2019 5.7 trans cooler location
Discussion in '2.5 Gen Tundras (2014-2021)' started by jcop1, Oct 18, 2018.
  1. Oct 17, 2019 at 6:04 PM
    #331
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
    I've read most of this thread. I am still a little confused if you can add the transmission cooler to the 2019? Please chime in if possible. I'd rather pay a few hundred dollars then sacrifice reliability.
  2. Oct 17, 2019 at 6:14 PM
    #332
    timsp8
    NY
    No one knows 100% cause I don’t think anyone has done it, but it appears there is just a spacer you’ll have to switch out for the trans thermostat. Should be same trans and same holes since 07. Then run the lines and get a cooler.
    Gaspssr likes this.
  3. Oct 18, 2019 at 1:04 AM
    #333
    Westside_cook
    Westside_cook New Member
    2018 Double Cab in Superwhite
    Stock
    I don't have much to contribute but holy crap I read through every single post in this thread. I give myself a round of applause for it.
    TTund16 and RPKEAN like this.
  4. Oct 18, 2019 at 5:00 AM
    #334
    What is everyone using to monitor transmission temps?
  5. Oct 18, 2019 at 5:04 AM
    #335
    mundra
    mundra New Member
    Ormond Beach, Florida
    2019 platinum 4x4
    315/70/17 Ridge Grapplers on Rock Warrior Wheels, Tinted windows,remote start,tech12volts audio upgrade w/2-10" subs, console charger, more to come soon.
    Wouldn’t this fall into a lawsuit since our window stickers show Eng/Trans coolers and there’s no trans cooler being sold that we should either get a discounted rebate back to us or a dealer installed trans cooler. This would make sense, since I bought my truck thinking it had a trans cooler on it. So, I was sold a false bill of goods that had poor representation listed on the mfg window sticker!
  6. Oct 18, 2019 at 5:42 AM
    #336
    NCTundra1980
    NCTundra1980 New Member
    Stephen
    2019 SR5
    I’m wondering how the window sticker says it has a cooler but they removed it I’m not happy about that part at all
    Alex38 likes this.
  7. Oct 18, 2019 at 5:44 AM
    #337
    mundra
    mundra New Member
    2019 platinum 4x4
    Not my exact truck but a window sticker showing Eng/tans coolers “plural”
  8. Oct 18, 2019 at 5:48 AM
    #338
    What's going to tick me off is when they add the cooler back to the tundra in 2021 model year.
    Tanya2020, mundra and Dodger46 like this.
  9. Oct 18, 2019 at 6:04 AM
    #339
    timsp8
    NY
    I use a BD tuner. Some use a scangauge. Some use an OBD Bluetooth thing to their cell phone app.
  10. Oct 18, 2019 at 6:04 AM
    #340
    I would want something that I can use on my phone. Any recommendations?
  11. Oct 18, 2019 at 6:11 AM
    #341
    timsp8
    NY
    I’ve never used a phone app but there are a lot on Amazon. Probably mostly Chinese made but maybe someone else on here has experience with one.
  12. Oct 18, 2019 at 8:31 AM
    #342
    Greg Marmalard
    Greg Marmalard New Member
    2019 Tundra TRD Off Road Double Cab
    I use iPhone app OBD Fusion. You can buy an add on for ~$10 that has ATF temp codes preinstalled so no messing with PID's
    Coupled with Foseal Improved Version Car WiFi OBD2 Scanner for $20 from Amazon I get all I need. The Foseal is just a branded version of an OBD. If you see similar for cheaper I'd grab it!
    I almost went with one of the "nicer" blue tooth ones but read fine print as many dont support ATF temps under any circumstances.
  13. Oct 18, 2019 at 8:39 AM
    #343
    Greg Marmalard
    Thanks for that but it clearly says in the article:
    "The vehicle manufacturer looks at all the data and decides what towing limits to place on that particular make/model vehicle."
    Word on the street is Toyota has always been more conservative than rival brands..... Just like the floor mat issue they KNOW if catastrophic failures result in deaths it's better to point at a spec that was exceeded.
  14. Oct 18, 2019 at 8:50 AM
    #344
    Word on the street huh? I like it.
    We should probably not pick little parts out and copy/paste.
    “Then a series of tests are conducted that target handling, trailer sway, braking, acceleration and component durability. The tests also include driving up the Davis Dam, a 7 percent grade that runs eastward out of Laughlin, Nev., for 11 miles to the top of the 3,500-foot summit in daytime temperatures of 100 degrees with the air conditioning going full blast. The vehicle manufacturer looks at all the data and decides what towing limits to place on that particular make/model vehicle.”
    In short, what used to be a the old ratings would not comply with this test. Weight had to be reduced to successfully complete and pass the SAE J2807 standard.
    I guess some people forgot I used to own a Tundra CM and only see GMC 3500HD. There’s a reason I had to go larger...and it wasn’t because the Tundra isn’t a hard workhorse.
    Rider0120 and TTund16 like this.
  15. Oct 18, 2019 at 9:36 AM
    #345
    Greg Marmalard
    Well we could go round and round about this; certain vehicles behave differently under different circumstances and can't all be subjected to the same tests. Take the front impact crash test where Tundra basically fails BUT notice they are ramming it into a sharp immovable object like I have yet to see in normal driving.
    Manufacturers are free to rate lower which I think Toyota does. I imagine they could rate closer to max if they preferred.
