2019 TRD Pro bbs wheels
Discussion in 'Wheels & Tires' started by Tundra1078, Sep 12, 2018.
  1. Oct 6, 2018 at 2:14 PM
    #61
    SoCal619
    SoCal619 New Member
    315 FTW...
  2. Oct 6, 2018 at 2:18 PM
    #62
    CCTundra
    CCTundra New Member
    Seattle,WA
    2016 Platinum Tundra
    FabTech 4" lift with dirt logic coil overs, Canopy, LT305/55R20 Cooper ST Max, 20" Black Fuel Wheels
    I love the 305/55/20's. I have the Fabtech Dirt Logic lift kit that they offer. It's about a 3" lift in the front and a small lift in the back. I love my lift. The dirt logic shocks are amazing. I love the ride man. I used to drive a 2008 F-150 Harley Davidson edition on 35's. Suspension was rough. This truck rides like I am riding on a cloud. I have a 20x9 with a +25 offset wheel. I like the combo a lot. Wheels stick out a little bit, but not too much. I have some aftermarket mud flaps that keep the rocks away from my truck.
  3. Oct 6, 2018 at 2:22 PM
    #63
    fatalkhaos
    fatalkhaos New Member
    2019 Tundra TRD PRO CM
    Sway Bar 20x10 Fuel Assault 295/55r20 Toyo AT
    Yeah I have an aggressive offset with 20x10 but the fender flares cover the offset perfectly with 295/55. However looking to possibly do a coach builder shim for just little more lift but want to be able to fill the qheel well
  4. Oct 8, 2018 at 9:22 AM
    #64
    Yotaman18
    Yotaman18 New Member
    Corey
    Houma, LA
    2018 Platinum 4x4 Bitching Blue
    Anyone know the offset on the 2019 trd pro wheels?
  5. Oct 8, 2018 at 9:44 AM
    #65
    jordanpop1
    jordanpop1 New Member
    +60 mm
  6. Oct 8, 2018 at 10:08 AM
    #66
    Yotaman18
    Corey
    Houma, LA
    Thanks! So I'd be in the same situation as I am with my tss rims basically but man they sure are pretty.
  7. Oct 8, 2018 at 3:30 PM
    #67
    Xrunner1224
    Xrunner1224 New Member
    Jeff
    2017 cement tundra trd pro
    The truck has alot more get up and go now
    SR5 AZUL likes this.
  8. Oct 12, 2018 at 10:08 AM
    #68
    Paul
    Paul New Member
    Roman, this is incredibly helpful. If you don't mind, I was wondering what the part number is for the center cap? I've poked through your encyclopedic threads (pasted below), but was unable to track down the center cap part number.
    On a related note, is Toyota of Cool Springs still on a manual allocation (require VIN) for the BBS (PT960-34190-02)?
    https://www.tundras.com/threads/2019-tundra-trd-pro-parts.29476/
    https://www.tundras.com/threads/ultimate-oem-toyota-parts-thread.10707/
    fatalkhaos likes this.
  9. Oct 12, 2018 at 12:21 PM
    #69
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    Here is a link to the center cap:
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-btn-ctr-cap-tun-trd-pt2803419002
    As of right now, these wheels are not on our MAC report. So, they should be good to go for ordering.
    Watt maker likes this.
  10. Oct 12, 2018 at 1:56 PM
    #70
    Paul
    Paul New Member
  11. Oct 12, 2018 at 2:15 PM
    #71
    Roman
    Roman
    Franklin, TN
    No problem. According to the information Toyota has on the wheels, the offset is +60.
  12. Oct 14, 2018 at 7:11 PM
    #72
    Paul
    Paul New Member
    Hi Roman,
    I was planning on installing these BBS wheels on a 2014 Land Cruiser (110.0 mm center bore). However, I think (but am not sure) that the center bore for the Tundra enlarged slightly from 110.0 mm in 2013 (same as my Land Cruiser) to 110.5 mm starting in the Tundra's 2014 model year. Accordingly, the BBS may not be compatible if my desire was to use the BBS wheels as "hub centric" (rather than "lug centric") to bear the brunt of the ~6,000 lb Land Cruiser. Would it be possible to check the center bore for the BBS wheel?
