2019 5.7 trans cooler location
Discussion in '2.5 Gen Tundras (2014-2021)' started by jcop1, Oct 18, 2018.
  1. Jan 18, 2020 at 10:09 AM
    #541
    jtwags
    jtwags Concrete jungle
    League City, TX
    2018 Tundra CM
    Undercover Elite LX, Xact Contour
    I second starting a new thread. Let's get an Obd thread going for Tundras so we can compare and share pids, gauge setups, etc...
  2. Jan 18, 2020 at 10:19 AM
    #542
    WNY PAT
    WNY PAT New Member
    Ruggybuggy likes this.
  3. Jan 18, 2020 at 12:49 PM
    #543
    TTund16
    TTund16 New Member
    Nice job!
    Now that you are familiar with the car, is there any good spot besides the drain plug, to install an engine oil temperature sensor?
  4. Jan 18, 2020 at 12:52 PM
    #544
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
    I have no idea. Maybe the drain plug?...
    TTund16[QUOTED] likes this.
  5. Jan 18, 2020 at 6:41 PM
    #545
    Jtundra81
    Jtundra81 Just a member
    Joe
    2019 cement tundra crewmax
    Nice job , did you get the chance to check the trans temp after installing the cooler ? Interested to see how much you are getting
  6. Jan 18, 2020 at 7:32 PM
    #546
    Buddy took me to supercross. I will check it tomorrow!
  7. Jan 21, 2020 at 4:43 PM
    #547
    pickeledpigsfeet
    pickeledpigsfeet New Member
    Sierra Foothills, Ca
    2019 Tundra/14 FJ/ 90 SASed xcab
    Kings & Icons
    @chasenicholas93 had asked that if possible that I post some pics of the hard lines mounts. Figured I would post them here for everyone. The old rusty pics are from my 08 and the shiny ones are my 19.
  8. Jan 21, 2020 at 5:44 PM
    #548
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Do the Toyota hard lines come with the bolts? Also how close to the rad do the hard lines go and can you just add regular trans hose on that end or do you need heat insulation on them as well? Thanks for posting these.:thumbsup:
  9. Jan 21, 2020 at 5:47 PM
    #549
    pickeledpigsfeet
    Kings & Icons
    You have to order the bolts separately. It dumps out under the alternator and from there just use standard 3/8 atf hose to go out to the cooler.
    Bolts are 9008010400
    sask3m[QUOTED] likes this.
  10. Jan 21, 2020 at 5:53 PM
    #550
    pickeledpigsfeet
    Kings & Icons
    Here is a pic
    mdrabicki, TTund16 and sask3m like this.
  11. Jan 22, 2020 at 4:22 AM
    #551
    blaserdude
    blaserdude New Member
    Eugene
    2019 Tundra Limited Double Cab
    none
    Excellent work!
    bc
  12. Jan 22, 2020 at 12:11 PM
    #552
    Jtundra81
    Joe
    Were you able to get reading from your transmission after installing the cooler?
    TTund16 likes this.
  13. Jan 22, 2020 at 12:13 PM
    #553
    TTund16
    TTund16 New Member
    It's a long supercross :D
  14. Jan 22, 2020 at 12:17 PM
    #554
    Jtundra81
    Joe
    Looks like it :bikewhoops:
  15. Jan 22, 2020 at 12:54 PM
    #555
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Jtundra81[QUOTED] likes this.
  16. Jan 22, 2020 at 3:31 PM
    #556
    Posted to the wrong thread... here is what I posted.
    Okay, everyone. I can now say it's complete. I did the tempature check and only had to fill 1 quart of ATF. I went on a 1 hour drive while it was 62° outside going up and down hilly terrain with wide open throttle on a lot of them. Pan temp maintained 189-191° the whole time. The torque converter got up to 210° but quickly dropped to match the ATF temp within 15 seconds of slowing down or going back down a hill. The hill I was using was close to a 1 mile long. Me doing this prior to the cooler the pan temp would get to 220° pretty fast. The cooler does it's job. After the drive, the cooler was very hot to the touch and was dispersing the heat very well.
    mdrabicki, TTund16, VRC and 1 other person like this.
