2019 Tundra LED bulbs
Discussion in 'Lighting' started by ALP_Tundra, Mar 29, 2019.
  1. Mar 29, 2019 at 9:41 PM
    ALP_Tundra
    ALP_Tundra [OP] New Member
    2019 Cement Tundra SR5 CrewMax
    Hello I’m trying to change my stock bulbs to LED. I want to make sure I purchase the correct ones since my local Auto Zone does not have them in their system. By any chance can someone share/recommend what headlight bulbs are needed. Appreciate the help.
  2. Mar 29, 2019 at 10:38 PM
    rmvcard0303
    rmvcard0303 New Member
    Ray
    San Gabriel Valley, CA
    2019 White Tundra TRD Sport CM
    I’d rather not list. My wife might see it.
    AZ would be the last place to go for
    your mods. Many vendors (Headlight Revolution, VLEDS, etc) offer vehicle specific LED replacements. That would be the easiest route but not necessarily the cheapest. I’ve used these vendors and very happy with the results.
    I’ve also experimented with cheaper bulb replacements via Amazon. I use modifiedlife.com as a guide to which bulbs to buy for a specific light I am trying to replace. Not all LED bulbs (even the same model number) are the same and are plug and play replacements. READ the bulb description and see if it is the application you want.
    Most sites only list up to 2018. I have a 2019 model and no issues using the “2018” replacement guides. Good luck.
  3. Mar 30, 2019 at 5:15 AM
    TundraTSS19
    TundraTSS19 New Member
    San Antonio, TX
    2020 Tundra TSS SR5 Crewmax 5.7L
    LED step bar light strips
    rmvcard0303 likes this.
  4. Apr 9, 2019 at 7:59 AM
    ncorry
    ncorry New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    I listened to TundraTSS19 and went with the Auxbeam set up too. I am very happy with them. Just pay attention to which direction the silver spoon in the halogen light is oriented when removing them and make sure to orient the AuxBeam headlight the same way.
    TundraTSS19[QUOTED] likes this.
  5. Apr 11, 2019 at 9:59 AM
    steve-smith
    steve-smith New Member
    2019 Toyota Tundra
    310 to 381 hp
    Something weird going on with my truck, about a year ago my turning signals just quit working no hazards either. Traced it to the hazard key itself replaced it and now my turning signals are hot all the time but work and my battery drains after 24 hours. I can look at the battery gauge and see that it's not all the on 0 so thing is staying hot without the key in it. Please advice me guys from your end.
  6. Apr 11, 2019 at 10:04 AM
    So these new '18-'19 led HL's, the led bulb high/low can be changed out? I thought I read somewhere that they couldn't be changed out?
  7. Apr 11, 2019 at 10:55 AM
    TundraTSS19
    San Antonio, TX
    If they're actual LED headlights then no they can't be changed out. If they're the halogen housing with halogen bulbs then the halogen bulbs can be changed out for LED bulbs.
    I've also changed out my brake, turnsignal and 3rd brake light and front turnsignal bulbs to all LED as well. Front turn signals are brighter and the tail/brake and turnsignals are brighter and crisper now with the flash on and off instead of glow on and off. I put a 50ohm resistor on the rear tail lights to avoid hyper flash and all is good.
    4PCS ARTR 50W 6ohm Load Resistors - Fix LED Bulb Fast Hyper Flash Turn Signal Blink Error Code(Resistor gets very hot during working) https://www.amazon.com/dp/B00UNG3EXQ/ref=cm_sw_r_cp_apa_i_gb4RCb2ZWTBM3
    NAKOBO 921 912 906 LED Bulb 1000 Lumens 45-SMD 4014 Chipsets Error Free 902 904 T15 W16W LED Bulbs for Back Up Lights Reverse Lights, Pure Red(pack of 4) https://www.amazon.com/dp/B07MVG9LKH/ref=cm_sw_r_cp_apa_i_Ib4RCbVDK7EGB
    ANTLINE Extremely Bright 3157 3156 3057 4057 4157 3157LL 4157K 3057K 3457 21-SMD 1260 Lumens LED Bulb Replacement Amber Yellow for Car Turn Signal Blinker Side Marker Lights Bulbs (Pack of 4) https://www.amazon.com/dp/B07MYWPFTD/ref=cm_sw_r_cp_apa_i_4b4RCb17THRH3
    ANTLINE Extremely Bright 3157 3156 3156A 3057 4057 4157 3057LL 3457 3157K 21-SMD 1260 Lumens LED Bulb Replacement Brilliant Red for Car Brake Tail Turn Signal Blinker Lights Bulbs (Pack of 4) https://www.amazon.com/dp/B07MYX6Z2N/ref=cm_sw_r_cp_apa_i_oc4RCbMC8WAPM
  8. Apr 11, 2019 at 11:12 AM
    My tails and 3rd brake are both LED, except reverse and license plate which I don't care for, Actually they are Sylvania super white halogen, I just put the '19 PRO HL's on, the side maker are halogen but amber, the turns are halogen as well but think about switching to LED, thanks for info
