2019 5.7 trans cooler location
Discussion in '2.5 Gen Tundras (2014-2021)' started by jcop1, Oct 18, 2018.
  1. Sep 19, 2019 at 4:50 PM
    #61
    timsp8
    NY
    Just drove home and the trans got up to 194 and was going back and forth between 194 and 192. Felt the lines and the lower line going in to the cooler was hot. Top line wasn’t as hot so it wasn’t engine heat. So the thermostat opens somewhere less than 194f, I’d guess right around 194f.
  2. Oct 2, 2019 at 6:00 PM
    #62
    NCTundra1980
    NCTundra1980 New Member
    Stephen
    2019 SR5
    I do not have a cooler either on my 19 sr5
  3. Oct 3, 2019 at 6:51 AM
    #63
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    So for the 19/20’s the window sticker says it has trans cooler but it’s not actually on the truck?!!
    Wow that’s crazy that’s a rip-off!
  4. Oct 3, 2019 at 7:00 AM
    #64
    msmmce1
    msmmce1 New Member
    All this talk about temps people are comfortable with, anyone heard of a heat related failure?
  5. Oct 3, 2019 at 7:51 AM
    #65
    Tundracollector
    Tundracollector New Member
    16 Dc trd pro, 04 Dc, 08 rcsb
  6. Oct 3, 2019 at 8:11 AM
    #66
    pickeledpigsfeet
    pickeledpigsfeet New Member
    Sierra Foothills, Ca
    2019 Tundra/14 FJ/ 90 SASed xcab
    Kings & Icons
    I just got in the early 2nd gen atf thermo plate and am still waiting for the hard lines that route past the motor. Still trying to decide on doing it now and probably affecting my drivetrain warranty or waiting.
    I have an 08 and the coolant heater/cooler is exactly the same, so I think it is very likely that the atf plate will work.
  7. Oct 3, 2019 at 9:02 AM
    #67
    Fourknights
    Fourknights Goin Coastal
    Georgia/Florida
    2019 sr double cab 4x4 5.7
    Coverking ballistic seat covers, dipped 4x4 emblem, intermittent wiper mod, Toyota bed mat, Toyota rear under seat storage, dirty deeds budget, icon rebound 17”, bfg ko2s 285/70/17, matte black uws low profile toolbox, grill surround painted matte black
    Thinking of doing the same. Hoping Toyota will come out with a TSB for people that tow and have experienced high coolant temps. My 19 is a 4x4 it has a heat shield for front driveshaft. The coolant lines that run to trans are not even shielded from exhaust.
  8. Oct 4, 2019 at 6:08 AM
    #68
    sundance
    sundance New Member
    So you believe the transmission fluid can't handle the temps? What spec are you using to judge this?
    I thought the 19s didn't have coolant lines running to the transmission? I know everyone is talking about this now but it seems a little contrived to me. Just trying to understand.
  9. Oct 4, 2019 at 6:09 AM
    #69
    sundance
    sundance New Member
    The diagram and part numbers in the video are the same for all Tundras with a cooler since 07.
  10. Oct 4, 2019 at 6:30 AM
    #70
    Fourknights
    Georgia/Florida
    19 has coolant lines running to trans. No trans lines running to external cooler. Just seems crazy after all these years of production that Toyota would decide a external cooler is not needed. The only think that changed was the Freon.
  11. Oct 4, 2019 at 6:34 AM
    #71
    sundance
    sundance New Member
    I've been research it and there have always been coolant lines running to the Gen3. They run down the back/top side of the transmission. I'll post a pick from the 2015 manual.
    The question I have is if the external "radiator" is really gone.
    Its called "Air Cooled Transmission Oil Cooler" in the service manual.
  12. Oct 4, 2019 at 7:03 AM
    #72
    pickeledpigsfeet
    Kings & Icons
    Do you have a 19? Go out and check for yourself. Why are you questioning owners of 19s that can physically crawl under their truck and compare it to earlier trucks? As I have said before in my driveway is an 08 and a 19. 19 does not have any atf lines. There is no external cooler, either standalone, bottom of the rad or in the condensor.
    Jtundra81 likes this.
  13. Oct 4, 2019 at 7:05 AM
    #73
    pickeledpigsfeet
    Kings & Icons
    Here is a pic of my 19 and then 08. The atf fluid thermo was not installed.
