2018 Tundra LED headlight wiring info with diagrams
Discussion in 'Lighting' started by thomasbus337, Sep 6, 2017.
  1. Sep 11, 2017 at 3:46 PM
    #61
    MMichaelJJ
    MMichaelJJ New Member
    14 Platinum CM
    Have there been any night pictures of the beam pattern outside posted anywhere?
    OP - thank you for all your work putting this together.
  2. Sep 11, 2017 at 5:04 PM
    #62
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Yes, in the other 2018 led headlight thread posted by Roman. A member posted few pics comparing stock vs these. Output is way better.
  3. Sep 11, 2017 at 5:09 PM
    #63
    Berdine
    Binghamton, NY
  4. Sep 12, 2017 at 10:21 AM
    #64
    pvdubber
    pvdubber New Member
    Auburn CA
    2017 Silver Sky
    I am away for one weekend and you change the game on me. Nice job. I am still awaiting on my parts as I assume I will be for a little while.
  5. Sep 13, 2017 at 7:07 PM
    #65
    thomasbus337
    thomasbus337 [OP] New Member
    2020 TRD Sport DC
    I checked with The Retrofit Source about the usage of the Bi-Xenon relay harness to control our 2018 LED headlights. There should be no problem running the low beams off the “ballast” plugs but they were concerned about the amperage for the hi beams. I bench tested them and the high beams draw slightly more than one amp of power. The Motocontrol harness wiring for the hi beams are 20-gauge wiring, so while it works it’s not ideal. I’m going to try installing a relay and use the signal from the “high beam” plug to control the relay with a thicker gauge wire just to be safe. I’ll update the parts list again once I test it out. Here’s how the newest version of the PnP harness looks. The gray plugs with plug into the Moto relay harness and the black plug will mate with the factory 14-17 DRL plugs.
  6. Sep 13, 2017 at 7:15 PM
    #66
    pvdubber
    pvdubber New Member
    Auburn CA
    2017 Silver Sky
    If I remember correctly 20 gauge wire can handle up to 1.5 Amps. How far north of that did the bench test show?
  7. Sep 13, 2017 at 8:45 PM
    #67
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    @thomasbus337 I need a crimper for the pins. Can you share a link on Amazon that you recommend/?
  8. Sep 13, 2017 at 8:48 PM
    #68
    pvdubber
    pvdubber New Member
    Auburn CA
    2017 Silver Sky
    BlueBottle[QUOTED] likes this.
  9. Sep 13, 2017 at 8:57 PM
    #69
    RLHULK
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    You guys that can figure that stuff out are amazing. I have never been able to wrap my head around wiring diagrams and such. Amazed am I....
    4x4_Angel and Quebec like this.
  10. Sep 14, 2017 at 3:25 AM
    #70
    thomasbus337
    2020 TRD Sport DC
  11. Sep 14, 2017 at 3:27 AM
    #71
    thomasbus337
    2020 TRD Sport DC
    It was 1.01 something. My driver's side headlight should be here today so I'm going to test for amp readings again when they are installed on the truck.
    pvdubber[QUOTED] likes this.
  12. Sep 14, 2017 at 7:01 AM
    #72
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    I'm in on this I have started collecting parts. c2892a6827a47d8c5a5c1ce4c5b30b6a_13d24ed59c2a9154b4e9083b6e803341aeea9dfb.jpg
    Berdine and pvdubber like this.
  13. Sep 14, 2017 at 7:12 AM
    #73
    pvdubber
    pvdubber New Member
    Auburn CA
    2017 Silver Sky
    Nice you are half the distance to the goal, I am completely in the dark (pun intended), also did you ever get an amperage reading on the stock halogen lights? I would bet it would show similar or more current draw. I have nothing here yet I am living vicariously through you.
  14. Sep 14, 2017 at 7:30 AM
    #74
    SilverRider
    SilverRider New Member
    Las Vegas
    2015 Silver Crewmax Limited 4x4 TRD Off Road
  15. Sep 14, 2017 at 9:12 AM
    #75
    kkim124
    kkim124 New Member
    Torrance, CA
    2016 Tundra Platunum 4x4
    Wow. This is awesome info. I'm hoping someone will be selling a pnp harness.
  16. Sep 14, 2017 at 9:24 AM
    #76
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    TundraTex likes this.
