2019 5.7 trans cooler location
Discussion in '2.5 Gen Tundras (2014-2021)' started by jcop1, Oct 18, 2018.
  1. Nov 5, 2019 at 7:56 AM
    #391
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    I set up OBD Fusion and paid the extra $10 as well. Engine oil is right in the list of selectables. I’ll share a screen shot.
    TTund16 likes this.
  2. Nov 5, 2019 at 8:54 AM
    #392
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
    Has anyone done a external cooler retrofit on their tundra yet?
  3. Nov 6, 2019 at 8:34 AM
    #393
    CO_Native
    CO_Native New Member
    Englewood, CO
    2024 Limited CM Silver/Nightshade
    I've been following this thread, kinda freaking myself out a bit..."oh no, my new baby (I love this truck) may be defective? Say it ain't so!"
    Then I think: It's a brand-new 2019 with only 3000 miles on it so far, half of those were towing miles already. The factory/dash temp-gauge barely rises above the middle mark when going uphill with the trailer and it's a Toyota and it's got a factory Warranty.
    If 240 degrees is as bad in actuality as it is in theory in these transmissions, I think it would fail within the Warranty period, right? 3 years of towing @ 240+ would surely cause a failure of some kind, right?
    F'it, I'm going to trust Toyota & rely on that Warranty. If she dies, she dies. Best case, nothing goes wrong. Worst case, get the trans swapped & trade it in having learned a lesson....or....Toyota makes it right & gives me/us a cooler after they fix the damage. :fingerscrossed:
    Let's see what happens :popcorn:
  4. Nov 6, 2019 at 8:44 AM
    #394
    cnoyes72
    cnoyes72 New Member
    CT
    2018 Tundra SR5 DoubleCab 4x4
    Driver-side assist handle, extang trifect 2.0 tonneau cover
    You'll find this forum can quickly become an amplified echo chamber, where a post about a minor drivetrain change by Toyota quickly becomes "My transmission is in full meltdown! Argh!!!!".
    Ruggybuggy, viha22, snivilous and 2 others like this.
  5. Nov 6, 2019 at 8:54 AM
    #395
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    UNLESS...Toyota has already put hundreds of thousands of test miles on 2019/2020 Tundras, and they know that under nominal towing conditions, the normal distribution of transmission failures median is at 38 months, and that one standard deviation is two weeks. In other words, that could be an optimistic assumption. :D
  6. Nov 6, 2019 at 9:06 AM
    #396
    timsp8
    NY
    Warranty for drive train is 5 yr/60k. I had a transmission fail at about 59k on my 2010 and it was replaced under warranty. Still had issues after that until i traded it in at about 94k.
  7. Nov 6, 2019 at 9:22 AM
    #397
    JohnLakeman
    I was just messing with @CO_Native. :D
    My point was Toyota ALREADY knows they aren't going to be replacing every transmission under warranty. Hopefully, they have considered the towing owner's wallet as well, but that may be further down their priority list.
    CO_Native and Cpl_Punishment like this.
  8. Nov 6, 2019 at 9:57 AM
    #398
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I'm with @JohnLakeman on this one. I suspect the transmission won't fail in the first 5 years/60k miles but I also suspect it may have a lower probability of making it to a million miles than pre-2019s.
    sf319 and Eric32444 like this.
  9. Nov 6, 2019 at 3:15 PM
    #399
    Gaspssr
    Gaspssr New Member
    2019 cement grey limited 5.7
    Afe pro dry filter with trd accelerator.
    Sooo who’s adding an air cooler to a 2019-2020? Didn’t someone post on here they had all the parts just waiting for warranty to expire?
  10. Nov 6, 2019 at 5:31 PM
    #400
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    You have a transmission temp guage on your 19?
  11. Nov 7, 2019 at 4:47 AM
    #401
    msbaugh440
    msbaugh440 2019 limited, TRD package, cement
    Utah
    2019 Tundra limited, TRD off road, Cement
    what do you think? Of course not.
  12. Nov 7, 2019 at 8:26 AM
    #402
    CO_Native
    Englewood, CO
    No, I said the "factory/dash temp guage".
    I assume it's a measurement of the cooling system as with any other vehicle, not necessarily transmission.
    That said, since they're "integrated" now, might it be fairly safe to assume that gauge is a rough estimate of the overall conditions, including the transmission?
  13. Nov 7, 2019 at 8:34 AM
    #403
    That is your engine oil coolant temp. Not the same as ATF temp from the pan.
  14. Nov 7, 2019 at 9:34 AM
    #404
    JohnLakeman
    Actually, there is no oil temp. The gauge above the circled one is the oil pressure.
    No, that would not necessarily be a "safe" assumption. Most of this thread has been about the cooling requirements of the transmission (ATF) exceeding the capacity of that little warmer/cooler under heavy towing conditions. Tundras driven in town as daily drivers probably won't have a problem.
