2018 Tundra which Tpms to use?
Discussion in 'Wheels & Tires' started by CrewmaxMoonTwp, Jul 7, 2018.
  1. Jul 7, 2018 at 9:33 AM
    CrewmaxMoonTwp
    CrewmaxMoonTwp [OP] New Member
    Hello everyone, new to the site. Looking for help. I currently bought a set of 2017 TRD Pro wheels for my 2018 Tundra SR5, replacing the steel rims. Can figure out which TPMS to use. 18 needs a 7 digit number, with a 40 degree angle, but the 2018 alluminum 0c091, are 20 degree. All the 2017 and older have an 8 digit id, so they do not work either...I'm stuck! The original steel ones 0c0101 broke off when tryin gnome to use cause they have a 20 degree angle.. any success story is greatly appreciated ..thanks Mike
  2. Jul 7, 2018 at 9:38 AM
    ARamirez73
    ARamirez73 MGM CRÜE NATIÖN WIDE TTC #158
    The Lone Star State, RGV, TEXAS
    2014 CM TSS 4WD SR5 5.7 MGM
    Rough Country 6" lift / 35x12.50R20 Cooper Discoverer ST Maxx/ 20x9 +20 Fuel wheels "Mavericks" (Came with) / S&B CAI/ 2-10" Rockford Fosgates R2/ Massive Audio Nano N2 amp (Came with)/ KatSkins seat covers (Came with)/ Weathertechs window vent visors and floor mats/ 1A-AUTO.com aftermarket tow mirrors/ Undercover tonneau bed cover/ Viper alarm 3305V/ Flowmaster Super 40 Dual in-out/ 40" led light bar/ TRD Pro grille/Rough Country 30" LED light bar/TRD rear sway bar/ Ranch Hand legend grille gaurd/ Nfab nurf bars
    Welcome from Texas, someone will chime in to assist
  3. Jul 7, 2018 at 10:58 AM
    epa4wd
    epa4wd New Member
    Ed
    These are the ones you need for a 2018 Tundra with aluminum wheels. Let me know if you are interested.
    pizzabud likes this.
  4. Jul 7, 2018 at 11:38 AM
    CrewmaxMoonTwp
    Thank you for the reply, the toyota dealer said the 091 are set at 20 degree and I need the 40 degree for the 2017 rims?
  5. Jul 7, 2018 at 11:41 AM
    epa4wd
    epa4wd New Member
    Ed
    Dealership is wrong.
    Alloy wheels use 20 degrees
    Steel wheels use 40 degrees
    regardless of the year.
    Regards
    Ed.
    atl1glf, landphil and jeremyd like this.
  6. Jul 7, 2018 at 3:22 PM
    CrewmaxMoonTwp
    I appreciate your input..this is so frustrating. The toyota dealership says 2017 and older used 40 degree tpms, such as 42607-0c080, 315 mhz , but in 2018 both steel.and alloys use 20 degree tpms, in which 42607-0c091 is 20 degree but also a 415 or 425 mhz and would only work on 2018 rims, meaning there is no tpms for a 2018 tundra if using rims that are not 2018.
  7. Jul 7, 2018 at 3:39 PM
    my2ndtundra
    my2ndtundra New Member
    chuck
    2018 SR5 DC
    I'm in the same boat as you. Bought 2014 1794 wheels for my 2018 with steel wheels. Turned my steel ones upside down and that worked for awhile, now I can't get the low tire light to turn off.
  8. Jul 7, 2018 at 4:26 PM
    epa4wd
    epa4wd New Member
    Ed
    Wheels whether 2017 or 2018 are the same, the only thing that changed is what you mentioned in your first post, that 2018+ use a 7 digit TPMS and frequency is different, 2017 and earlier use 8 digit TPMS.
    Steel wheels 40 degree 2018 and earlier
    Alloy wheels 20 degrees 2018 and earier
    2018 Steel and Alloy wheels are the same as 2017 and older.
    MotoTundra and landphil like this.
  9. Jul 7, 2018 at 4:31 PM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Exterior LEDs, Pioneer 4200NEX, iDatalink Maestro, Ambit RS02, Nitto Ridge Grappler, Toytec/Radflo
    co-sign that this is the correct answer
    MotoTundra, landphil and epa4wd like this.
  10. Jul 7, 2018 at 7:52 PM
    CrewmaxMoonTwp
    Thank you, so what part number has been successful for 2017 trd rims on a 2018 tundra?
  11. Jul 7, 2018 at 7:57 PM
    epa4wd
    epa4wd New Member
    Ed
    The one in my picture above.
    Regards
    Ed.
  12. Jul 7, 2018 at 8:38 PM
    CrewmaxMoonTwp
    Thank you, how much you want for the 4 of them...
  13. Jul 8, 2018 at 7:20 AM
    CrewmaxMoonTwp
  14. Jul 8, 2018 at 8:15 AM
    Masher59
    Masher59 New Member
    Ponchatoula, La
    2018 Platinum Tundra
    I went aluminum to aluminum and the stealership wanted 100 bones each lol. I had my installer pull the ones from my wheels I was taking off and put em in my new wheels.
