2019 5.7 trans cooler location
Discussion in '2.5 Gen Tundras (2014-2021)' started by jcop1, Oct 18, 2018.
  1. Jan 16, 2020 at 7:38 AM
    #511
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    C
    Can you add custom pid's to the fussion app? Also if you buy the Tundra add on for the app what does it give you?
  2. Jan 16, 2020 at 8:35 AM
    #512
    jtwags
    jtwags Concrete jungle
    League City, TX
    2018 Tundra CM
    Undercover Elite LX, Xact Contour
    Yes, custom pids can be added. The advanced pack is pretty extensive but unless you are really diagnosing and/or testing mods it may be excessive for typical needs.
    Below is a sample of what is visible to delve into but i have only tested a few things and only use a couple of the extended pids. It does have the atf degredation pid which is Toyota's atf fluid life calculation based on conditions.
  3. Jan 16, 2020 at 8:58 AM
    #513
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Thank you very much for the help. I going to purchase and give it a try. I do have the Torque app but I think this one will work better.
  4. Jan 16, 2020 at 9:00 AM
    #514
    jtwags
    League City, TX
    2018 Tundra CM
    Let us know if it reads the 2020 pids properly. If you want my dashboard layout and custom guage setup i can pm you the export file too.
  5. Jan 16, 2020 at 9:02 AM
    #515
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Yes please. I have a chance today to play with it.
  6. Jan 16, 2020 at 3:41 PM
    #516
    Jtundra81
    Jtundra81 Just a member
    Joe
    2019 cement tundra crewmax
    All eyes on you , we are waiting for test results :popcorn:
    WNY PAT[QUOTED] likes this.
  7. Jan 16, 2020 at 3:52 PM
    #517
    TTund16
    TTund16 New Member
    do you know where your engine oil temperature reading is coming from? I am told Tundra does not have any oil temp sensor and ECU should not have any data either.
    Do you remember engine oil temperature readings after an hour or so of driving?
    Thanks
  8. Jan 16, 2020 at 3:58 PM
    #518
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Ok saw I did buy the Toyota enhancements for the 2019. Where do I apply it? I'm not seeing trans temps.
  9. Jan 16, 2020 at 4:31 PM
    #519
    jtwags
    League City, TX
    2018 Tundra CM
    It was pulling data when I was checking all the different pids for values and it seems to show a different value compared to trans temps when I am pulling a load. It is usually same or close to coolant temp except at startup. I dont know if it is an actual sensor from the oil but seems to be measuring something :)
    TTund16[QUOTED] likes this.
  10. Jan 16, 2020 at 5:10 PM
    #520
    Vizsla
    Vizsla pretend2send
    There is an estimated oil temp pid, maybe that’s what you are watching. Lots of stuff available through the obd port, LOL! Here are the enhanced obd fusion parameters for Toyota.
    https://www.obdsoftware.net/software/toyotaenhancedparameters
    jtwags[QUOTED] likes this.
  11. Jan 16, 2020 at 5:23 PM
    #521
    WNY PAT
    WNY PAT New Member
    Well I’ll report back ASAP. It’s gonna be 15 degrees here tomorrow... so no one is missing much. It’s going to take me a weekend and a coding course to get the app up and running. Lol It’ll be summer before it gets really interesting. I bring equipment back and forth to our hunting camp on a big trailer - will be maxed out and one hill in particular is a long pull. If it’s going to overheat around these parts... it’ll be on that hill. I will post my winter numbers once I get this working tho - the trailer I’m pulling is 6000# give or take a few hundred lbs.
    sask3m and specter208 like this.
  12. Jan 16, 2020 at 6:05 PM
    #522
    TTund16
    TTund16 New Member
    do you recall the highest engine oil temperature that you've ever seen?
  13. Jan 16, 2020 at 6:16 PM
    #523
    jtwags
    League City, TX
    2018 Tundra CM
    I didnt keep a log for oil but it has never been higher than the transmission pan temps anytime i have looked at it. I have logs of trans pan and torque converter temps. Highest torque converter temp was 222 and pan temp 208. That is what I have record of but I have seen torque converter temp spike to 230 on occasion when not logging. These logs are from October in south texas. I will get more logs this summer.
    WNY PAT and TTund16 like this.
  14. Jan 17, 2020 at 6:53 PM
    #524
    WNY PAT
    WNY PAT New Member
    @jtwags
    Quick question before I buy the app: once I have the code added to the torque app, will this work for both my 2017 and 2019? I’d like to just be able to swap out the scan tool back and forth if I can. If not, will I need another OBD-2 scanner? I will buy another if I have to, but I’d like to avoid that. Thx in advance.
