2018 Tundra LED headlight wiring info with diagrams
Discussion in 'Lighting' started by thomasbus337, Sep 6, 2017.
  1. Mar 17, 2018 at 7:57 AM
    #811
    tgun
    tgun New Member
    Tom
    Northern Illinois
    2025 TRD Pro (Mudbatch)
    Decked 2.0, Wildpeak ATw 35x11.5x18 Class C, bed step, predator steps, Baja s8 amber light bar and S2 amber fogs
    Hello!
    I’m starting my led headlight install and I’m confused as to where the green DRL gets plugged into? I have the 2017 Limited model581A78B3-5129-4990-8E84-EA624C1A6055.jpg
  2. Mar 17, 2018 at 8:12 AM
    #812
    tgun
    tgun New Member
    Tom
    Northern Illinois
    I think I figured it out! Goes to plug that has the fuse tap. Correct?
  3. Mar 17, 2018 at 8:27 AM
    #813
    METRO32168
    METRO32168 New Member
    2016 CM PLATINUM SILVER
    DECKED STORAGE UNIT,BACKFLIP G2 COVER,THULE ROOF RACKS, AMP RESEARCH POWERSTEP, TRD BILSTEINS COIL OVER SHOCKS (3" LIFT), TRD BILSTEINS SHOCKS REAR, SETINA BUMPER GUARD
    I converted mine With H4 this plug.
    Didn’t use the harness
  4. Mar 17, 2018 at 8:27 AM
    #814
    METRO32168
    No issues/ worries about cutting/rapping .
  5. Mar 17, 2018 at 8:35 AM
    #815
    tgun
    tgun New Member
    Tom
    Northern Illinois
    If I do it @eledoblelu way I plug green into here. Correct?A2931B1A-8A46-4BD5-B627-16128AEA09DB.jpg
  6. Mar 17, 2018 at 8:45 AM
    #816
    Kwikfish
    Kwikfish Get your poop in a group!
    Tri cities,WA
    16 CM SSM
    What harness did you go with?let me know how long it takes you total if you could as i now have all my parts for the front end remodel
  7. Mar 17, 2018 at 8:48 AM
    #817
    tgun
    tgun New Member
    Tom
    Northern Illinois
    I purchase @eledobleu harness! Started at 8:30. Still plugging away. Deciding if I want to disconnect grey wire??
  8. Mar 17, 2018 at 9:14 AM
    #818
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    You didn’t use a motocontrol?
    Do your lows stay on with high beams ?
  9. Mar 17, 2018 at 10:46 AM
    #819
    tgun
    tgun New Member
    Tom
    Northern Illinois
    Got it all completed just under 4hrs. For now i decided to leave the amber DRL. Kinda like the look......Thank you for all the help and especially @eledobleu for building these harnesses...I have attached a few pics of my truck and now its onto 2018 LED fogs at some point! IMG_7485.jpgfullsizeoutput_2a88.jpgIMG_7488.jpgIMG_7490.jpg
    OceanSkyWolf, NCinCO and METRO32168 like this.
  10. Mar 17, 2018 at 10:50 AM
    #820
    METRO32168
    Didn’t want it that way.
    It’s an easy splice to do it.
    LEDs don’t use a lot of power so I didn’t use the motocontrol
  11. Mar 17, 2018 at 11:05 AM
    #821
    Kwikfish
    Tri cities,WA
    16 CM SSM
    Tgun it looks great man!im going to leave tje ambers on as well,what sliders are those?
    tgun likes this.
  12. Mar 17, 2018 at 12:29 PM
    #822
    tgun
    tgun New Member
    Tom
    Northern Illinois
    Thank you @Kwikfish! Those are Apex Rock Sliders.
  13. Mar 17, 2018 at 12:33 PM
    #823
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Do your lows stay on with highs though? That was the problem @thomasbus337 had when he did it this way.
  14. Mar 22, 2018 at 11:16 AM
    #824
    METRO32168
    Hi/lo beams work fine just had to switch the leads around.
    If ur talking about the drl lights they work like factory settings.
  15. Mar 29, 2018 at 7:20 PM
    #825
    mrlakeside
    mrlakeside New Member
    So are there any harnesses where you don't need the Morimoto h4 controller? I have a 2017 Limited I am being told that I need the lights, DRL power harness and conversion harness. Is that all I need? -Confused
    Thanks for your help
  16. Mar 30, 2018 at 5:14 AM
    #826
    METRO32168
    Check to see if ur limited has the led drl light like the platinum. I didn’t need the morimoto and added a h4 plug.
    Any one here can chime in on this about the wiring info for limited model as I do not have any info to confirm.
  17. Mar 30, 2018 at 11:47 AM
    #827
    iHacker
    iHacker SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    Yes Limited don’t have LED DRL from factory is just like a luxury SR5 with Amber DRL
  18. Mar 30, 2018 at 4:40 PM
    #828
    MMichaelJJ
    MMichaelJJ New Member
    14 Platinum CM
    Work fine and they work at the same time together?
    Switch the leads? What do you mean?
    I’m wanting to get rid of my motocontrol and cut down on the wiring.
    I tested the leads on the OE harness and the low and high beams don’t stay on at the same time. That’s the same issue the OP had and the reason he went with the moritmoto harness.
