2018 Tundra LED headlight wiring info with diagrams
Discussion in 'Lighting' started by thomasbus337, Sep 6, 2017.
  1. Sep 20, 2017 at 9:10 PM
    #181
    PROTX
    PROTX New Member
    Edgar
    2017 TRD PRO Barcelona Red Metalic
    Are the drls working as they Should? Do they switch from bright to dim when you turn on the low beams?
  2. Sep 20, 2017 at 9:26 PM
    #182
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    If you can do the retrofit job yourself it would def be cheaper and brighter. this is more of a OEM solution that doesn't include baking headlights. I just don't want to deal with opening up headlights and if a part fails inside, have to open them again. But these are PnP! With the harness lol
    4RNR[QUOTED] likes this.
  3. Sep 20, 2017 at 9:40 PM
    #183
    4RNR
    4RNR トヨタ
    America
    16 Tundra SR5 CM
    Switched from 16 Taco
    Agree.
    But I have retros on my 4Runner for about two years, maybe more, so far zero issues.
    OEM leds can fail too and Toyota won’t cover them, I’m sure.
    I don’t know what to do:)
    I’ll keep an eye on this thread for now:)
    BlueBottle likes this.
  4. Sep 21, 2017 at 9:06 AM
    #184
    Redlineaz
    Redlineaz New Member
    I'm in for a set of plug and play harnesses for my 1794, anyone willing to sell me some? @thomasbus337 or anyone else here willing to do it for me and sell me some? Ideally I would like to have the LED DRL on full brightness, regardless of if the low/high beam are on, and upgraded gauge wiring to allow the low/highbeam to stay on at the same time. Is this doable? Really appreciate it guys!!!!
    Also, what are these lights running shipped to your door?
  5. Sep 21, 2017 at 9:14 AM
    #185
    AK-in-MI
    AK-in-MI New Member
    Joey
    Michigan
    2015 Platinum Crewmax
    D.A.P. Tune Bilstien 6112/5160 33x12.50xr20 Toyo Open Country M/T 20x9 Fuel Coupler TRD Exhaust
    @Redlineaz I put my order in last week and the total shipping and all was $644. I am in the same boat as you waiting for someone to make a harness.. I have a 15 platinum and I would like to have the leds stay bright as well.
    Redlineaz likes this.
  6. Sep 21, 2017 at 12:52 PM
    #186
    zwillz
    zwillz New Member
    2015 sr5 Crewmax
    I'm also in the same boat as the rest.... I have no idea, or where to even start with making a pnp harness lol. I'm def ok with a PayPal payment to one of you guys who have them up and working properly. I HAVE THESE BAD BOYS IN FRONT OF ME READY TO INSTALL, just need the key component! Someone help a brotha out lol
    TIA
    757TUNDRA and Redlineaz like this.
  7. Sep 21, 2017 at 1:49 PM
    #187
    be77solo
    be77solo New Member
    2017 Silver Crewmax 4x4 5.7L
    KO2's on ENKEI ST6's, BakFlip MX4
    Looks like my headlights will be here tomorrow woohoo! Faster than I thought, need to order wire parts now ha
    So, for '17 SR5, is this still the correct list of parts and diagram for what I need to order? (post 42 in this thread).
    https://www.tundras.com/threads/201...g-info-with-diagrams.16225/page-2#post-350235
    I've been going through this thread the past couple weeks, but I've seen a couple revisions, after thoughts etc... just wanted to order and build whatever is the latest and great revision for an SR5 with the stock amber DRLs.
    Thanks! Depending on how it goes I may be up for building an extra harness or two depending if I have to order some parts in higher quantities than needed.
  8. Sep 21, 2017 at 1:55 PM
    #188
    texbambam
    texbambam New Member
    Tundra TRD PRO sand
    I have time as the lights have not shipped yet...but hey...
    Tundracollector likes this.
  9. Sep 21, 2017 at 2:33 PM
    #189
    thomasbus337
    thomasbus337 [OP] New Member
    2020 TRD Sport DC
    Yes, post 42 still lists the correct parts. The quantities for the terminals and seals are the exact numbers needed, but I'd recommend ordering a few extra of each for spare parts. If you want to add an extra relay for a heavier gauge wiring for high beams then refer to post 106.
