2018 Tundra LED headlight wiring info with diagrams
Discussion in 'Lighting' started by thomasbus337, Sep 6, 2017.
  1. Jan 12, 2018 at 7:06 PM
    #781
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Right on.
  2. Jan 12, 2018 at 7:12 PM
    #782
    darkknight2014
    darkknight2014 Mods mods and more mods!!
    Phil
    New york
    2014 tundra sr5
    20" Cooper STT Pros on md rims, quadfire lights, pro grille, leather interior, navi, retrofitted headlights, blacked out chrome, TRD sway bar, hypertech interceptor, k&n air intake, Banks exhaust
    Where would it connect too i hate this kinda stuff lol.
  3. Jan 13, 2018 at 5:21 AM
    #783
    darkknight2014
    Phil
    New york
    2014 tundra sr5
    Where did u guys get the turn signal bulb being its different now. I assume toyota is the best place. You'd think you would get the bulbs with it jeez.
  4. Jan 13, 2018 at 11:45 AM
    #784
    darkknight2014
    Phil
    New york
    2014 tundra sr5
    One question i folloed directions to a t for adding the lights to an sr5. I noted while driving when i used my blinkers the radio cluster screen would dim high low with the blinker. I then noticed the area where the havc knobs are they are on all the time while the truck is running. Any help would be great.
  5. Jan 17, 2018 at 8:07 PM
    #785
    sano502
    sano502 New Member
    17 Tundra TRD Pro Cement
  6. Jan 17, 2018 at 8:14 PM
    #786
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    Post up what's giving you trouble, maybe someone else can help faster...
  7. Jan 17, 2018 at 8:15 PM
    #787
    inferno_pro_satx
    inferno_pro_satx New Member
    Roger
    2016 Tundra TRD Pro
    What’s the problem
  8. Jan 17, 2018 at 8:19 PM
    #788
    sano502
    sano502 New Member
    @inferno_pro_satx i got the PNP harness for the SR5/Pro models from @thomasbus337 and I also got the DRL Relay harness from his as well. I finally received the Triton V6 ambers i was waiting for also. I have a motor control too. Now I want to get the 2018 headlights that I have installed. A buddy of mine offered to install them but I need a diagram to show how to hook it all up.
  9. Jan 17, 2018 at 8:26 PM
    #789
    boostedtrdpro
    Jeremy
    Wish I could help. It was pretty easy as iHacker had all the connectors labeled. I bought his harness.
  10. Jan 17, 2018 at 8:30 PM
    #790
    sano502
    sano502 New Member
    @iHacker are you selling your harness with labels and all that still? If so, I’ll buy
  11. Jan 17, 2018 at 8:30 PM
    #791
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    Sending you a pm
  12. Jan 30, 2018 at 4:03 PM
    #792
    METRO32168
    METRO32168 New Member
    2016 CM PLATINUM SILVER
    DECKED STORAGE UNIT,BACKFLIP G2 COVER,THULE ROOF RACKS, AMP RESEARCH POWERSTEP, TRD BILSTEINS COIL OVER SHOCKS (3" LIFT), TRD BILSTEINS SHOCKS REAR, SETINA BUMPER GUARD
    where can i find some connectors to make my own wire harness?
  13. Jan 30, 2018 at 7:19 PM
    #793
    u2asian
    u2asian New Member
    From Thomas on Pg 2:
    Parts
    Any part with a CONN – XXXXX can be ordered from www.bmotorsports.com
    (1) Morimoto Motocontrol 9003/H4 Bi-Xenon HID relay wire harness (www.theretrofitsource.com)
    (2) Toyota 8 Pin female plug 90980-10897
    (2) Toyota 4 pin female plug 90980-10869 OR (CONN 75928)
    (2) Toyota 4 Pin Male plug 90980-10868 or CONN-75929 (USE ONLY IF ADDING DRLS to NON DRL TRUCK)
    (4) Delphi 9006 Male 2-pin Plug CONN- 75893
    (14) Sumitomo TS/SL Female terminals CONN-11856
    (14) Sumitomo HM/MT/TS wire seals CONN-00145
    (10) Sumitomo MT/TS/HX/SL cavity plug CONN-100550
    nxrunner likes this.
