2019 5.7 trans cooler location
Discussion in '3rd Gen Tundras (2014-2021)' started by jcop1, Oct 18, 2018.
  1. Oct 18, 2018 at 3:21 PM
    jcop1
    jcop1 [OP] New Member
    I have looked at 5 2019 5.7 tundras the cooler is not in same location as previous yrs,this is an old topic but I can't believe no one else noticed this feedback please
  2. Oct 18, 2018 at 5:10 PM
    Tracy Perry
    Tracy Perry New Member
    Tracy
    East Texas
    2019 MGM TRD Off-Road 4x4
  3. Oct 18, 2018 at 5:25 PM
    jcop1
    I know about it integrated with the ac condensor I don't see the lines going to the upper part rt side of condensor I looked at 5 different trucks
    Rica25 likes this.
  4. Oct 18, 2018 at 5:26 PM
    Tracy Perry
    Tracy
    East Texas
    If it ever quits raining here I'll try and get out to mine and see if I can grab a photo.
    Beginning to think we need to be on the lookout for Moses in this part of Texas.
    EDIT:
    The only places I could find that looked like they had lines coming in was on the front of the radiator... one was a U shaped with fins on it and the other looked like it fed into a smaller radiator on the front of the main one. the small one on the right looked like it was attached to the darker framed cooler to the left of it. I couldn't find the standard lines/hoses that you would running from the transmission that one would expect either, so they are either "hidden" in the bowels of the engine compartment or are invisible.
    Was to wet to pull the stuff off the front to look. I pulled the truck into the garage and crawled under it trying to find more out.
    Some of this may be HVAC related. I'm more familiar with the layout on my old '96 Ford F-250 that went off to trade for this one.
  5. Oct 18, 2018 at 8:46 PM
    jcop1
    Thanks for the effort,that looks like the ps cooler,bit like I said the 2019 looks different than previous yrs I wonder why they changed it
    Rica25 likes this.
  6. Oct 19, 2018 at 5:55 AM
    Tracy Perry
    Tracy
    East Texas
    That's from a 2019 that we just got. Probably changed it because of cost saving measures. Hopefully someone will chime in that knows where they connect for sure since they aren't where one would normally expect.
    Black Wolf likes this.
  7. Oct 20, 2018 at 9:57 PM
    acmesupply
    acmesupply New Member
    2018 SR5 CM Silver TRD
    :popcorn:
    Rica25 likes this.
  8. Oct 21, 2018 at 2:39 AM
    TTund16
    TTund16 New Member
    Did the 5 you looked at had tow packages! I think only the trucks with tow pkg have trans cooler ... & engine oil cooler.
    Rica25 and netranger6 like this.
  9. Oct 21, 2018 at 5:13 AM
    jcop1
    Yes they did all 5.7 trucks have the tow package
    Rica25 likes this.
  10. Nov 9, 2018 at 6:41 PM
    acmesupply
    20181109_131729.jpg 20181109_131740.jpg Pictures from a 2019 with tow package.
    NoKenDo, OR18TRD and georgiey22 like this.
  11. Nov 10, 2018 at 5:28 AM
    jcop1
    Thanks for the pictures but I still don't see the trans cooler lines on top of a.c. condensor
    OR18TRD likes this.
  12. Nov 10, 2018 at 10:25 AM
    acmesupply
    There is no cooler on top of the ac condenser like all previous 2014-2018 but don't hold me it on 2018's. Maybe the new 1234 Freon has something to do with it?
    Anyone with a 2018? Or someone with a 2019 with a tow package can take a picture of the new trans cooler location????
  13. Nov 10, 2018 at 11:46 AM
    jcop1
    The 2018 have trans cooler on the top portion of the ac condensor not so on 2019 a picture of new location or anybingonwoild be nice
  14. Nov 10, 2018 at 1:34 PM
    Vizsla
    Vizsla New Member
    Dave
    Arizona
    2018 Cement Crewmax
    Did you maybe look at a 4.6? They do not have the cooler. Never mind saw you said 5.7.
  15. Nov 11, 2018 at 1:56 AM
    rsgt
    rsgt New Member
    2019 crew cab TRD sport 4x4
    all stock
    I have a 2019 Ill try to locate and take pictures I have the 5.7 tow package
    OR18TRD likes this.