    My extra parts should be in tomorrow, so by the end of the weekend I'll have an additional write up and parts list for the SR5,Limited and Pro crowd with two different options to be PnP with the new LED DRL's
  10. Sep 21, 2017 at 2:39 PM
    #190
    be77solo
    be77solo New Member
    Ok, thanks for the fast reply! But, now I'm confused ha.... Is it safe to order everything from post 42 and you are just updating the wiring connections, or should I wait for the additional write up and parts list for the SR5? I'm so not trying to be a pain in the ass ha, you are invaluable with what you have contributed! :cheers:
    Reason I ask is I have everything it my cart from post 42 about to order ha
  11. Sep 21, 2017 at 2:50 PM
    #191
    Tundracollector
    Tundracollector New Member
    16 Dc trd pro, 04 Dc, 08 rcsb
    Where are you buying everything from?
  12. Sep 21, 2017 at 2:51 PM
    #192
    thomasbus337
    2020 TRD Sport DC
    Yes, it's safe to order the parts now, nothing on the main harness has changed. The two different options would be related to the way you want to interface with your current violet wires for the parking lights/DRL harness. To be safe I'd order about 12 extra CONN 11856 female pins and 12 CONN100069 male pins just to have.
    iHacker and be77solo like this.
  13. Sep 21, 2017 at 2:53 PM
    #193
    be77solo
    be77solo New Member
    His source of Ballenger Motorsports has almost everything with great prices. The other two items I'm going to get from @Roman and Retrofit Source down in Atlanta. Luckily, all are fairly close by so cheap shipping will only be a 2-3 days.
  14. Sep 21, 2017 at 2:56 PM
    #194
    be77solo
    be77solo New Member
    Perfect, thanks! Ordering now and will look forward to your write up as I wait for the parts to arrive next week.
    Your part numbers and Ballenger source was ridiculously helpful.
    You are the man! If ever in Charlotte hit me up and I'll buy you a beer.
  15. Sep 21, 2017 at 3:04 PM
    #195
    Redlineaz
    Let me know my friend!!! Thanks so much!
    be77solo[QUOTED] likes this.
  16. Sep 21, 2017 at 3:41 PM
    #196
    Young80i
    Young80i New Member
    Kyle
    Garden Grove CA
    2015 Platinum
    Hi guys.. what is the length of the wire should I make for the harness? And where is a good place to buy some 16 Gauge GXL wires. Getting all the parts ready before I receive the headlight. thanks guys!
  17. Sep 21, 2017 at 3:41 PM
    #197
    be77solo
    be77solo New Member
    So I apologize for quoting you twice, but curiosity won over.. Got all the parts ordered as you suggested, thanks! Will wait for your latest thoughts before wiring, and can't thank you enough for what you have already done.
    Have to ask though, being from the High Point area, is that the source of your user name??
  18. Sep 21, 2017 at 3:48 PM
    #198
    thomasbus337
    2020 TRD Sport DC
    No problem at all. Yes, my day job consists of maintaining a fleet of High Point's finest TBB's, good catch.
  19. Sep 21, 2017 at 3:53 PM
    #199
    BlueBottle
    '16 Platinum 4x4
    See fine print
    @thomasbus337 thanks for putting this together. I know you really don’t have to. A lot of people owe you beers!!!! Better be ready lol. If you ever in my hood I’ll get you.
  20. Sep 21, 2017 at 4:00 PM
    #200
    thomasbus337
    2020 TRD Sport DC
    I ordered my wiring from ebay. I figured it would be more helpful if my "how-to" pics showed wiring that was color coded to match the factory wiring and wire diagram colors. I measured out the three headlight wires @ 24" and the DRL's @ 18". It was more than enough and I secured the excess with plastic zip ties
  21. Sep 21, 2017 at 4:18 PM
    #201
    iHacker
    iHacker SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    Ordered my 2018 Black LED headlights today, so if I make them work properly I'll have my set of retrofitted Pro headlights for sale. :dancingbacon::broccoli::bananadance:
    757TUNDRA likes this.
