2019 Tundra Tranny Temps 225-235F
Discussion in '2.5 Gen Tundras (2014-2021)' started by 2019CementTRD, Nov 25, 2020.
  1. Mar 29, 2021 at 2:39 PM
    #241
    Professional Hand Model
    Hand Protectors
    Crowd: Transmission temps are too high. What no Cooler now?
    Peanut Gallery: Just buy a Transmission Cooler and watch those temps cool!
    Random Guy: But watch out because if Toyota finds out they’ll void your warranty!
    Guy on fence:
  2. Mar 29, 2021 at 4:13 PM
    #242
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    An honest service manager.
    BravoDeltaRomeo and JohnLakeman like this.
  3. Mar 29, 2021 at 5:02 PM
    #243
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Peanut Gallery Tale of Probablilities For 2019+ Transmission Failure, Outside of Warranty with 60K mile fluid changes:
    Tundra transmission failure in normal service (no towing, no off road): 5%
    Tundra transmission failure towing heavy WITHOUT auxiliary cooler: 85%
    Tundra transmission failure towing heavy WITH retrofitted cooler: 15%
    Help from Toyota after warranty expiration: 0%
    Conclusion: Grow a pair. It's a good transmission under reasonable service conditions. Give warranty the bird. :D
  4. Mar 29, 2021 at 5:37 PM
    #244
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    Where did you get the numbers?
  5. Mar 29, 2021 at 6:55 PM
    #245
    JohnLakeman
    Where did I get the numbers?...From (1) 10% Peanut Gallery JOOMA, (2) 55% long life experience, (3) 25% old age treachery, and (4) 10% capriciousness.
    As good as it's going to get regarding "rock solid evidence" on the internet...at least for now. :thumbsup:
  6. Mar 30, 2021 at 4:13 AM
    #246
    Hand Protectors
    Only Rock Solid evidence I needed to see was that letter from the Toyota Engineer (anonymous) basically saying they should have kept the Cooler.
    Other evidence: I have actually have an OEM Cooler that cools too well in winter and decided to put a Thermostatic Valve to Bypass the Cooler. Trying to keep those temps up in the 140-170° range vs. 110-130°.
  7. Mar 30, 2021 at 7:33 PM
    #247
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    Considering I've had to draw back the hardness on some types of tool steel as low as 400 degrees F, a warning fluid temperature of 300 doesn't make sense to me. The fluid cools the gears, so by the laws of physics as there's no such thing as a zero friction gear tooth the gears passing torque will always be warmer than the fluid, and if the planets lose their surface hardness then I imagine bad things happen. Some steels can take higher temps for longer but in general, high heat + time together gradually softens heat treated steel. This is what messed up 5th gear on my R155F Tacoma. The output shaft gear for 5th was completely above the fluid level and it's small. Barely bigger than a golf ball. It always ran hot and on the drive side of the tooth faces developed blue discoloration and pitting that made it whine like crazy. The larger engaging gear on the countershaft had no damage whatsoever because it was 5" across and half submerged. That was factory tires, a 159 hp engine, and never towing.
    I wonder what the viscosity of WS is at 300F.
    This must be why Toyota says tow in S4 now. 1:1 ratio means no generating heat in the gearing and the extra rpm keeps the torque converter locked more. Good luck in the mountains though. It hits 240 with the cooler
  8. Mar 31, 2021 at 5:59 AM
    #248
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    I dont think Toyota said to tow in S4 but to use tow mode. Holy hell 240 with cooler you would be 300 plus without.
  9. Mar 31, 2021 at 6:26 AM
    #249
    Kanobi13
    Kanobi13 New Member
    Here we go with s4!!
