2019 5.7 trans cooler location
Discussion in '2.5 Gen Tundras (2014-2021)' started by jcop1, Oct 18, 2018.
  1. Dec 22, 2019 at 9:22 PM
    #451
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    sask3m likes this.
  2. Dec 22, 2019 at 9:26 PM
    #452
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
  3. Dec 23, 2019 at 3:13 AM
    #453
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Superior information JohnLakeman. Thank-You, that really helps to understand some more. Source of information? Can we get to it (cost)?
    Good place to connect the dots to "Pinning" information. I've just got started on enabling my android version of Torque Pro to read Trans temps. Boy are they High, IMHO. Yes I know Toyota engineers are far smarter than I but it doesn't stop me from trying.
    Still perfecting my new PID formula that I borrowed but had to modify because the first reading was exceedingly high. Should finish perfecting that formula today with a fresh cold start. But thus far with about 95% accuracy, I'm seeing in 50 degree ambient weather in smooth easy highway driving 216 degrees at the TC!!! Ouch - I really do NOT like that - I don't care which engineer says its better - I cannot be convinced. It cannot be better than 180. That is my goal. We'll see and I'll report back.
    Luck all and enjoy the Hot Toyotas. : ^ )))
    sask3m likes this.
  4. Dec 23, 2019 at 11:52 AM
    #454
    JohnLakeman
    My source for information about Toyota ATF cooling systems was internet Tundra parts listings. On Toyota dealer of choice site (https://parts.toyotaofcoolsprings.com in my case): Go to "Search All Vehicles">Year/Make/Model/Trim/Engine>Cooling System>Trans Oil Cooler. Follow the list of fitments for the various parts.
    You'll discover that all Tundras (3.4L, 4.0L, 4.7L, 5.7L) had air/fluid ATF coolers in the front with no temperature control through 2006. In fact, "tow package" wasn't even a Tundra thing until 2007. From 2007-2009, all "tow package" Tundras continued to have stand-alone ATF coolers without temperature regulation, and non-tow package Tundras were equipped with the warmer/cooler mounted to the transmission (a slight revision from my earlier statement). In 2010, the ATF thermostat was first added with the new 4.6L tow package with ATF cooler built into AC condenser. That configuration was extended to the 5.7L tow package in 2011.
    Cost? If you're talking about retrofitting an ATF cooler to a 2019+, I would use as many Toyota parts as possible from the last applicable production year, 2018, and use a cheaper aftermarket cooler and final connections up front. If you use an aftermarket cooler, the parts needed are fairly reasonable. Any significant deviation from that plan or poor execution could result in a transmission disaster imo.
    timsp8 likes this.
  5. Dec 23, 2019 at 1:04 PM
    #455
    timsp8
    NY
    Just 1 correction (not that it matters), the change was in mid 10. I had a 2010 model built in May of 10 and had the 5.7 with trans/ac combined cooler.
  6. Dec 23, 2019 at 3:26 PM
    #456
    JohnLakeman
    You said that before...I wondered about it, but never followed up because it wasn't important.
    Your experience is interesting input, and probably not available any other way except from an astute original owner. I based my comments on the thermostat part link below. Note that 5.7L fitment begins in MY 2011, not 2010. So, if you had needed a ATF cooler thermostat, you would have had an interesting encounter with the parts department. That's one reason they ask now for a VIN when any kind of parts are being ordered.
    https://parts.toyotaofcoolsprings.c...9dHVuZHJhJnk9MjAxMSZ0PXNyNSZlPTUtN2wtdjgtZ2Fz
    Historically in automotive manufacturing, there have been "running changes" made during a model year. In classic car restoration, part of the game is to determine the VIN range when a "running change" was made to a new, revised part number. Such changes happen for a number of reasons, but usually on an almost identical part, not something as big as changing transmissions (new stock would have had warmer/cooler and thermostat mounted), cooling lines, and ATF cooler/AC condenser. It's very interesting to compare Toyota thinking to the Big Three...they must have thought the changeover was mega-important for some reason.
  7. Jan 2, 2020 at 1:17 PM
    #457
    Ronin73
    Ronin73 New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    If I don't tow at all and rarely have more than a few hundred pounds in the bed a few times a year, I should be good, right? Hell, I even drive very conservatively.
  8. Jan 2, 2020 at 2:16 PM
    #458
    JohnLakeman
    If you don't tow, I think you'll be fine. In fact, Toyota has probably planned it that way for owners that don't tow.
    From other 2019+ owners input, I believe for daily driving, you will be looking at about 215-220 deg F max. You'll have to decide if that temp level with ATF WS bothers you. With cooler winter ambient temps in Central Texas, I haven't been able to get my 4.6L/A760E over 190 deg according to my Ultra-Gauge Blue. Beginning in 2019, with no ATF cooler, your ATF "cooler" config is the same as mine; i.e. warmer only.
    Ronin73[QUOTED] likes this.
  9. Jan 2, 2020 at 3:31 PM
    #459
    Jtundra81
    Jtundra81 Just a member
    Joe
    2019 cement tundra crewmax
    I towed more then 6 times last summer around 5000lb travel trailer and never went above 217 for pan and occasionally hitting 228 and goes down fast on the torque
    sask3m and Cpl_Punishment like this.
  10. Jan 2, 2020 at 7:48 PM
    #460
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Was that in S4?
