2019 Tundra Tranny Temps 225-235F
Discussion in '2.5 Gen Tundras (2014-2021)' started by 2019CementTRD, Nov 25, 2020.
  1. Dec 1, 2020 at 6:28 AM
    #151
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    :rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl:
  2. Dec 1, 2020 at 6:28 AM
    #152
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    So, have you changed your fluid to Amsoil and sent in a WS sample to Blackstone?
    Cpl_Punishment and Saltyhero13 like this.
  3. Dec 1, 2020 at 6:29 AM
    #153
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Yeah, this thread has lost it's focus and is going in circles. I can see I'm going have to help you guys understand this dilemma by resorting to visual aids:
    All right, all you fellows at Counter 1: If you don't have a Tundra with a real damn air-to-oil cooler with hoses/tubes leading up to the grille area, then do yourself a favor: Spend a few hundred dollars and retrofit a real ATF cooler NOW. If you haven't seen a destructed transmission on a two year old truck, what the heck did you expect?...They're covered by Mama Toyota for five years/60K miles! :eek:
    All you guys at Counter 2: Quit muddying the water up for the ignorant. If you don't tow heavy, you DON'T NEED a dang ATF cooler. We know this because Toyota has already run the hell out of these trucks in the heat of the southern desert, and up the side of mountains. They KNOW they are capable without that silly-ass ATF cooler. Toyota engineers are so confident in these trucks, they have raised the OMG fluid temp alarm to 302 degrees for fluid that starts going to shit about 230 degrees! So, quit worrying, you don't need an ATF cooler...well, for at least the first 5 years/60K miles, whichever comes first. Just do your normal lifetime fluid changes, OR...as often as you see fit. You will get your reward in the end.
    (Tongue-in-cheek. I already have my retrofit ATF cooler. :D)
    Bammer, Jaypown and BravoDeltaRomeo like this.
  4. Dec 1, 2020 at 6:47 AM
    #154
    RyeHog
    RyeHog New Member
    2014 MGM Sr5 Tundra
    I’ve watched a lot of their Ike gauntlet videos and will say although it’s only 8 minutes of towing it’s near max tow weight and the truck is basically at redline the whole time. I guess more of a worst case towing scenario instead of a normal towing scenario
  5. Dec 1, 2020 at 6:49 AM
    #155
    timsp8
    NY
    When I had a TT, mine would slowly get hotter over time. Like an hour or 2. I wasn’t at max but it seems like a short spike isn’t as bad as long sustained towing.
    JohnLakeman likes this.
  6. Dec 1, 2020 at 6:50 AM
    #156
    timsp8
    NY
    Sorry, I didn’t take a picture when my 2010’s transmission went out at 59k and then the replacement one again at around 106k.
  7. Dec 1, 2020 at 6:51 AM
    #157
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Exactly. Chasing problems that have not even occurred yet.
  8. Dec 1, 2020 at 6:54 AM
    #158
    timsp8
    NY
    You speak with confidence, however I personally know of 2 “destroyed” transmissions in a tundra.
    tttrdpro and RyeHog like this.
  9. Dec 1, 2020 at 7:08 AM
    #159
    RyeHog
    RyeHog New Member
    2014 MGM Sr5 Tundra
    You can assume confidence when there are millions of these trucks on the road and the transmission isn’t an issue.
  10. Dec 1, 2020 at 7:12 AM
    #160
    timsp8
    NY
    Well when people are saying it hasn’t happened, as in 0% failure rate, and I am at 66% failure rate (2 failed in my 2010 and 1 good one in my 2018), there isn’t as much confidence for me.
    And million”s” is a stretch. 15 years (07-21) at around 100,000 a year is 1.5 mil minus any wrecked or broken ones.
    Edit: yes, Toyota is reliable and there hasn’t been anyone saying their transmission caught fire because of the lack of a cooler. But Toyota isn’t 100% perfect.
    RyeHog[QUOTED] likes this.
  11. Dec 1, 2020 at 7:20 AM
    #161
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    That’s the funniest thing I’ve read lately, thanks for the laugh! :rofl::rofl::rofl:
    SShooterZ likes this.