    I think Toyota only rates the Tundra payload ~100lbs more than Tacoma which is patently ridiculous! My Tacoma was sagging under a load and performance suffering, hence the change to Tundra, I transferred exact load and could not even feel it in the Tundra. Added another several 100lbs and no different in performance or handling....
    But my point is there are numerous things that could be done to save the cost of an ATF cooler if profit margin was prime concern. I've never seen a power steering cooler before! Never had a power steering pump fail......Even if would you rather replace a dozen ps pumps or one transmission?
    Thanks
    sask3m likes this.
  16. Oct 18, 2019 at 10:31 AM
    #346
    Since you have no idea, as do I why the cooler was removed for a different system, right now it’s just speculation.
    Yes I have changed a PS pump before. Both were on Toyota’s.
  17. Oct 18, 2019 at 11:17 AM
    #347
    Greg Marmalard
    Yes absolutely speculation!
    I argue it's not a big deal but am still fraught with curiosity as to why!
    All the rhetoric I've read hear does not satisfy my inquiring mind.
  18. Oct 18, 2019 at 11:45 AM
    #348
    I was surprised as well to hear the front mounted heat exchanger was replaced.
    Let’s keep in mind that the old system didn’t even open up until 230 degrees. Most of the time, never in use.
    So did the 2007-2018 trucks have transmission failures constantly? We have a few that did, but very rare.
  19. Oct 18, 2019 at 11:51 AM
    #349
    There must be something else going on here. If the cooler does not open until 230 degrees why do the 2019+ maintain 20-30 degree average above the previous models?
    Cpl_Punishment likes this.
  20. Oct 18, 2019 at 11:53 AM
    #350
    Not sure, but I might imagine it could be due to the new system temps.
  21. Oct 18, 2019 at 12:09 PM
    #351
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    There is not nearly as much heat transfer area in the warmer/cooler as in the old air-to-fluid exchanger, which was additive to the cooling provided by the warmer/cooler. Plus, the cooling medium (engine coolant @ 200 deg) is far less efficient than ambient air at say 100 deg F.
    In other words, the warmer/cooler on 2019s has inadequate cooling capacity to keep the transmission fluid at 230 deg using engine coolant as a cooling medium. The fluid temp is going to climb until equilibrium is reached for the operating conditions.
  22. Oct 18, 2019 at 12:16 PM
    #352
    timsp8
    NY
    When my trans reaches 194 as measured by a BD tuner, the ATF hose coming from the transmission is warm. I believe it opens well under 230.
    In my previous 2010 where the grill opened with the hood and I could get to it, the ATF cooler was hot when the trans got to around 200.
  23. Oct 18, 2019 at 1:03 PM
    #353
    Don’t disagree with you here.
    So I asked my buddy with a 2011 F250 on what temps he runs for the past 140k miles. He is at 200-230 all the time, with spikes a little higher. He uses this truck for tow duties only.
    I’m not sure I would worry about that temp a whole lot.
    Leaving my house...
    Destination NE CO
    That trailer by itself with rigs is 14000 lbs.
    I really doubt you have anything to worry about.
    Enjoy your trucks, and if you do get a transmission fail, warranties are for that purpose.
  24. Oct 18, 2019 at 1:08 PM
    #354
    JohnLakeman
    Leaving your house...forever? :rofl:
  25. Oct 18, 2019 at 1:10 PM
    #355
    Eric32444
    Eric32444 "Pick up your balls and load up your cannons..."
    Eric
    Panama City FL, Lynn Haven
    looks like he is TAKING his house...lol
  26. Oct 18, 2019 at 1:11 PM
    #356
    Soon enough. Can’t wait. Probably buy a 2024 GMC 3500, a nice toyhauler, and disappear for a long time.
  27. Oct 18, 2019 at 1:12 PM
    #357
    When I was homeless for a short stent, we lived in GA for a while. Haven’t used it since. Lol
  28. Oct 18, 2019 at 1:16 PM
    #358
    JohnLakeman
    Wait...what's the date on this thread. I'm posting in a time-warp; feeling deja-veax all over again. :D
  29. Oct 19, 2019 at 10:41 AM
    #359
    19crewmaxTRD
    19crewmaxTRD Tundra Enthusiast
    Seth
    2019 white tundra crewmax
    Posted this in the other transmission thread but this is more trafficked and I want to get some more opinions on this.
    Has anybody thought about adding just a small coolent radiator to the inlet side of the "warmer". I've noticed that the tranny temp mirrors the coolent temp going in pretty closely. It's not as intuitive to check actual coolent temp at the inlet. I measured with ir gun and the coolent was only a few degrees cooler than what the obd2 was reading for trans pan temp
  30. Oct 19, 2019 at 2:08 PM
    #360
    pickeledpigsfeet
    pickeledpigsfeet New Member
    Sierra Foothills, Ca
    2019 Tundra/14 FJ/ 90 SASed xcab
    Kings & Icons
    I am concerned about screwing with the flow of coolant. I dont want to compromise the motor to maybe help the trans. I dont want to stress the water pump as it is the only thing pushing the water and the small channels in a cooler do add back pressure.
    Now I have thought about removing the trans warmer completely from the engine coolant circuit. You can just tie the 2 coolant lines from the motor together effectively bypassing the trans. then run all new lines from the warmer and install a secondary radiator(small, intercooler size with efan) and a electric water pump.
    Eric32444 likes this.