    I built my own harness with his directions and I’m having a hard time justifying spending another $90 on a harness. The part(s) I need is proably less than $10 to make mine work.
  19. Mar 30, 2018 at 4:58 PM
    #829
    iHacker
    iHacker SW TRD PRO
    Mario
    Really simple just need a Schottky Rectifier anything above 3Amps should be Ok I made my own and testing in my truck passenger side and driver side still with the Motocontrol for about 2 weeks so far no problems and thanks to TRS Andrew (motopowers) who reminded me that old school method I used before in my 2000 Civic Si to keep the Lo with Hi beams the problem is that this decreased the life of the bulbs significantly due to heat but I’m not sure if will cause problems in the LED headlights I guess not because we already doing this with the Motocontrol
    The only problem I see here is that checking with @Roman Toyota don’t produce a male H4/9003 OEM connector since the male part for this connector is the bulb itself so this let us to the mercy of the Chinese junk for sale online I don’t trust those connectors but seems to be the only option available
    For the diode I recommend you this over the cheap junk others use this is high quality (2 diodes one for each side)
    https://www.mouser.com/ProductDetail/Rectron/SR560-T?qs=sGAEpiMZZMtQ8nqTKtFS/DR0Vw63NIMR/3%2bfI/tJKEA=
    And unfortunately this is the only option available to crimp your self a better quality wire than buying it with wire already
    2pc HID H4 9003 HB2 Male Connector Plugs Wire Socket Adapter Free Shipping H-4 https://www.ebay.com/ulk/itm/332269291372
    Send me a PM if you need more details
  20. Mar 30, 2018 at 4:58 PM
    #830
    mrlakeside
    My 2017 limited does not have LED DRL's but it does have the Amber DRL's - So I need the drl harness then. What is an H4 plug and do I need to add that somehow? Thankks
  21. Mar 31, 2018 at 1:42 PM
    #831
    LKSR5-14
    LKSR5-14 New Member
    Chicago Northwest suburbs, Illinois
    2016 Tundra SR5 DC
    Tundra SR5 DC 2016 Upgrade: pro wheels, headlights retrofit, head unit Kenwood 694s, bed cover, lineX, Viper security and starter system, pro grille, tinted windows, LED lighting, black wrap on all end chrome corners, ceramic coating
    Since I have retrofit done by @eledobleu and moto control harness wondering if I want to replace my retro with new 2018 led headlights, what more harness I need to get in order to have amber and led strips working as OEM? My retrofit with halos can be seen at @iHacker post.
    iHacker likes this.
  22. Mar 31, 2018 at 1:46 PM
    #832
    iHacker
    iHacker SW TRD PRO
    Mario
    Those were the most useful pictures I could ever find for the Motocontrol install, I remember that day when you installed your retros :D
    LKSR5-14[QUOTED] likes this.
  23. Mar 31, 2018 at 1:52 PM
    #833
    LKSR5-14
    LKSR5-14 New Member
    2016 Tundra SR5 DC
    @iHacker Not a problem at all
    I still love them but I my put them up here for sale if someone interested and they are done by @eledobleu and probably I will order OEM 2018 led headlights but would like to keep led and amber as drl but not sure what I need to order in order to correctly work I have pulled out as I remember my gray wire under the dash if that helps.
    Any comment what should I get besides new headlights?
  24. Mar 31, 2018 at 1:55 PM
    #834
    iHacker
    iHacker SW TRD PRO
    Mario
    We all have a good selection for the harness now or at least the 3 most mentioned here, one from a guy user name @iHacker and other 2 harnesses @eledobleu and one from @motopowers or most know as Retrofit source
    Depending on what you are looking for those are all the options available
  25. Mar 31, 2018 at 2:01 PM
    #835
    LKSR5-14
    LKSR5-14 New Member
    2016 Tundra SR5 DC
    @iHacker So as you are familiar what retros i have i would like to order correct harness wires in order to install new 2018 headlights and to have always drl led, also amber as a drl, kind of like it.
    So questions i have would led dim when I do turn signal or what options are available?
    My truck is 2016 SR5
  26. Mar 31, 2018 at 2:10 PM
    #836
    iHacker
    iHacker SW TRD PRO
    Mario
    Yeah Amber DRL and LED look cool just a great example, pictures from @JoshuaA
    JoshuaA likes this.
  27. Mar 31, 2018 at 2:13 PM
    #837
    LKSR5-14
    LKSR5-14 New Member
    2016 Tundra SR5 DC
    @iHacker That's exactly what I want. Are they flashing while turn signal is on? LED strip as a turn signal or not?
  28. Mar 31, 2018 at 2:21 PM
    #838
    iHacker
    iHacker SW TRD PRO
    Mario
    Not the LED strip only the ambers are used as turn signal
  29. Mar 31, 2018 at 2:23 PM
    #839
    LKSR5-14
    LKSR5-14 New Member
    2016 Tundra SR5 DC
    I wish they could be switchback as my retrofit
  30. Mar 31, 2018 at 2:27 PM
    #840
    iHacker
    iHacker SW TRD PRO
    Mario
    It’s posible but that’s another story, you will need to take them apart and change the LED DRL boards Diode Dynamics is working on this now not sure but I guess Retrofit source is doing this too.
