2018 Tundra which Tpms to use?
Discussion in 'Wheels & Tires' started by CrewmaxMoonTwp, Jul 7, 2018.
  1. Nov 10, 2018 at 2:39 PM
    1999cutiger
    1999cutiger Top Flow Lifestyle
    2017 Toyota Tundra SR5 4x4
    RBP 67R AK-8 20x9 wheels General Grabber ATX 275/60/20
    No reset. Install and go.
  2. Nov 14, 2018 at 12:57 PM
    wrtnaz
    wrtnaz New Member
    Tucson, Az
    2018 MGM Tundra SR5 CrewMax
    Wireless Charging Center Console Tray 6 3/4" Antenna Mast OEM Bed Mat Weather Tech In-Channel Low Profile Wind Deflectors Chrome Mirror Caps/Handles Limited Grill w/Chrome Surround Ionic 5" Oval Stainless Step Bars Center Console 110v and USB Power Converter Black Tundra Door Sill Protecters Undercover Swing Case Wireless LED Bed Light Strip Toyota Chrome Exhaust Tip 18" TRD Wheels
    Quick update. I went with the dealer recommendations and used the same TPMS from my steel wheels on the TRD aluminum wheels and everything is working great so far. Its been 3K miles and no problem at all. I will update again if anything changes
  3. Nov 14, 2018 at 1:12 PM
    para38s
    para38s New Member
    When I switched wheels on my Tacoma. I went from steel to allow. They some how made the TPMS sensors work.
  4. Jan 31, 2019 at 6:28 AM
    bigdogk9
    bigdogk9 New Member
    Ed
    2018 Toyota Tundra 1794 Edition
    42607-0c091 is not 415 or 425 mhz it is a 315
  5. Jan 31, 2019 at 6:38 AM
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    Technically you do need the 40-degree-angle sensors with the 7 digits. However, when I took my Pro alloys to be mounted in place of my stock steel wheels, Discount Tire said they swap the 20-degree-sensors all the time with no problem. They did break one when doing the swap, but replaced it for free. If you have to buy new ones I'd just get the "correct" ones, but tire shops should be able to swap the steel sensors.
  6. Mar 13, 2019 at 9:40 AM
    Enyar
    Enyar New Member
    Going to bump this. I have a 2013 with steel wheels and I want to swap to the wheels below. Everyone says I can just turn the sensors but the shop pulled one of my tires and said the old sensor wouldnt fit. Should I tell them to try harder? Try a different shop? Buy new sensors?
  7. Feb 10, 2021 at 4:28 PM
    DevildogVa
    DevildogVa New Member
    Jamie
    Black 2013 Tundra
    I have a 2013 with steel wheels and I want to swap to the wheels below. Everyone says I can use the old sensors but the shop pulled one of my tires and said the old sensor wouldnt fit. Is this true?Screenshot_20210210-180307_Chrome.jpg
  8. Feb 10, 2021 at 6:33 PM
    BuckWallace
    Oregon
    Sierra 3500 AT4 L8T
    They "technically" don't fit, but they can make them work. I took my 2010 to Discount Tire to swap my stock steel wheels with TRD Off-Road wheels and they just flipped my stock sensors. They work just fine. :thumbsup:
  9. Feb 11, 2021 at 2:42 AM
    DevildogVa
    Jamie
    Black 2013 Tundra
    @BuckWallace Do you remember how much it cost to swap eveything?
  10. Feb 11, 2021 at 7:55 AM
    BuckWallace
    Oregon
    Sierra 3500 AT4 L8T
    I don't remember exactly what it cost, but I'm pretty sure they just charged me for the balancing of the swapped tires. I do remember it being very reasonable.
  11. Mar 10, 2022 at 7:54 PM
    terryfd42
    terryfd42 New Member
    2021 tundra SR5
    I installed Trd wheels from a 2020. To replace my steel wheels on my 2021. They flipped sensors but after driving about 30 min they lose signal. Now don’t know what tpms sensors will work for the 2021 sr5
