2019+ External Transmission Cooler
Discussion in '2.5 Gen Tundras (2014-2021)' started by Genuine Cooling Systems, Oct 17, 2019.
  1. Jan 15, 2020 at 7:34 PM
    #181
    Genuine Cooling Systems [OP] New Member Vendor
    The thermostat will control the fluid going to the cooler. If the atf is not 190-200 degrees the thermostat won't open.
    The warmer will warm the atf until it it reaches that point, then the warmer gets cut off.
    sask3m[QUOTED] likes this.
  2. Jan 17, 2020 at 6:30 PM
    #182
    Got the hose on. Going to do the check and fill tomorrow morning.
    jtwags, sask3m and Mike19 like this.
  3. Jan 17, 2020 at 6:42 PM
    #183
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Double clamped? Different than the warmer clamps.
    So did the spacer removal and thermostat addition go well, any difficulties?
  4. Jan 17, 2020 at 8:09 PM
    #184
    Finally done. Filling her up tomorrow.
  5. Jan 17, 2020 at 8:11 PM
    #185
    Put the double just in case. It is almost impossible to put the clamps on when the cooler is installed so you have to clamp the hose while the cooler is dangling then install.
  6. Jan 17, 2020 at 8:15 PM
    #186
    For anyone interested. I have 2 brackets just like the one I installed with all the hardware for 150$. PM me if interested.
  7. Jan 17, 2020 at 8:45 PM
    #187
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I have to ask, did you use trans cooler hose and not fuel line hose?
  8. Jan 17, 2020 at 8:47 PM
    #188
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Impossible? You mean where you double clamped the thermostat or was it the cooler up front that was difficult to clamp?
  9. Jan 17, 2020 at 8:50 PM
    #189
    Gates transmission cooler hose.
    Ruggybuggy[QUOTED] likes this.
  10. Jan 17, 2020 at 8:52 PM
    #190
    It's a tight space. I was not able to get the hose on the barbs while it was installed.
  11. Jan 17, 2020 at 9:05 PM
    #191
    Jorgy1
    Jorgy1 New Member
    Shaun
    Lethbridge AB
    2019 MGM Tundra CrewMax 4x4
    Looks great Nick. I just picked up my bracket from you at the border today, looks great thanks.
  12. Jan 17, 2020 at 9:14 PM
    #192
    Boosted4runner
    Boosted4runner Join the NRA please.
    WA
    2015 DC MGM TRD Tundra, Kings, 5.7, 2018 front end
    Resi Kings, 35” Trail Grapplers on 18” Methods, ICON Delta Upper Arms, Front-Runner bed rack, Yakima SkyBox16, 2018 honeycomb grill, 2018 LED headlights, plastidipped bumper covers
    LOL! Completely off topic and random, but I started cracking up when I read this. For 30 years I thought “nip it in the butt” as well. Never thought twice about it .
    One day I googled it, and found out the correct terminology is “nip it in the bud”. As in cutting off the growth of a plant - or stopping something.
    Just thought I’d mention it. LMAO!
  13. Jan 17, 2020 at 11:06 PM
    #193
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    How about breaks and brakes. :rolleyes:
    Jorgy1 and Cpl_Punishment like this.
  14. Jan 18, 2020 at 2:04 AM
    #194
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    AN and JIC are NOT the same (.5* difference in taper) but are interchangeable.
    Just for people searching in the future.
    HappyGilmore likes this.
  15. Jan 18, 2020 at 4:00 AM
    #195
    They are 10 AN fittings with O-Ring. I know because that's what I have installed.
  16. Jan 18, 2020 at 4:08 AM
    #196
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    How much of the cooler does the mounting bracket cover? Hard too tell from yesterdays pics.
  17. Jan 18, 2020 at 4:22 AM
    #197
    rockmup
    rockmup New Member
    Todd
    I wasn't disputing that, you're correct, that's what they are. I didn't say they weren't.
    I actually quoted the wrong guy, he said AN and JIC are the same. While they do interchange, they are not the same.