  11. Jan 2, 2020 at 7:50 PM
    #461
    Jtundra81
    Joe
    Yes S4 and tow/ haul , drive between 55 and 60 mph
  12. Jan 3, 2020 at 7:10 AM
    #462
    specter208
    specter208 New Member
    2017 Tacoma and 2005 Tundra RGCAB
    Imagine an overloaded twin-turbo small displacement engine in a towing truck with regular engine coolant temps between 210-230°F with this same Trans cooling setup.
  13. Jan 3, 2020 at 7:20 AM
    #463
    Johnsonman
    Austin
    Sequoia
    I'm in Weird town, couple days ago after 40 miles of driving my 5.7 (2015) in 60ish weather, no rain, it hit 212. So I guess the 4.6 and 5.7 react a bit different to roughly the same environment?
    I'm getting used to this new WS higher temp concept (not easy), but those are horrible numbers if it were my 3rd gen 4Runner considering how cool it is, no towing, no stop/go, no hills,just steady eddy highway driving.... uggg.
    I'm just gonna have the fluid flushed periodically w/WS if nothing else to sleep a hair better.
  14. Jan 3, 2020 at 8:05 AM
    #464
    JohnLakeman
    Our different experience is likely because I haven't gotten that much driving time or distance with ATF temp monitoring yet. I'll eventually get a drive to Houston. Then, it will get a good heat soaking, and I'll know where the ATF temp going to end up. After that, I'll know what I'm dealing with and adjust my maintenance plans accordingly. I can tell you now WS fluid will not be in those plans, only full synthetic ATF will be used.
  15. Jan 3, 2020 at 9:05 AM
    #465
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    How do you know for certain that WS isn't a full synthetic? Have you had it analysed?
  16. Jan 3, 2020 at 9:09 AM
    #466
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    So your getting 212 driving a 2015 Sequouia? Doesn't the 15 come with an external trans cooler in the a/c condensor?
  17. Jan 3, 2020 at 9:19 AM
    #467
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
  18. Jan 3, 2020 at 10:34 AM
    #468
    pickeledpigsfeet
    pickeledpigsfeet New Member
    Sierra Foothills, Ca
    2019 Tundra/14 FJ/ 90 SASed xcab
    Kings & Icons
    Flash point is low for a full synth. Here is 2 of my analysis.
    Joe333x and JohnLakeman like this.
  19. Jan 3, 2020 at 11:13 AM
    #469
    JohnLakeman
    Sadly, courts and lawyers have pretty much rendered the simple name "synthetic" meaningless as applied to US lubricants. If a lubricant contains any bit of a "synthetic" substance, e.g. polyalphaolefins (PAO), the product can now be labeled as "synthetic".
    However, the lawyers apparently did set some rules: In the case of Mobil1, a "full synthetic" labeled motor oil, my son brought a Japanese MSDS to my attention that clearly indicates Mobil1 as having 40-50 percent PAO. (Revelation of trade secrets less important to the Japanese?) A motor oil labeled "100% Synthetic" is all PAO, which is where Mobil1 began carving out the niche. A lubricant that is simply labeled "synthetic"?...well, presumably it has some PAO in it's composition. In the case of WS ATF, the PAO bit that it has is not enough to give it adequate temperature resistance imo, bwdik.
  20. Jan 3, 2020 at 2:48 PM
    #470
    specter208
    Does the 19/20 have an actual Trans coolers yes or no. Simple answer please. Thanks!
  21. Jan 3, 2020 at 2:50 PM
    #471
    Johnsonman
    Austin
    Sequoia
    Yes - crazy design. I don't know exactly how it works. Does the compressor have to operate to warm trans? If so seems counter intuitive for fuel efficiency. I'd rather just have an external cooler with a built in cold fluid by-pass valve fr cooling and let it warm up naturally. : ^ )))
    sask3m[QUOTED] likes this.
  22. Jan 3, 2020 at 3:02 PM
    #472
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    It doesn't have an external cooler like it did previous to 19. Toyota says it has cooler but in reality it seems to just be what they used to call a warmer.
    specter208[QUOTED] likes this.
  23. Jan 3, 2020 at 3:05 PM
    #473
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Kinda like Macdonalds hamburgers, is it 100% beef or "all" beef. o_O
    specter208 likes this.
  24. Jan 3, 2020 at 4:22 PM
    #474
    timsp8
    NY
    No. Just a warmer that also acts as a cooler. The ATF fluid itself does not go anywhere to be cooled.
  25. Jan 4, 2020 at 4:35 PM
    #475
    Jtundra81
    Joe
    Joe333x and belanger9 like this.
  26. Jan 4, 2020 at 5:18 PM
    #476
    Joe333x
    Joe333x Member
    Boston
    CCATT-RN likes this.
  27. Jan 4, 2020 at 5:35 PM
    #477
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Classified.
    My eyes only.
    Neutron, jtwags and Vizsla like this.
  28. Jan 4, 2020 at 6:00 PM
    #478
    WNY PAT
    WNY PAT New Member
    Oh how I wish I lived close by that “test” climb. I’d Offer up my leased 2019 and load up my dual axle trailer with 9,000ish# of crap and a trans temp monitor and run it! I hope someone here can do that and report temps. I find it odd that he wouldn’t state what the “target temp” is for this set up. 250? 260? 270? Damn shame they changed it now... how much could they possibly be saving?
    JohnLakeman likes this.
  29. Jan 4, 2020 at 6:20 PM
    #479
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    His reply isn't giving me a lot of confidence. There's no reason they can't give us an option to add one ( a cooler) without losing warranty.
    I wish he'd have said what temps they were hitting pulling max up that hill.
    specter208 and Cpl_Punishment like this.
  30. Jan 4, 2020 at 8:46 PM
    #480
    JohnLakeman