  14. Oct 4, 2019 at 7:07 AM
    #74
    sundance
    sundance New Member
    Because you don't know what you're looking at. Do you have an 18 to compare it to?
  15. Oct 4, 2019 at 7:10 AM
    #75
    sundance
    sundance New Member
    When the air cooler is installed the fluid runs forward down the passenger side to the air cooler.
    When it is not, the same "COOLER ASSY" runs up the back of the transmission to the radiator. That is what you don't understand. That is how it has been for a long time.
    Which is why I said what I said.
    There are bunch of people running around complaining when they don't fully understand what they're talking about.
  16. Oct 4, 2019 at 7:38 AM
    #76
    Fourknights
    Georgia/Florida
    I’m throwing in the towel!
    JohnLakeman likes this.
  17. Oct 4, 2019 at 7:42 AM
    #77
    sundance
    sundance New Member
    Why?
    Here is a screen grab from the 2015 manual showing the same assembly routing to the radiator.
  18. Oct 4, 2019 at 7:49 AM
    #78
    NCTundra1980
    Stephen
    2019 SR5
    Let’s hope Toyota offers some explanations soon
  19. Oct 4, 2019 at 7:56 AM
    #79
    sundance
    sundance New Member
    I'm curious as to what kind of explanations you're looking to receive?
    This what I've seen so far.
    1. Complaints that transmission fluid temps are running 15 to 30 degrees higher than what others have seen in previous models.
    To which I would ask, what spec are you using to determine optimal temperature of Toyota WS fluid?
    2. No extra air cooler = bad
    This isn't necessarily true. The existing air cooler on previous Gens practically blocked the radiator. I have always thought the Tundra needed an electric fan to cool better and the ATM air cooler doesn't help. There have been a few in the past that created electric fan mods. Most are not around anymore.
    I do know that a good radiator with a good ATM internal cooling system works well.
  20. Oct 4, 2019 at 8:01 AM
    #80
    NCTundra1980
    Stephen
    2019 SR5
    Just curious as to what they did since it’s on the sticker and not on the truck
  21. Oct 4, 2019 at 8:05 AM
    #81
    sundance
    sundance New Member
    I do agree with you here. They shouldn't list it the same if the air cooler is not there.
    I suspect they are considering the radiator cooling to qualify but that is a little deceptive to me. The existing transmission without towing package probably have close the same system.
    I suppose there is a chance the system/radiator is larger or has more capacity with the tow package. I would like to know myself. Which why I started looking at it. I've considered a Army Green 2020 but would like to know before I buy.
    Tundracollector likes this.
  22. Oct 4, 2019 at 8:11 AM
    #82
    sundance
    sundance New Member
    The transmission shows to be the same part# for a 4x4 AB60F for 2019 as previous models. I can't seem to find anything on the air cooler part.
  23. Oct 4, 2019 at 8:14 AM
    #83
    sundance
    sundance New Member
  24. Oct 4, 2019 at 8:15 AM
    #84
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    My BIL has a ‘19 and I have an ‘18.
    We did park side by side and you can tell immediately looking through the grill that there is missing hardware and lines.
    However, we both have a lot of trust in the Toyota engineers. He just got worried because he tows his Wake Setter all over hell. I pull the occasional landscaping trailer...
    sundance likes this.
  25. Oct 4, 2019 at 8:20 AM
    #85
    sundance
    sundance New Member
    Radiator for 2019 is the same part # as previous models.... 16400-0S030
  26. Oct 4, 2019 at 8:50 AM
    #86
    NCTundra1980
    Stephen
    2019 SR5
    This is getting interesting
  27. Oct 4, 2019 at 8:53 AM
    #87
    sundance
    sundance New Member
    I might ride by my local dealer tonight and look.
    NCTundra1980[QUOTED] likes this.
  28. Oct 4, 2019 at 9:18 AM
    #88
    NCTundra1980
    Stephen
    2019 SR5
    I’d like to know for sure tgat the 20s do or do not some people are saying they saw the cooler on the 20s
  29. Oct 4, 2019 at 9:32 AM
    #89
    sundance
    sundance New Member
    I'm wondering if some got away from the factory without it. If that is what has happened, Toyota needs to make it right for sure.
  30. Oct 4, 2019 at 9:53 AM
    #90
    NCTundra1980
    Stephen
    2019 SR5
    Yes definitely