  18. Jan 18, 2020 at 4:22 AM
    #198
    20" x 10"
  19. Jan 18, 2020 at 7:56 AM
    #199
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    That was me. I stand corrected.
  20. Jan 18, 2020 at 9:25 AM
    #200
    rockmup
    rockmup New Member
    Todd
    No worries.
  21. Jan 18, 2020 at 3:27 PM
    #201
    SnowLizard
    SnowLizard New Member
    Richard
    this is ODD...
    just stumbled on this thread and it's kinda hard to believe that I don't have a transmission cooler...
    the REASON I find it hard is my 'purchase sticker' from the truck the day i bought it says...
    So, does my 2019 SR5 with Tow Package have a trans cooler or not??
    Looking through this thread, and seeing pictures, and checking my truck... I have the round body with two hoses going to the "Trans cooler" on the Pas Side of trans, but not the "Thermostat Unit"... that goes between trans and cooler...
    so I def have a trans cooler... but how does it work? what is being sent into the the trans cooler? is that water? or is trans fluid being sent out?
    Just try'n to learn something new...
  22. Jan 18, 2020 at 4:19 PM
    #202
    Gotcha. I didn't
    If you have a 2019+ you don't have a cooler, just a warmer.
    rockmup[QUOTED] likes this.
  23. Jan 18, 2020 at 5:04 PM
    #203
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    The cooler your looking at uses antifreeze from the engine to cool the oil in the transmission. If the engine temp runs at a stead 200F then when the transmission is colder the temp is brought up to a warmer temp. When the transmission is running warmer in the summer, say 220F, the excess heat is dumped into the engine cooling system. Liquid to liquid heat exchangers are more efficient than air to liquid. Some here are worried that the temps on the 2019 and 2020 may run too warm when towing and cause reliability issues.
    WNY PAT and GODZILLA like this.
  24. Jan 18, 2020 at 6:25 PM
    #204
    WNY PAT
    WNY PAT New Member
    And others worry that over time, with this design, the transmission fluid can mix with the antifreeze creating the “strawberry milkshake of death”... which is another way of taking out the transmission.
    I leased my 2019 for 2 years / 24K so I’m in this just out of curiosity... I’m sure it’ll be fine in the short term regardless of increased temps... and I do tow a lot with it... so it’ll make a good test mule. I also have a 2017... so this summer I plan to do some back to back testing just for fun.
    sask3m and Ruggybuggy like this.
  25. Jan 18, 2020 at 7:00 PM
    #205
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Well nothing has really changed as far as this milkshake thing cause the warmer has been cycling coolant on these trucks down there since at least 07.
    GODZILLA, WNY PAT and Ruggybuggy like this.
  26. Jan 18, 2020 at 7:21 PM
    #206
    WNY PAT
    WNY PAT New Member
    Ah. I thought that prior years it couldn’t mix for some reason.
  27. Jan 18, 2020 at 11:31 PM
    #207
    SnowLizard
    Richard
    so it is a cooler, they just moved the 'radiator' coil (from the bottom tank) next to the trans... at least it's not running water into the trans itself, it's outside the trans, and the fluid doesn't have to go as far.
    I tow a 20ft 4k lbs camper trailer, it'll be interesting to see once I get a monitor for that (probably ultra gauge)... wish the built in dash could do that.
  28. Jan 19, 2020 at 7:06 AM
    #208
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    That's the million dollar question. Does the 2019-20 need an additional cooler? Some members had reported higher trans temps than the previous years so the question that's debated is what is an acceptable transmission temp and will running the transmission warmer than previous years cause a reliability problem.
    To monitor you trans temps the cheapest way is to use the Torque or Fusion apps with an obd2 bluetooth adapter. Total cost is can be as low as $20 depending on what you buy.
  29. Jan 19, 2020 at 9:47 AM
    #209
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    What about the big three do any of their trucks use a similar cooling setup or do they all still use external coolers? Of course we all know their trannys can't compete with the Aisin.:thumbsup:
  30. Jan 19, 2020 at 9:50 AM
    #210
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Doesn't Ram use an Aisin transmission in their heavy duty diesels?
    This is what GM's website says their trucks have.
