2019 Tundra SR - LED Conversion HELP
Discussion in 'Lighting' started by bjl10100, Feb 6, 2019.
  1. Feb 20, 2019 at 10:33 AM
    TundraTSS19
    TundraTSS19 New Member
    San Antonio, TX
    2020 Tundra TSS SR5 Crewmax 5.7L
    LED step bar light strips
    If that's the case this may be the reason why everything looks messed up. Let me go out to my truck and take a picture of it. I want to make sure I didn't tell you wrong.
  2. Feb 20, 2019 at 10:40 AM
    TundraTSS19
    San Antonio, TX
    20190220_123510.jpg my apologies. The cup should be facing down .you can barely see it. If you zoom in you can see the high beam chip and then to the left you can see the cup facing downwards. I'm a dumb@$$
    ant8262 likes this.
  3. Feb 20, 2019 at 11:34 AM
    rustynail11
    rustynail11 New Member
    Scott
    Mansfield,TX (DFW Area)
    2017 Grey Tundra TRD
    Thanks! Will look to see how I installed mine
  4. Feb 20, 2019 at 11:44 AM
    turkeycreek29010
    turkeycreek29010 New Member
    Chuck
    Bishopville SC
    2019 Cement Tundra Crew Max
    3/1 Level Kit, 20 inch Gear Wheel, 285/65/20 BFG
    I have the same bulbs in mine (Dealer installed them, long story) and I'm thinking mine are not in right also. They are not near as bright as I would have thought. The high beam is terrible.
    TundraTSS19 likes this.
  5. Feb 21, 2019 at 5:17 AM
    rustynail11
    Scott
    Thanks for the help, I looked and had them in upside down. Pulled everything apart switched the bulbs around and now the patter is much better. Now on to new fogs
    Thanks again for all the help.
    TundraTSS19[QUOTED] likes this.
  6. Feb 21, 2019 at 6:42 AM
    bfd300
    bfd300 New Member
    So you guys are liking the Auxbeams?
    I had the Lasfit in my tundra for a few days, hated them, light scatter everywhere. Took them out and went with a brighter halogen. But I still want led’s.
  7. Feb 21, 2019 at 7:03 AM
    rustynail11
    Scott
    Now that I have them in correctly I like them. good cut offs and very litter scatter
    bfd300 likes this.
  8. Feb 21, 2019 at 7:54 AM
    TundraTSS19
    San Antonio, TX
    Yes I like them a lot. ive had mine in for 3 months now and they've been great. I have them in the headlights and fogs. No issues and the best thing I like about them are fanless. Only thing I felt I needed to do was adjust the headlights down one click of the wheel and it was perfect from there. Foglight took me 10 min to do both. You can't beat the price for the performance of these.
    bfd300[QUOTED] likes this.
  9. Feb 21, 2019 at 7:57 AM
    bfd300
    bfd300 New Member
    Which fogs did you get?
  10. Feb 21, 2019 at 7:58 AM
    TundraTSS19
    San Antonio, TX
    Auxbeam NF-S1 H11
  11. Feb 25, 2019 at 2:35 PM
    mortiz21
    mortiz21 New Member
    Marissa
    2015 Tundra CrewMax Limited Attitude Black
    275/60/20 Nitto Ridge Grapplers on Fuel Mavericks 5100 Bilsteins in the front EAG Raptor Grill Insert
    Does the Canbus wiring harness adapter need to be purchased in order for the Auxbeam NF-S1 bulbs to work properly?
  12. Feb 25, 2019 at 2:50 PM
    ncorry
    ncorry New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    Was not required for me when I installed them into the 2019 OEM headlamps with halogen headlights and LED DRL. I don't know how much difference there is in the 2019 halogen headlights and the 2014-2017 halogen headlamps. However, the construction of the NF-S1 appears to be very similar to the halogen bulbs that I removed. I thought that the canbus stuff was mainly for flashing lights like turn signals.
  13. Feb 25, 2019 at 2:53 PM
    mortiz21
    mortiz21 New Member
    Marissa
    Ive done so much reading on LEDs and new housings are at the moment in the budget since wheels and tires and coming in this week, I just hate yellow looking halogens and want a cleaner look. But since it's a pain in the ass to get to the headlights, I wanted to make sure I wasnt going to have errors and have to take the grill back off to install an adapter. I might just order the adapter just to have them, and see how it goes!
