2019 tundra transmission thermostat location
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jtundra81, Mar 21, 2019.
  1. Aug 7, 2020 at 9:00 PM
    #91
  2. Aug 8, 2020 at 8:20 AM
    #92
    GroovDog2
    GroovDog2 New Member
    Michael
    2020 Crewmax SR5 TSS
    4” lift, 35/12.5 22”
    Yeah, that me he’s talking about. We’ve been talking back and forth. He’s finding out some interesting info from the engineers.
  3. Aug 8, 2020 at 8:26 AM
    #93
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Tim just commented that you took the truck in and the dealer didn't find an issue. Are you planning on adding an aftermarket cooler?
  4. Aug 8, 2020 at 9:02 AM
    #94
    I figured it was a member and on this thread.
    Personally, I don’t like the fact the trans coolers are not included in the tow package. This would be a no-go for me in the purchase process. Buying a truck now days is like performing brain surgery.
    AircareTundra likes this.
  5. Aug 8, 2020 at 10:45 AM
    #95
    Pappion
    Pappion New Member
    It's fraud. False Advertising. Ripe for a class action lawsuit. You paid for a Tow Package which includes a transmission cooler. You didn't get it and it runs hot and hotter when towing.
    Jtundra81[OP] likes this.
  6. Aug 8, 2020 at 12:00 PM
    #96
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Not really fraud. The transmission still has a cooler. It has a coolant/oil heat exchanger rather than a air/oil heat exchanger but a heat exchanger never the less.
    GroovDog2 likes this.
  7. Aug 8, 2020 at 1:12 PM
    #97
    Pappion
    Pappion New Member
    BS to that. You paid for something extra to help endure towing and you got stock instead. Misrepresentation in a financial transaction.
  8. Aug 8, 2020 at 1:25 PM
    #98
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    ...and you got a tranny cooler, it just doesn't perform the way you think it should. I'm pretty sure the Toyota lawyers would have looked at any liability but feel free to talk to your lawyer about it. Hope you have deep pockets.
  9. Aug 8, 2020 at 2:01 PM
    #99
    Pappion
    Pappion New Member
    So what your saying is: If your a big enough bully, you can defraud anyone, with no consequences.
  10. Aug 8, 2020 at 2:39 PM
    #100
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    It may not be fraud but it was definitely on the shady side.
  11. Aug 8, 2020 at 3:03 PM
    #101
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Welcome to the real world.
    GODZILLA, Azblue and AZBoatHauler like this.
  12. Aug 8, 2020 at 3:06 PM
    #102
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Definitely shady. :cool:
    rebmo, GroovDog2 and sask3m[QUOTED] like this.
  13. Aug 8, 2020 at 4:16 PM
    #103
    GroovDog2
    Michael
    I have one ordered and its all OEM parts, so Toyota won’t be able to come at me if a warranty issue comes up.
    Ruggybuggy[QUOTED] likes this.
  14. Aug 8, 2020 at 4:18 PM
    #104
    GroovDog2
    Michael
    That’s the thing, I didn’t know they removed it. It still says on the sticker that it’s there.
  15. Aug 8, 2020 at 4:29 PM
    #105
    GroovDog2
    Michael
    I’m married to my lawyer and she said the same thing as you. I’m still adding another REAL cooler.
  16. Aug 8, 2020 at 4:31 PM
    #106
    timsp8
    NY
    One is there according to Toyota. The cooler they reference is the old “warmer” that uses engine coolant. They technically didn’t lie about it.
  17. Aug 8, 2020 at 4:33 PM
    #107
    I didn’t either. It actually floored me a bit.
    GroovDog2[QUOTED] likes this.
  18. Aug 13, 2020 at 5:25 PM
    #108
    Ghost23
    Ghost23 New Member
    2015 Tundra
    I have a 2015 Tundra 4.6. Does not have a trans cooler, only heat exchanger. IfI have some ideas after looking at the heat exchanger. Can I disconnect the coolant lines and connect them together to bypass the exchanger. Take the trans fluid line that feeds the exchanger and extend it to a front mount aux cooler. Then run a return like from cooler to where the exit line for the exchanger went into the trans. There are 90 elbows coming out of the trans feeding fluid to the exchanger. They make block off kits for Dodge diesels to block or bypass the exchanger and only use the aux cooler. Had one on mine. Cooled the trans a lot better with out the exchanger. Never got to cold in the winter. Our Cherokee has 2 small aux coolers and never gets to cold in the winter. My Chevelle never gets to cold, on colder days. Here is a pic from a different model. But mine looks the same. Please let me know if this is possible or anyone else has done this.
  19. Aug 13, 2020 at 5:27 PM
    #109
    timsp8
    NY
    If you read one of the 3 threads you posted this in, there was already talk about it. I forgot which thread though.
  20. Aug 13, 2020 at 5:29 PM
    #110
    Ghost23
    Ghost23 New Member
    2015 Tundra
    I've read so many posts on all different forums. It's all scrambles in my brain now! I will go back and look. Thanks!
  21. Aug 13, 2020 at 5:37 PM
    #111
    timsp8
    NY
    I think the consensus was it probably wouldn’t do anything, but if you find the post you can ask the guy if he ever tried it. I forgot who it was.
