2019 Tundra Pro Transmission Failure 19000 miles
Discussion in '2.5 Gen Tundras (2014-2021)' started by one4x4dad, Jan 24, 2020.
  1. Jan 31, 2020 at 4:08 PM
    #61
    one4x4dad
    one4x4dad [OP] New Member
    James
    Houston TX
    2019 Tundra Crew Pro
  2. Jan 31, 2020 at 4:10 PM
    #62
    one4x4dad
    James
    Houston TX
    They have guys around here remanufacturing transmissions for under $700. They are especialists!!
    jewsNbrews likes this.
  3. Jan 31, 2020 at 5:28 PM
    #63
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    That's scary, buying a rebuilt from a guy that is an "especialist" and can't spell "heavy". There are all kinds of rebuilt transmission and how they are rebuilt. Some of cheaper trans rebuilders will only replace what they see is the issue and leave the rest.
    rodm1 and WNY PAT like this.
  4. Jan 31, 2020 at 5:47 PM
    #64
    Ob1
    Ob1 New Member
    You better ride that tranny hard now (no pun), cause if it craps out on you after warranty, you might be needing that "especialist" tranny guy.
  5. Apr 8, 2020 at 9:15 AM
    #65
    Paxrom
    Paxrom New Member
    2020 Tundra SR5
    Leds
    Now I'm even more paranoid about them removing muh transcooler. Yup adding back the transcooler is going to be my first performance mod.
  6. Apr 8, 2020 at 9:41 AM
    #66
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Maybe just relax and stay off the forum, keep searching and you will be scared to drive it. :goingcrazy:
  7. Apr 8, 2020 at 10:22 AM
    #67
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Ya'll are being too hard on tranny guy. After all, his wife probably had to translate that ad from Espanol to English. :D
    Ob1[QUOTED] likes this.
  8. Apr 8, 2020 at 11:59 AM
    #68
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    They won't do factory new at 19K but at least they did Remanufactured.
    Generally, "remanufactured" indicates that a unit has had additional machine work that bring the quality level to the same standard as a new part.
    While a "rebuilt" transmission usually implies that only worn-out parts have been replaced, the process to remanufacture a transmission is typically much more thorough...
    Ruggybuggy and JLS in WA like this.
  9. Jul 24, 2020 at 5:39 AM
    #69
    blanchard7684
    blanchard7684 New Member
    OP...any updates? Things going well for you?
  10. Jul 24, 2020 at 5:59 AM
    #70
    TundraGuy68
    TundraGuy68 New Member
    My 2 cents.
    If the trans is being replaced by a Toyota dealer, under Toyota warranty you will get a "new / re-manufactured" trans from Toyota corporate which is a GREAT trans. Not a rebuilt trans from some local shop.
    Factory REMAN is quite different than local shop rebuild. Just watch the engine assembly videos, showing how they torque the engines main cap bolts with a multi socket tool that torques them ALL at the same time! Not the 1 bolt, 2 bolt, 3 bolt, etc. torque sequence that local shops have to follow.
    I would tell the Service Manager that you want the trans pan pulled so you can look at the fluid in the pan. If you see anything that looks like metal or "metallic paint shimmer" in the pan, demand a new torque converter. Because any metal in the TC cannot be flushed out and the TC is trash.
    Don't let them give you that "We don't allow customers in the shop" BS, I had my 2018 Corvette Z06 transmission valve body replaced under warranty at a Chevy shop here in CO and watched them do the WHOLE job. There was no way I was letting my $100K car out of my sight!
    BTW: is Bruce Jenner a re-manufactured trans?
    Ob1 likes this.
  11. Jul 24, 2020 at 6:01 AM
    #71
    TundraGuy68
    My bad, you said REMAN. I agree, under warranty you get a factory reman trans.
  12. Jul 24, 2020 at 7:09 AM
    #72
    timsp8
    NY
    Trans went out on my 2010 within warranty. I got a remanufactured one. It went out 30k later.
  13. Jul 24, 2020 at 8:48 AM
    #73
    JohnLakeman
    Surest way to message a poster using a post is the tag. @one4x4dad
    jewsNbrews and YardBird like this.
  14. Jul 26, 2020 at 12:55 PM
    #74
    Ob1
    Ob1 New Member
    Did they replace it the second time? And with what, remanufactured again? And has it held up?
  15. Jul 26, 2020 at 2:43 PM
    #75
    timsp8
    NY
    First time was just under 60k so it was under power train warranty. I traded it in around 94k. I could tell it was going out and got a few check engine codes right before I traded it in. Had Toyota look at it and they said it was fine so I traded it.
    A few days ago I got an email that my car fax report was ready. I guess the new owner got it serviced and my email was still in the system for the vin. I looked at the car fax and about 8 months after he bought it, it said replaced transmission.
    I guess my original post should have said it was going out 30k later. It now has 116k according to car fax, so between 94k and 116k it had to be replaced again.
    The remanufactured one they gave me had a lot of issues though. Always shifted weird and would get up to 250F on hills sometimes not pulling anything.
  16. Jul 26, 2020 at 8:37 PM
    #76
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    We had a similar issue with a Tacoma at the dealership. Customer was having shifting issues. TASC said to replace the transmission but not the torque converter. Tacoma came back a month later and this time TASC said replace the transmission again with the TC. We did the work and the customer traded it in. It was sold at the dealership as used to a new customer and it came back after another month with transmission issues. TASC told us to replace the transmission, TC and ECM. Never came back, yet.
    Ob1 and jewsNbrews like this.