  17. Sep 14, 2017 at 4:54 PM
    #77
    pvdubber
    pvdubber New Member
    Auburn CA
    2017 Silver Sky
    Does the new headlight indicate what the wattage is for low, and high beams, because if so we could just calculate the combined amperage is given that we know the voltage.
  18. Sep 14, 2017 at 6:50 PM
    #78
    thomasbus337
    2020 TRD Sport DC
    Today was the day! My driver’s side headlight arrived, so naturally I had to finish this retrofit. The low beam is 20.8w and the high beam is 14w. I tested the amp draw with the truck running and one side is drawing 1.025 amps and the other 1.045 amps. TRS had requested this information and replied letting me know that this should be ok to use because the 20-gauge wiring on the “high beam” wiring has a max output of 2amps. Of course, this information would come after I ordered a handful of relays from Amazon. Anyways I’m still going to configure a relay setup with heavier wire for those who might want a more robust high beam setup. The harness I put together and posted yesterday, connected flawlessly to the Motocontrol relay harness and works like a charm.
  19. Sep 14, 2017 at 6:53 PM
    #79
    Kevin1741
    Kevin1741 New Member
    So when are you going to start taking orders?
  20. Sep 14, 2017 at 9:02 PM
    #80
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    2018 Ram 2500 Cummins Laramie
    IG: PLC721
    Yes sign me up please haha
  21. Sep 14, 2017 at 10:04 PM
    #81
    Midnighttaco08
    Midnighttaco08 High Quality H2O Inspector
    Sam
    Gilbert, AZ
    2017 Quicksand TRD OR 4x4 2008 Indigo Ink Tacoma TRDOR
    None yet!
    In for a harness!
  22. Sep 15, 2017 at 9:57 AM
    #82
    kkim124
    kkim124 New Member
    Torrance, CA
    :bowdown:
    Please sign me up for a harness as well.
  23. Sep 15, 2017 at 9:58 AM
    #83
    jdm ctr '00
    jdm ctr '00 New Member
    los Angeles, CA
    2016 Tundra TRD PRO
    :thumbsup:
  24. Sep 15, 2017 at 12:32 PM
    #84
    jdm ctr '00
    los Angeles, CA
    2016 Tundra TRD PRO
    So 20-gauge wires for the whole harness is ok?
    I just went to the dealer and checked out a 2018. Lights are awesome, Will the LED fog lights plug in to the 2016 harness?
    Kevin1741 likes this.
  25. Sep 15, 2017 at 1:05 PM
    #85
    thomasbus337
    2020 TRD Sport DC
    I made my harness using 16 gauge GXL grade wiring which is recommended for under hood applications. It has a higher heat rating 257 F compared to 221 F of standard auto parts store wiring. The only 20 g wiring in my setup is on the Moto relay harness for the high beams.
    st33l likes this.
  26. Sep 15, 2017 at 2:36 PM
    #86
    pvdubber
    pvdubber New Member
    Auburn CA
    2017 Silver Sky
    I have learned that I have little to no patience, my parts cant get here soon enough.
  27. Sep 15, 2017 at 3:39 PM
    #87
    Young80i
    Young80i New Member
    Kyle
    Garden Grove CA
    2015 Platinum
    Please sign me up for a harness for my Platinum!
  28. Sep 16, 2017 at 1:10 AM
    #88
    MMichaelJJ
    14 Platinum CM
    I literally was going to post a topic / question asking what wire type works best for wiring in the engine compartment. I just started researching and saw there are other types of wires; normally I would have just bought "primary wire."
    I'll be picking up some "cross-link" wire for the higher heat resistance.
    Thanks.
  29. Sep 16, 2017 at 10:40 AM
    #89
    bryanpwatson
    bryanpwatson New Member
    2017 Grey Tundra XS-P
    None to date but coming!
    I have my 2018 Platinum LED headlights just need a harness for a 17 SR5! Take my money!
  30. Sep 16, 2017 at 8:48 PM
    #90
    st33l
    st33l New Member
    2014 Tundra MGM Platinum
    Installed my 2018 headlights today. Big thanks to thomasbuss337 for doing all the hard work with providing this community with the wiring diagram for the harness. Works perfectly.
    20170916_130759.jpg 20170916_174928.jpg 20170916_172907.jpg 20170916_191549.jpg 20170916_191714.jpg 20170916_192149.jpg 20170916_193451.jpg
    Meltz, dradd, darkknight2014 and 19 others like this.