  15. Nov 7, 2019 at 9:42 AM
    #405
    CO_Native
    Englewood, CO
    Fair enough, I learn something every day.
  16. Nov 8, 2019 at 3:28 AM
    #406
    Fourknights
    Fourknights Goin Coastal
    Georgia/Florida
    2019 sr double cab 4x4 5.7
    Coverking ballistic seat covers, dipped 4x4 emblem, intermittent wiper mod, Toyota bed mat, Toyota rear under seat storage, dirty deeds budget, icon rebound 17”, bfg ko2s 285/70/17, matte black uws low profile toolbox, grill surround painted matte black
    TundraDude34 posted a video on YouTube a week ago. Mike Sweers Chief Engineer at Toyota is building a 2020 tundra. Has already done suspension and wheels and tires, said SC is coming. I bet his truck will be getting a real air to fluid trans cooler!
  17. Nov 9, 2019 at 8:18 AM
    #407
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Or maybe he knows there is no need for one.
  18. Nov 9, 2019 at 8:34 AM
    #408
    timsp8
    NY
    Yep. I’m thinking of taking mine off my 18. It’s just another part that adds to global warming. I mean if these transmissions can handle 240+ regularly then why did every previous year have one. Seems like it was a waste of money.
  19. Nov 9, 2019 at 11:25 AM
    #409
    Eric32444
    Eric32444 "Pick up your balls and load up your cannons..."
    Eric
    Panama City FL, Lynn Haven
    i see what u did there, lol....
  20. Nov 9, 2019 at 3:21 PM
    #410
    msbaugh440
    Utah
    He’s got an excellent point though. Most Toyota fan boys on here just aren’t willing to admit that Toyota might have made a trade off
  21. Nov 9, 2019 at 8:35 PM
    #411
    panicman
    Eric
    As a long time Toyota fan boy, I too question the decision to remove the transmission cooler, especially doing so without any explanation when current users are seeing operating temps far beyond what are normally considered contributory to longevity. It doesn’t make sense, and as this thread proves, it creates a sense of doubt that Toyota doesn’t seem to want to address.
  22. Nov 10, 2019 at 9:26 AM
    #412
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Oh don't get me wrong I wish my 19 had the same cooler my 08 had. I was simply suggesting the possibility that the engineers at Toyota know something we don't.
    I still haven't talked to my dealer about the possibility of adding an external cooler but plan on.
    CO_Native likes this.
  23. Nov 10, 2019 at 9:31 AM
    #413
    RLHULK
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    Maybe the engineers are Toyota are preparing for the 2021 model and making small changes like this for what,s to come. I seem to recall that the 2016 or 2017 tundras have a spot on the fuse panel under the dash marked led lights, but there were no wires connected to anything, then in 2018 bam LED headlights, I dunno just a guess.
    The 2015 tundras have all the holes located for the 38 gallon tank but only had the 24 gallon tank, then in 2016 bam 38 gallon tanks.
  24. Nov 10, 2019 at 10:05 AM
    #414
    I'm honestly waiting for someone to go ahead and do it themselves and make a DIY thread. Once that happens, I will jump on the wagon and do it as well.
    sask3m[QUOTED] likes this.
  25. Nov 10, 2019 at 10:12 AM
    #415
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    I doubt you'll see many doing it unless Toyota okays the warranty.
  26. Nov 10, 2019 at 11:02 AM
    #416
    timsp8
    NY
    If I had a 19 I’d also think about adding one if I towed a lot. I think Toyota is taking their chances with the less than 10% of owners who actually tow. 90%+ will never have an issue or probably even know there isn’t a cooler. But I’d worry about longevity.
    Cpl_Punishment likes this.
  27. Nov 10, 2019 at 3:25 PM
    #417
    Dodger46
    Dodger46 New Member
    2019 Silver Sky Metallic SR5 Crewmax
    Someone should get their fluid changed and analyzed. Especially if they tow a lot.
  28. Nov 15, 2019 at 4:36 AM
    #418
    NCTundra1980
    NCTundra1980 New Member
    Stephen
    2019 SR5
    Has anyone gotten a straight answer from Toyota? I opened a case to ask month ago or more and was told it is what it is. Was hoping someone got a better answer than that.
  29. Nov 15, 2019 at 10:06 AM
    #419
    blaserdude
    blaserdude New Member
    Eugene
    2019 Tundra Limited Double Cab
    none
    There is another user of this forum who is pursuing the same course. Without significant failures that can be attributed to the temperature of the fluid, I doubt Toyota is going to budge. The gen4 is coming soon and that will be their focus. Good luck and keep up posted.
    bc
  30. Nov 15, 2019 at 2:50 PM
    #420
    mundra
    mundra New Member
    Ormond Beach, Florida
    2019 platinum 4x4
    315/70/17 Ridge Grapplers on Rock Warrior Wheels, Tinted windows,remote start,tech12volts audio upgrade w/2-10" subs, console charger, more to come soon.
    No gen 4 until winter 2021 I saw