  14. Jan 31, 2018 at 7:00 AM
    #794
    METRO32168
    Thank you
  15. Jan 31, 2018 at 7:03 AM
    #795
    METRO32168
    I want the Drl to shut off when headlights come on.
    Will this wiring for the 2018 headlights do just that?
    Let me know if there is any different wiring diagram.
    Tia
  16. Jan 31, 2018 at 7:05 AM
    #796
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    No, this wiring is for factory like operation, if you follow correctly the drl’s will dim when headlights are turned on.
    METRO32168[QUOTED] likes this.
  17. Jan 31, 2018 at 5:35 PM
    #797
    METRO32168
    thank you
  18. Feb 5, 2018 at 7:27 AM
    #798
    d0zer
    d0zer I beat the internet.
    Definitely somewhere
    2017 MGM Platinum
    ADS 3.0" & 2.5" AllPro APEX Sliders SCS SR8 on Cooper ST MAXX 295/70r18
    So I installed my 2018 lights and everything seemed to go fine. The DRL on the passenger side however is having some odd behavior. When the car is off, I can manually turn the DRLs on via the stalk. When I turn the car, I loose the passenger DRL? Headlights work fine, and when the headlight is on, it illuminates the DRL.
    Thoughts?
  19. Feb 8, 2018 at 6:31 PM
    #799
    METRO32168
    does the new led headlights use that much power that you need a relay?
  20. Feb 8, 2018 at 6:48 PM
    #800
    METRO32168
  21. Feb 19, 2018 at 7:09 PM
    #801
    samo2018
    samo2018 New Member
    fred
    I wired in pig tails for my sno dogg plow Every thing works fine but when I plug in the plow I get a notification on the dash to contact a dealer I there is a head light malfunction any thoughts?
  22. Feb 21, 2018 at 5:14 PM
    #802
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    inferno_pro_satx and iHacker like this.
  23. Feb 21, 2018 at 6:08 PM
    #803
    iHacker
    iHacker SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    True and for SR5 or models with amber DRL no dimming function, but Hell of a deal on headlights better than black friday, $600 with free shipping could be less if you apply code to around $540
  24. Feb 22, 2018 at 5:42 AM
    #804
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    Yup just seen this, if y’all are fine with the low beams off when the highs are on very good deal.
  25. Feb 22, 2018 at 10:48 AM
    #805
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Nice so they put a diode between the high beam and the wire to the low beam!? clever. Thanks for clarifying. Just curious how you know? Do you have a set or you an insider?
  26. Feb 24, 2018 at 6:44 AM
    #806
    JoeDenver
    JoeDenver New Member
    Joe
    Denver
    2018 Crewmax MGM
    Lomax Tonneau, Line-X Bedliner, Clear Mask, Chrome Tip Exhaust, Stubby Antenna
    Anyone in Denver making something like these and installing them?
  27. Feb 27, 2018 at 6:20 AM
    #807
    JoeDenver
    Joe
    Denver
    2018 Crewmax MGM
  28. Mar 13, 2018 at 5:40 AM
    #808
    tgun
    tgun New Member
    Tom
    Northern Illinois
    2025 TRD Pro (Mudbatch)
    Decked 2.0, Wildpeak ATw 35x11.5x18 Class C, bed step, predator steps, Baja s8 amber light bar and S2 amber fogs
    I just purchased the 2018 headlights. Do I still need to purchase turn signal bulbs? If so does anyone have part #? Sorry if I missed this. Thank you
  29. Mar 13, 2018 at 6:08 AM
    #809
    Snow
    Snow New Member
    2017 MGM Tundra SR5 TRD
    No, all bulbs are included
    tgun and iHacker like this.
  30. Mar 13, 2018 at 7:15 AM
    #810
    iHacker
    iHacker SW TRD PRO
    Mario
    All bulbs and leveling motors included in the new housings
    tgun[QUOTED] likes this.