  15. Jan 17, 2020 at 6:56 PM
    #525
    Jtundra81
    Joe
    It should work on both
  16. Jan 17, 2020 at 7:10 PM
    #526
    jtwags
    League City, TX
    2018 Tundra CM
    Funny you ask because RuggyBuggy and I were working through an issue he had when using with his 2020. The purchased pids were not showing up. He purchased the 2019 pids. When using the app you need to have the same year entered as the pid pack you purchased or it wont work. Check with RuggyBuggy to verify they are reading correctly when using a different year than your actual truck. I am also not sure if there was a change in pid programming between 2017 and 2019.
  17. Jan 17, 2020 at 7:15 PM
    #527
    WNY PAT
    WNY PAT New Member
    Got it -
    Ah. Ok. Thx.
  18. Jan 17, 2020 at 7:36 PM
    #528
    WNY PAT
    WNY PAT New Member
    @jtwags
    Hey - so I just bought the OBD Fusion app. It looks like I need to connect it to the Tundra to set up the dashboard? Do I have to purchase anything additional or will I be able to set up the dashboard like yours once it starts to communicate with the truck? My truck is sitting at work - going to go there tomorrow to set this up and just want to be sure I have everything downloaded. Thx again for the help.
  19. Jan 17, 2020 at 7:45 PM
    #529
    jtwags
    League City, TX
    2018 Tundra CM
    Should be able to setup even when not connected to truck. You can do some pretty cool things with the dashboard. Over on the tacoma forum they have created some great looking dashboards and other pids i havent tried yet from the advanced pids.
    https://www.tacomaworld.com/threads/obd-fusion-tips-and-tricks.590248/
  20. Jan 17, 2020 at 7:51 PM
    #530
    WNY PAT
    WNY PAT New Member
    Thank you @jtwags - I’ll check it out!
  21. Jan 17, 2020 at 8:28 PM
    #531
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I had a chance to play with today and almost every pid in the purchased Toyota enhancements didn't work. I was able to do a custom pid for the trans pan temps that work but haven't found one for the converter temps that worked. The trans temp in the enhancement did give a reading but it didn't make any sense.
    WNY PAT likes this.
  22. Jan 17, 2020 at 8:31 PM
    #532
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
    Installed the cooler today. For those interested, I will be selling the cooler bracket, hardware, and horn relocation bracket just like the photos for 150$. I am going to do the ATF fill and check tomorrow and go on a test drive. I will be doing a full write up on how to install in the next couple days.
  23. Jan 17, 2020 at 8:34 PM
    #533
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    nice job, looks clean and tidy. :thumbsup:
  24. Jan 18, 2020 at 6:54 AM
    #534
    jtwags
    League City, TX
    2018 Tundra CM
    Well, that is no bueno. I think it is safe to say the pid pack needs to match the year of the vehicle as there seem to be differences between some years in the way pids are mapped.
  25. Jan 18, 2020 at 7:35 AM
    #535
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    My understanding was the 2019 and 2020 are using the same modules so I would have expected it to work. Somebody with a 2019 has to give the app a try and see if the enhancement package will work.
  26. Jan 18, 2020 at 8:18 AM
    #536
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Stacked plate vs plate and fin trans coolers. Any experts on here about which type is better when placed in "front of the rad"? Looking at either the b&m 70274(stacked plate) or hayden 778(plate and fin).
  27. Jan 18, 2020 at 8:37 AM
    #537
    If your interested in the Hayden 778 I can make a bracket for that as well. I will just need 3 people interested in order to have it designed and CNC.
    sask3m[QUOTED] likes this.
  28. Jan 18, 2020 at 8:42 AM
    #538
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    I can confirm that OBDLink MX+ works for my 2019 Trans pan and toque converter temps as well as engine oil and coolant temps. The advanced Toyota PIDs are free will the MX+,the app actually looks exactly the same as the OBD Fusion app.
    https://www.amazon.com/dp/B07JFRFJG6/ref=cm_sw_r_cp_apa_i_erZiEbZDX3TXW
  29. Jan 18, 2020 at 8:56 AM
    #539
    WNY PAT
    WNY PAT New Member
    OK. That’ll be me then. I have my 2017 up and running just fine with the Fusion app. I’m not a tech guy lol but I’ll take a ride over to my shop later and play around with the 2019 and can at least tell you guys if it behaves the same and is as easy to set up as my 2017. Maybe I’ll start a new thread for this... hate to hijack this thread. Here’s my 2017 dashboard (I assumed trans temp 1 pid output was pan and trans temp 2 pid output was torque converter... might be wrong). BTW in just driving around this AM with my 2017 (empty no trailer) the trans temp ranged from 170- 190 and the coolant temp ranged from 180-185.
    jtwags and Ruggybuggy[QUOTED] like this.
  30. Jan 18, 2020 at 9:15 AM
    #540
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Yeah I'm still not sure what I want is the thing. I do tow a 6500lb 5th wheel through mountains in the summer so there is that, just want to make sure I go big enough.
