM
    #370
    Roman
    Roman [OP] Toyota Parts Master Vendor
    Roman
    Franklin, TN
    If you have a regular halogen headlight bulb, you will need an adapter harness to make the Pro headlights work. Hit up @iHacker for the harness.
    iHacker and SprinterAE86[QUOTED] like this.
  11. Nov 14, 2019 at 2:23 PM
    #371
    SprinterAE86
    Ian
    One more thing, is the 2020 TRD Pro headlight the same as the 19? Thanks Roman!
  12. Nov 15, 2019 at 7:01 AM
    #372
    Roman
    Roman
    Franklin, TN
    Yep, they're the same.
  13. Nov 28, 2019 at 1:52 PM
    #373
    Jsnake89
    Jsnake89 New Member
    Dane
    2019 Tundra TSS SR5 8W2
    Bilstein 5100 3/1 Pro Comp 1" Blocks, 12Volt Remote start.
    @Roman.
    So if I read this correct the 19 Pro Led’s Will plug right into my 19 TSS?
  14. Nov 29, 2019 at 7:27 AM
    #374
    Roman
    Roman
    Franklin, TN
    As long as you have LED headlights. If you have halogen headlights, you will need an adapter harness.
  15. Dec 7, 2019 at 8:41 PM
    #375
    bashar368
    bashar368 New Member
    anyone have a coupon code
  16. Jan 7, 2020 at 2:11 PM
    #376
    BlueTundra2019
    BlueTundra2019 New Member
    2019 Voodoo Blue Tundra TRD Pro
    Lifted 8 inches, 37x13.50R22 on 22x12, Rhino BR5 Bumper with Warner winch, TRD Sway Bars, Full-size spare with matching rim in bed, Train horns, Rigid LED lights, Monster Hammer Head rope hooks.
    @Roman.
    What is the current in-dash outside rear-view mirror switch part number that we can use for the power folding Tow Mirrors in a TRD Pro 2019? I only have power adjustment and heated currently. Thanks !!!
  17. Jan 8, 2020 at 7:07 AM
    #377
    Roman
    Roman
    Franklin, TN
    Others have used this part number with success, though there are aftermarket ones that are a LOT cheaper that some guys have been using as well.
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-switch-outer-mirror-8487201010
  18. Jan 11, 2020 at 5:23 AM
    Jsnake89
    Jsnake89 New Member
    Dane
    Woke up to some snow today
    iHacker likes this.
  19. Feb 4, 2020 at 2:15 PM
    #379
    COTundra23
    COTundra23 New Member
    Anyone selling their honeycomb grill with white surround and bulge?
  20. Feb 4, 2020 at 6:12 PM
    #380
    Jsnake89
    Jsnake89 New Member
    Dane
    don’t know if this has been asked, but will the new Navi for the 20’s work the the 19’s?
  21. Feb 4, 2020 at 7:06 PM
    #381
    KeetAz
    KeetAz New Member
    Gilbert AZ
    2020 SuperWhite PRO
    That’s a negative ghost rider
    Roman[OP] likes this.
  22. Feb 5, 2020 at 11:35 AM
    #382
    Jsnake89
    Jsnake89 New Member
    Dane
    Dam.
  23. Aug 6, 2020 at 7:02 PM
    #383
    Jsnake89
    Jsnake89 New Member
    Dane
    42848E5E-82D2-4C93-970C-AF80CD2444FC.jpg 83B23620-BFD6-40D3-94ED-2DC46277AF9F.jpg @Roman @iHacker Finally got my TRD Pro head lights installed and could not be happier.
    Roman[OP], iHacker and Mater like this.
  24. Dec 13, 2020 at 3:51 AM
    #384
    Klew916
    Klew916 New Member
    K
    2018 tundra sr5 cm
    @Roman will the 2019 Trd pro grills fit a 2018? Thanks
  25. Dec 13, 2020 at 7:03 AM
    #385
    Elduder
    Elduder New Member
    Yes
  26. Dec 25, 2020 at 9:46 PM
    #386
    JAZZY
    JAZZY New Member
    Will the 19-20 led fit a16 SR5
  27. Dec 31, 2020 at 7:10 AM
    #387
    Garvin74
    Garvin74 New Member
    2017 Tundra CM SR5
    Roman,
    Any way I could just get the bracket that the fog light sits in. I have the lights and the bezels just need the mounting bracket?
  28. Dec 31, 2020 at 7:59 AM
    #388
    Garvin74
    Garvin74 New Member
    2017 Tundra CM SR5
    @Roman sorry forgot to tag Roman in my above post
  29. Oct 24, 2023 at 11:00 AM
    #389
    mettler
    mettler New Member
    Is anyone else experiencing massive delays with grills/lights. I ordered my grill back in early Sept and was told it wouldn't be in until mid December. I also ordered some headlights, but those haven't shipped yet.
  30. Oct 24, 2023 at 1:32 PM
    #390
    MotoTundra
    MotoTundra The Ocho
    Don
    I waited 4 months for a Lexus headlight to come in.
