2019+ External Transmission Cooler
Discussion in '2.5 Gen Tundras (2014-2021)' started by Genuine Cooling Systems, Oct 17, 2019.
  1. Jan 12, 2020 at 9:37 AM
    #151
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Some. Probably less than a quart. The ATF won't be under pump pressure, and you're talking only about passage and cavity volumes higher than the side openings. The real volume in the converter is pretty much trapped.
    In your position, I would forget about trying to jack up the right side higher than the left to prevent ATF leaking out. Whatever that volume is; it is what it is. ATF is cheap compared to your safety. You may need to jack the truck up, and place jackstands on four corners just to get working room (Don't do this unless you need to; working under a raised vehicle is risky enough without jackstands.) Jacking one side higher than the other, especially while using jackstands, is the perfect recipe to get you squashed like a bug. :eek:
    WNY PAT likes this.
  2. Jan 12, 2020 at 9:40 AM
    #152
    Genuine Cooling Systems [OP] New Member Vendor
    Okay, if it's less than a quart I will be good. I have 4 quarts on hand to fill the cooler, hose, and whatever I lose from taking off the plate. Thanks for your help.
  3. Jan 12, 2020 at 9:43 AM
    #153
    JohnLakeman
    I said maybe less than a quart, but I have absolutely no way of knowing. Buy 20% to 30% more fluid than you think you'll need. If you have some left over, you can always use it for "drain and fill" maintenance.
  4. Jan 12, 2020 at 9:47 AM
    #154
    Hmmm. I might just jack the side up so I don't lose more than I have. I have 6-ton jack stands that will be more than safe. Plus, the truck only have 1900 miles on it, no need to lose fluid if it is preventable.
  5. Jan 12, 2020 at 10:04 AM
    #155
    JohnLakeman
    The issue is NOT the capacity of the jackstands. The problem is the stability of jack stands with the contact patch potentially angled or sloped, potential contact area reduction, unstable platform, etc. If you don't have enough experience to make a good assessment, you could injure or kill yourself.
    For the safety of you and your Tundra, my advice once more before you begin is that you should pay someone to install this cooler for you. Take your Tundra and the parts you've acquired to an RV store/shop and get a quote for the installation labor.
  6. Jan 12, 2020 at 10:26 AM
    #156
    It is honestly not that hard. If you use the frame and have double redundancy it's not an issue. I will not pay someone to do this when I have all the tools needed and common sense.
  7. Jan 12, 2020 at 10:37 AM
    #157
    timsp8
    NY
    Maybe get some ramps instead of jack stands and just drive the passenger side front and rear up on them. Seems safer as long as you chalk it so it doesn’t roll.
    I’m always worried every time I work under a jacked up vehicle.
    JohnLakeman and WNY PAT like this.
  8. Jan 12, 2020 at 10:55 AM
    #158
    I am not trying to overthink it.
    sask3m likes this.
  9. Jan 12, 2020 at 11:21 AM
    #159
    JohnLakeman
    "Reports that say that something hasn't happened are always interesting to me, because as we know, there are known knowns; there are things we know we know. We also know there are known unknowns; that is to say we know there are some things we do not know. But there are also unknown unknowns – the ones we don't know we don't know. And if one looks throughout the history of our country and other free countries, it is the latter category that tend to be the difficult ones."
    Donald Rumsfeld, 2/12/2002
    Cpl_Punishment and Ruggybuggy like this.
  10. Jan 12, 2020 at 12:51 PM
    #160
    I guess I choose to live in the "unknown unknowns".
  11. Jan 12, 2020 at 12:55 PM
    #161
    JohnLakeman
    With what's at stake here, I would consider "overthinking it" a good thing, but's thats just me.
  12. Jan 12, 2020 at 1:22 PM
    #162
    Already done boss.
    Vizsla likes this.
  13. Jan 12, 2020 at 4:31 PM
    #163
    Got the spacer removed and the cooler installed. Only lost ATF that was in the warmer. Now, just waiting for my final revision of my cooler radiator mount to come in on Tuesday and will get everything buttoned up.