  15. Jul 8, 2018 at 9:16 AM
    CrewmaxMoonTwp
    Looks awesome, do you recall what model tpms sensor you had in there?
  16. Jul 8, 2018 at 9:27 AM
    Masher59
    Masher59 New Member
    Ponchatoula, La
    Looked just like these.
  17. Jul 10, 2018 at 1:47 PM
    jason.bird
    jason.bird New Member
    Idaho Falls, Idaho
    2018 Toyota Tundra SR5 Sport
    Before I pull the trigger on some used rims I want to make sure the TPMS sensors on my current wheels will work on the new (used) wheels work. I have a 2018 Tundra crewmax Sport with stock 20" rims and I want to get the 18" factory rims. Will I need new TPMS sensors?
    First image on the left are the 18" rims I want and the 2nd image are the 20" rims I have on my truck now.
    @Roman
  18. Jul 19, 2018 at 6:42 AM
    CrewmaxMoonTwp
    Update, just wanted to let everyone know that the TPMS 42607-0c091 are the correct sensors to use on a 2018 Tundra in which you purchased Trd or Trd Pro 18 inch wheels from any other year. I had them programmed fine at the toyota dealer..thanks everyone..
    epa4wd likes this.
  19. Jul 19, 2018 at 7:32 AM
    pschiller86
    pschiller86 2017 SR5 CrewMax
    Paul
    Temecula, CA
    What did the dealer charge you?
  20. Jul 19, 2018 at 7:36 AM
    CrewmaxMoonTwp
    $105...what a joke
  21. Jul 20, 2018 at 4:51 AM
    epa4wd
    epa4wd New Member
    Ed
    You can get techstream on ebay and program them yourself. Its just a matter of registering the IDs.
  22. Jul 20, 2018 at 4:53 AM
    epa4wd
    epa4wd New Member
    Ed
    You will just need to move your tpms sensors to the other wheels and thats it.
    jason.bird likes this.
  23. Jul 20, 2018 at 7:06 AM
    jason.bird
    Idaho Falls, Idaho
    Thanks! @epa4wd
  24. Aug 18, 2018 at 2:52 PM
    Metanium
    Metanium New Member
    2014 Double Cab
    Many
    I disabled the TPMS with a resistor and diode in my 2010 crewmax. Was hoping to do the same in 2014 model, but plugs in passenger side kick panel look different. Anyone know which wires to do the same?
  25. Aug 18, 2018 at 5:40 PM
    1999cutiger
    1999cutiger Community Organizer
    2017 Toyota Tundra SR5 4x4
    RBP 67R AK-8 20x9 wheels Nitto Ridge Grapplers 275/55/20
    I am using my tpms sensors from my factory steel wheels on my RBP wheels without any issues.
  26. Aug 18, 2018 at 6:43 PM
    pizzabud
    pizzabud New Member
    USA
    18' 5.7 CM White
    Price?
  27. Sep 16, 2018 at 9:30 AM
    wrtnaz
    wrtnaz New Member
    Tucson, Az
    2018 MGM Tundra SR5 CrewMax
    Center Console Tray 6 3/4" Antenna Mast OEM Bed Mat Weather Tech In-Channel Low Profile Wind Deflectors Chrome Mirror Caps/Handles Limited Grill w/Chrome Surround Ionic 5" Oval Stainless Step Bars Center Console 110v and USB Power Converter Black Tundra Door Sill Protecters 18" TRD Wheels
    How much are these? I am in the same boat. I just bought used trd wheels off a ‘17 to replace my ‘18 steel ones. Dealership says I can use my existing TPMS from steel wheels on the ‘17 wheels??? Is this going to work or do I need to buy new sensors? I was hoping to swap wheels this week so need to know quick. Thanks
  28. Sep 16, 2018 at 9:55 AM
    pizzabud
    pizzabud New Member
    USA
    18' 5.7 CM White
    I just replaced my 18 steel wheels with TRD pro wheels. I used the same sensors. The guys at the tire shop said it was a tight fit and that they had to turn them some type of way. Didn't bother buying the right sensors. Had them on for almost a week without an issue.
    wrtnaz likes this.
  29. Sep 16, 2018 at 2:14 PM
    mrflyinghigh
    mrflyinghigh New Member
    Jared
    2018 Blazing Blue Tundra Platinum
    I just bought some Fuel Throttle 20x9’s. I’m hoping the TPMS will work just fine after installation. Did you just reset the system after install or what? Thanks
  30. Nov 10, 2018 at 2:17 PM
    KirthGersen
    KirthGersen New Member
    So Calif
    2018 SR5 Crewmax
    Would those TPMS also need a "fitting kit", part # 04423-0C170, for installation onto a new 18" Toyota TRD wheel?
    Edit: at post#3 on this thread,
    https://www.tundras.com/threads/tpms-sensor-help.27842/
    Roman @ Toyota of Cool Springs previously confirmed that fitting kit is needed.