  14. Feb 25, 2019 at 3:02 PM
    Professional Hand Model
    Hand Protectors
    Just installed the SuperNova v.4 LED fogs (9006) for 1st Gen and they are awesome. Plug and play fanless. Way brighter and a nice beam pattern even in the OEM reflector housing. Very good investment. May do the headlamps next, but leary of the LED fans and daytime running/high-low beam single bulb set up that is an 02’ thing.
  15. Feb 25, 2019 at 8:19 PM
    TundraTSS19
    San Antonio, TX
    You don't need a canbus
  16. Mar 1, 2019 at 5:02 PM
    bfd300
    bfd300 New Member
    Ok just ordered the Auxbeams for head and fogs. Amazon I got both sets for $58 free shipping.
  17. Mar 10, 2019 at 3:14 PM
    lewi3069
    lewi3069 New Member
    2017 Crew Max 4x4 Sunset Bronze
    Little late, but this may help someone else.
    Install:
    Test Drive:
    UncleJimmy likes this.
  18. Apr 18, 2019 at 6:02 PM
    danjmurr
    danjmurr New Member
    2019 Toyota Tundra TSS 4x4
    New to the forum and not sure if I'm doing this correctly. TundraTSS19 did you get the H11 for the headlight and then H16 for the fog lights? Thats what Amazon is saying I need. I have the same Tundra as you.
  19. Apr 18, 2019 at 7:18 PM
    #49
    TundraTSS19
    San Antonio, TX
    H4 for the headlights and H11 for the foglights. I know I've provided links to these bulbs a few times.
  20. Apr 19, 2019 at 12:57 PM
    #50
    danjmurr
    danjmurr New Member
    Thank you!
  21. May 6, 2019 at 12:52 PM
    #51
    codygs83
    codygs83 New Member
    Cody
    TX
    2019 Tundra TSS
    I love the auxbeam light output and beam pattern. But don't care for the blue tint. Are there any other good quality led h4 bulbs that are closer to white?
  22. May 6, 2019 at 1:15 PM
    #52
    TundraTSS19
    San Antonio, TX
    Blue tint? They're 5000k. That's pure white. You must be seeing things.
    bfd300 likes this.
  23. May 6, 2019 at 1:54 PM
    #53
    codygs83
    codygs83 New Member
    Cody
    TX
    2019 Tundra TSS
    All the
    I must be. All the info I've seen say 6k. And the pics from user reviews have a light blue tint to them
  24. May 6, 2019 at 3:51 PM
    #54
    TundraTSS19
    San Antonio, TX
    No you were right. My mistake. It is 6000k. I don't notice a blue tint though
    bfd300 likes this.
  25. May 6, 2019 at 4:19 PM
    #55
    codygs83
    codygs83 New Member
    Cody
    TX
    2019 Tundra TSS
    Yeah no worries. It could even be my phone screen showing more blue than they actually are. I had the cheaper hikari LEDs on my last car and they were 6.5k and too blue for my taste. But I do know that differ t brands are different colors regardless of the color they claim to be.
  26. May 6, 2019 at 4:26 PM
    #56
    TundraTSS19
    San Antonio, TX
    Phone screen versus in person is surely different
  27. Sep 29, 2019 at 1:02 PM
    #57
    ImmortallyInsane
    ImmortallyInsane New Member
    Hate to dig up an old thread but it may help someone in the future. Either I misunderstood or didn’t understand the orientation of the bulb. The “cup” needs to be at the bottom of the bulb when installing, meaning the cup is open towards the top as in this picture. I just finished pulling everything apart to turn the bulbs around. This made the auxbeam logo face the passenger side for both lights.
  28. Oct 3, 2019 at 11:14 AM
    #58
    TundraTSS19
    San Antonio, TX
    If you look at the picture and zoom in, you can see the cup is on the bottom.
  29. Oct 5, 2019 at 6:01 PM
    #59
    Yota100
    Yota100 New Member
    14 Tundra 4x4 97 T100 4x4
    14 Tundra 2.5 kings all around with remote reservoir and adjusters with 700# springs Total chaos bushing style control arms Camburg 1.5 inch lift shackles Coachbuilder polt bushings in leaf springs Bmc and front bumper trimmed 37x12.50x17 toyo MTs 17 inch Icon rebounds +25 offset 5% tint Winjet taillights True dual flowmaster super 40s ARB summit bumper Smittybuilt 12k winch White Knuckle Offroad sliders
    So the opening of the "cup" is open to the bottom ?
  30. Oct 7, 2019 at 6:49 AM
    #60
    TundraTSS19
    San Antonio, TX
    No. You just install it with the cup on the bottom. Simple as that and no need to over think it
