2019 crewmax limited no stake pockets?
Discussion in '2.5 Gen Tundras (2014-2021)' started by soobahru, Jun 19, 2020.
  1. Jun 27, 2020 at 7:58 AM
    ekinnee
    ekinnee New Member
    North Central Texas
    2020 Tundra Quicksand SR5 TSS
    So for those of us with edge caps that have no markings, are the stake pockets the 5 bumps just under the lip of the bed? I don’t have the rail system, on mine there’s what appear to be shallow stake pockets with a screw hole in them.
  2. Jun 27, 2020 at 9:28 AM
    LJOHNS
    LJOHNS New Member
    Look inside the bed and find the hole where you would expect a stale pocket to be. Use a straight edge to find the center and mark that on the plastic bed cap cover. Use a drill bit to put a hole in the cap cover and cut the rest out with a Dremil or utility knife.
    zzavadel and Cpl_Punishment like this.
  3. Jun 27, 2020 at 9:55 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    zzavadel, soobahru[OP] and ekinnee like this.
  4. Jun 28, 2020 at 4:58 AM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    Right...didn’t know they changed the plastic molding on the side rails...interesting...
  5. Jun 30, 2020 at 9:01 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    Toyota probably doesn't want the average owner (non forum member DIYer) to be able to find them.
    That way they can charge you $600 for cutting them out
    Cpl_Punishment likes this.
  6. Jun 30, 2020 at 11:01 AM
    rebmo
    Rural SE Wisconsin
    2020 CM LImited 5.7L V8 4WD
    It’s for improved aerodynamic flow and better mpg.
    GODZILLA and BravoDeltaRomeo like this.
  7. Jul 1, 2020 at 7:41 AM
    dugfur
    dugfur New Member
    doug
    2016 limited DC
    I have a 2016 limited that had them originally. I recently bought new ones from Roman at cool springs cause I had a run in with a snow bank last winter and the replacement did not have the cut-outs. Maybe Roman can chime in...………………...
  8. Jul 2, 2020 at 4:00 AM
    timdske
    timdske Another Old Guy
    Fort Worth Texas.
    2019 MGM SR5 4x4 Tundra TSS Offroad
    My 19 has the cutouts marked. I don't need them at this point so I'm leaving them alone.
  9. Jul 22, 2021 at 1:03 PM
    jlarkin1918
    jlarkin1918 New Member
    Jared
    Western Massachusetts
    2020 SR5 TRD Offroad Crewmax-Cement
    OEM Spray-In Liner TRD Pro Black Badges & center caps GoRhino RB20 running boards Lomax cover
    Anyone have measurements for a 2020 crewmax as those don’t have the cutouts marked on the top.
    I guess I can pop the rail cap out and cut from the bottom but I’d rather just find the stake pocket and use a trim router. Bull Rings are in the mail, Hoping to install 4 this weekend.
  10. Jul 22, 2021 at 2:27 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    my 2021 SR5 has the cutouts on the plastic. Maybe it matters which trim level/package it is for people who dont have the cutouts.....
  11. Jul 22, 2021 at 2:42 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Use a router with follower bearing, or a zip tool for cutting outlets holes on sheet rock
  12. Jul 27, 2021 at 11:00 PM
    soobahru
    soobahru [OP] New Member
    2015 tundra 5.7L double cab 6.5ft 2019 tundra 5.7L limited crewmax
    I need to cut the holes for a ladder rack to be installed.
    Here's what I did I used a plastic pry tool to pop them off.
    Then used a new blade on utility knife to slowly cut out the holes.
    Any rough or sharp edges were de-burred with dremel with sanding attachment.
    Reinstall is easy, re-align and give them a whack back down.
    Easy peasy, Don't over think it. Remove it and you'll see what see I'm talking about.
    Winning8 likes this.
  13. Jul 28, 2021 at 6:12 AM
    jlarkin1918
    Jared
    9CF465B2-A46C-4A72-8165-19BF1B046FEC.jpg E59E2C96-2BF2-4D45-A2E5-02248C96C2AC.jpg I was able to pry the sides of the cover up enough to see where the pockets were, you can also look inside the bed and see a bolt hole where the pocket will be.
    Once located i drilled a pilot hole in the plastic just to mark it, then finished the cut out with a drywall zip tool bit and traced the pocket opening. I did put a little tape on the tip of the bit to minimize scratching the pocket too much. Worked pretty well.