  22. Aug 13, 2020 at 5:46 PM
    #112
    Ghost23
    Ghost23 New Member
    2015 Tundra
    Hmmm. It's hard to believe it wouldn't do anything. Especially since you would be bypassing the heat exchanger and running the fluid through an auxiliary cooler. I know on my past and current vehicles it works. The trans fluid will almost always stay at what the coolant temp is, or hotter. I think the heat exchanger is just a way to increase mpg due to the thinner oil. That way Toyota can sell trucks. They don't care about the live of the fluid. Especially since they say you have to use their fluid in the trans.
    An aux cooler with a fan mounted in front of the radiator would surely cool the fluid better than 200 degree coolant. I know coolant (fluid) carries heat away very well. But, 200 degree coolant is not going to keep a trans at 175 degrees. Mine is a steady 200-215 once everything is up to temp. It was in the 240s a few times pulling my single axle 16ft empty trailer on a county road. That isn't good.
  23. Aug 13, 2020 at 6:45 PM
    #113
    19crewmaxTRD
    19crewmaxTRD Tundra Enthusiast
    Seth
    2019 white tundra crewmax
    Since coolent is what’s running through those lines you would also need some sort of coolent pump for circulation to the cooler. The belt driven water pump is what is currently pushing fluid through the warmer/cooler puck.
  24. Aug 13, 2020 at 6:49 PM
    #114
    timsp8
    NY
    Check this thread. There is talk about it starting around page 6. They even mentioned adding a heater core I guess to cool the fluid.
    https://www.tundras.com/threads/install-complete-on-additional-transmission-cooler.12385/page-7
  25. Aug 13, 2020 at 7:00 PM
    #115
    Ghost23
    Ghost23 New Member
    2015 Tundra
    Coolant running through which lines? The bigger lines are coolant.I want to disconnect those from the heat exchanger and connect the ends together. Just like bypassing a heater core. Coolant would just make a big loop and go back to the engine. The two smaller lines are trans fluid. One exits the trans to the heat exchanger, the other exits exchanger and enters trans. No coolant is flowing through the trans.
  26. Aug 13, 2020 at 8:38 PM
    #116
    19crewmaxTRD
    Seth
    Yes those are coolent lines that come from the engine cooling circuit from so where around the back of the block, they are not filled with atf. I thought about adding in a small fluid cooler with electric pump and fan somewhere under the truck but I decided the factory setup is tried and true and would rather install oem parts.
  27. Aug 13, 2020 at 8:42 PM
    #117
    19crewmaxTRD
    Seth
    I just did a second take on your picture I didn’t notice the factory thermostat. I was under the impression that the 4.7 didn’t have that thermostat. So you are correct about adding a cooler in the smaller lines. But why disconnect the warmer at that point? Getting you trans up to temp sooner will be better for the longevity and economy. I would add the cooler and leave the warmer installed.
  28. Aug 13, 2020 at 9:11 PM
    #118
    Ghost23
    Ghost23 New Member
    2015 Tundra
    I don't want the coolant lines having anything to do with the transmission. That's why I want to disconnect them and and clamp each end to a piece of hard pipe to loop it right back to the engine. Then, disconnect the small line coming off the trans that feeds trans fluid into the warmer, pick, heat exchanger, whatever you wanna call it. Run that line to an auxiliary cooler. Run a line from cooler back to the other small line that fluid leaves the exchanger to return to the trans. This way the exchanger would do absolutely nothing. I really don't even have to disconnect the coolant lines since the trans fluid won't be going through the exchanger any longer.
  29. Aug 13, 2020 at 9:19 PM
    #119
    Ghost23
    Ghost23 New Member
    2015 Tundra
    My thinking is on 3 other vehicles, I have never had a problem with the trans fluid getting to temp when it's cold out. Trans fluid does not like heat. 175 is optimal. Heat is terrible on clutches. No way should trans temp be 200-215 while locked up going 65. My Chevelle with a 3 speed and high stall non lock up TC runs cooler than my tundra. Toyota wanted thin hot fluid for less friction to help fuel economy. I want long trans life. Guess I will try it and see what the ultragauge says.
  30. Aug 13, 2020 at 9:30 PM
    #120
    Ghost23
    Ghost23 New Member
    2015 Tundra
    And I do agree with you. I could leave the coolant lines hooked up. There are several ways to route the trans fluid lines. Into the warmer first, out to aux cooler, back to the trans. That works fine and that's how almost every aux cooler is ran. Through rad first then to cooler, then to trans. That's mainly for getting the trans to temp quicker on colder days. That's how our coolers in our Cherokee are hooked up. It has a Toyota trans. On my Cummins, I got rid of the heat exchanger all together. All it did was add heat to an already hot trans. Bypassed it and ran straight to aux cooler that had a thermostat built in. Ended up bypassing the thermostat valve and trans stayed at a steady temp. Chevelle is straight to the cooler with a fan. I'm only going off my past experience. But, I think it would be easier to keep the coolant lines hooked up since the cooler I have is one of the larger one BM makes. Plus it has a fan.