  22. Sep 21, 2017 at 4:19 PM
    #202
    Young80i
    Young80i New Member
    Kyle
    Garden Grove CA
    2015 Platinum
    Thanks thomasbus337! I have bunch of 16 gauge wire but it label at 105f is it safe to use?
  23. Sep 21, 2017 at 4:27 PM
    #203
    be77solo
    be77solo New Member
    :thumbsup:
    Private message me your paypal email address and I'd love to send over some funds to buy you and your significant other dinner. Your diagrams and input/responses are priceless for those of us that need this!!
  24. Sep 21, 2017 at 5:26 PM
    #204
    92lt
    92lt New Member
    Western NY
    2016 Tundra Black LTD
    Just a warning to those thinking of doing the led upgrade... If you ever have any electrical issues on your truck, there is a good chance your dealer may not cover the repairs. I(it usually depends on the dealer)
    I want these led lights real bad, but I don't want to risk my warranty especially since I have an extended warranty.
  25. Sep 21, 2017 at 5:37 PM
    #205
    757TUNDRA
    757TUNDRA Not a New Member
    Illinois
    2018 Barcelona Red Metallic Platinum 4x4
    OEM Bed Cover, OEM Bed Rail System, OEM Bedmat, OEM Doorsill Protectors, OEM TRD Rear Sway Bar, OEM Color Matched Door Handles, OEM Color Matched Mirror Caps, OEM Bed Net, OEM Driver Side Grab Handle, BFG K02 LT275/60/20, WeatherTech Digifit FloorLiners, Salex OCD Console Organizer, Salex Console Tray
    I had that same thought yesterday but didn't want to say it ... lol.
  26. Sep 21, 2017 at 5:40 PM
    #206
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Someone needs to set him up a gofundme page!
    be77solo likes this.
  27. Sep 21, 2017 at 5:42 PM
    #207
    be77solo
    be77solo New Member
    I guess, sure, if I have poorly wired headlights and fuss about an electrical problem, absolutely....
    But with a plug and play (no wires cut or modified), I could simply plug back in my stock OEM '17 headlights instead of my OEM '18 headlights...
    I can't see this being a problem with a proper harness, and have zero concern.
    Quebec, Redlineaz, PROTX and 3 others like this.
  28. Sep 21, 2017 at 6:03 PM
    #208
    pvdubber
    pvdubber New Member
    Auburn CA
    2017 Silver Sky
    I think that would be real difficult for Toyota to try to do, as they would have to prove that what ever we did caused the electrical issues. Secondly the way in which this is done prevents any cutting of any wires and this mod actually puts less strain on the electrical system due to the fact that less actual current is being used to provide a greater amount of light. I had to move only 2 pins. Third the lights are a Toyota OEM product not an aftermarket product so I would struggle to see how Toyota would benefit form not covering any unrelated electrical issues. Finally with this setup I can return my truck to stock within a 1/2 hour.
    I am not and electrical engineer but this is my harness almost completed. It is completed now and installed
    I am very impressed with the light output. I put this together a midnight last night out of necessity.
    one more gratuitous photo just because I love the look of these pick-ups.
    @thomasbus337 (thank you) after looking at the wiring diagram I am 100% confident in this set-up, and would recommend it to you or anyone on the fence. It just out performs the the 14-17 stock headlights with out being obnoxious.
  29. Sep 21, 2017 at 6:27 PM
    #209
    iHacker
    iHacker SW TRD PRO
    Mario
    love the look of your truck :thumbsup:, those headlights were meant to be there, lets see how they look in my super white Pro :thumbsup::thumbsup::thumbsup:
    pvdubber[QUOTED] likes this.
  30. Sep 21, 2017 at 6:34 PM
    #210
    pvdubber
    pvdubber New Member
    Auburn CA
    2017 Silver Sky
    Thanks man, I appreciate that.
    iHacker[QUOTED] likes this.
