2019 Tundra SR - LED Conversion HELP
Discussion in 'Lighting' started by bjl10100, Feb 6, 2019.
  1. Feb 6, 2019 at 2:04 PM
    bjl10100
    bjl10100 [OP] New Member
    2019 Tundra SR
    Hello all!
    Just purchased a brand new 2019 Toyota Tundra SR (Work Truck Package).
    However, I would love to swap the stock halogen healdlight bulbs to a Cool White LED bulb (H4/9003/HB2). I dont need anything super bright. Just looking for the nice cool white appearance .
    I found two options on Amazon, but have had a hard time finding confirmed positive reviews for Tundras. Would love some suggestions and first hand successes!
    Here is what I found on amazon so far:
    https://www.amazon.com/Auxbeam-Head...65&keywords=auxbeam+nfs1&psc=1∣=AFLE0NKKTARYW
    https://www.amazon.com/Cougar-Motor...+HEADLIGHT&dpPl=1&dpID=51gmVUHlqlL&ref=plSrch
    Thanks in advance for any help!!
    ant8262 likes this.
  2. Feb 6, 2019 at 2:06 PM
    rustynail11
    rustynail11 New Member
    Scott
    Mansfield,TX (DFW Area)
    2017 Grey Tundra TRD
    results may not be what you are expecting unless you get new housings as well. You will scatter light, have bad cutoffs, and probably get flashed by other drivers quite a bit. LED bulbs don't perform well in the stock (or any) reflecting housing.
    Toothpick likes this.
  3. Feb 6, 2019 at 2:07 PM
    bjl10100
    2019 Tundra SR
    Really? Darn, That's unfortunate.
    Any other options that will give me what I'm looking for?
  4. Feb 6, 2019 at 2:49 PM
    bdpeelgren
    bdpeelgren New Member
    Round Rock, TX
    2014 Tundra CrewMax Super White
    Readylift 3/1, Rigid D-series fog lights, Supernova V.4, F/R Coverking covers.
    You can achieve a pretty good cut-off with LEDs. They just have to be aimed right.
    Even halogens have a little bit of scatter above the cutoff line. It’s unavoidable with a reflector housing.
  5. Feb 6, 2019 at 3:45 PM
    bjl10100
    2019 Tundra SR
    @bdpeelgren, Nice! Stock housings? Which bulbs are you using?
  6. Feb 6, 2019 at 4:34 PM
    Top
    Top New Member
    Tom
    2019 Crew Max Limited 4WD
    Bike Carrier
    I put in an HID kit from Xenon Depot on my wife's '14 4Runner. Had them for about 6 months now with no issues. Lots of wires/ballasts to hide. They don't heat up as much as the LEDs. You do have to adjust the level of the beam though but that's not difficult. One of the reasons we got the Limited Tundra was the LED lights.
    SWIPE and bjl10100[OP] like this.
  7. Feb 6, 2019 at 4:37 PM
    TundraTSS19
    TundraTSS19 New Member
    San Antonio, TX
    2020 Tundra TSS SR5 Crewmax 5.7L
    LED step bar light strips
    20181231_202703.jpg 20181231_202912.jpg 20181231_202916.jpg 20181231_200838.jpg
    No problems with my Auxbeam NF-S1. I Jane them in the headlights and fog lights. Only needed to adjust down one dial. Never been flashed in the 2 months I've had them installed. I'm out the door every morning at 530am so always night driving. Beam pattern is the same
    kbark, UncleJimmy and bjl10100[OP] like this.
  8. Feb 6, 2019 at 4:44 PM
    War Machine
    War Machine SSEM # 5 3MW
    Where are you located?
    Pudge likes this.
  9. Feb 6, 2019 at 4:48 PM
    TundraTSS19
    San Antonio, TX
    Sorry but that statement that HID bulbs running cooler than leds is untrue. HID bulbs consume more power than led bulbs and they get hotter than leds.
    bjl10100[OP] likes this.
  10. Feb 6, 2019 at 4:49 PM
    bjl10100
    2019 Tundra SR
    @TundraTSS19, thanks man! stock housings? Low and High beams are good?
    And @Top, I've never looked into HID's before, only because it seemed like less of a drop-in. Is there an advantage in the performance with stock housings?
    Also, I've seen some complaints of LED's screwing with people's car radio signals. What's that about?
    And @War Machine, I am located in Upstate NY.
  11. Feb 6, 2019 at 4:52 PM
    TundraTSS19
    San Antonio, TX
    Yes stock halogen housings and no issues with radio. Doesn't create any kind of interference. Surely don't put HID Kit into a halogen housing because there is no way to control the beam period!! The Auxbeam has the proper cap above the low beam to direct the light.
    bjl10100[QUOTED][OP] likes this.
  12. Feb 6, 2019 at 4:53 PM
    bjl10100
    2019 Tundra SR
    TundraTSS19 likes this.
  13. Feb 6, 2019 at 4:55 PM
    TundraTSS19
    San Antonio, TX
    They are polarity sensitive meaning you can install them backwards and there are two ways you can install them. Just make sure you install them with the metal cup facing downwards. You can remove the bulb from the black mount to install onto the headlight housing and then place the black headlight cap on before installing the bulb.
  14. Feb 6, 2019 at 5:12 PM
    War Machine
    In case you aren’t aware, you have to take the grill off and remove the headlights to change the lamps. If in your budget, it may be a good time to get aftermarket headlights if you want them.
    Same amount of work.
  15. Feb 6, 2019 at 5:31 PM
    bjl10100
    2019 Tundra SR
    Understood @War Machine,
    My budget is exactly the problem right now.