  13. Oct 15, 2018 at 1:42 PM
    #73
    Roman
    Roman
    Franklin, TN
    Unfortunately, Toyota does not list the hub bore with the wheels specs, but I do know the hub bore of a 2019 Tundra is 110.5mm.
    equin likes this.
  14. Oct 22, 2018 at 11:05 AM
    #74
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    2010 Super White DC
    Do these have removable center caps? I'm considering buying some of these but want to black out the red in the center and am wondering how difficult that would be...
  15. Oct 22, 2018 at 12:47 PM
    #75
    Roman
    Roman
    Franklin, TN
  16. Nov 27, 2018 at 8:36 AM
    #76
    bensky
    bensky RedRover
    Ben
    Utah
    2018 Red Platinum Tundra
    Did you sell these?
  17. Nov 27, 2018 at 4:05 PM
    #77
    jordanpop1
    Yes they have been sold
  18. Nov 27, 2018 at 4:06 PM
    #78
    bensky
    bensky RedRover
    Ben
    Utah
    Thanks for the reply!
  19. Nov 29, 2018 at 3:36 PM
    #79
    upserkyle
    upserkyle New Member
    ‘18 Cement Limited
    Will the ‘19 Pro center caps fit the TRD off road wheels?
  20. Nov 29, 2018 at 3:45 PM
    #80
    Donkeypunch
    Donkeypunch New Member
    Anyone else have a set they want to get rid of?
  21. Nov 30, 2018 at 6:35 AM
    #81
    alpinepro4
    alpinepro4 New Member
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    I can’t be looking at this shit! New fordge wheels are sick. Now I need a set, saving my pennies now.
  22. Dec 22, 2018 at 11:00 AM
    #82
    kgb4187
    kgb4187 New Member
    equin and bensky like this.
  23. Dec 26, 2018 at 2:58 PM
    #83
    Ubnpast
    Ubnpast New Member
    Nice wheel, too bad michelin doesnt make an aggressive looking tire.
  24. Dec 30, 2018 at 6:42 PM
    #84
    rnssncman
    rnssncman Purveyor of the Good News
    2019 Tundra Limited White
  25. Dec 31, 2018 at 9:22 AM
    #85
    Roman
    Roman
    Franklin, TN
    They will not. they only fit the 2019 TRD Pro Tundra wheels.
  26. Jan 5, 2019 at 2:52 PM
    #86
    bensky
    bensky RedRover
    Ben
    Utah
    @Roman Need BBS Wheels and Fox TRD suspension. Please help!:help:
    ryanwgregg likes this.
  27. Jan 5, 2019 at 7:35 PM
    #87
    hunter35745
    hunter35745 New Member
    Keith
    Prince George, VA
    2018 Tundra Platinum Super White
    Ionic 5" stainless tube steps, Weathertech vent visors front and rear,Weathertec all weather mats, Shorty antenna, TRD cold air intake,oil cap,radiator cap ,rear sway bar and dual exhaust,console safe, color match mirror caps,gloss black color match door handles, Tinted D&P front windows, Line X Premium spray in bed liner, TRD front swaybar
    I want those and the tires, who wants to sell theirs. I really like the look, So can anyone buy those from a dealer
  28. Jan 7, 2019 at 8:11 AM
    #88
    Roman
    Roman
    Franklin, TN
  29. Jan 7, 2019 at 11:57 AM
    #89
    SR5 AZUL
    SR5 AZUL TRD
    2015 Blue Ribbon Tundra SR5 Trd off road crewmax 4x4
    iHacker likes this.
  30. Jan 7, 2019 at 12:32 PM
    #90
    Berettafan
    Berettafan New Member
    2017 CM
    what do these wheels weigh vs the prior pro wheels?