  16. Nov 11, 2018 at 4:20 AM
    jcop1
    Okay thank u
  17. Nov 12, 2018 at 4:16 AM
    rsgt
    rsgt New Member
    all stock
    Well I tried to look very difficult to pin point the location. Im probably wrong but isn't the small rad on the very bottom of the front. Im no mechanic lol
  18. Nov 12, 2018 at 5:38 AM
    jcop1
    No that is the ps cooler i am very curious as to why they moved it i wonder if anyone else can comment
  19. Nov 12, 2018 at 5:50 AM
    timsp8
    timsp8 Member
    NY
    2018 Tundra Limited Crewmax
  20. Nov 12, 2018 at 9:09 AM
    jcop1
    Yes we do I don't have a tundra yet
  21. Feb 16, 2019 at 12:23 PM
    blaserdude
    blaserdude New Member
    Eugene
    2019 Tundra Limited Double Cab
    none
  22. Feb 16, 2019 at 12:28 PM
    blaserdude
    Eugene
    none
    I just looked at my 19. Same thing. The black finned tube is the PS cooler. The right aluminum tube is part of the AC. As far as I can see, the evaporator is only connected to AC lines, (I traced on drivers side). I think the transmission cooler is now a OTW (oil to water) system imbedded in the engine cooling system/ There are two new lines coming from the oil filter fitting that route under the manifold. So for all I see coming from the transmission is the thermostat lines.
    bc
    TTund16 likes this.
  23. Feb 16, 2019 at 1:22 PM
    acmesupply
    Thanks, blaserdude, can you take pictures of the complete radiator and the ac condenser if your able to. It sounds like they increased the ac condenser size and went back to a trans heater/cooler in the radiator, not a fan of if you keep the vehicle for 10 plus years. I've seen to many milky radiators and transmissions. Thanks again
  24. Feb 16, 2019 at 1:24 PM
    acmesupply
    Forgot, I have asked about r1234yf freon at the dealer and a body shop. Both stated 10-15 percent increase in efficiency and cooling.
    Rica25 likes this.
  25. Feb 16, 2019 at 2:00 PM
    blaserdude
    Eugene
    none
    I doubt if I can get pics. Back injury keeps me from doing much crawling around. The lines I saw go into the engine oil cooling exchanger. Perhaps the ATF preheater is now dual purpose (thermostat). The description on the window sticker says engine/transmission oil cooler as in one device. OTW is much more efficient with respect to heat transfer rate than OTA. The red flag is when the water gets too hot and cooks the fluid or when the two mix as you stated. When I can get the think on stands, then I can look for other lines and routing.
    bc
  26. Feb 16, 2019 at 2:14 PM
    jcop1
    Thanks i am very curious
  27. Feb 17, 2019 at 10:19 AM
    blaserdude
    Eugene
    none
    This is from a Toyota promotion web posting:
    With its standard Tow Hitch Receiver and Tow Package (available on all grades), the 5.7-liter V8 Tundra offers a maximum certified tow capacity of up to 10,200 pounds (SAE J2807). A one-piece towing receiver utilizes 12 high-strength bolts, integrating it into the frame. The 5.7-liter’s Tow Package upgrades Tundra’s cooling and electrical systems as well. Integrated engine and transmission oil coolers, in conjunction with an added heavy-duty battery and alternator, help the powertrain handle the strenuous demands of towing under a full load.
    As I suspected, the system now is integrated with the engine oil cooling system on the oil filter mounting fitment.
    BC
  28. Feb 17, 2019 at 1:03 PM
    jcop1
    Thank u i wonder if the new system is more effective than the old system is it connected to the radiator
  29. Feb 17, 2019 at 2:11 PM
    timsp8
    timsp8 Member
    NY
    If it’s integrated with the engine oil cooler, seems like it’d be less effective. The ones that share a cooler with the ac at least have lots of fins and airflow. Did they also change the oil cooler?
  30. Feb 17, 2019 at 3:46 PM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    I'm pretty sure earlier trucks had the engine coolant flowing to the trans. I've read it helps with warm up, but I'm contrast it keeps the trans the same temp as the engine coolant. My tundra trans temps run pretty high, In contrast my Tacoma with tow package is like 30* cooler in same situations.
    D4x4TRD likes this.