    Unless there are quality aftermarket headlights sub $150 I dont know about, lol.
  16. Feb 6, 2019 at 5:36 PM
    War Machine
    Just so happens I know a guy who just put in some new headlights and has some Spyders he doesn’t need.
  17. Feb 6, 2019 at 5:45 PM
    bjl10100
    2019 Tundra SR
    Honestly, they would have to be dirt cheap. There's a reason I'm only spending 40-60$ on just the bulbs right now. Things be tight.
  18. Feb 6, 2019 at 7:11 PM
    mrburns05
    mrburns05 New Member
    Jacob
    Menifee CA.
    2018 4.6L White DC SR5
    Maxtrac 3.5” Spindles Bilstein 6112 Icon AAL Icon 2.5” PB shocks Coachbuilder +1 Shackles AFE dry filter TRD AIA Magnaflow muffler TB Coolant Bypass
    I have the auxbeams, and I really like them. The light pattern is really good
  19. Feb 8, 2019 at 12:03 AM
    Hams
    Hams New Member
    Joel
    Fort Myers, FL
    16- Pro
    Camburg uniball UCA, Cooper AT3 XLT 295, Coachbuilder shims, shackles, and steering kit, SCS Ray 10, Undercover Flex Cover Ultra, GTR Lighting LED headlight and fog.
    I went with GTR lighting from headlight revolution. Led headlight and fogs, not cheap, but massive improvement over stock and cheaper than a quality headlight swap. Pic show low, low + fog, highs. As u can see the high beams scatter but rarely use them.
    SWIPE likes this.
  20. Feb 8, 2019 at 4:39 AM
    bjl10100
    2019 Tundra SR
    @Hams, GTR lighting - are those just bulbs swaps?
  21. Feb 8, 2019 at 9:55 AM
    Hams
    Hams New Member
    Joel
    Fort Myers, FL
    16- Pro
    Yes
  22. Feb 9, 2019 at 1:33 PM
    gs1197tx
    gs1197tx New Member
    TX
    Changed mine out with the Auxbeam NF-S1 a few weeks ago.
    My only complaint so far (and I don't believe it's a bulb issue because the stock halogen cast the same pattern) is the right side has a very noticeable bright spot about 25-30 feet out to the far right. I'm leaning towards it being a crappy reflector and the led just makes it stand out more.
    But I can see what's on the shoulder of the road much better, so not a total loss.
    Left side has an even pattern.
    Haven't been flashed by oncoming traffic....yet.
  23. Feb 11, 2019 at 9:14 AM
    rustynail11
    Scott
    I stand corrected on my earlier post. I have been wanting to switch to LED's but really can't drop the $500 plus for new housings with LED's. I have done a ton of reading and seen nothing but negative reviews on LED's in the stock housing.
    Looks like some good success with the Auxbeams. With the low price point may have to give them a try.
    One thing I really miss about my Jeep Wrangler is the abundance of aftermarket parts. When I switched to LED's I had a ton of options from $175 all the way up to $650
  24. Feb 11, 2019 at 12:13 PM
    TundraTSS19
    San Antonio, TX
    The negative reviews can come from not picking the proper led bulb. Some manufacturers claim to be good but utter garbage. The Auxbeam NF-S1 is designed exactly like a halogen with the leds placed exactly as the filament in a halogen bulb for low beam and high beam It also has the metal reflector for the low beam to project properly which gives an exactly beam pattern as a halogen. Some people have said that it produces light scatter. Well halogen ukbs produce light scatter as well. It's not a perfect cutoff but the Auxbeam will produce a pattern exactly as the oem bulb. Only thing I did was aim my lights down one click.
    ant8262 and bjl10100[OP] like this.
  25. Feb 19, 2019 at 12:49 PM
    rustynail11
    Scott
    I installed my Auxbeams over the weekend and not sure I did it right. Wheat do you mean by "metal cup facing on top" There was a cup and that is on top of the LED that way I installed. Is that what oyu mean or should the cup be in the bottom facing up?
    ant8262 likes this.
  26. Feb 19, 2019 at 7:21 PM
    TundraTSS19
    San Antonio, TX
    If you have a garage you can utilize or a wall or soenthing then you'll know if they're installed correctly. Have you tried driving at night to make sure the beam pattern is correct as well as the high beams? I'll have to get a picture of mine when it's light outside. It's late right now.
    ant8262 likes this.
  27. Feb 20, 2019 at 7:28 AM
    rustynail11
    Scott
    Need to check out the beam pattern against the garage door. I have drivin at night and it just seems that they are throwing light really high, like I go under a bridge and the underside is lit up. On the bright side (no pun intended) I haven't been flashed at all.
  28. Feb 20, 2019 at 7:59 AM
    TundraTSS19
    San Antonio, TX
    The only thing I had to do is adjust the headlights down one click of the adjustment wheel in the cab. Verify your high beams are actually throwing light further than low beam. When I initially installed my lights I had one in 180 degrees so when I used high beams the high beams would be lower than the low beams.
  29. Feb 20, 2019 at 8:04 AM
    ncorry
    ncorry New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    Well TSS19 Talked me into it. Amazon was running a 40% off coupon for the H11 fog lights so I got them too. I'll have the front off as soon as I get the dual color LED bar for the bumper mount delivered so I hope to do all the work at one time.
  30. Feb 20, 2019 at 9:17 AM
    rustynail11
    Scott
    May have to check the orientation of lights but I thought I was sure to put the metal cup so it was on top. When I was checking out the patterns on a dark back road while driving to work early this morning it appears as if the high beam was actually throwing more light towards the ground so maybe I need to flip them.