    Joe333x, Jorgy1, sask3m and 1 other person like this.
  14. Jan 12, 2020 at 5:21 PM
    #164
    pickeledpigsfeet
    pickeledpigsfeet New Member
    Sierra Foothills, Ca
    2019 Tundra/14 FJ/ 90 SASed xcab
    Kings & Icons
    Did you notice if the spacer orings were the same size as the ones that came with cooler plate? Thinking about picking up some spare orings incase one gets pinched, but if the spacer ones are the same size then I wont bother.
  15. Jan 12, 2020 at 5:54 PM
    #165
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Your still alive. :thumbsup:
    Cpl_Punishment and Vizsla like this.
  16. Jan 12, 2020 at 5:56 PM
    #166
    The spacer o-rings are the same size. The cooler I bought came with the o-rings on it so the ones in the photo are extras.
  17. Jan 12, 2020 at 5:56 PM
    #167
    It was a close call.
    Vizsla and sask3m[QUOTED] like this.
  18. Jan 12, 2020 at 6:05 PM
    #168
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    How tight did you go with the warmer/thermostat bolts when you reassembled?
  19. Jan 12, 2020 at 6:19 PM
    #169
    I just snugged them then put maybe a 8th of a turn. We will see if it leaks when I get everything hooked up.
  20. Jan 12, 2020 at 6:24 PM
    #170
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Yeah, they're squeezing o- rings so good and snug is likely enough.
    Trying to slow myself down, lol, -30 here so gonna be awhile till I attempt this.
  21. Jan 12, 2020 at 6:26 PM
    #171
    Lol. Yeah I'm sure your transmission doesn't need a cooler right now.
    sask3m[QUOTED] likes this.
  22. Jan 14, 2020 at 5:26 AM
    #172
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    I’m surprised no one has added a b&m tranny pan, It adds an additional 3.5qts capacity...
  23. Jan 14, 2020 at 2:47 PM
    #173
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Does it make a significant difference in temperature though? Pretty expensive to find out.
  24. Jan 14, 2020 at 5:46 PM
    #174
  25. Jan 15, 2020 at 6:57 AM
    #175
    blaserdude
    blaserdude New Member
    Eugene
    2019 Tundra Limited Double Cab
    none
    Nice! Looks like your new mount is in a different position than at first. Any chance of a pic w/o the grill?
    Regards,
    bc
  26. Jan 15, 2020 at 7:03 AM
    #176
    WNY PAT
    WNY PAT New Member
    Wouldn’t think so as the transmission temp is going to generally follow the temp of the coolant with this set up, right? It might take a bit longer to get additional fluid up to the “designed” operating temp but once it’s there it *should* be pretty stable unless you’re really pulling up a hill. But it’s probably going to average 220ish all the time with the factory set up regardless.
  27. Jan 15, 2020 at 8:20 AM
    #177
    This is a picture I took last night so not the best quality. The cooler is not tightened all the way so its sagging a little bit. I am now just waiting on 45° adaptors to come in the mail to hook up the hose and fill the tranny with ATF with a level check. I am trying to complete this project as soon as the adaptors come in then I will see if there is any interest in folks buying the mount I designed.
    TRD15559, jtwags and sask3m like this.
  28. Jan 15, 2020 at 9:03 AM
    #178
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Did you end up running hose all the way from the trans thermostat to the cooler or did you use the oem metal lines as well?
    Cooler design change, just using the three tapped areas to mount it?
  29. Jan 15, 2020 at 10:39 AM
    #179
    I haven't ran hose yet. I need to wait until the adapters come in then drill holes and put grommets on the air deflector. I will have everything done here in a few days.
  30. Jan 15, 2020 at 2:39 PM
    #180
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    I see many trans coolers have what they call "cold weather bypss" that redirects thicker trans fluid back to the transmission until it warms up. Is a type of cooler like this necessary seeing as we also have the warmer?
    On the other hand I guess the thermostat kind of controls flow regardless.