  12. Dec 1, 2020 at 7:28 AM
    #162
    JohnLakeman
    External appearance would remain unchanged. Most automatic transmissions stop functioning long before enough heat and friction accumulate to cause external damage. Unless an owner specifically requested it, only AT technicians, and not Toyota techs, get to view the destruction inside. Here is a couple of videos if you want to see inside. The first is specific to a 2007 Tundra AB60F 4X4. It had to be towed in, some comments on welding of convertor neck to the bushing:
    https://www.youtube.com/watch?v=AoyCfW8NPrE
    If you want to see real internal carnage check out Precision Transmission videos. They only do post mortem teardowns on GMs and some are pretty ugly:
    Edit: Ah, jeez, destruction of "planet gear" usually "indicates cooler failure", or "lack of cooling". :eek::eek:
    https://www.youtube.com/watch?v=1Xkfr1XjMXk
    Saltyhero13 and Jaypown[QUOTED] like this.
  13. Dec 1, 2020 at 7:30 AM
    #163
    RyeHog
    RyeHog New Member
    2014 MGM Sr5 Tundra
    Ya your situation is a little different. I think for the general person that will google “20xx Toyota Tundra problems” they aren’t going to get anything with the transmission. It could be the 4L60 and go out every 100k on the dot.
  14. Dec 1, 2020 at 7:34 AM
    #164
    Saltyhero13
    Saltyhero13 Throbbing Member
    You need to get out more, there is a brave new world out there! Just don't get too curious <wink>
    Jaypown likes this.
  15. Dec 1, 2020 at 7:37 AM
    #165
    Saltyhero13
    Oh sure! Exclude the 2019s there /sarc
    I liked this thread better when we were posting Prius oil samples.
  16. Dec 1, 2020 at 7:51 AM
    #166
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
    Did your 10 have the cooler?
    Cpl_Punishment likes this.
  17. Dec 1, 2020 at 7:52 AM
    #167
    Saltyhero13
    More importantly was your 2010 a 2019+?
  18. Dec 1, 2020 at 7:53 AM
    #168
    timsp8
    NY
    Yes, the one in the condenser. It was built mid 10 when they made the change.
  19. Dec 1, 2020 at 7:53 AM
    #169
    SamW
    SamW New Member
    Sam
    2020 Tundra TRD Pro
    What's toyota's designed operating range for the trans?
  20. Dec 1, 2020 at 7:55 AM
    #170
    timsp8
    NY
    Even more importantly, the post I quoted regarding my 2010 didn’t differentiate between years. It just said “Can someone post a picture of their overheated/destroyed transmission in their Tundra?”
  21. Dec 1, 2020 at 7:57 AM
    #171
    Saltyhero13
    I have your permission to ignore the context of the OP.
  22. Dec 1, 2020 at 7:58 AM
    #172
    Saltyhero13
    and the WS fluid.
  23. Dec 1, 2020 at 8:01 AM
    #173
    timsp8
    NY
    I wasn’t quoting the OP in my reply. You also have my permission to reread those other posts too.
  24. Dec 1, 2020 at 8:02 AM
    #174
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    FWIW the ATF is not a lifetime fluid, the maintenance cards show an ATF service at 60k.
  25. Dec 1, 2020 at 8:03 AM
    #175
    Saltyhero13
    Very informative videos! Thanks for sharing.
  26. Dec 1, 2020 at 8:08 AM
    #176
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Your 2010 didn't have a cooler?
  27. Dec 1, 2020 at 8:12 AM
    #177
    blanchard7684
    blanchard7684 New Member
    you’ve lost two... is this a configuration with a factory cooler?
    what was the root cause of the failure?
  28. Dec 1, 2020 at 8:15 AM
    #178
    timsp8
    NY
    Had the one in the ac condenser.
    Don’t know, but they said the first one had lots of metal shavings in it. It ran hotter after that, like over 250 on flat ground. Dealer said it was normal. Cooler got a leak years later and they replaced it and it ran cooler after that. I think the cooler was clogged but they insisted it didn’t need to be replaced when I had the trans replaced the first time.
  29. Dec 1, 2020 at 8:15 AM
    #179
    Saltyhero13
    We'll since we have included Priuses into the body of evidence...
    JLS in WA and Cpl_Punishment like this.
  30. Dec 1, 2020 at 8:16 AM
    #180
    timsp8
    NY
    And a 2005 Highlander. It was in one of the posts.
